  3. GPS not working
GPS not working
sentinel
49 Posts 7 Posters 31.3k Views 4 Watching
    you will likely want to configure px4 params to suit your exact use case, e.g. some people will want it to arm without a gps lock, some won't. As a starting point we have "helper" files that can be loaded through QGC that set up the handful of relevant PX4 params for indoor vs outdoor flight
    Here is the outdoor helper for px4 1.12:
    https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.12/ekf2_outdoor_gps_mag.params
    And the helpers for PX4 1.14:
    https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/tree/master/params/v1.14/EKF2_helpers
    J Offline
    J Offline
    JustinDev23
    @James-Strawson If i stop and disable the VIO server will that still allow GPS to pass through? I am getting good satellite and HDOP but the GPS never transitions from flashing blue to green with the ekf2_outdoor_gps_baro params. it is causing the platform to not allow me to put it in POSCTL. I do not intend to do GPS denied flights at this time and am trying to focus on outdoor 5G flights for a while to build confidence in our GCS software interactions with VOXL.
    • J JustinDev23
      @JustinDev23 These parameter settings won't affect the ability of the GPS receiver to get a lock. It is an independent unit and not affected by VIO in any way.
      J 1 Reply Last reply
        J Offline
        J Offline
        JustinDev23
        @Eric-Katzfey, thanks for the response and clarifying.
        I had a 3D Fix but wasnt able to switch from Manual to Position. I have worked on other projects with Ardupilot mission planner and it could blend or use best from different sources. I wasnt sure exactly how your implementation of GPS and VIO were working together on feeding positional data to the PX4 autopilot.
        A 1 Reply Last reply
        • J JustinDev23
          Andre Moura
          @JustinDev23 You can have GPS fix and not have GPS lock on the PX4. Have you checked the number of satellites on QGC? From my experience, GPS lock (required to switch to Position mode) is achieved with 12 satellites or more.
          Maybe test the drone on a new location with more open space, that did the trick for me.
          • A Andre Moura
            J Offline
            J Offline
            JustinDev23
            @Andre-Moura sat and hdop have not been an issue on QGC. ekf2_req_nsats is set to 6 and i have had no obstructions and in open space.
            GPS Horizontal Pos Error too high with 9 sats and 1.4 hdop
            • J JustinDev23
              J Offline
              J Offline
              JustinDev23
              And if it is not that it is GPS Speed Accuracy too low
              I would hate to disable those checks but i feel like it is something else that is causing this to occur.
              @Eric-Katzfey Is there a flow chart for what all is feeding position information to PX4 from VOXL2?
                @JustinDev23 This is the closest to what you're looking for: https://docs.modalai.com/voxl-px4-developer-guide/
                  J Offline
                  J Offline
                  JustinDev23
                  @tom Thanks! Looks like what i needed.
                    @andremoura The GPS unit will come up and get a fix on it's own after it has been powered on so that doesn't indicate anything about the health of the connection to the flight controller. If the result of px4-listener sensor_gps is never published then there is likely a problem with your connection to the GPS unit. The GPS driver on VOXL2 runs on the DSP, not on the applications processor so you have to use qshell to interact with it. So, for status, you would use px4-qshell gps status. Have you made any changes to the Sentinel hardware or is it exactly the same as it was shipped?
                    Captain 7thC Offline
                    Captain 7th
                    @Eric-Katzfey I have the same issue. I tried the method that you mentioned, not only voxl-px4 is not working now, but also I got this error:
                    INFO [muorb] SLPI: muorb aggregator thread running
                    INFO [muorb] muorb protobuf initalize method succeeded
                    INFO [muorb] succesfully did ADVERTISE_TEST_TYPE
                    INFO [muorb] SLPI: Creating pthread test_MUORB
                    INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
                    INFO [muorb] succesfully did SUBSCRIBE_TEST_TYPE
                    INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
                    INFO [muorb] succesfully did TOPIC_TEST_TYPE
                    INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
                    INFO [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
                    INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
                    INFO [muorb] muorb test passed
                    INFO [muorb] SLPI: Advertising remote topic log_message
                    | ___ \ \ \ / / / |
                    | |/ / \ V / / /| |
                    | __/ / \ / /
                    | | / /^\ \ ___ |
                    _| / / |_/
                    px4 starting.
                    INFO [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
                    INFO [parameters] Starting param sync THREAD
                    GPS: HOLYBRO
                    RC: SPEKTRUM
                    OSD: DISABLE
                    EXTRA STEPS:
                    INFO [muorb] SLPI: Starting param sync THREAD
                    Running on M0054
                    INFO [muorb] SLPI: before starting the qshell_entry task
                    INFO [muorb] SLPI: Creating pthread qshell
                    INFO [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
                    INFO [muorb] SLPI: qshell entry.....
                    INFO [muorb] SLPI: after starting the qshell_entry task
                    INFO [muorb] SLPI: Init app map initialized
                    INFO [param] selected parameter default file /data/px4/param/parameters
                    INFO [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
                    INFO [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
                    INFO [muorb] SLPI: Advertising remote topic parameter_update
                    INFO [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to
                    INFO [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
                    INFO [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to
                    INFO [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
                    INFO [parameters] BSON document size 3022 bytes, decoded 3022 bytes (INT32:43, FLOAT:98)
                    INFO [logger] logger started (mode=all)
                    INFO [qshell] Send cmd: 'icm42688p start -s'
                    INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                    INFO [muorb] SLPI: qshell gotten: icm42688p start -s
                    INFO [muorb] SLPI: arg0 = 'icm42688p'
                    INFO [muorb] SLPI: arg1 = 'start'
                    INFO [muorb] SLPI: arg2 = '-s'
                    INFO [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
                    INFO [uORB] Advertising remote topic sensor_accel
                    INFO [uORB] Advertising remote topic sensor_gyro
                    INFO [muorb] SLPI: ICM42688P::probe successful!
                    INFO [muorb] SLPI: on SPI bus 1
                    INFO [muorb] SLPI: >>> ICM42688P this: 3176e460
                    INFO [muorb] SLPI: icm42688p #0 on SPI bus 1
                    INFO [muorb] SLPI:
                    INFO [muorb] SLPI: Ok executing command: icm42688p start -s
                    INFO [uORB] Advertising remote topic qshell_retval
                    INFO [qshell] qshell return value timestamp: 63895427, local time: 63898740
                    INFO [muorb] SLPI: Register interrupt b21d3164 e620e69c 3176e460
                    INFO [uORB] Advertising remote topic sensor_gyro_fifo
                    INFO [uORB] Advertising remote topic sensor_accel_fifo
                    INFO [uORB] Advertising remote topic imu_server
                    INFO [qshell] Send cmd: 'icp101xx start -I -b 5'
                    INFO [muorb] SLPI: qshell gotten: icp101xx start -I -b 5
                    INFO [muorb] SLPI: arg0 = 'icp101xx'
                    INFO [muorb] SLPI: arg2 = '-I'
                    INFO [muorb] SLPI: arg3 = '-b'
                    INFO [muorb] SLPI: arg4 = '5'
                    INFO [muorb] SLPI: *** I2C Device ID 0xb76329 12018473
                    INFO [muorb] SLPI: icp101xx #0 on I2C bus 5
                    INFO [muorb] SLPI: address 0x63
                    INFO [muorb] SLPI:
                    INFO [muorb] SLPI: Ok executing command: icp101xx start -I -b 5
                    INFO [qshell] qshell return value timestamp: 64943196, local time: 64943952
                    Starting Holybro magnetometer
                    INFO [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
                    INFO [muorb] SLPI: arg0 = 'ist8310'
                    INFO [muorb] SLPI: arg2 = '-R'
                    INFO [muorb] SLPI: arg3 = '10'
                    INFO [muorb] SLPI: arg4 = '-X'
                    INFO [muorb] SLPI: arg5 = '-b'
                    INFO [muorb] SLPI: arg6 = '1'
                    INFO [muorb] SLPI: *** I2C Device ID 0x60e09 396809
                    INFO [muorb] SLPI: ist8310 #0 on I2C bus 1
                    INFO [muorb] SLPI: (external)
                    INFO [muorb] SLPI: address 0xE
                    INFO [muorb] SLPI: rotation 10
                    INFO [muorb] SLPI:
                    INFO [muorb] SLPI: Ok executing command: ist8310 start -R 10 -X -b 1
                    INFO [qshell] qshell return value timestamp: 64990484, local time: 64992712
                    INFO [qshell] Send cmd: 'gps start'
                    INFO [muorb] SLPI: qshell gotten: gps start
                    INFO [muorb] SLPI: arg0 = 'gps'
                    INFO [muorb] SLPI: Creating pthread gps
                    INFO [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097648
                    INFO [muorb] SLPI: Ok executing command: gps start
                    INFO [qshell] qshell return value timestamp: 65023088, local time: 65025096
                    Starting Holybro LED driver
                    INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
                    INFO [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                    INFO [muorb] SLPI: arg0 = 'rgbled_ncp5623c'
                    INFO [muorb] SLPI: arg2 = '-X'
                    INFO [muorb] SLPI: arg4 = '1'
                    INFO [muorb] SLPI: arg5 = '-f'
                    INFO [muorb] SLPI: arg6 = '400'
                    INFO [muorb] SLPI: arg7 = '-a'
                    INFO [muorb] SLPI: arg8 = '56'
                    INFO [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
                    INFO [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
                    INFO [muorb] SLPI: address 0x38
                    INFO [muorb] SLPI:
                    INFO [muorb] SLPI: Ok executing command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                    INFO [qshell] qshell return value timestamp: 65062554, local time: 65063907
                    INFO [uORB] Advertising remote topic sensor_mag
                    INFO [qshell] Send cmd: 'modal_io start'
                    INFO [muorb] SLPI: qshell gotten: modal_io start
                    INFO [muorb] SLPI: arg0 = 'modal_io'
                    INFO [uORB] Advertising remote topic actuator_outputs
                    INFO [uORB] Advertising remote topic sensor_baro
                    INFO [muorb] SLPI: Ok executing command: modal_io start
                    INFO [muorb] SLPI: Opened UART ESC device
                    INFO [qshell] qshell return value timestamp: 65169377, local time: 65171079
                    INFO [uORB] Advertising remote topic actuator_outputs_debug
                    INFO [uORB] Advertising remote topic esc_status
                    Starting Spektrum RC
                    INFO [qshell] Send cmd: 'spektrum_rc start'
                    INFO [muorb] SLPI: qshell gotten: spektrum_rc start
                    INFO [muorb] SLPI: arg0 = 'spektrum_rc'
                    INFO [muorb] SLPI: Creating pthread spektrum_rc_main
                    INFO [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097645
                    INFO [muorb] SLPI: Ok executing command: spektrum_rc start
                    INFO [qshell] qshell return value timestamp: 66215910, local time: 66216633
                    INFO [qshell] Send cmd: 'voxlpm start -X -b 2'
                    INFO [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
                    INFO [muorb] SLPI: arg0 = 'voxlpm'
                    INFO [muorb] SLPI: arg4 = '2'
                    INFO [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
                    INFO [muorb] SLPI: Set i2c address 0x6a, fd 3
                    INFO [muorb] SLPI: Set i2c address 0x44, fd 3
                    INFO [uORB] Advertising remote topic battery_status
                    INFO [muorb] SLPI: voxlpm #0 on I2C bus 2
                    INFO [muorb] SLPI: address 0x44
                    INFO [muorb] SLPI:
                    INFO [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
                    INFO [uORB] Advertising remote topic power_monitor
                    INFO [qshell] qshell return value timestamp: 67272854, local time: 67275718
                    INFO [qshell] Send cmd: 'sensors start'
                    INFO [muorb] SLPI: qshell gotten: sensors start
                    INFO [muorb] SLPI: arg0 = 'sensors'
                    INFO [uORB] Advertising remote topic sensor_selection
                    INFO [uORB] Advertising remote topic sensors_status_imu
                    INFO [uORB] Advertising remote topic vehicle_acceleration
                    INFO [uORB] Advertising remote topic vehicle_angular_velocity
                    INFO [uORB] Advertising remote topic sensor_combined
                    INFO [uORB] Advertising remote topic vehicle_air_data
                    INFO [uORB] Advertising remote topic vehicle_gps_position
                    INFO [uORB] Advertising remote topic vehicle_magnetometer
                    INFO [uORB] Advertising remote topic sensor_preflight_mag
                    INFO [uORB] Advertising remote topic vehicle_imu
                    INFO [uORB] Advertising remote topic vehicle_imu_status
                    INFO [muorb] SLPI: Ok executing command: sensors start
                    INFO [uORB] Advertising remote topic sensors_status_mag
                    INFO [qshell] qshell return value timestamp: 67434965, local time: 67437421
                    INFO [uORB] Advertising remote topic sensors_status_baro
                    INFO [qshell] Send cmd: 'ekf2 start'
                    INFO [muorb] SLPI: qshell gotten: ekf2 start
                    INFO [muorb] SLPI: arg0 = 'ekf2'
                    INFO [uORB] Advertising remote topic vehicle_attitude
                    INFO [uORB] Advertising remote topic vehicle_local_position
                    INFO [uORB] Advertising remote topic estimator_event_flags
                    INFO [uORB] Advertising remote topic estimator_innovation_test_ratios
                    INFO [uORB] Advertising remote topic estimator_innovation_variances
                    INFO [uORB] Advertising remote topic estimator_innovations
                    INFO [uORB] Advertising remote topic estimator_sensor_bias
                    INFO [uORB] Advertising remote topic estimator_states
                    INFO [uORB] Advertising remote topic estimator_status_flags
                    INFO [muorb] SLPI: Ok executing command: ekf2 start
                    INFO [qshell] qshell return value timestamp: 67750482, local time: 67753672
                    INFO [uORB] Advertising remote topic ekf2_timestamps
                    INFO [uORB] Advertising remote topic vehicle_odometry
                    INFO [uORB] Advertising remote topic estimator_aid_src_baro_hgt
                    INFO [uORB] Advertising remote topic estimator_aid_src_fake_pos
                    INFO [uORB] Advertising remote topic estimator_aid_src_fake_hgt
                    INFO [uORB] Advertising remote topic estimator_aid_src_mag_heading
                    INFO [uORB] Advertising remote topic estimator_aid_src_gravity
                    INFO [qshell] Send cmd: 'mc_pos_control start'
                    INFO [muorb] SLPI: qshell gotten: mc_pos_control start
                    INFO [muorb] SLPI: arg0 = 'mc_pos_control'
                    INFO [uORB] Advertising remote topic takeoff_status
                    INFO [muorb] SLPI: Ok executing command: mc_pos_control start
                    INFO [qshell] qshell return value timestamp: 67859638, local time: 67861554
                    INFO [qshell] Send cmd: 'mc_att_control start'
                    INFO [muorb] SLPI: qshell gotten: mc_att_control start
                    INFO [muorb] SLPI: arg0 = 'mc_att_control'
                    INFO [muorb] SLPI: Ok executing command: mc_att_control start
                    INFO [qshell] qshell return value timestamp: 67918747, local time: 67920290
                    INFO [qshell] Send cmd: 'mc_rate_control start'
                    INFO [muorb] SLPI: qshell gotten: mc_rate_control start
                    INFO [muorb] SLPI: arg0 = 'mc_rate_control'
                    INFO [uORB] Advertising remote topic rate_ctrl_status
                    INFO [muorb] SLPI: Ok executing command: mc_rate_control start
                    INFO [qshell] qshell return value timestamp: 68027813, local time: 68030404
                    INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start'
                    INFO [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
                    INFO [muorb] SLPI: arg0 = 'mc_hover_thrust_estimator'
                    INFO [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
                    INFO [qshell] qshell return value timestamp: 68087592, local time: 68089224
                    INFO [qshell] Send cmd: 'mc_autotune_attitude_control start'
                    INFO [muorb] SLPI: qshell gotten: mc_autotune_attitude_control start
                    INFO [muorb] SLPI: arg0 = 'mc_autotune_attitude_control'
                    INFO [uORB] Advertising remote topic autotune_attitude_control_status
                    INFO [muorb] SLPI: Ok executing command: mc_autotune_attitude_control start
                    INFO [qshell] qshell return value timestamp: 68137157, local time: 68138847
                    INFO [qshell] Send cmd: 'land_detector start multicopter'
                    INFO [muorb] SLPI: qshell gotten: land_detector start multicopter
                    INFO [muorb] SLPI: arg0 = 'land_detector'
                    INFO [muorb] SLPI: arg2 = 'multicopter'
                    INFO [muorb] SLPI: Ok executing command: land_detector start multicopter
                    INFO [qshell] qshell return value timestamp: 68188877, local time: 68189722
                    INFO [uORB] Advertising remote topic vehicle_land_detected
                    INFO [qshell] Send cmd: 'manual_control start'
                    INFO [muorb] SLPI: qshell gotten: manual_control start
                    INFO [muorb] SLPI: arg0 = 'manual_control'
                    INFO [muorb] SLPI: Ok executing command: manual_control start
                    INFO [uORB] Advertising remote topic manual_control_setpoint
                    INFO [qshell] qshell return value timestamp: 68237903, local time: 68239705
                    INFO [qshell] Send cmd: 'control_allocator start'
                    INFO [muorb] SLPI: qshell gotten: control_allocator start
                    INFO [muorb] SLPI: arg0 = 'control_allocator'
                    INFO [uORB] Advertising remote topic control_allocator_status
                    INFO [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
                    INFO [uORB] Advertising remote topic actuator_motors
                    INFO [uORB] Advertising remote topic actuator_servos
                    INFO [uORB] Advertising remote topic actuator_servos_trim
                    INFO [muorb] SLPI: Ok executing command: control_allocator start
                    INFO [qshell] qshell return value timestamp: 68577984, local time: 68579385
                    INFO [qshell] Send cmd: 'rc_update start'
                    INFO [muorb] SLPI: qshell gotten: rc_update start
                    INFO [muorb] SLPI: arg0 = 'rc_update'
                    INFO [muorb] SLPI: Ok executing command: rc_update start
                    INFO [qshell] qshell return value timestamp: 68873945, local time: 68874998
                    INFO [qshell] Send cmd: 'commander start'
                    INFO [muorb] SLPI: qshell gotten: commander start
                    INFO [muorb] SLPI: arg0 = 'commander'
                    INFO [muorb] SLPI: Creating pthread commander
                    INFO [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097641
                    INFO [uORB] Advertising remote topic led_control
                    INFO [muorb] SLPI: LED: open /dev/led0 failed (22)
                    INFO [muorb] SLPI: Ok executing command: commander start
                    INFO [uORB] Advertising remote topic tune_control
                    INFO [qshell] qshell return value timestamp: 69104924, local time: 69107190
                    INFO [uORB] Advertising remote topic event
                    INFO [uORB] Advertising remote topic health_report
                    INFO [uORB] Advertising remote topic failsafe_flags
                    INFO [uORB] Advertising remote topic actuator_armed
                    INFO [uORB] Advertising remote topic vehicle_control_mode
                    INFO [uORB] Advertising remote topic vehicle_thrust_setpoint
                    INFO [uORB] Advertising remote topic vehicle_torque_setpoint
                    INFO [uORB] Advertising remote topic vehicle_rates_setpoint
                    INFO [uORB] Advertising remote topic vehicle_status
                    INFO [uORB] Advertising remote topic failure_detector_status
                    INFO [uORB] Advertising remote topic vehicle_local_position_setpoint
                    INFO [uORB] Advertising remote topic vehicle_attitude_setpoint
                    INFO [qshell] Send cmd: 'commander mode manual'
                    INFO [muorb] SLPI: qshell gotten: commander mode manual
                    INFO [muorb] SLPI: arg1 = 'mode'
                    INFO [muorb] SLPI: arg2 = 'manual'
                    INFO [uORB] Advertising remote topic vehicle_command
                    INFO [muorb] SLPI: Ok executing command: commander mode manual
                    INFO [qshell] qshell return value timestamp: 69148498, local time: 69150136
                    INFO [uORB] Advertising remote topic vehicle_command_ack
                    INFO [uORB] Marking DeviceNode(vehicle_attitude_setpoint) as advertised in process_remote_topic
                    INFO [qshell] Send cmd: 'param_set_selector start'
                    INFO [muorb] SLPI: qshell gotten: param_set_selector start
                    INFO [muorb] SLPI: arg0 = 'param_set_selector'
                    INFO [muorb] SLPI: Ok executing command: param_set_selector start
                    INFO [qshell] qshell return value timestamp: 69186104, local time: 69187696
                    INFO [qshell] Send cmd: 'flight_mode_manager start'
                    INFO [muorb] SLPI: qshell gotten: flight_mode_manager start
                    INFO [muorb] SLPI: arg0 = 'flight_mode_manager'
                    INFO [uORB] Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
                    INFO [muorb] SLPI: Ok executing command: flight_mode_manager start
                    INFO [qshell] qshell return value timestamp: 69346243, local time: 69347753
                    INFO [uORB] Advertising remote topic actuator_controls_status_0
                    INFO [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
                    INFO [muorb] SLPI: Advertising remote topic transponder_report
                    INFO [muorb] SLPI: Advertising remote topic rtl_time_estimate
                    INFO [muorb] SLPI: Advertising remote topic position_setpoint_triplet
                    INFO [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
                    INFO [muorb] SLPI: Advertising remote topic telemetry_status
                    INFO [mavlink] partner IP: 127.0.0.1
                    INFO [muorb] SLPI: Advertising remote topic vehicle_visual_odometry
                    INFO [muorb] SLPI: Advertising remote topic obstacle_distance
                    INFO [muorb] SLPI: Advertising remote topic offboard_control_mode
                    INFO [muorb] SLPI: Advertising remote topic timesync_status
                    INFO [uORB] Advertising remote topic estimator_aid_src_ev_hgt
                    INFO [uORB] Advertising remote topic estimator_aid_src_ev_pos
                    INFO [uORB] Advertising remote topic estimator_aid_src_ev_vel
                    INFO [uORB] Advertising remote topic estimator_aid_src_ev_yaw
                    INFO [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
                    INFO [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
                    INFO [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
                    INFO [px4] Startup script returned successfully
                    INFO [muorb] SLPI: u-blox firmware version: SPG 3.01
                    INFO [muorb] SLPI: u-blox protocol version: 18.00
                    INFO [muorb] SLPI: u-blox module: NEO-M8N-0
                    INFO [uORB] Advertising remote topic sensor_gps
                    INFO [muorb] SLPI: Advertising remote topic ping
                    INFO [uORB] Advertising remote topic mavlink_log
                    INFO [muorb] SLPI: Connection to ground station lost
                    INFO [muorb] SLPI: GCS connection regained
                    WARN [uORB] orb_advertise_multi: failed to set queue size
                      @andremoura Okay, that's not very useful. Let's try something else. First of all can you post the contents of the file /etc/systemd/system/voxl-px4.service? Then, stop the service from autostarting voxl-px4 with the commands systemctl disable voxl-px4 and sync. Then reboot the drone. When you adb back in to the drone you can run voxl-inspect-services to verify that voxl-px4 isn't running. Then you can start voxl-px4 manually from the command line with voxl-px4 and then post all of the output from that.
                      Captain 7th
                      I tried this method, but it still is not working! Here is the console:
                      ______  __   __    ___
                      | ___ \ \ \ / /   /   |
                      | |_/ /  \ V /   / /| |
                      |  __/   /   \  / /_| |
                      | |     / /^\ \ \___  |
                      \_|     \/   \/     |_/
                      px4 starting.
                      GPS: HOLYBRO
                      RC: SPEKTRUM
                      OSD: DISABLE
                      EXTRA STEPS:
                      Running on M0054
                      INFO  [muorb] SLPI:
                      INFO  [muorb] SLPI:
                      INFO  [muorb] SLPI:
                      INFO  [muorb] SLPI:
                      INFO  [muorb] SLPI:
                      • Captain 7thC Captain 7th
                        ______  __   __    ___
                        | ___ \ \ \ / /   /   |
                        | |_/ /  \ V /   / /| |
                        |  __/   /   \  / /_| |
                        | |     / /^\ \ \___  |
                        \_|     \/   \/     |_/
                        px4 starting.
                        GPS: HOLYBRO
                        RC: SPEKTRUM
                        OSD: DISABLE
                        EXTRA STEPS:
                        Running on M0054
                        INFO  [muorb] SLPI:
                        INFO  [muorb] SLPI:
                        INFO  [muorb] SLPI:
                        INFO  [muorb] SLPI:
                        INFO  [muorb] SLPI:
                        @Captain-7th Are you saying that the GPS is not working? I don't see anything in the included logs to indicate that GPS is not working.
                        Captain 7thC 1 Reply Last reply
                          Captain 7th
                          @Eric-Katzfey Dear Eric,
                          The log shows that the voxl-px4 is does not get completed and it crashes after a while:
                          what are these errors? after these messages, I couldn't run again the voxl-px4 again! so I decided the follow this way:
                          After reading some posts, I decided to upgrade the SDK version to the latest. I tried to upgrade the SDK from 1.0.0 to 1.3.0. Then running "apt update && apt upgrade"
                          Then, followed some hints from you that you mentioned in some other post. I found the /usr/bin/voxl-px4-start file and added these commands at the end of the file:
                          1. qshell gps stop
                          2. /bin/sleep 1
                          3. qshell gps start -b 9600
                          Then, in my browser (HTTP://ip.address), it shows 255 satellites, but the GPS is still blinking in red color (should it be blue color?) Also, I checked the QGS app, it does not show the number of satellites and the drone location on the map. (I am in an indoor env, but I put the drone very close to the open window.)
                            1. qshell gps stop
                            2. /bin/sleep 1
                            @Captain-7th The connection to ground station has nothing to do with GPS. That is probably something related to your wireless network link. So I still don't see why you think GPS wasn't working.
                              Captain 7th
                              @Eric-Katzfey Could you please tell me when the GPS is working, should it start blinking blue or red? Currently, mine is red! Please also let me know how I can check my GPS is working properly or not.
                                @Captain-7th That LED is a general PX4 status LED. If it is red it could indicate any number of different problems. It is not specifically tied to the GPS.
                                  Captain 7th
                                  @Eric-Katzfey Thanks for the reply. Can you guide me on how can I check what are the problems?
                                  Also, I have a wifi problem. Can you help me with that? My question is here: https://forum.modalai.com/topic/3600/how-to-set-up-the-voxl-wifi-station-mode-for-hidden-networks?_=1719998452051
                                    @Captain-7th Please check the new forum post where you ask all these questions again.
