  3. Timeline for open-vins documentation
28 Posts 9 Posters 9.9k Views 4 Watching
  • Viktor GalV Viktor Gal
    @Zachary-Lowell-0 it's a typical indoor environment (a room in a flat).
    # Onboard parameters for Vehicle 1
    # Stack: PX4 Pro
    # Vehicle: Multi-Rotor
    # Version: 1.14.0 dev
    # Git Revision: 70d986f08a020054
    # Vehicle-Id Component-Id Name Value Type
    1	1	ASPD_SCALE_1	1.000000000000000000	9
    1	1	BAT1_CAPACITY	3950.000000000000000000	9
    1	1	BAT1_N_CELLS	2	6
    1	1	BAT1_R_INTERNAL	0.021999999880790710	9
    1	1	BAT1_SOURCE	0	6
    1	1	BAT1_V_CHARGED	4.099999904632568359	9
    1	1	BAT1_V_EMPTY	2.799999952316284180	9
    1	1	BAT1_V_LOAD_DROP	0.100000001490116119	9
    1	1	BAT_AVRG_CURRENT	4.300000190734863281	9
    1	1	BAT_CRIT_THR	0.100000001490116119	9
    1	1	BAT_EMERGEN_THR	0.050000000745058060	9
    1	1	BAT_LOW_THR	0.150000005960464478	9
    1	1	BAT_N_CELLS	3	6
    1	1	BAT_V_CHARGED	4.050000190734863281	9
    1	1	BAT_V_EMPTY	3.599999904632568359	9
    1	1	BAT_V_LOAD_DROP	0.300000011920928955	9
    1	1	CAL_ACC0_ID	2490378	6
    1	1	CAL_ACC0_PRIO	50	6
    1	1	CAL_ACC0_ROT	-1	6
    1	1	CAL_ACC0_XOFF	-0.004399999976158142	9
    1	1	CAL_ACC0_XSCALE	1.000000000000000000	9
    1	1	CAL_ACC0_YOFF	0.004999999888241291	9
    1	1	CAL_ACC0_YSCALE	1.000000000000000000	9
    1	1	CAL_ACC0_ZOFF	-0.136299997568130493	9
    1	1	CAL_ACC0_ZSCALE	1.000000000000000000	9
    1	1	CAL_ACC1_ID	0	6
    1	1	CAL_ACC2_ID	0	6
    1	1	CAL_ACC3_ID	0	6
    1	1	CAL_AIR_CMODEL	0	6
    1	1	CAL_AIR_TUBED_MM	1.500000000000000000	9
    1	1	CAL_AIR_TUBELEN	0.200000002980232239	9
    1	1	CAL_BARO0_ID	0	6
    1	1	CAL_BARO1_ID	0	6
    1	1	CAL_BARO2_ID	0	6
    1	1	CAL_BARO3_ID	0	6
    1	1	CAL_GYRO0_ID	2490378	6
    1	1	CAL_GYRO0_PRIO	50	6
    1	1	CAL_GYRO0_ROT	-1	6
    1	1	CAL_GYRO0_XOFF	0.009499999694526196	9
    1	1	CAL_GYRO0_YOFF	0.012900000438094139	9
    1	1	CAL_GYRO0_ZOFF	0.003199999919161201	9
    1	1	CAL_GYRO1_ID	0	6
    1	1	CAL_GYRO2_ID	0	6
    1	1	CAL_GYRO3_ID	0	6
    1	1	CAL_MAG0_ID	527625	6
    1	1	CAL_MAG0_PRIO	75	6
    1	1	CAL_MAG0_ROT	0	6
    1	1	CAL_MAG0_XCOMP	0.000000000000000000	9
    1	1	CAL_MAG0_XODIAG	-0.002300000051036477	9
    1	1	CAL_MAG0_XOFF	0.019600000232458115	9
    1	1	CAL_MAG0_XSCALE	0.371300011873245239	9
    1	1	CAL_MAG0_YCOMP	0.000000000000000000	9
    1	1	CAL_MAG0_YODIAG	0.009100000374019146	9
    1	1	CAL_MAG0_YOFF	0.122199997305870056	9
    1	1	CAL_MAG0_YSCALE	0.383500009775161743	9
    1	1	CAL_MAG0_ZCOMP	0.000000000000000000	9
    1	1	CAL_MAG0_ZODIAG	0.008999999612569809	9
    1	1	CAL_MAG0_ZOFF	-4.477099895477294922	9
    1	1	CAL_MAG0_ZSCALE	0.055500000715255737	9
    1	1	CAL_MAG1_ID	0	6
    1	1	CAL_MAG1_ROT	-1	6
    1	1	CAL_MAG2_ID	0	6
    1	1	CAL_MAG2_ROT	-1	6
    1	1	CAL_MAG3_ID	0	6
    1	1	CAL_MAG3_ROT	-1	6
    1	1	CAL_MAG_COMP_TYP	0	6
    1	1	CAL_MAG_SIDES	63	6
    1	1	CA_AIRFRAME	0	6
    1	1	CA_FAILURE_MODE	0	6
    1	1	CA_METHOD	2	6
    1	1	CA_R0_SLEW	0.000000000000000000	9
    1	1	CA_R10_SLEW	0.000000000000000000	9
    1	1	CA_R11_SLEW	0.000000000000000000	9
    1	1	CA_R1_SLEW	0.000000000000000000	9
    1	1	CA_R2_SLEW	0.000000000000000000	9
    1	1	CA_R3_SLEW	0.000000000000000000	9
    1	1	CA_R4_SLEW	0.000000000000000000	9
    1	1	CA_R5_SLEW	0.000000000000000000	9
    1	1	CA_R6_SLEW	0.000000000000000000	9
    1	1	CA_R7_SLEW	0.000000000000000000	9
    1	1	CA_R8_SLEW	0.000000000000000000	9
    1	1	CA_R9_SLEW	0.000000000000000000	9
    1	1	CA_ROTOR0_AX	0.000000000000000000	9
    1	1	CA_ROTOR0_AY	0.000000000000000000	9
    1	1	CA_ROTOR0_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR0_CT	6.500000000000000000	9
    1	1	CA_ROTOR0_KM	0.050000000745058060	9
    1	1	CA_ROTOR0_PX	0.085000000894069672	9
    1	1	CA_ROTOR0_PY	0.062500000000000000	9
    1	1	CA_ROTOR0_PZ	0.000000000000000000	9
    1	1	CA_ROTOR10_AX	0.000000000000000000	9
    1	1	CA_ROTOR10_AY	0.000000000000000000	9
    1	1	CA_ROTOR10_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR10_CT	6.500000000000000000	9
    1	1	CA_ROTOR10_KM	0.050000000745058060	9
    1	1	CA_ROTOR10_PX	0.000000000000000000	9
    1	1	CA_ROTOR10_PY	0.000000000000000000	9
    1	1	CA_ROTOR10_PZ	0.000000000000000000	9
    1	1	CA_ROTOR11_AX	0.000000000000000000	9
    1	1	CA_ROTOR11_AY	0.000000000000000000	9
    1	1	CA_ROTOR11_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR11_CT	6.500000000000000000	9
    1	1	CA_ROTOR11_KM	0.050000000745058060	9
    1	1	CA_ROTOR11_PX	0.000000000000000000	9
    1	1	CA_ROTOR11_PY	0.000000000000000000	9
    1	1	CA_ROTOR11_PZ	0.000000000000000000	9
    1	1	CA_ROTOR1_AX	0.000000000000000000	9
    1	1	CA_ROTOR1_AY	0.000000000000000000	9
    1	1	CA_ROTOR1_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR1_CT	6.500000000000000000	9
    1	1	CA_ROTOR1_KM	0.050000000745058060	9
    1	1	CA_ROTOR1_PX	-0.085000000894069672	9
    1	1	CA_ROTOR1_PY	-0.062500000000000000	9
    1	1	CA_ROTOR1_PZ	0.000000000000000000	9
    1	1	CA_ROTOR2_AX	0.000000000000000000	9
    1	1	CA_ROTOR2_AY	0.000000000000000000	9
    1	1	CA_ROTOR2_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR2_CT	6.500000000000000000	9
    1	1	CA_ROTOR2_KM	-0.050000000745058060	9
    1	1	CA_ROTOR2_PX	0.085000000894069672	9
    1	1	CA_ROTOR2_PY	-0.062500000000000000	9
    1	1	CA_ROTOR2_PZ	0.000000000000000000	9
    1	1	CA_ROTOR3_AX	0.000000000000000000	9
    1	1	CA_ROTOR3_AY	0.000000000000000000	9
    1	1	CA_ROTOR3_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR3_CT	6.500000000000000000	9
    1	1	CA_ROTOR3_KM	-0.050000000745058060	9
    1	1	CA_ROTOR3_PX	-0.085000000894069672	9
    1	1	CA_ROTOR3_PY	0.062500000000000000	9
    1	1	CA_ROTOR3_PZ	0.000000000000000000	9
    1	1	CA_ROTOR4_AX	0.000000000000000000	9
    1	1	CA_ROTOR4_AY	0.000000000000000000	9
    1	1	CA_ROTOR4_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR4_CT	6.500000000000000000	9
    1	1	CA_ROTOR4_KM	0.050000000745058060	9
    1	1	CA_ROTOR4_PX	0.000000000000000000	9
    1	1	CA_ROTOR4_PY	0.000000000000000000	9
    1	1	CA_ROTOR4_PZ	0.000000000000000000	9
    1	1	CA_ROTOR5_AX	0.000000000000000000	9
    1	1	CA_ROTOR5_AY	0.000000000000000000	9
    1	1	CA_ROTOR5_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR5_CT	6.500000000000000000	9
    1	1	CA_ROTOR5_KM	0.050000000745058060	9
    1	1	CA_ROTOR5_PX	0.000000000000000000	9
    1	1	CA_ROTOR5_PY	0.000000000000000000	9
    1	1	CA_ROTOR5_PZ	0.000000000000000000	9
    1	1	CA_ROTOR6_AX	0.000000000000000000	9
    1	1	CA_ROTOR6_AY	0.000000000000000000	9
    1	1	CA_ROTOR6_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR6_CT	6.500000000000000000	9
    1	1	CA_ROTOR6_KM	0.050000000745058060	9
    1	1	CA_ROTOR6_PX	0.000000000000000000	9
    1	1	CA_ROTOR6_PY	0.000000000000000000	9
    1	1	CA_ROTOR6_PZ	0.000000000000000000	9
    1	1	CA_ROTOR7_AX	0.000000000000000000	9
    1	1	CA_ROTOR7_AY	0.000000000000000000	9
    1	1	CA_ROTOR7_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR7_CT	6.500000000000000000	9
    1	1	CA_ROTOR7_KM	0.050000000745058060	9
    1	1	CA_ROTOR7_PX	0.000000000000000000	9
    1	1	CA_ROTOR7_PY	0.000000000000000000	9
    1	1	CA_ROTOR7_PZ	0.000000000000000000	9
    1	1	CA_ROTOR8_AX	0.000000000000000000	9
    1	1	CA_ROTOR8_AY	0.000000000000000000	9
    1	1	CA_ROTOR8_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR8_CT	6.500000000000000000	9
    1	1	CA_ROTOR8_KM	0.050000000745058060	9
    1	1	CA_ROTOR8_PX	0.000000000000000000	9
    1	1	CA_ROTOR8_PY	0.000000000000000000	9
    1	1	CA_ROTOR8_PZ	0.000000000000000000	9
    1	1	CA_ROTOR9_AX	0.000000000000000000	9
    1	1	CA_ROTOR9_AY	0.000000000000000000	9
    1	1	CA_ROTOR9_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR9_CT	6.500000000000000000	9
    1	1	CA_ROTOR9_KM	0.050000000745058060	9
    1	1	CA_ROTOR9_PX	0.000000000000000000	9
    1	1	CA_ROTOR9_PY	0.000000000000000000	9
    1	1	CA_ROTOR9_PZ	0.000000000000000000	9
    1	1	CA_ROTOR_COUNT	4	6
    1	1	CA_R_REV	0	6
    1	1	CA_SV0_SLEW	0.000000000000000000	9
    1	1	CA_SV1_SLEW	0.000000000000000000	9
    1	1	CA_SV2_SLEW	0.000000000000000000	9
    1	1	CA_SV3_SLEW	0.000000000000000000	9
    1	1	CA_SV4_SLEW	0.000000000000000000	9
    1	1	CA_SV5_SLEW	0.000000000000000000	9
    1	1	CA_SV6_SLEW	0.000000000000000000	9
    1	1	CA_SV7_SLEW	0.000000000000000000	9
    1	1	CBRK_AIRSPD_CHK	0	6
    1	1	CBRK_FLIGHTTERM	121212	6
    1	1	CBRK_IO_SAFETY	22027	6
    1	1	CBRK_SUPPLY_CHK	894281	6
    1	1	CBRK_USB_CHK	197848	6
    1	1	CBRK_VTOLARMING	0	6
    1	1	COM_ACT_FAIL_ACT	0	6
    1	1	COM_ARM_ARSP_EN	1	6
    1	1	COM_ARM_AUTH_ID	10	6
    1	1	COM_ARM_AUTH_MET	0	6
    1	1	COM_ARM_AUTH_REQ	0	6
    1	1	COM_ARM_AUTH_TO	1.000000000000000000	9
    1	1	COM_ARM_BAD_INOV	0	6
    1	1	COM_ARM_CHK_ESCS	0	6
    1	1	COM_ARM_EKF_BIAS	3.000000000000000000	9
    1	1	COM_ARM_EKF_HGT	1.000000000000000000	9
    1	1	COM_ARM_EKF_POS	0.500000000000000000	9
    1	1	COM_ARM_EKF_VEL	0.500000000000000000	9
    1	1	COM_ARM_EKF_YAW	0.500000000000000000	9
    1	1	COM_ARM_HFLT_CHK	1	6
    1	1	COM_ARM_IMU_ACC	0.699999988079071045	9
    1	1	COM_ARM_IMU_GYR	0.250000000000000000	9
    1	1	COM_ARM_MAG_ANG	60	6
    1	1	COM_ARM_MAG_STR	2	6
    1	1	COM_ARM_MIS_REQ	0	6
    1	1	COM_ARM_ODID	0	6
    1	1	COM_ARM_SDCARD	0	6
    1	1	COM_ARM_SWISBTN	0	6
    1	1	COM_ARM_WO_GPS	1	6
    1	1	COM_CPU_MAX	-1.000000000000000000	9
    1	1	COM_DISARM_FORCE	0	6
    1	1	COM_DISARM_LAND	0.100000001490116119	9
    1	1	COM_DISARM_PRFLT	20.000000000000000000	9
    1	1	COM_DL_LOSS_T	10	6
    1	1	COM_FAIL_ACT_T	5.000000000000000000	9
    1	1	COM_FLIGHT_UUID	0	6
    1	1	COM_FLTMODE1	0	6
    1	1	COM_FLTMODE2	0	6
    1	1	COM_FLTMODE3	2	6
    1	1	COM_FLTMODE4	2	6
    1	1	COM_FLTMODE5	7	6
    1	1	COM_FLTMODE6	7	6
    1	1	COM_FLT_PROFILE	0	6
    1	1	COM_FLT_TIME_MAX	-1	6
    1	1	COM_FORCE_SAFETY	0	6
    1	1	COM_HLDL_LOSS_T	120	6
    1	1	COM_HLDL_REG_T	0	6
    1	1	COM_HOME_EN	1	6
    1	1	COM_HOME_IN_AIR	0	6
    1	1	COM_IMB_PROP_ACT	0	6
    1	1	COM_KILL_DISARM	0.000000000000000000	9
    1	1	COM_LKDOWN_TKO	3.000000000000000000	9
    1	1	COM_LOW_BAT_ACT	0	6
    1	1	COM_MOT_TEST_EN	1	6
    1	1	COM_OBC_LOSS_T	5.000000000000000000	9
    1	1	COM_OBL_RC_ACT	0	6
    1	1	COM_OBS_AVOID	0	6
    1	1	COM_OF_LOSS_T	1.000000000000000000	9
    1	1	COM_PARACHUTE	0	6
    1	1	COM_POSCTL_NAVL	0	6
    1	1	COM_POS_FS_DELAY	1	6
    1	1	COM_POS_FS_EPH	5.000000000000000000	9
    1	1	COM_POS_LOW_EPH	-1.000000000000000000	9
    1	1	COM_POWER_COUNT	1	6
    1	1	COM_PREARM_MODE	0	6
    1	1	COM_QC_ACT	0	6
    1	1	COM_RCL_EXCEPT	0	6
    1	1	COM_RC_ARM_HYST	1000	6
    1	1	COM_RC_IN_MODE	3	6
    1	1	COM_RC_LOSS_T	0.500000000000000000	9
    1	1	COM_RC_OVERRIDE	1	6
    1	1	COM_RC_STICK_OV	30.000000000000000000	9
    1	1	COM_SPOOLUP_TIME	2.000000000000000000	9
    1	1	COM_TAKEOFF_ACT	0	6
    1	1	COM_VEL_FS_EVH	1.000000000000000000	9
    1	1	COM_WIND_MAX	-1.000000000000000000	9
    1	1	COM_WIND_WARN	-1.000000000000000000	9
    1	1	CP_DELAY	0.400000005960464478	9
    1	1	CP_DIST	-1.000000000000000000	9
    1	1	CP_GO_NO_DATA	0	6
    1	1	CP_GUIDE_ANG	30.000000000000000000	9
    1	1	EKF2_ABIAS_INIT	0.200000002980232239	9
    1	1	EKF2_ABL_ACCLIM	25.000000000000000000	9
    1	1	EKF2_ABL_GYRLIM	3.000000000000000000	9
    1	1	EKF2_ABL_LIM	0.400000005960464478	9
    1	1	EKF2_ABL_TAU	0.500000000000000000	9
    1	1	EKF2_ACC_B_NOISE	0.003000000026077032	9
    1	1	EKF2_ACC_NOISE	0.349999994039535522	9
    1	1	EKF2_AID_MASK	0	6
    1	1	EKF2_ANGERR_INIT	0.100000001490116119	9
    1	1	EKF2_ARSP_THR	0.000000000000000000	9
    1	1	EKF2_ASPD_MAX	20.000000000000000000	9
    1	1	EKF2_ASP_DELAY	100.000000000000000000	9
    1	1	EKF2_AVEL_DELAY	5.000000000000000000	9
    1	1	EKF2_BARO_CTRL	1	6
    1	1	EKF2_BARO_DELAY	0.000000000000000000	9
    1	1	EKF2_BARO_GATE	5.000000000000000000	9
    1	1	EKF2_BARO_NOISE	3.500000000000000000	9
    1	1	EKF2_BCOEF_X	100.000000000000000000	9
    1	1	EKF2_BCOEF_Y	100.000000000000000000	9
    1	1	EKF2_BETA_GATE	5.000000000000000000	9
    1	1	EKF2_BETA_NOISE	0.300000011920928955	9
    1	1	EKF2_DECL_TYPE	7	6
    1	1	EKF2_DRAG_CTRL	0	6
    1	1	EKF2_DRAG_NOISE	2.500000000000000000	9
    1	1	EKF2_EAS_NOISE	1.399999976158142090	9
    1	1	EKF2_EVA_NOISE	0.100000001490116119	9
    1	1	EKF2_EVP_GATE	5.000000000000000000	9
    1	1	EKF2_EVP_NOISE	0.100000001490116119	9
    1	1	EKF2_EVV_GATE	3.000000000000000000	9
    1	1	EKF2_EVV_NOISE	0.100000001490116119	9
    1	1	EKF2_EV_CTRL	15	6
    1	1	EKF2_EV_DELAY	0.000000000000000000	9
    1	1	EKF2_EV_HGT_TO	5000	6
    1	1	EKF2_EV_NOISE_MD	0	6
    1	1	EKF2_EV_POS_TO	1000	6
    1	1	EKF2_EV_POS_X	0.000000000000000000	9
    1	1	EKF2_EV_POS_Y	0.000000000000000000	9
    1	1	EKF2_EV_POS_Z	0.000000000000000000	9
    1	1	EKF2_EV_QMIN	1	6
    1	1	EKF2_FUSE_BETA	0	6
    1	1	EKF2_GBIAS_INIT	0.100000001490116119	9
    1	1	EKF2_GND_EFF_DZ	4.000000000000000000	9
    1	1	EKF2_GND_MAX_HGT	0.500000000000000000	9
    1	1	EKF2_GPS_CHECK	245	6
    1	1	EKF2_GPS_CTRL	0	6
    1	1	EKF2_GPS_DELAY	110.000000000000000000	9
    1	1	EKF2_GPS_POS_X	0.000000000000000000	9
    1	1	EKF2_GPS_POS_Y	0.000000000000000000	9
    1	1	EKF2_GPS_POS_Z	0.000000000000000000	9
    1	1	EKF2_GPS_P_GATE	5.000000000000000000	9
    1	1	EKF2_GPS_P_NOISE	0.500000000000000000	9
    1	1	EKF2_GPS_V_GATE	5.000000000000000000	9
    1	1	EKF2_GPS_V_NOISE	0.300000011920928955	9
    1	1	EKF2_GRAV_NOISE	1.000000000000000000	9
    1	1	EKF2_GSF_TAS	15.000000000000000000	9
    1	1	EKF2_GYR_B_LIM	0.150000005960464478	9
    1	1	EKF2_GYR_B_NOISE	0.001000000047497451	9
    1	1	EKF2_GYR_NOISE	0.014999999664723873	9
    1	1	EKF2_HDG_GATE	2.599999904632568359	9
    1	1	EKF2_HEAD_NOISE	0.300000011920928955	9
    1	1	EKF2_HGT_REF	3	6
    1	1	EKF2_IMU_CTRL	3	6
    1	1	EKF2_IMU_POS_X	0.004300000146031380	9
    1	1	EKF2_IMU_POS_Y	0.007300000172108412	9
    1	1	EKF2_IMU_POS_Z	-0.016000000759959221	9
    1	1	EKF2_MAG_ACCLIM	0.500000000000000000	9
    1	1	EKF2_MAG_B_NOISE	0.000099999997473788	9
    1	1	EKF2_MAG_CHECK	1	6
    1	1	EKF2_MAG_DECL	0.000000000000000000	9
    1	1	EKF2_MAG_DELAY	0.000000000000000000	9
    1	1	EKF2_MAG_E_NOISE	0.001000000047497451	9
    1	1	EKF2_MAG_GATE	3.000000000000000000	9
    1	1	EKF2_MAG_NOISE	0.050000000745058060	9
    1	1	EKF2_MAG_TYPE	5	6
    1	1	EKF2_MAG_YAWLIM	0.200000002980232239	9
    1	1	EKF2_MCOEF	0.150000005960464478	9
    1	1	EKF2_MIN_RNG	0.100000001490116119	9
    1	1	EKF2_NOAID_NOISE	10.000000000000000000	9
    1	1	EKF2_NOAID_TOUT	5000000	6
    1	1	EKF2_OF_CTRL	0	6
    1	1	EKF2_OF_DELAY	20.000000000000000000	9
    1	1	EKF2_OF_GATE	3.000000000000000000	9
    1	1	EKF2_OF_N_MAX	0.500000000000000000	9
    1	1	EKF2_OF_N_MIN	0.150000005960464478	9
    1	1	EKF2_OF_POS_X	0.000000000000000000	9
    1	1	EKF2_OF_POS_Y	0.000000000000000000	9
    1	1	EKF2_OF_POS_Z	0.000000000000000000	9
    1	1	EKF2_OF_QMIN	1	6
    1	1	EKF2_PCOEF_XN	0.000000000000000000	9
    1	1	EKF2_PCOEF_XP	0.000000000000000000	9
    1	1	EKF2_PCOEF_YN	0.000000000000000000	9
    1	1	EKF2_PCOEF_YP	0.000000000000000000	9
    1	1	EKF2_PCOEF_Z	0.000000000000000000	9
    1	1	EKF2_PREDICT_US	10000	6
    1	1	EKF2_REQ_EPH	3.000000000000000000	9
    1	1	EKF2_REQ_EPV	5.000000000000000000	9
    1	1	EKF2_REQ_GPS_H	5.000000000000000000	9
    1	1	EKF2_REQ_HDRIFT	0.100000001490116119	9
    1	1	EKF2_REQ_NSATS	6	6
    1	1	EKF2_REQ_PDOP	2.500000000000000000	9
    1	1	EKF2_REQ_SACC	1.500000000000000000	9
    1	1	EKF2_REQ_VDRIFT	0.200000002980232239	9
    1	1	EKF2_RNG_A_HMAX	5.000000000000000000	9
    1	1	EKF2_RNG_A_IGATE	1.000000000000000000	9
    1	1	EKF2_RNG_A_VMAX	1.000000000000000000	9
    1	1	EKF2_RNG_CTRL	0	6
    1	1	EKF2_RNG_DELAY	5.000000000000000000	9
    1	1	EKF2_RNG_GATE	5.000000000000000000	9
    1	1	EKF2_RNG_K_GATE	1.000000000000000000	9
    1	1	EKF2_RNG_NOISE	0.100000001490116119	9
    1	1	EKF2_RNG_PITCH	0.000000000000000000	9
    1	1	EKF2_RNG_POS_X	0.000000000000000000	9
    1	1	EKF2_RNG_POS_Y	0.000000000000000000	9
    1	1	EKF2_RNG_POS_Z	0.000000000000000000	9
    1	1	EKF2_RNG_QLTY_T	1.000000000000000000	9
    1	1	EKF2_RNG_SFE	0.050000000745058060	9
    1	1	EKF2_SYNT_MAG_Z	0	6
    1	1	EKF2_TAS_GATE	3.000000000000000000	9
    1	1	EKF2_TAU_POS	0.250000000000000000	9
    1	1	EKF2_TAU_VEL	0.250000000000000000	9
    1	1	EKF2_TERR_GRAD	0.500000000000000000	9
    1	1	EKF2_TERR_MASK	3	6
    1	1	EKF2_TERR_NOISE	5.000000000000000000	9
    1	1	EKF2_WIND_NSD	0.009999999776482582	9
    1	1	FD_ACT_EN	1	6
    1	1	FD_ACT_MOT_C2T	2.000000000000000000	9
    1	1	FD_ACT_MOT_THR	0.200000002980232239	9
    1	1	FD_ACT_MOT_TOUT	100	6
    1	1	FD_ESCS_EN	1	6
    1	1	FD_EXT_ATS_EN	0	6
    1	1	FD_EXT_ATS_TRIG	1900	6
    1	1	FD_FAIL_P	60	6
    1	1	FD_FAIL_P_TTRI	0.300000011920928955	9
    1	1	FD_FAIL_R	60	6
    1	1	FD_FAIL_R_TTRI	0.300000011920928955	9
    1	1	FD_IMB_PROP_THR	30	6
    1	1	FLW_TGT_ALT_M	0	6
    1	1	FLW_TGT_DST	8.000000000000000000	9
    1	1	FLW_TGT_FA	180.000000000000000000	9
    1	1	FLW_TGT_HT	8.000000000000000000	9
    1	1	FLW_TGT_MAX_VEL	5.000000000000000000	9
    1	1	FLW_TGT_RS	0.100000001490116119	9
    1	1	FW_AIRSPD_MAX	20.000000000000000000	9
    1	1	FW_AIRSPD_TRIM	15.000000000000000000	9
    1	1	FW_ARSP_MODE	0	6
    1	1	FW_PSP_OFF	0.000000000000000000	9
    1	1	FW_T_CLMB_R_SP	3.000000000000000000	9
    1	1	FW_T_SINK_R_SP	2.000000000000000000	9
    1	1	GF_ACTION	2	6
    1	1	GF_ALTMODE	0	6
    1	1	GF_COUNT	-1	6
    1	1	GF_MAX_HOR_DIST	0.000000000000000000	9
    1	1	GF_MAX_VER_DIST	0.000000000000000000	9
    1	1	GF_PREDICT	0	6
    1	1	GF_SOURCE	0	6
    1	1	GND_SPEED_THR_SC	1.000000000000000000	9
    1	1	GPIO_CTL_CH	0	6
    1	1	GPS_1_GNSS	0	6
    1	1	GPS_1_PROTOCOL	1	6
    1	1	GPS_DUMP_COMM	0	6
    1	1	GPS_PITCH_OFFSET	0.000000000000000000	9
    1	1	GPS_SAT_INFO	0	6
    1	1	GPS_UBX_BAUD2	230400	6
    1	1	GPS_UBX_CFG_INTF	0	6
    1	1	GPS_UBX_DYNMODEL	7	6
    1	1	GPS_UBX_MODE	0	6
    1	1	GPS_YAW_OFFSET	0.000000000000000000	9
    1	1	HTE_ACC_GATE	3.000000000000000000	9
    1	1	HTE_HT_ERR_INIT	0.100000001490116119	9
    1	1	HTE_HT_NOISE	0.003599999938160181	9
    1	1	HTE_THR_RANGE	0.200000002980232239	9
    1	1	HTE_VXY_THR	10.000000000000000000	9
    1	1	HTE_VZ_THR	2.000000000000000000	9
    1	1	IMU_ACCEL_CUTOFF	80.000000000000000000	9
    1	1	IMU_DGYRO_CUTOFF	60.000000000000000000	9
    1	1	IMU_GYRO_CUTOFF	80.000000000000000000	9
    1	1	IMU_GYRO_DNF_BW	15.000000000000000000	9
    1	1	IMU_GYRO_DNF_EN	1	6
    1	1	IMU_GYRO_DNF_HMC	3	6
    1	1	IMU_GYRO_DNF_MIN	25.000000000000000000	9
    1	1	IMU_GYRO_NF0_BW	20.000000000000000000	9
    1	1	IMU_GYRO_NF0_FRQ	0.000000000000000000	9
    1	1	IMU_GYRO_NF1_BW	20.000000000000000000	9
    1	1	IMU_GYRO_NF1_FRQ	0.000000000000000000	9
    1	1	IMU_GYRO_RATEMAX	800	6
    1	1	IMU_INTEG_RATE	200	6
    1	1	LNDMC_ALT_GND	2.000000000000000000	9
    1	1	LNDMC_ALT_MAX	-1.000000000000000000	9
    1	1	LNDMC_ROT_MAX	30.000000000000000000	9
    1	1	LNDMC_TRIG_TIME	0.500000000000000000	9
    1	1	LNDMC_XY_VEL_MAX	1.500000000000000000	9
    1	1	LNDMC_Z_VEL_MAX	0.250000000000000000	9
    1	1	LND_FLIGHT_T_HI	0	6
    1	1	LND_FLIGHT_T_LO	0	6
    1	1	MAN_ARM_GESTURE	1	6
    1	1	MAV_COMP_ID	1	6
    1	1	MAV_FWDEXTSP	1	6
    1	1	MAV_HASH_CHK_EN	1	6
    1	1	MAV_HB_FORW_EN	1	6
    1	1	MAV_PROTO_VER	0	6
    1	1	MAV_RADIO_TOUT	5	6
    1	1	MAV_SIK_RADIO_ID	0	6
    1	1	MAV_SYS_ID	1	6
    1	1	MAV_TYPE	2	6
    1	1	MAV_USEHILGPS	0	6
    1	1	MC_ACRO_EXPO	0.689999997615814209	9
    1	1	MC_ACRO_EXPO_Y	0.689999997615814209	9
    1	1	MC_ACRO_P_MAX	720.000000000000000000	9
    1	1	MC_ACRO_R_MAX	720.000000000000000000	9
    1	1	MC_ACRO_SUPEXPO	0.699999988079071045	9
    1	1	MC_ACRO_SUPEXPOY	0.699999988079071045	9
    1	1	MC_ACRO_Y_MAX	540.000000000000000000	9
    1	1	MC_AIRMODE	0	6
    1	1	MC_AT_APPLY	1	6
    1	1	MC_AT_AXES	3	6
    1	1	MC_AT_RISE_TIME	0.140000000596046448	9
    1	1	MC_AT_START	0	6
    1	1	MC_AT_SYSID_AMP	0.699999988079071045	9
    1	1	MC_BAT_SCALE_EN	0	6
    1	1	MC_INJECT_AMP	0.050000000745058060	9
    1	1	MC_INJECT_CNT	12	6
    1	1	MC_INJECT_EN	0	6
    1	1	MC_INJECT_INC	1.000000000000000000	9
    1	1	MC_INJECT_REST_T	1.000000000000000000	9
    1	1	MC_INJECT_RPY	2	6
    1	1	MC_INJECT_SINE_T	5.000000000000000000	9
    1	1	MC_INJECT_START	3.000000000000000000	9
    1	1	MC_MAN_TILT_TAU	0.000000000000000000	9
    1	1	MC_ORBIT_RAD_MAX	1000.000000000000000000	9
    1	1	MC_PITCHRATE_D	0.001099999994039536	9
    1	1	MC_PITCHRATE_FF	0.000000000000000000	9
    1	1	MC_PITCHRATE_I	0.228000000119209290	9
    1	1	MC_PITCHRATE_K	1.000000000000000000	9
    1	1	MC_PITCHRATE_MAX	130.000000000000000000	9
    1	1	MC_PITCHRATE_P	0.097000002861022949	9
    1	1	MC_PITCH_CUTOFF	30.000000000000000000	9
    1	1	MC_PITCH_P	16.000000000000000000	9
    1	1	MC_PR_INT_LIM	0.300000011920928955	9
    1	1	MC_ROLLRATE_D	0.000899999984540045	9
    1	1	MC_ROLLRATE_FF	0.000000000000000000	9
    1	1	MC_ROLLRATE_I	0.171000003814697266	9
    1	1	MC_ROLLRATE_K	1.000000000000000000	9
    1	1	MC_ROLLRATE_MAX	130.000000000000000000	9
    1	1	MC_ROLLRATE_P	0.071999996900558472	9
    1	1	MC_ROLL_CUTOFF	30.000000000000000000	9
    1	1	MC_ROLL_P	16.000000000000000000	9
    1	1	MC_RR_INT_LIM	0.300000011920928955	9
    1	1	MC_THR_CURVE_ACR	0	6
    1	1	MC_YAWRATE_D	0.000000000000000000	9
    1	1	MC_YAWRATE_FF	0.000000000000000000	9
    1	1	MC_YAWRATE_I	0.500000000000000000	9
    1	1	MC_YAWRATE_K	1.000000000000000000	9
    1	1	MC_YAWRATE_MAX	150.000000000000000000	9
    1	1	MC_YAWRATE_P	0.150000005960464478	9
    1	1	MC_YAW_CUTOFF	10.000000000000000000	9
    1	1	MC_YAW_P	2.799999952316284180	9
    1	1	MC_YAW_WEIGHT	0.400000005960464478	9
    1	1	MC_YR_INT_LIM	0.300000011920928955	9
    1	1	MIS_DIST_1WP	900.000000000000000000	9
    1	1	MIS_LND_ABRT_ALT	30	6
    1	1	MIS_MNT_YAW_CTL	0	6
    1	1	MIS_PD_TO	5.000000000000000000	9
    1	1	MIS_TAKEOFF_ALT	2.500000000000000000	9
    1	1	MIS_TKO_LAND_REQ	0	6
    1	1	MIS_YAW_ERR	12.000000000000000000	9
    1	1	MIS_YAW_TMT	-1.000000000000000000	9
    1	1	MODALAI_CONFIG	0	6
    1	1	MOT_SLEW_MAX	0.000000000000000000	9
    1	1	MPC_ACC_DOWN_MAX	3.000000000000000000	9
    1	1	MPC_ACC_HOR	3.000000000000000000	9
    1	1	MPC_ACC_HOR_MAX	1000.000000000000000000	9
    1	1	MPC_ACC_UP_MAX	3.000000000000000000	9
    1	1	MPC_ALT_MODE	0	6
    1	1	MPC_HOLD_DZ	0.100000001490116119	9
    1	1	MPC_HOLD_MAX_XY	0.000000000000000000	9
    1	1	MPC_HOLD_MAX_Z	0.000000000000000000	9
    1	1	MPC_JERK_AUTO	4.000000000000000000	9
    1	1	MPC_JERK_MAX	40.000000000000000000	9
    1	1	MPC_LAND_ALT1	10.000000000000000000	9
    1	1	MPC_LAND_ALT2	5.000000000000000000	9
    1	1	MPC_LAND_ALT3	1.000000000000000000	9
    1	1	MPC_LAND_CRWL	0.300000011920928955	9
    1	1	MPC_LAND_RADIUS	1000.000000000000000000	9
    1	1	MPC_LAND_RC_HELP	0	6
    1	1	MPC_LAND_SPEED	1.000000000000000000	9
    1	1	MPC_MANTHR_MIN	0.079999998211860657	9
    1	1	MPC_MAN_TILT_MAX	35.000000000000000000	9
    1	1	MPC_MAN_Y_MAX	150.000000000000000000	9
    1	1	MPC_MAN_Y_TAU	0.079999998211860657	9
    1	1	MPC_POS_MODE	4	6
    1	1	MPC_THR_CURVE	0	6
    1	1	MPC_THR_HOVER	0.340000003576278687	9
    1	1	MPC_THR_MAX	0.600000023841857910	9
    1	1	MPC_THR_MIN	0.079999998211860657	9
    1	1	MPC_THR_XY_MARG	0.300000011920928955	9
    1	1	MPC_TILTMAX_AIR	30.000000000000000000	9
    1	1	MPC_TILTMAX_LND	12.000000000000000000	9
    1	1	MPC_TKO_RAMP_T	1.000000000000000000	9
    1	1	MPC_TKO_SPEED	1.500000000000000000	9
    1	1	MPC_USE_HTE	1	6
    1	1	MPC_VELD_LP	5.000000000000000000	9
    1	1	MPC_VEL_MANUAL	3.000000000000000000	9
    1	1	MPC_VEL_MAN_BACK	-1.000000000000000000	9
    1	1	MPC_VEL_MAN_SIDE	-1.000000000000000000	9
    1	1	MPC_XY_CRUISE	3.000000000000000000	9
    1	1	MPC_XY_ERR_MAX	2.000000000000000000	9
    1	1	MPC_XY_MAN_EXPO	0.449999988079071045	9
    1	1	MPC_XY_P	3.500000000000000000	9
    1	1	MPC_XY_TRAJ_P	0.500000000000000000	9
    1	1	MPC_XY_VEL_ALL	-10.000000000000000000	9
    1	1	MPC_XY_VEL_D_ACC	0.000000000000000000	9
    1	1	MPC_XY_VEL_I_ACC	0.100000001490116119	9
    1	1	MPC_XY_VEL_MAX	3.000000000000000000	9
    1	1	MPC_XY_VEL_P_ACC	3.000000000000000000	9
    1	1	MPC_YAWRAUTO_MAX	45.000000000000000000	9
    1	1	MPC_YAW_EXPO	0.300000011920928955	9
    1	1	MPC_YAW_MODE	0	6
    1	1	MPC_Z_MAN_EXPO	0.100000001490116119	9
    1	1	MPC_Z_P	5.000000000000000000	9
    1	1	MPC_Z_VEL_ALL	-3.000000000000000000	9
    1	1	MPC_Z_VEL_D_ACC	0.000000000000000000	9
    1	1	MPC_Z_VEL_I_ACC	2.000000000000000000	9
    1	1	MPC_Z_VEL_MAX_DN	1.000000000000000000	9
    1	1	MPC_Z_VEL_MAX_UP	1.000000000000000000	9
    1	1	MPC_Z_VEL_P_ACC	8.000000000000000000	9
    1	1	MPC_Z_V_AUTO_DN	1.000000000000000000	9
    1	1	MPC_Z_V_AUTO_UP	1.000000000000000000	9
    1	1	NAV_ACC_RAD	10.000000000000000000	9
    1	1	NAV_DLL_ACT	0	6
    1	1	NAV_FORCE_VT	1	6
    1	1	NAV_FW_ALTL_RAD	5.000000000000000000	9
    1	1	NAV_FW_ALT_RAD	10.000000000000000000	9
    1	1	NAV_LOITER_RAD	80.000000000000000000	9
    1	1	NAV_MC_ALT_RAD	0.800000011920928955	9
    1	1	NAV_MIN_LTR_ALT	-1.000000000000000000	9
    1	1	NAV_RCL_ACT	2	6
    1	1	NAV_TRAFF_AVOID	1	6
    1	1	NAV_TRAFF_A_HOR	500.000000000000000000	9
    1	1	NAV_TRAFF_A_VER	500.000000000000000000	9
    1	1	NAV_TRAFF_COLL_T	60	6
    1	1	PLD_BTOUT	5.000000000000000000	9
    1	1	PLD_FAPPR_ALT	0.100000001490116119	9
    1	1	PLD_HACC_RAD	0.200000002980232239	9
    1	1	PLD_MAX_SRCH	3	6
    1	1	PLD_SRCH_ALT	10.000000000000000000	9
    1	1	PLD_SRCH_TOUT	10.000000000000000000	9
    1	1	RC10_DZ	0.000000000000000000	9
    1	1	RC10_MAX	2000.000000000000000000	9
    1	1	RC10_MIN	1000.000000000000000000	9
    1	1	RC10_REV	1.000000000000000000	9
    1	1	RC10_TRIM	1500.000000000000000000	9
    1	1	RC11_DZ	0.000000000000000000	9
    1	1	RC11_MAX	2000.000000000000000000	9
    1	1	RC11_MIN	1000.000000000000000000	9
    1	1	RC11_REV	1.000000000000000000	9
    1	1	RC11_TRIM	1500.000000000000000000	9
    1	1	RC12_DZ	0.000000000000000000	9
    1	1	RC12_MAX	1988.000000000000000000	9
    1	1	RC12_MIN	1011.000000000000000000	9
    1	1	RC12_REV	1.000000000000000000	9
    1	1	RC12_TRIM	1499.000000000000000000	9
    1	1	RC13_DZ	0.000000000000000000	9
    1	1	RC13_MAX	2000.000000000000000000	9
    1	1	RC13_MIN	1000.000000000000000000	9
    1	1	RC13_REV	1.000000000000000000	9
    1	1	RC13_TRIM	1500.000000000000000000	9
    1	1	RC14_DZ	0.000000000000000000	9
    1	1	RC14_MAX	2000.000000000000000000	9
    1	1	RC14_MIN	1000.000000000000000000	9
    1	1	RC14_REV	1.000000000000000000	9
    1	1	RC14_TRIM	1500.000000000000000000	9
    1	1	RC15_DZ	0.000000000000000000	9
    1	1	RC15_MAX	2000.000000000000000000	9
    1	1	RC15_MIN	1000.000000000000000000	9
    1	1	RC15_REV	1.000000000000000000	9
    1	1	RC15_TRIM	1500.000000000000000000	9
    1	1	RC16_DZ	0.000000000000000000	9
    1	1	RC16_MAX	2000.000000000000000000	9
    1	1	RC16_MIN	1000.000000000000000000	9
    1	1	RC16_REV	1.000000000000000000	9
    1	1	RC16_TRIM	1500.000000000000000000	9
    1	1	RC17_DZ	0.000000000000000000	9
    1	1	RC17_MAX	2000.000000000000000000	9
    1	1	RC17_MIN	1000.000000000000000000	9
    1	1	RC17_REV	1.000000000000000000	9
    1	1	RC17_TRIM	1500.000000000000000000	9
    1	1	RC18_DZ	0.000000000000000000	9
    1	1	RC18_MAX	2000.000000000000000000	9
    1	1	RC18_MIN	1000.000000000000000000	9
    1	1	RC18_REV	1.000000000000000000	9
    1	1	RC18_TRIM	1500.000000000000000000	9
    1	1	RC1_DZ	10.000000000000000000	9
    1	1	RC1_MAX	2000.000000000000000000	9
    1	1	RC1_MIN	1000.000000000000000000	9
    1	1	RC1_REV	1.000000000000000000	9
    1	1	RC1_TRIM	1500.000000000000000000	9
    1	1	RC2_DZ	10.000000000000000000	9
    1	1	RC2_MAX	2000.000000000000000000	9
    1	1	RC2_MIN	1000.000000000000000000	9
    1	1	RC2_REV	1.000000000000000000	9
    1	1	RC2_TRIM	1500.000000000000000000	9
    1	1	RC3_DZ	10.000000000000000000	9
    1	1	RC3_MAX	2000.000000000000000000	9
    1	1	RC3_MIN	1000.000000000000000000	9
    1	1	RC3_REV	1.000000000000000000	9
    1	1	RC3_TRIM	1500.000000000000000000	9
    1	1	RC4_DZ	10.000000000000000000	9
    1	1	RC4_MAX	2000.000000000000000000	9
    1	1	RC4_MIN	1000.000000000000000000	9
    1	1	RC4_REV	1.000000000000000000	9
    1	1	RC4_TRIM	1500.000000000000000000	9
    1	1	RC5_DZ	10.000000000000000000	9
    1	1	RC5_MAX	1988.000000000000000000	9
    1	1	RC5_MIN	1011.000000000000000000	9
    1	1	RC5_REV	1.000000000000000000	9
    1	1	RC5_TRIM	1500.000000000000000000	9
    1	1	RC6_DZ	10.000000000000000000	9
    1	1	RC6_MAX	1988.000000000000000000	9
    1	1	RC6_MIN	1011.000000000000000000	9
    1	1	RC6_REV	1.000000000000000000	9
    1	1	RC6_TRIM	1500.000000000000000000	9
    1	1	RC7_DZ	10.000000000000000000	9
    1	1	RC7_MAX	1988.000000000000000000	9
    1	1	RC7_MIN	1011.000000000000000000	9
    1	1	RC7_REV	1.000000000000000000	9
    1	1	RC7_TRIM	1500.000000000000000000	9
    1	1	RC8_DZ	10.000000000000000000	9
    1	1	RC8_MAX	1988.000000000000000000	9
    1	1	RC8_MIN	1011.000000000000000000	9
    1	1	RC8_REV	1.000000000000000000	9
    1	1	RC8_TRIM	1500.000000000000000000	9
    1	1	RC9_DZ	0.000000000000000000	9
    1	1	RC9_MAX	2000.000000000000000000	9
    1	1	RC9_MIN	1000.000000000000000000	9
    1	1	RC9_REV	1.000000000000000000	9
    1	1	RC9_TRIM	1500.000000000000000000	9
    1	1	RC_ARMSWITCH_TH	0.750000000000000000	9
    1	1	RC_CHAN_CNT	16	6
    1	1	RC_CRSF_TEL_EN	0	6
    1	1	RC_ENG_MOT_TH	0.750000000000000000	9
    1	1	RC_FAILS_THR	0	6
    1	1	RC_GEAR_TH	0.750000000000000000	9
    1	1	RC_KILLSWITCH_TH	0.750000000000000000	9
    1	1	RC_LOITER_TH	0.750000000000000000	9
    1	1	RC_MAP_ACRO_SW	0	6
    1	1	RC_MAP_ARM_SW	0	6
    1	1	RC_MAP_AUX1	0	6
    1	1	RC_MAP_AUX2	0	6
    1	1	RC_MAP_AUX3	0	6
    1	1	RC_MAP_AUX4	0	6
    1	1	RC_MAP_AUX5	0	6
    1	1	RC_MAP_AUX6	0	6
    1	1	RC_MAP_ENG_MOT	0	6
    1	1	RC_MAP_FAILSAFE	0	6
    1	1	RC_MAP_FLAPS	0	6
    1	1	RC_MAP_FLTMODE	6	6
    1	1	RC_MAP_FLTM_BTN	0	6
    1	1	RC_MAP_GEAR_SW	0	6
    1	1	RC_MAP_KILL_SW	5	6
    1	1	RC_MAP_LOITER_SW	0	6
    1	1	RC_MAP_MAN_SW	0	6
    1	1	RC_MAP_MODE_SW	0	6
    1	1	RC_MAP_OFFB_SW	0	6
    1	1	RC_MAP_PARAM1	0	6
    1	1	RC_MAP_PARAM2	0	6
    1	1	RC_MAP_PARAM3	0	6
    1	1	RC_MAP_PITCH	2	6
    1	1	RC_MAP_POSCTL_SW	0	6
    1	1	RC_MAP_RATT_SW	0	6
    1	1	RC_MAP_RETURN_SW	0	6
    1	1	RC_MAP_ROLL	1	6
    1	1	RC_MAP_STAB_SW	0	6
    1	1	RC_MAP_THROTTLE	3	6
    1	1	RC_MAP_TRANS_SW	0	6
    1	1	RC_MAP_YAW	4	6
    1	1	RC_OFFB_TH	0.750000000000000000	9
    1	1	RC_RETURN_TH	0.750000000000000000	9
    1	1	RC_TRANS_TH	0.750000000000000000	9
    1	1	RTL_CONE_ANG	45	6
    1	1	RTL_DESCEND_ALT	30.000000000000000000	9
    1	1	RTL_HDG_MD	0	6
    1	1	RTL_LAND_DELAY	0.000000000000000000	9
    1	1	RTL_LOITER_RAD	80.000000000000000000	9
    1	1	RTL_MIN_DIST	10.000000000000000000	9
    1	1	RTL_PLD_MD	0	6
    1	1	RTL_RETURN_ALT	60.000000000000000000	9
    1	1	RTL_TIME_FACTOR	1.100000023841857910	9
    1	1	RTL_TIME_MARGIN	100	6
    1	1	RTL_TYPE	0	6
    1	1	SDLOG_BOOT_BAT	0	6
    1	1	SDLOG_DIRS_MAX	0	6
    1	1	SDLOG_MISSION	0	6
    1	1	SDLOG_MODE	0	6
    1	1	SDLOG_PROFILE	129	6
    1	1	SDLOG_UTC_OFFSET	0	6
    1	1	SDLOG_UUID	1	6
    1	1	SENS_BARO_QNH	1013.250000000000000000	9
    1	1	SENS_BARO_RATE	20.000000000000000000	9
    1	1	SENS_BOARD_ROT	0	6
    1	1	SENS_BOARD_X_OFF	-0.067400000989437103	9
    1	1	SENS_BOARD_Y_OFF	-0.318699985742568970	9
    1	1	SENS_BOARD_Z_OFF	0.000000000000000000	9
    1	1	SENS_DPRES_OFF	0.000000000000000000	9
    1	1	SENS_GPS_MASK	7	6
    1	1	SENS_GPS_PRIME	0	6
    1	1	SENS_GPS_TAU	10.000000000000000000	9
    1	1	SENS_IMU_AUTOCAL	0	6
    1	1	SENS_IMU_MODE	1	6
    1	1	SENS_MAG_AUTOCAL	0	6
    1	1	SENS_MAG_AUTOROT	0	6
    1	1	SENS_MAG_MODE	1	6
    1	1	SENS_MAG_RATE	15.000000000000000000	9
    1	1	SENS_MAG_SIDES	63	6
    1	1	SYS_AUTOCONFIG	0	6
    1	1	SYS_AUTOSTART	4001	6
    1	1	SYS_CAL_TDEL	24	6
    1	1	SYS_CAL_TMAX	10	6
    1	1	SYS_CAL_TMIN	5	6
    1	1	SYS_FAC_CAL_MODE	0	6
    1	1	SYS_FAILURE_EN	0	6
    1	1	SYS_HAS_BARO	1	6
    1	1	SYS_HAS_GPS	1	6
    1	1	SYS_HAS_MAG	1	6
    1	1	SYS_HAS_NUM_DIST	0	6
    1	1	SYS_HITL	0	6
    1	1	SYS_MC_EST_GROUP	2	6
    1	1	SYS_RGB_MAXBRT	1.000000000000000000	9
    1	1	SYS_STCK_EN	1	6
    1	1	SYS_VEHICLE_RESP	-0.400000005960464478	9
    1	1	THR_MDL_FAC	0.899999976158142090	9
    1	1	TRIG_MODE	0	6
    1	1	UAVCAN_ENABLE	0	6
    1	1	VOXL_ESC_BAUD	2000000	6
    1	1	VOXL_ESC_CONFIG	1	6
    1	1	VOXL_ESC_FUNC1	102	6
    1	1	VOXL_ESC_FUNC2	103	6
    1	1	VOXL_ESC_FUNC3	101	6
    1	1	VOXL_ESC_FUNC4	104	6
    1	1	VOXL_ESC_MODE	0	6
    1	1	VOXL_ESC_PUB_BST	1	6
    1	1	VOXL_ESC_REV	0	6
    1	1	VOXL_ESC_RPM_MAX	15000	6
    1	1	VOXL_ESC_RPM_MIN	2000	6
    1	1	VOXL_ESC_SDIR1	0	6
    1	1	VOXL_ESC_SDIR2	0	6
    1	1	VOXL_ESC_SDIR3	0	6
    1	1	VOXL_ESC_SDIR4	0	6
    1	1	VOXL_ESC_T_COSP	0.990000009536743164	9
    1	1	VOXL_ESC_T_DEAD	20	6
    1	1	VOXL_ESC_T_EXPO	35	6
    1	1	VOXL_ESC_T_MINF	0.150000005960464478	9
    1	1	VOXL_ESC_T_OVER	0	6
    1	1	VOXL_ESC_T_PERC	90	6
    1	1	VOXL_ESC_T_WARN	0	6
    1	1	VOXL_ESC_VLOG	1	6
    1	1	VTO_LOITER_ALT	80.000000000000000000	9
    1	1	VT_B_DEC_MSS	2.000000000000000000	9
    1	1	WV_EN	0	6
    1	1	WV_GAIN	1.000000000000000000	9
    1	1	WV_ROLL_MIN	1.000000000000000000	9
    1	1	WV_YRATE_MAX	90.000000000000000000	9
    1	1	XRCE_DDS_DOM_ID	0	6
    1	1	XRCE_DDS_KEY	1	6
    Viktor GalV Offline
    Viktor GalV Offline
    Viktor Gal
    note when dumping the same params on the another starling v2 drone i'm getting a slightly different set of params, which i have no idea why it is.
    # Stack: PX4 Pro
    1	1	BAT1_SOURCE	0	6
    1	1	BAT_N_CELLS	3	6
    1	1	CAL_ACC0_XOFF	-0.041400000452995300	9
    1	1	CAL_ACC0_YOFF	-0.014000000432133675	9
    1	1	CAL_ACC0_ZOFF	-0.050900001078844070	9
    1	1	CAL_ACC1_ID	0	6
    1	1	CAL_ACC2_ID	0	6
    1	1	CAL_ACC3_ID	0	6
    1	1	CAL_GYRO0_XOFF	0.001399999950081110	9
    1	1	CAL_GYRO0_YOFF	0.019099999219179153	9
    1	1	CAL_GYRO0_ZOFF	-0.001799999969080091	9
    1	1	CAL_MAG0_XODIAG	-0.027599999681115150	9
    1	1	CAL_MAG0_XOFF	-0.093400001525878906	9
    1	1	CAL_MAG0_XSCALE	1.085199952125549316	9
    1	1	CAL_MAG0_YODIAG	0.014800000004470348	9
    1	1	CAL_MAG0_YOFF	0.249599993228912354	9
    1	1	CAL_MAG0_YSCALE	0.836799979209899902	9
    1	1	CAL_MAG0_ZODIAG	-0.007000000216066837	9
    1	1	CAL_MAG0_ZOFF	-0.107400000095367432	9
    1	1	CAL_MAG0_ZSCALE	1.048200011253356934	9
    1	1	CAL_MAG1_ID	0	6
    1	1	CAL_MAG2_ID	0	6
    1	1	CAL_MAG3_ID	0	6
    1	1	CA_AIRFRAME	0	6
    1	1	CA_METHOD	2	6
    1	1	CA_R_REV	0	6
    1	1	COM_HOME_EN	1	6
    1	1	COM_QC_ACT	0	6
    1	1	FD_ACT_EN	1	6
    1	1	FD_ESCS_EN	1	6
    1	1	FD_FAIL_P	60	6
    1	1	FD_FAIL_R	60	6
    1	1	GF_ACTION	2	6
    1	1	GF_ALTMODE	0	6
    1	1	GF_COUNT	-1	6
    1	1	GF_PREDICT	0	6
    1	1	GF_SOURCE	0	6
    1	1	GPIO_CTL_CH	0	6
    1	1	GPS_1_GNSS	0	6
    1	1	MAV_COMP_ID	1	6
    1	1	MAV_SYS_ID	1	6
    1	1	MAV_TYPE	2	6
    1	1	MC_AIRMODE	0	6
    1	1	MC_AT_APPLY	1	6
    1	1	MC_AT_AXES	3	6
    1	1	MC_AT_START	0	6
    1	1	MPC_USE_HTE	1	6
    1	1	NAV_DLL_ACT	0	6
    1	1	NAV_RCL_ACT	2	6
    1	1	RC12_MAX	2000.000000000000000000	9
    1	1	RC12_MIN	1000.000000000000000000	9
    1	1	RC12_TRIM	1500.000000000000000000	9
    1	1	RC1_MIN	1001.000000000000000000	9
    1	1	RC1_TRIM	1499.000000000000000000	9
    1	1	RC2_MIN	1001.000000000000000000	9
    1	1	RC2_TRIM	1501.000000000000000000	9
    1	1	RC3_MIN	1001.000000000000000000	9
    1	1	RC3_TRIM	1001.000000000000000000	9
    1	1	RC4_MIN	1001.000000000000000000	9
    1	1	RC4_TRIM	1507.000000000000000000	9
    1	1	RC5_TRIM	1499.000000000000000000	9
    1	1	RC6_TRIM	1499.000000000000000000	9
    1	1	RC7_TRIM	1499.000000000000000000	9
    1	1	RC8_TRIM	1499.000000000000000000	9
    1	1	RC_MAP_AUX1	0	6
    1	1	RC_MAP_AUX2	0	6
    1	1	RC_MAP_AUX3	0	6
    1	1	RC_MAP_AUX4	0	6
    1	1	RC_MAP_AUX5	0	6
    1	1	RC_MAP_AUX6	0	6
    1	1	RC_MAP_ROLL	1	6
    1	1	RC_MAP_YAW	4	6
    1	1	RTL_HDG_MD	0	6
    1	1	RTL_PLD_MD	0	6
    1	1	RTL_TYPE	0	6
    1	1	SDLOG_MODE	0	6
    1	1	SDLOG_UUID	1	6
    1	1	SENS_BOARD_X_OFF	-0.587000012397766113	9
    1	1	SENS_BOARD_Y_OFF	-0.263300001621246338	9
    1	1	SYS_HAS_GPS	1	6
    1	1	SYS_HAS_MAG	1	6
    1	1	SYS_HITL	0	6
    1	1	SYS_STCK_EN	1	6
    1	1	TRIG_MODE	0	6
    1	1	WV_EN	0	6
      # Stack: PX4 Pro
      1	1	BAT1_SOURCE	0	6
      1	1	BAT_N_CELLS	3	6
      1	1	CAL_ACC1_ID	0	6
      1	1	CAL_ACC2_ID	0	6
      1	1	CAL_ACC3_ID	0	6
      1	1	CAL_MAG1_ID	0	6
      1	1	CAL_MAG2_ID	0	6
      1	1	CAL_MAG3_ID	0	6
      1	1	CA_AIRFRAME	0	6
      1	1	CA_METHOD	2	6
      1	1	CA_R_REV	0	6
      1	1	COM_HOME_EN	1	6
      1	1	COM_QC_ACT	0	6
      1	1	FD_ACT_EN	1	6
      1	1	FD_ESCS_EN	1	6
      1	1	FD_FAIL_P	60	6
      1	1	FD_FAIL_R	60	6
      1	1	GF_ACTION	2	6
      1	1	GF_ALTMODE	0	6
      1	1	GF_COUNT	-1	6
      1	1	GF_PREDICT	0	6
      1	1	GF_SOURCE	0	6
      1	1	GPIO_CTL_CH	0	6
      1	1	GPS_1_GNSS	0	6
      1	1	MAV_COMP_ID	1	6
      1	1	MAV_SYS_ID	1	6
      1	1	MAV_TYPE	2	6
      1	1	MC_AIRMODE	0	6
      1	1	MC_AT_APPLY	1	6
      1	1	MC_AT_AXES	3	6
      1	1	MC_AT_START	0	6
      1	1	MPC_USE_HTE	1	6
      1	1	NAV_DLL_ACT	0	6
      1	1	NAV_RCL_ACT	2	6
      1	1	RC_MAP_AUX1	0	6
      1	1	RC_MAP_AUX2	0	6
      1	1	RC_MAP_AUX3	0	6
      1	1	RC_MAP_AUX4	0	6
      1	1	RC_MAP_AUX5	0	6
      1	1	RC_MAP_AUX6	0	6
      1	1	RC_MAP_ROLL	1	6
      1	1	RC_MAP_YAW	4	6
      1	1	RTL_HDG_MD	0	6
      1	1	RTL_PLD_MD	0	6
      1	1	RTL_TYPE	0	6
      1	1	SDLOG_MODE	0	6
      1	1	SDLOG_UUID	1	6
      1	1	SYS_HAS_GPS	1	6
      1	1	SYS_HAS_MAG	1	6
      1	1	SYS_HITL	0	6
      1	1	SYS_STCK_EN	1	6
      1	1	TRIG_MODE	0	6
      1	1	WV_EN	0	6
      Viktor GalV Offline
      Viktor GalV Offline
      Viktor Gal
      just for clarity here's the diff of the two params above:
      --- px4.params	2024-10-30 16:15:04.683354722 +0100
      +++ Downloads/params_update.params	2024-10-30 16:59:34.597742954 +0100
      @@ -25,11 +25,11 @@
      -1	1	CAL_ACC0_XOFF	-0.004399999976158142	9
      +1	1	CAL_ACC0_XOFF	-0.041400000452995300	9
      -1	1	CAL_ACC0_YOFF	0.004999999888241291	9
      +1	1	CAL_ACC0_YOFF	-0.014000000432133675	9
      -1	1	CAL_ACC0_ZOFF	-0.136299997568130493	9
      +1	1	CAL_ACC0_ZOFF	-0.050900001078844070	9
       1	1	CAL_ACC1_ID	0	6
       1	1	CAL_ACC2_ID	0	6
      @@ -44,9 +44,9 @@
      -1	1	CAL_GYRO0_XOFF	0.009499999694526196	9
      -1	1	CAL_GYRO0_YOFF	0.012900000438094139	9
      -1	1	CAL_GYRO0_ZOFF	0.003199999919161201	9
      +1	1	CAL_GYRO0_XOFF	0.001399999950081110	9
      +1	1	CAL_GYRO0_YOFF	0.019099999219179153	9
      +1	1	CAL_GYRO0_ZOFF	-0.001799999969080091	9
      @@ -54,17 +54,17 @@
      -1	1	CAL_MAG0_XODIAG	-0.002300000051036477	9
      -1	1	CAL_MAG0_XOFF	0.019600000232458115	9
      -1	1	CAL_MAG0_XSCALE	0.371300011873245239	9
      +1	1	CAL_MAG0_XODIAG	-0.027599999681115150	9
      +1	1	CAL_MAG0_XOFF	-0.093400001525878906	9
      +1	1	CAL_MAG0_XSCALE	1.085199952125549316	9
      -1	1	CAL_MAG0_YODIAG	0.009100000374019146	9
      -1	1	CAL_MAG0_YOFF	0.122199997305870056	9
      -1	1	CAL_MAG0_YSCALE	0.383500009775161743	9
      +1	1	CAL_MAG0_YODIAG	0.014800000004470348	9
      +1	1	CAL_MAG0_YOFF	0.249599993228912354	9
      +1	1	CAL_MAG0_YSCALE	0.836799979209899902	9
      -1	1	CAL_MAG0_ZODIAG	0.008999999612569809	9
      -1	1	CAL_MAG0_ZOFF	-4.477099895477294922	9
      -1	1	CAL_MAG0_ZSCALE	0.055500000715255737	9
      +1	1	CAL_MAG0_ZODIAG	-0.007000000216066837	9
      +1	1	CAL_MAG0_ZOFF	-0.107400000095367432	9
      +1	1	CAL_MAG0_ZSCALE	1.048200011253356934	9
       1	1	CAL_MAG1_ID	0	6
       1	1	CAL_MAG2_ID	0	6
      @@ -632,10 +632,10 @@
      -1	1	RC12_MAX	1988.000000000000000000	9
      -1	1	RC12_MIN	1011.000000000000000000	9
      +1	1	RC12_MAX	2000.000000000000000000	9
      +1	1	RC12_MIN	1000.000000000000000000	9
      -1	1	RC12_TRIM	1499.000000000000000000	9
      +1	1	RC12_TRIM	1500.000000000000000000	9
      @@ -668,44 +668,44 @@
      -1	1	RC1_MIN	1000.000000000000000000	9
      +1	1	RC1_MIN	1001.000000000000000000	9
      -1	1	RC1_TRIM	1500.000000000000000000	9
      +1	1	RC1_TRIM	1499.000000000000000000	9
      -1	1	RC2_MIN	1000.000000000000000000	9
      +1	1	RC2_MIN	1001.000000000000000000	9
      -1	1	RC2_TRIM	1500.000000000000000000	9
      +1	1	RC2_TRIM	1501.000000000000000000	9
      -1	1	RC3_MIN	1000.000000000000000000	9
      +1	1	RC3_MIN	1001.000000000000000000	9
      -1	1	RC3_TRIM	1500.000000000000000000	9
      +1	1	RC3_TRIM	1001.000000000000000000	9
      -1	1	RC4_MIN	1000.000000000000000000	9
      +1	1	RC4_MIN	1001.000000000000000000	9
      -1	1	RC4_TRIM	1500.000000000000000000	9
      +1	1	RC4_TRIM	1507.000000000000000000	9
      -1	1	RC5_TRIM	1500.000000000000000000	9
      +1	1	RC5_TRIM	1499.000000000000000000	9
      -1	1	RC6_TRIM	1500.000000000000000000	9
      +1	1	RC6_TRIM	1499.000000000000000000	9
      -1	1	RC7_TRIM	1500.000000000000000000	9
      +1	1	RC7_TRIM	1499.000000000000000000	9
      -1	1	RC8_TRIM	1500.000000000000000000	9
      +1	1	RC8_TRIM	1499.000000000000000000	9
      @@ -774,8 +774,8 @@
      -1	1	SENS_BOARD_X_OFF	-0.067400000989437103	9
      -1	1	SENS_BOARD_Y_OFF	-0.318699985742568970	9
      +1	1	SENS_BOARD_X_OFF	-0.587000012397766113	9
      +1	1	SENS_BOARD_Y_OFF	-0.263300001621246338	9
      • Zachary Lowell 0Z Offline
        Zachary Lowell 0
        Yeah those parameters are changed when you calibrate some sensors. @Viktor-Gal can you try calibrating the imu_apps on your drones via voxl-calibrate-imu and then retry flying OVINS and see if that helps?
        Viktor GalV 1 Reply Last reply
          Viktor GalV Offline
          Viktor GalV Offline
          Viktor Gal
          @Zachary-Lowell-0 so those params are after running voxl-configure-mpa; i still dont understand why there's a diff between the apparently same v2 starlings.
          i can run the imu_apps calibration and retry OV.
            Viktor GalV Offline
            Viktor GalV Offline
            Viktor Gal
            @Zachary-Lowell-0 hey so i did what you suggested, here's the full output of openvins server but it's the very same behaviour; the qvio is nicely picking up the movements, openvins is just stationary on the portal. here are the detailed logs:
            voxl2:~$ voxl-open-vins-server --verbosity 0
            Setting printing level to: SILENT
            Setting printing level to: ALL
            Loading our own config file
            =========================AUTO RESET==============================
            en_auto_reset:                    1
            auto_reset_max_velocity:          20.000
            auto_reset_max_v_cov_instant:      0.100
            auto_reset_max_v_cov:              0.100
            auto_reset_max_v_cov_timeout_s:    0.500
            auto_reset_min_features:          1
            auto_reset_min_feature_timeout_s:  3.000
            auto_fallback_timeout_s:  3.000
            auto_fallback_min_v:  0.600
            en_cont_yaw_checks: false
            fast_yaw_thresh:  5.000
            fast_yaw_timeout_s:  1.750
            ===========================STATE=================================
            do fej:                           true
            imu avg:                          true
            use rk4 integration:              true
            cam to imu refinement:            true
            cam intrins refinement:           true
            cam imu ts refinement:            true
            max clone size:                   8
            max slam features:                40
            max slam in update:               25
            max msckf in update:              25
            feat rep msckf:                   ANCHORED_MSCKF_INVERSE_DEPTH
            feat rep slam:                    ANCHORED_MSCKF_INVERSE_DEPTH
            cam imu time offset:              0.00150
            slam delay:                       1.00000
            =====================INERTIAL INITIALIZER========================
            gravity mag:                      9.80665
            init window time:                 1.00000
            init imu thresh:                  1.00000
            init dyn use:                         false
            ==========================IMU NOISE==============================
            imu sigma w:                      0.00014
            imu sigma wb:                     0.00000
            imu sigma a:                      0.00389
            imu sigma ab:                     0.00006
            ========================FEATURE NOISE============================
            msckf chi^2 multiplier:           1.00000
            msckf sigma px:                   1.00000
            slam chi^2 multiplier:            40.00000
            slam sigma px:                    1.80000
            zupt chi^2 multiplier:            1.00000
            zupt sigma px:                    1.00000
            =============================ZUPT================================
            try zupt:                         true
            zupt max velocity:                0.03000
            zupt only at beginning:           true
            zupt noise multiplier:            1.00000
            zupt max disparity:               3.00000
            use mask:                         true
            use stereo:                       false
            use baro:                       false
            ========================FEATURE INITIALIZER======================
            triangulate 1d:                   false
            refine features:                  false
            max runs:                         5
            init lamda:                       0.00100
            max lamda:                        10000000000.00000
            min dx:                           0.00000
            min dcost:                        0.00000
            lam mult:                         10.00000
            min dist:                         0.10000
            max dist:                         60.00000
            max baseline:                     40.00000
            num_opencv_threads:                  9
            fast_threshold:                  15
            histogram_method:                  HISTOGRAM
            knn_ratio:                  0.70000
            track_frequency:                  15.00000
            publish_frequency:                  3
            imu takeoff accel thresh:                  0.10000
            force init on takeoff:                  false
            use takeoff_camera_as:                  0
            takeoff_threshold(m):                  -0.100000
            publish stats:                  false
            max_allowable_cep:                  1.00000
            force FLU to NED transform:                  false
            VIO always on (for bench testing):                  false
            Number of cameras found for this config: 1
            [INFO] External feature trackers being used? false
            camera count: 1
            MONO mode (using cam idx: 0)
            camera count: 1
            Skipping camera group index: 2, not enabled
            Loading OpenCV intrinsics cal file from: /data/modalai/opencv_tracking_front_intrinsics.yml
            Loading OpenCV intrinsics cal file from: /data/modalai/opencv_tracking_down_intrinsics.yml
            cam_load_extrinsics_file
            World Rotation Matrix:
             1.000000  0  0
             0  1.000000  0
             0  0  1.000000
            load extrinsics 2
            Using extrinsics under camera ID: tracking_front
            [INFO] Camera: 0 -- converted extrinsics *in FLU* are: Roll: -0.000000, Pitch 90.000000, Yaw -90.000000
            (local) CAMERA ROTATION MATRIX:
            [0, 0, 1;
             -1, 0, 0;
             0, -1, 0]
            (local) CAMERA TRANSLATION:
              0.037
                 -0
            -0.0006
            Using extrinsics under camera ID: tracking_down
            [INFO] Camera: 1 -- converted extrinsics *in FLU* are: Roll: -0.000000, Pitch 180.000000, Yaw -360.000000
            [-1, 0, 0;
             0, 1, 0;
             0, 0, -1]
            -0.08825
              0.0045
            -0.00269
            Done transfer camera configuration transfer
            ==========================CAMERA 0================================
            mode:                             MONO
            camera matrix:
            460.27780 0.00000 621.21213
            0.00000 459.85438 408.51998
            0.00000 0.00000 1.00000
            distortion coefficients:
            0.05324 0.02329 -0.00926 0.00026
            ==========================CAMERA 1================================
            mode:                             MONO
            camera matrix:
            462.04073 0.00000 660.98324
            0.00000 462.09738 397.45450
            0.04984 0.04004 -0.02646 0.00611
            =============================KLT=================================
            num_features_to_track:            30
            grid_x:                           5
            grid_y:                           5
            min_pix_dist:                     50
            pyramid_levels:                   5
            [block] window_size:                 (25 x 25)
            ===========================KLTGYRO===============================
            tmp_imu_name:                         imu_apps
            tracking_front wrt imu_apps:
            -1.00000 0.00000 0.00000
            0.00000 -1.00000 0.00000
            tracking_down wrt imu_apps:
            0.00000 1.00000 0.00000
            0.00000 0.00000 -1.00000
            Loading external config file
            =====> imu to read from: imu
            OpenVINS using fisheye camera
            OpenVINS FINAL Cam extrinsics to IMU for tracking_front: 7
                -0.5
                0.5
               -0.5
                0.5
              0.037
                 -0
            -0.0006
            OpenVINS FINAL Cam extrinsics to IMU for tracking_down: 7
             -1.22465e-16
                      -1
             -7.4988e-33
            -6.12323e-17
                -0.08825
                  0.0045
                -0.00269
            OpenVINS reports number of cameras being used, regardless of delivery method (pipe, merge, etc...):  2
            VioManagerOptions.h:108 ESTIMATOR PARAMETERS:
            StateOptions.h:108   - use_fej: 1
            StateOptions.h:109   - use_imuavg: 1
            StateOptions.h:110   - use_rk4int: 1
            StateOptions.h:111   - calib_cam_extrinsics: 1
            StateOptions.h:112   - calib_cam_intrinsics: 1
            StateOptions.h:113   - calib_cam_timeoffset: 1
            StateOptions.h:114   - max_clones: 8
            StateOptions.h:115   - max_slam: 40
            StateOptions.h:116   - max_slam_in_update: 25
            StateOptions.h:117   - max_msckf_in_update: 25
            StateOptions.h:118   - max_aruco: 1024
            StateOptions.h:119   - max_cameras: 2
            StateOptions.h:120   - feat_rep_msckf: ANCHORED_MSCKF_INVERSE_DEPTH
            StateOptions.h:121   - feat_rep_slam: ANCHORED_MSCKF_INVERSE_DEPTH
            StateOptions.h:122   - feat_rep_aruco: GLOBAL_3D
            InertialInitializerOptions.h:125 INITIALIZATION SETTINGS:
            InertialInitializerOptions.h:150   - init_window_time: 1.00
            InertialInitializerOptions.h:151   - init_imu_thresh: 1.00
            InertialInitializerOptions.h:152   - init_max_disparity: 3.00
            InertialInitializerOptions.h:153   - init_max_features: 0.00
            InertialInitializerOptions.h:171   - init_dyn_use: 0
            InertialInitializerOptions.h:172   - init_dyn_mle_opt_calib: 0
            InertialInitializerOptions.h:173   - init_dyn_mle_max_iter: 20
            InertialInitializerOptions.h:174   - init_dyn_mle_max_threads: 20
            InertialInitializerOptions.h:175   - init_dyn_mle_max_time: 2.00
            InertialInitializerOptions.h:176   - init_dyn_num_pose: 8
            InertialInitializerOptions.h:177   - init_dyn_min_deg: 45.00
            InertialInitializerOptions.h:178   - init_dyn_inflation_ori: 1.00e+01
            InertialInitializerOptions.h:179   - init_dyn_inflation_vel: 1.00e+01
            InertialInitializerOptions.h:180   - init_dyn_inflation_bg: 1.00e+02
            InertialInitializerOptions.h:181   - init_dyn_inflation_ba: 1.00e+02
            InertialInitializerOptions.h:182   - init_dyn_min_rec_cond: 1.00e-15
            InertialInitializerOptions.h:188   - init_dyn_bias_g: 0.00, 0.00, 0.00
            InertialInitializerOptions.h:189   - init_dyn_bias_a: 0.00, 0.00, 0.00
            InertialInitializerOptions.h:216 NOISE PARAMETERS:
            InertialInitializerOptions.h:224   - gyroscope_noise_density: 0.000170
            InertialInitializerOptions.h:225   - accelerometer_noise_density: 0.00200
            InertialInitializerOptions.h:226   - gyroscope_random_walk: 0.0000194
            InertialInitializerOptions.h:227   - accelerometer_random_walk: 0.003000
            InertialInitializerOptions.h:228   - sigma_pix: 1.00
            InertialInitializerOptions.h:318 STATE PARAMETERS:
            InertialInitializerOptions.h:319   - gravity_mag: 9.8066
            InertialInitializerOptions.h:320   - gravity: 0.000, 0.000, 9.807
            InertialInitializerOptions.h:321   - num_cameras: 2
            InertialInitializerOptions.h:322   - use_stereo: 0
            InertialInitializerOptions.h:323   - downsize cameras: 0
            InertialInitializerOptions.h:332   - calib_camimu_dt: 0.0000
            InertialInitializerOptions.h:348 cam_0_fisheye:1
            cam_0_wh:
            1280 x 800
            cam_0_intrinsic(0:3):
            460.278 459.854 621.212  408.52
            cam_0_intrinsic(4:7):
              0.0532387   0.0232891  -0.0092603 0.000263136
            cam_0_extrinsic(0:3):
            -0.5  0.5 -0.5  0.5
            cam_0_extrinsic(4:6):
              0.037      -0 -0.0006
            T_C0toI:
                       0  2.22045e-16            1       0.0006
                      -1  2.22045e-16            0        0.037
            -2.22045e-16           -1  2.22045e-16  8.34888e-18
                       0            0            0            1
            InertialInitializerOptions.h:348 cam_1_fisheye:1
            cam_1_wh:
            1280 x 800
            cam_1_intrinsic(0:3):
            462.041 462.097 660.983 397.455
            cam_1_intrinsic(4:7):
             0.0498391   0.040037 -0.0264578  0.0061076
            cam_1_extrinsic(0:3):
            -1.22465e-16           -1  -7.4988e-33 -6.12323e-17
            cam_1_extrinsic(4:6):
            -0.08825   0.0045 -0.00269
            T_C1toI:
                      -1  2.44929e-16  1.22465e-16     -0.08825
             2.44929e-16            1            0      -0.0045
            -1.22465e-16  2.99952e-32           -1     -0.00269
                       0            0            0            1
            VioManagerOptions.h:121   - dt_slam_delay: 1.0
            VioManagerOptions.h:122   - zero_velocity_update: 1
            VioManagerOptions.h:123   - zupt_max_velocity: 0.03
            VioManagerOptions.h:124   - zupt_noise_multiplier: 1.00
            VioManagerOptions.h:125   - zupt_max_disparity: 3.0000
            VioManagerOptions.h:126   - zupt_only_at_beginning?: 1
            VioManagerOptions.h:127   - record timing?: 0
            VioManagerOptions.h:128   - record timing filepath: ov_msckf_timing.txt
            VioManagerOptions.h:155 NOISE PARAMETERS:
            NoiseManager.h:62   - gyroscope_noise_density: 0.000140
            NoiseManager.h:63   - accelerometer_noise_density: 0.00389
            NoiseManager.h:64   - gyroscope_random_walk: 0.0000004
            NoiseManager.h:65   - accelerometer_random_walk: 0.000055
            VioManagerOptions.h:179   Updater MSCKF Feats:
            UpdaterOptions.h:45     - chi2_multipler: 1.0
            UpdaterOptions.h:46     - sigma_pix: 1.00
            VioManagerOptions.h:181   Updater SLAM Feats:
            UpdaterOptions.h:45     - chi2_multipler: 40.0
            UpdaterOptions.h:46     - sigma_pix: 1.80
            VioManagerOptions.h:183   Updater ARUCO Tags:
            UpdaterOptions.h:45     - chi2_multipler: 5.0
            VioManagerOptions.h:185   Updater ZUPT:
            VioManagerOptions.h:292 STATE PARAMETERS:
            VioManagerOptions.h:293   - gravity_mag: 9.8100
            VioManagerOptions.h:294   - gravity: 0.000, 0.000, 9.810
            VioManagerOptions.h:295   - camera masks?: 1
            VioManagerOptions.h:304   - calib_camimu_dt: 0.0015
            VioManagerOptions.h:320 cam_0_fisheye:1
            cam_0_wh:
            1280 x 800
            -0.5  0.5 -0.5  0.5
              0.037      -0 -0.0006
            T_C0toI:
                       0            0            0            1
            VioManagerOptions.h:320 cam_1_fisheye:1
            cam_1_wh:
            1280 x 800
            T_C1toI:
                       0            0            0            1
            VioManagerOptions.h:426 FEATURE TRACKING PARAMETERS:
            VioManagerOptions.h:427   - use_stereo: 0
            VioManagerOptions.h:428   - use_klt: 1
            VioManagerOptions.h:429   - use_aruco: 0
            VioManagerOptions.h:430   - downsize aruco: 1
            VioManagerOptions.h:431   - downsize cameras: 0
            VioManagerOptions.h:432   - num opencv threads: 9
            VioManagerOptions.h:433   - use multi-threading pubs: 1
            VioManagerOptions.h:434   - use multi-threading subs: 1
            VioManagerOptions.h:435   - num_pts: 30
            VioManagerOptions.h:436   - fast threshold: 15
            VioManagerOptions.h:437   - grid X by Y: 5 by 5
            VioManagerOptions.h:438   - min px dist: 50
            VioManagerOptions.h:439   - hist method: 1
            VioManagerOptions.h:440   - knn ratio: 0.700
            VioManagerOptions.h:441   - track frequency: 15.0
            VioManagerOptions.h:442   - limit imu propagation (windows based on init_imu+cam-imu delay): 1
            FeatureInitializerOptions.h:87 	- triangulate_1d: 0
            FeatureInitializerOptions.h:88 	- refine_features: 0
            FeatureInitializerOptions.h:89 	- max_runs: 5
            FeatureInitializerOptions.h:90 	- init_lamda: 0.001
            FeatureInitializerOptions.h:91 	- max_lamda: 10000000000.000
            FeatureInitializerOptions.h:92 	- min_dx: 0.0000010
            FeatureInitializerOptions.h:93 	- min_dcost: 0.0000010
            FeatureInitializerOptions.h:94 	- lam_mult: 10.000
            FeatureInitializerOptions.h:95 	- min_dist: 0.100
            FeatureInitializerOptions.h:96 	- max_dist: 60.000
            FeatureInitializerOptions.h:97 	- max_baseline: 40.000
            FeatureInitializerOptions.h:98 	- max_cond_number: 600000.000
            Set camera intrinsics and extrinsics
            ====> Using Internal KLT feature tracker <====
            >>>>>>>>>> Current reference counts:
            trackDB: 1
            trackFEATS: 1
            propagator: 2
            updaterMSCKF: 1
            updaterSLAM: 1
            active_tracks_initializer: 1
            initializer: 1
            setting scheduler
            INFO: set FIFO priority successfully!
            create_server_pipes
            connecting client pipes
            Number of Cameras active: 2
            Camera merge --- > ch: 1 to cam id: 0
            Opening camera pipe: tracking_front
            tmp_camera_pipe_names.push_back(): tracking_front
            Camera merge --- > ch: 2 to cam id: 1
            Opening camera pipe: tracking_down
            tmp_camera_pipe_names.push_back(): tracking_down
            imu pipe name: imu_apps
            Camera processing thread is now locked to the following cores: 7
            VioManager.cpp:454 [TIME]: 0.0358 seconds for tracking
            VioManagerHelper.cpp:174 [init]: failed initialization in 0.0000 seconds
            VioManager.cpp:454 [TIME]: 0.0139 seconds for tracking
            InertialInitializer.cpp:127 [init]: not enough feats to compute disp: 0,0 < 15
            VioManagerHelper.cpp:174 [init]: failed initialization in 0.0002 seconds
            VioManager.cpp:454 [TIME]: 0.0170 seconds for tracking
            VioManagerHelper.cpp:174 [init]: failed initialization in 0.0003 seconds
            VioManager.cpp:454 [TIME]: 0.0162 seconds for tracking
            InertialInitializer.cpp:127 [init]: not enough feats to compute disp: 0,62 < 15
            VioManagerHelper.cpp:174 [init]: failed initialization in 0.0001 seconds
            VioManager.cpp:454 [TIME]: 0.0112 seconds for tracking
            VioManager.cpp:454 [TIME]: 0.0175 seconds for tracking
            VioManager.cpp:454 [TIME]: 0.0156 seconds for tracking
            VioManager.cpp:454 [TIME]: 0.0105 seconds for tracking
            VioManager.cpp:454 [TIME]: 0.0169 seconds for tracking
            InertialInitializer.cpp:134 [init]: *** disparity is 0.000,0.000 (3.00 thresh)
            InertialInitializer.cpp:145 [init]: USING STATIC INITIALIZER METHOD!
            IMU samples too small, make your window smaller (params.init_window_time), can't initalize 241.141469 - 240.222589  (0.918880)
            StaticInitializer.cpp:55 [init-s]: unable to select window of IMU readings, not enough readings
            VioManagerHelper.cpp:174 [init]: failed initialization in 0.0004 seconds
            VioManager.cpp:454 [TIME]: 0.0115 seconds for tracking
            StaticInitializer.cpp:104 [init-s]: IMU excitation stats: 0.029,0.014
            VioManagerHelper.cpp:138 [init]: successful initialization in 0.0008 seconds
            VioManagerHelper.cpp:140 [init]: orientation = -0.0029, 0.0025, 0.0000, 1.0000
            VioManagerHelper.cpp:142 [init]: bias gyro = 0.0025, 0.0000, 0.0016
            VioManagerHelper.cpp:144 [init]: velocity = 0.0000, 0.0000, 0.0000
            VioManagerHelper.cpp:146 [init]: bias accel = 0.0000, 0.0000, -0.0046
            VioManagerHelper.cpp:148 [init]: position = 0.0000, 0.0000, 0.0000
            VioManagerHelper.cpp:168 [init]: moved the state forward 0.00 seconds
            StateHelper.cpp:686 new augment clone at timestamp: 241.367844
            waiting for enough clone states (1 of 5)....
            [INFO] TAKEOFF: DISPARITY disturbed, possible motion detected. Avg: 91.364071 (3.000000)	# feats: 5 (20).
            UpdaterZeroVelocity.cpp:242 [ZUPT]: failed disparity (91.364 > 3.000, 5 features)
            UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.003 (chi2 99.575 < 113.145)
            [INFO] TAKEOFF: DISPARITY disturbed, possible motion detected. Avg: 0.000000 (3.000000)	# feats: 5 (20).
            UpdaterZeroVelocity.cpp:242 [ZUPT]: failed disparity (0.000 > 3.000, 5 features)
            UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.007 (chi2 62.236 < 106.395)
            UpdaterZeroVelocity.cpp:233 [ZUPT]: passed disparity (0.000 < 3.000, 40 features)
            UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.004 (chi2 88.421 < 119.871)
            UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.004 (chi2 96.190 < 119.871)
            UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.003 (chi2 132.910 < 119.871)
            UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.003 (chi2 95.202 < 119.871)
            UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.003 (chi2 76.613 < 106.395)
            UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.002 (chi2 105.215 < 113.145)
            UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.002 (chi2 86.990 < 119.871)
              Zachary Lowell 0
              @Viktor-Gal said in Timeline for open-vins documentation:
              1 Reply Last reply about 15 hours ago Reply
              a day ago
              RE: No you are sending the PX4 parameters not the voxl2 parameters. Runnign voxl-configure-mpa will configure some px4 parameters, but after you open up qgc and then calibrateall the sensors in there, it will change some of those parameters, hence why those specific to imu calibration and mag cal are different from drone to drone. I highly recommend sticking to qvio with single camera tracking for now as OVINS is still heavily in development.
                a day ago
                Viktor GalV Offline
                Viktor GalV Offline
                Viktor Gal
                @Zachary-Lowell-0 i hear you, but could you maybe give some pointers how one could make the qvio more stable? as i said it is at the moment only has 25% success rate: meaning 1 out of 5 flights i dont have problems with the qvio, the rest of the time the drone becomes unstable and crashes.
                ModeratorM 1 Reply Last reply
                  @Viktor-Gal have you read through the troubleshooting VIO documentation? https://docs.modalai.com/flying-with-vio/#troubleshooting-vio
                  • ModeratorM Moderator
                    Viktor GalV Offline
                    Viktor GalV Offline
                    Viktor Gal
                    @Moderator yep, back and forth. unfortunately no change.
                      Viktor GalV Offline
                      Viktor GalV Offline
                      Viktor Gal
                      @Moderator et.al. i just want to follow up that switching to the nightly builds that uses out of box the openvins implementation for VIO, is significantly better than the qvio. in other words, it actually fixed all the problems that we were facing with the QVIO.
                      Eric KatzfeyE dleeD 2 Replies Last reply
                        @Viktor-Gal Excellent, thanks for the feedback!
                        • S Offline
                          S Offline
                          star123
                          wrote on last edited by star123
                          #24
                          I'll put a question here since it's open-vins documentation related. I also am successfully running nightly builds of open-vins, and it is working well for me.
                          I would like to add image masks to the tracking cameras to block out certain areas. I see the option "use_mask" in voxl-open-vins-server.conf, which I can set to true. I can't figure out where to put the mask files, or how to specify their path and file name?
                          If this should be a separate thread, please let me know and I can move my question elsewhere, cheers!
                          dleeD Cliff WongC 2 Replies Last reply
                          • A Aaky referenced this topic on
                          • S star123
                            dleeD Offline
                            dleeD Offline
                            dlee
                            @star123 What does nightly mean? The latest version of voxl-open-vins-server or voxl-suite. Thanks.
                            • dleeD dlee
                              tomT Online
                              tomT Online
                              @dlee We publish "nightly" SDK builds at https://storage.googleapis.com/platform-nightlies/voxl2/voxl2_SDK_nightly_20250213.tar.gz (URL will match yesterday's date, PST)
                              This takes the latest of each repo's dev branch as well as the latest system image built every night
                              • S star123
                                Cliff WongC Offline
                                Cliff WongC Offline
                                Cliff Wong
                                wrote on last edited by Cliff Wong
                                #27
                                @star123 At this time masks are supported through programmatic means only.
                                I'll add it to our feature list for the next release and should be in our nightly builds by mid-next week. If you take a look at /data/modalai/zero_ref.jpg is an example format to give you an idea when the feature is ready.
                                  dleeD Offline
                                  dleeD Offline
                                  dlee
                                  @Viktor-Gal I am troubling localization with QVIO. So I wanted to change vio algorithm to OpenVINS. I flashed my drone to nightly version but openvins still very unstable. Could you give me some guidance for openvins?
                                  Questions
                                  1. openvins configuration & versions
                                  2. Did you enable the voxl-feature-tracker?
                                  3. camera settings (single or multi, camera model, etc)
                                  My status
                                  • voxl-suite: 1.4.1-202502132201
                                  • Camera: old-version of tracking camera (640x480) - link
                                  • voxl-open-vins-server: 0.3.0-202502061726
                                  • voxl-feature-tracker: 0.5.2-202412171357
