  3. GPS not working
GPS not working
sentinel
49 Posts 7 Posters 32.5k Views 4 Watching
  • A Andre Moura
    @daniel I think that's all I did, but here is my /etc/modalai/voxl-px4.config, in case you want to look for any differences:
    #!/bin/sh
    # PX4 commands need the 'px4-' prefix in bash.
    # (px4-alias.sh is expected to be in the PATH)
    . px4-alias.sh
    # Figure out what platform we are running on.
    # Eventually there will be a utility called voxl-platform that will
    # return the platform tag or an error code. This utility is not yet
    # ubiquitous so it may be that it isn't available. Trying to call a
    # non existent program will generate an error code by the OS. If the
    # program exists and doesn't return an error code then use the results.
    PLATFORM=`/usr/bin/voxl-platform 2> /dev/null`
    RETURNCODE=$?
    if [ $RETURNCODE -ne 0 ]; then
        # If we couldn't get the platform from the voxl-platform utility then check
        # /etc/version to see if there is an M0052 substring in the version string. If so,
        # then we assume that we are on M0052. Otherwise assume M0054.
        VERSIONSTRING=$(</etc/version)
        M0052SUBSTRING="M0052"
        if [[ "$VERSIONSTRING" == *"$M0052SUBSTRING"* ]]; then
            PLATFORM="M0052"
        else
            PLATFORM="M0054"
        fi
    fi
    # We can only run on M0052 or M0054 so exit with error if that is not the case
    if [ $PLATFORM = "M0052" ]; then
        /bin/echo "Running on M0052"
        if [ "$RC" == "CRSF" ]; then
            /bin/echo "Error, crossfire not supported on M0052!"
            exit 0
        fi
    elif [ $PLATFORM = "M0054" ]; then
        /bin/echo "Running on M0054"
    else
        /bin/echo "Error, cannot determine platform!"
        exit 0
    fi
    uorb start
    muorb start
    # In order to just exit after starting the uorb / muorb modules define
    # the environment variable MINIMAL_PX4. (e.g. export MINIMAL_PX4=1)
    # This is useful for testing / debug where you may want to start drivers
    # and modules manually from the px4 command shell
    if [ ! -z $MINIMAL_PX4 ]; then
        /bin/echo "Running minimal script"
        exit 0
    fi
    # Sleep a little here. A lot happens when the uorb and muorb start
    # and we need to make sure that it all completes successfully to avoid
    # any possible race conditions.
    /bin/sleep 1
    # IMU (accelerometer / gyroscope)
    # Start this first because it gets the high rate interrupts coming in to the
    # DSP. Without this the DSP will oversleep and miss critical timeouts.
    # TODO: Why is that the case?
    if [ "$IMU" == "ROTATE_IMU_YAW_180" ]; then
        /bin/echo "Starting IMU driver with yaw 180 rotation"
        qshell icm42688p start -s -R 4
    else
    fi
    /bin/sleep 1
    # Load in all of the parameters that have been saved in the file
    param load
    # Start logging and use timestamps for log files when possible.
    # Add the "-e" option to start logging immediately. Default is
    # to log only when armed
    logger start -t
    # We do not change the value of SYS_AUTOCONFIG but if it does not
    # show up as used then it is not reported to QGC and we get a
    # missing parameter error.
    param touch SYS_AUTOCONFIG
    # Start all of the device drivers on DSP
    # Magnetometer
    if [ "$GPS" == "MATEK" ]; then
        # Use this line for the magnetometer in the Matek Systems M8Q-5883 module
        /bin/echo "Starting Mateksys M8Q-5883 magnetometer"
    elif [ "$GPS" == "HERE3" ]; then
        # Use this line for the magnetometer in the Here3 GPS module
        /bin/echo "Starting Here3 ak09916 magnetometer"
        qshell ak09916 start -R 2 -X
    else
        # Use this line for the magnetometer in the Holybro GPS module
        /bin/echo "Starting Holybro magnetometer"
    fi
    # LED driver for the Pixhawk 4 GPS module
    # Older units have i2c address 0x39 (57) and newer ones 0x38 (56)
    # M0054 only supports the newer one. M0052 can support either.
        qshell rgbled_ncp5623c start -X -b 1 -f 400 -a 57
    fi
    if [ "$GPS" == "HOLYBRO" ]; then
        /bin/echo "Starting Holybro LED driver"
        qshell rgbled_ncp5623c start -X -b 1 -f 400 -a 56
        # Use this line for the Here3 GPS module LED controller
        /bin/echo "Starting Here3 LED"
        qshell rgbled start -X -f 400
    fi
    # Barometer
    qshell icp10100 start -I -b 5
    # ESC driver
    # We start this even if there is a PX4IO module. If there is
    # a PX4IO (M0065) module it will be plugged into the RC port
    # and so this driver will output commands on an empty port.
    qshell modalai_esc start
    qshell mixer load /dev/uart_esc quad_x.main.mix
    # APM power monitor
    qshell voxlpm start -X -b 2
    # On M0052 the GPS and RC drivers run on the apps processor
        # Pixhawk 4 GPS module
        gps start -d /dev/ttyHS2
        # RC input may be coming via either an external M0065 (aka px4io) module
        # or a directly attached Spektrum receiver. First see if the M0065 is detected.
        px4io detect
        PX4IO_STATUS=$?
        /bin/echo "PX4IO detect returned value $PX4IO_STATUS"
        if [ $PX4IO_STATUS -eq 0 ]; then
            /bin/echo "Found M0065, starting px4io"
            # On M0052 px4io only supports RC input, not PWM output
            px4io start
        else
            /bin/echo "M0065 not detected, starting Spektrum RC driver"
            spektrum_rc start -d /dev/ttyHS1
        fi
    # On M0054 the GPS and RC drivers run on SLPI DSP
    else
            # Use this gps start line instead for Matek Systems M8Q-5883 module
            /bin/echo "Starting Mateksys M8Q-5883 GPS"
            qshell gps start
            /bin/echo "Starting Here3 GPS"
            qshell gps start
        else
            # Only the newer Holybro unit is supported on M0054
            /bin/echo "Starting Holybro GPS"
            qshell gps start
        fi
        # If RC is TBS Crossfire then start its driver.
        # Otherwise, it could be either a directly connected Spektrum receiver
        # or an external M0065 (aka px4io) module.
        if [ "$RC" == "CRSF_MAV" ]; then
            /bin/echo "Starting TBS crossfire RC - MAV Mode"
            qshell tbs_crossfire start -m -p 7 -b 115200
        elif [ "$RC" == "CRSF_RAW" ]; then
            /bin/echo "Starting TBS crossfire RC - CRSF Mode"
            qshell tbs_crossfire start -c -p 7 -b 250000
        else
            qshell px4io detect
            PX4IO_STATUS=$?
                # On M0054 we also support PWM output from M0065 (aka PX4IO)
                # If there are no pwm escs then that connector will be empty.
                qshell px4io start
                qshell px4io recovery
                qshell mixer load /dev/px4io quad_x_io.main.mix
                sleep 1
                qshell pwm rate -c 1234 -r 400
    			qshell pwm disarmed -c 1234 -p 900
    			qshell pwm min -c 1234 -p 1060
    			qshell pwm max -c 1234 -p 2000
                qshell pwm failsafe -c 1234 -p -1 -d /dev/px4io
            else
                qshell spektrum_rc start -d 8
            fi
        fi
    fi
    /bin/sleep 1
    # Start all of the processing modules on DSP
    qshell sensors start
    qshell ekf2 start
    qshell mc_pos_control start
    qshell mc_att_control start
    qshell mc_rate_control start
    qshell mc_hover_thrust_estimator start
    qshell land_detector start multicopter
    /bin/sleep 1
    # Start all of the processing modules on the applications processor
    rc_update start
    dataman start
    navigator start
    commander start
    commander mode manual
    # This is needed for altitude and position hold modes
    flight_mode_manager start
    # Start our service to update system time from GPS
    modalai_gps_timer start
    # As of 1.4.11 mavlink configuration has been changed!!! All communications are
    # now done via the mavlink server and voxl-vision-px4!!!
    param set MAV_BROADCAST 0
        # Slow everything way down if we are using TBS Crossfire
        mavlink start -a -x -u 14556 -o 14557 -r 10000 -n lo -m minimal
        /bin/sleep 1
    else
        mavlink start -x -u 14556 -o 14557 -r 100000 -n lo -m onboard
        /bin/sleep 1
        # slow down some of the fastest streams in onboard mode
        mavlink stream -u 14556 -s HIGHRES_IMU -r 10
        mavlink stream -u 14556 -s ATTITUDE -r 10
        mavlink stream -u 14556 -s ATTITUDE_QUATERNION -r 10
        # speed up rc_channels
        mavlink stream -u 14556 -s RC_CHANNELS -r 50
        /bin/sleep 1
    fi
        # Start up the IMU server to support VIO. This is done differently on M0054
        imu_server start
    fi
    mavlink boot_complete
    # For now we use a mavlink bridge for TBS Crossfire support
        mavlink_bridge start
    fi
    # Optional MSP OSD driver for DJI goggles
    # This is only supported on M0054 (with M0125 accessory board)
        if [ "$OSD" == "OSD" ]; then
            /bin/echo "Starting OSD driver"
            msp_osd start -d /dev/ttyHS1
        fi
    fi
    If your config is like this and it still doesn't work, maybe @Eric-Katzfey can help you better.
    D Offline
    D Offline
    daniel
    @Andre-Moura Thank You! We fixed our GPS setting problem.
    • J Offline
      J Offline
      JustinDev23
      @daniel what ended up being your fix? I was seeing the same issues yesterday with our Sentinel trying to do GPS only outdoor flights. It wouldn't ARM due to the GPS Speed Accuracy. Flashing blue for a minute or two and then turning green after what i assumed was VIO getting healthy.
      @Eric-Katzfey I don't want to use the Sentinel VIO so was hoping there was a GPS Only No VIO params file. It seems like the one posted on the git is still looking at VIO.
      • James StrawsonJ Offline
        James Strawson
        you will likely want to configure px4 params to suit your exact use case, e.g. some people will want it to arm without a gps lock, some won't. As a starting point we have "helper" files that can be loaded through QGC that set up the handful of relevant PX4 params for indoor vs outdoor flight
        Here is the outdoor helper for px4 1.12:
        https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.12/ekf2_outdoor_gps_mag.params
        And the helpers for PX4 1.14:
        https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/tree/master/params/v1.14/EKF2_helpers
        J 2 Replies Last reply
          J Offline
          J Offline
          JustinDev23
          @James-Strawson Awesome, thanks I am going to load the outdoor params. Just didn't know if someone had already blessed us all with a known good config.
            J Offline
            J Offline
            JustinDev23
            @James-Strawson If i stop and disable the VIO server will that still allow GPS to pass through? I am getting good satellite and HDOP but the GPS never transitions from flashing blue to green with the ekf2_outdoor_gps_baro params. it is causing the platform to not allow me to put it in POSCTL. I do not intend to do GPS denied flights at this time and am trying to focus on outdoor 5G flights for a while to build confidence in our GCS software interactions with VOXL.
            • J JustinDev23
              @JustinDev23 These parameter settings won't affect the ability of the GPS receiver to get a lock. It is an independent unit and not affected by VIO in any way.
              J 1 Reply Last reply
                J Offline
                J Offline
                JustinDev23
                @Eric-Katzfey, thanks for the response and clarifying.
                I had a 3D Fix but wasnt able to switch from Manual to Position. I have worked on other projects with Ardupilot mission planner and it could blend or use best from different sources. I wasnt sure exactly how your implementation of GPS and VIO were working together on feeding positional data to the PX4 autopilot.
                A 1 Reply Last reply
                • J JustinDev23
                  Andre Moura
                  @JustinDev23 You can have GPS fix and not have GPS lock on the PX4. Have you checked the number of satellites on QGC? From my experience, GPS lock (required to switch to Position mode) is achieved with 12 satellites or more.
                  Maybe test the drone on a new location with more open space, that did the trick for me.
                  • A Andre Moura
                    J Offline
                    J Offline
                    JustinDev23
                    @Andre-Moura sat and hdop have not been an issue on QGC. ekf2_req_nsats is set to 6 and i have had no obstructions and in open space.
                    GPS Horizontal Pos Error too high with 9 sats and 1.4 hdop
                    • J JustinDev23
                      J Offline
                      J Offline
                      JustinDev23
                      And if it is not that it is GPS Speed Accuracy too low
                      I would hate to disable those checks but i feel like it is something else that is causing this to occur.
                      @Eric-Katzfey Is there a flow chart for what all is feeding position information to PX4 from VOXL2?
                        @JustinDev23 This is the closest to what you're looking for: https://docs.modalai.com/voxl-px4-developer-guide/
                          J Offline
                          J Offline
                          JustinDev23
                          @tom Thanks! Looks like what i needed.
                            @andremoura The GPS unit will come up and get a fix on it's own after it has been powered on so that doesn't indicate anything about the health of the connection to the flight controller. If the result of px4-listener sensor_gps is never published then there is likely a problem with your connection to the GPS unit. The GPS driver on VOXL2 runs on the DSP, not on the applications processor so you have to use qshell to interact with it. So, for status, you would use px4-qshell gps status. Have you made any changes to the Sentinel hardware or is it exactly the same as it was shipped?
                            Captain 7thC Offline
                            Captain 7th
                            @Eric-Katzfey I have the same issue. I tried the method that you mentioned, not only voxl-px4 is not working now, but also I got this error:
                            INFO [muorb] SLPI: muorb aggregator thread running
                            INFO [muorb] muorb protobuf initalize method succeeded
                            INFO [muorb] succesfully did ADVERTISE_TEST_TYPE
                            INFO [muorb] SLPI: Creating pthread test_MUORB
                            INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
                            INFO [muorb] succesfully did SUBSCRIBE_TEST_TYPE
                            INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
                            INFO [muorb] succesfully did TOPIC_TEST_TYPE
                            INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
                            INFO [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
                            INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
                            INFO [muorb] muorb test passed
                            INFO [muorb] SLPI: Advertising remote topic log_message
                            | ___ \ \ \ / / / |
                            | |/ / \ V / / /| |
                            | __/ / \ / /
                            | | / /^\ \ ___ |
                            _| / / |_/
                            px4 starting.
                            INFO [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
                            INFO [parameters] Starting param sync THREAD
                            GPS: HOLYBRO
                            RC: SPEKTRUM
                            OSD: DISABLE
                            EXTRA STEPS:
                            INFO [muorb] SLPI: Starting param sync THREAD
                            Running on M0054
                            INFO [muorb] SLPI: before starting the qshell_entry task
                            INFO [muorb] SLPI: Creating pthread qshell
                            INFO [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
                            INFO [muorb] SLPI: qshell entry.....
                            INFO [muorb] SLPI: after starting the qshell_entry task
                            INFO [muorb] SLPI: Init app map initialized
                            INFO [param] selected parameter default file /data/px4/param/parameters
                            INFO [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
                            INFO [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
                            INFO [muorb] SLPI: Advertising remote topic parameter_update
                            INFO [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to
                            INFO [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
                            INFO [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to
                            INFO [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
                            INFO [parameters] BSON document size 3022 bytes, decoded 3022 bytes (INT32:43, FLOAT:98)
                            INFO [logger] logger started (mode=all)
                            INFO [qshell] Send cmd: 'icm42688p start -s'
                            INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                            INFO [muorb] SLPI: qshell gotten: icm42688p start -s
                            INFO [muorb] SLPI: arg0 = 'icm42688p'
                            INFO [muorb] SLPI: arg1 = 'start'
                            INFO [muorb] SLPI: arg2 = '-s'
                            INFO [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
                            INFO [uORB] Advertising remote topic sensor_accel
                            INFO [uORB] Advertising remote topic sensor_gyro
                            INFO [muorb] SLPI: ICM42688P::probe successful!
                            INFO [muorb] SLPI: on SPI bus 1
                            INFO [muorb] SLPI: >>> ICM42688P this: 3176e460
                            INFO [muorb] SLPI: icm42688p #0 on SPI bus 1
                            INFO [muorb] SLPI:
                            INFO [muorb] SLPI: Ok executing command: icm42688p start -s
                            INFO [uORB] Advertising remote topic qshell_retval
                            INFO [qshell] qshell return value timestamp: 63895427, local time: 63898740
                            INFO [muorb] SLPI: Register interrupt b21d3164 e620e69c 3176e460
                            INFO [uORB] Advertising remote topic sensor_gyro_fifo
                            INFO [uORB] Advertising remote topic sensor_accel_fifo
                            INFO [uORB] Advertising remote topic imu_server
                            INFO [qshell] Send cmd: 'icp101xx start -I -b 5'
                            INFO [muorb] SLPI: qshell gotten: icp101xx start -I -b 5
                            INFO [muorb] SLPI: arg0 = 'icp101xx'
                            INFO [muorb] SLPI: arg2 = '-I'
                            INFO [muorb] SLPI: arg3 = '-b'
                            INFO [muorb] SLPI: arg4 = '5'
                            INFO [muorb] SLPI: *** I2C Device ID 0xb76329 12018473
                            INFO [muorb] SLPI: icp101xx #0 on I2C bus 5
                            INFO [muorb] SLPI: address 0x63
                            INFO [muorb] SLPI:
                            INFO [muorb] SLPI: Ok executing command: icp101xx start -I -b 5
                            INFO [qshell] qshell return value timestamp: 64943196, local time: 64943952
                            INFO [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
                            INFO [muorb] SLPI: arg0 = 'ist8310'
                            INFO [muorb] SLPI: arg2 = '-R'
                            INFO [muorb] SLPI: arg3 = '10'
                            INFO [muorb] SLPI: arg4 = '-X'
                            INFO [muorb] SLPI: arg5 = '-b'
                            INFO [muorb] SLPI: arg6 = '1'
                            INFO [muorb] SLPI: *** I2C Device ID 0x60e09 396809
                            INFO [muorb] SLPI: ist8310 #0 on I2C bus 1
                            INFO [muorb] SLPI: (external)
                            INFO [muorb] SLPI: address 0xE
                            INFO [muorb] SLPI: rotation 10
                            INFO [muorb] SLPI:
                            INFO [muorb] SLPI: Ok executing command: ist8310 start -R 10 -X -b 1
                            INFO [qshell] qshell return value timestamp: 64990484, local time: 64992712
                            INFO [qshell] Send cmd: 'gps start'
                            INFO [muorb] SLPI: qshell gotten: gps start
                            INFO [muorb] SLPI: arg0 = 'gps'
                            INFO [muorb] SLPI: Creating pthread gps
                            INFO [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097648
                            INFO [muorb] SLPI: Ok executing command: gps start
                            INFO [qshell] qshell return value timestamp: 65023088, local time: 65025096
                            INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
                            INFO [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                            INFO [muorb] SLPI: arg0 = 'rgbled_ncp5623c'
                            INFO [muorb] SLPI: arg2 = '-X'
                            INFO [muorb] SLPI: arg4 = '1'
                            INFO [muorb] SLPI: arg5 = '-f'
                            INFO [muorb] SLPI: arg6 = '400'
                            INFO [muorb] SLPI: arg7 = '-a'
                            INFO [muorb] SLPI: arg8 = '56'
                            INFO [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
                            INFO [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
                            INFO [muorb] SLPI: address 0x38
                            INFO [muorb] SLPI:
                            INFO [muorb] SLPI: Ok executing command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                            INFO [qshell] qshell return value timestamp: 65062554, local time: 65063907
                            INFO [uORB] Advertising remote topic sensor_mag
                            INFO [qshell] Send cmd: 'modal_io start'
                            INFO [muorb] SLPI: qshell gotten: modal_io start
                            INFO [muorb] SLPI: arg0 = 'modal_io'
                            INFO [uORB] Advertising remote topic actuator_outputs
                            INFO [uORB] Advertising remote topic sensor_baro
                            INFO [muorb] SLPI: Ok executing command: modal_io start
                            INFO [muorb] SLPI: Opened UART ESC device
                            INFO [qshell] qshell return value timestamp: 65169377, local time: 65171079
                            INFO [uORB] Advertising remote topic actuator_outputs_debug
                            INFO [uORB] Advertising remote topic esc_status
                            Starting Spektrum RC
                            INFO [qshell] Send cmd: 'spektrum_rc start'
                            INFO [muorb] SLPI: qshell gotten: spektrum_rc start
                            INFO [muorb] SLPI: arg0 = 'spektrum_rc'
                            INFO [muorb] SLPI: Creating pthread spektrum_rc_main
                            INFO [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097645
                            INFO [muorb] SLPI: Ok executing command: spektrum_rc start
                            INFO [qshell] qshell return value timestamp: 66215910, local time: 66216633
                            INFO [qshell] Send cmd: 'voxlpm start -X -b 2'
                            INFO [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
                            INFO [muorb] SLPI: arg0 = 'voxlpm'
                            INFO [muorb] SLPI: arg4 = '2'
                            INFO [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
                            INFO [muorb] SLPI: Set i2c address 0x6a, fd 3
                            INFO [muorb] SLPI: Set i2c address 0x44, fd 3
                            INFO [uORB] Advertising remote topic battery_status
                            INFO [muorb] SLPI: voxlpm #0 on I2C bus 2
                            INFO [muorb] SLPI: address 0x44
                            INFO [muorb] SLPI:
                            INFO [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
                            INFO [uORB] Advertising remote topic power_monitor
                            INFO [qshell] qshell return value timestamp: 67272854, local time: 67275718
                            INFO [qshell] Send cmd: 'sensors start'
                            INFO [muorb] SLPI: qshell gotten: sensors start
                            INFO [muorb] SLPI: arg0 = 'sensors'
                            INFO [uORB] Advertising remote topic sensor_selection
                            INFO [uORB] Advertising remote topic sensors_status_imu
                            INFO [uORB] Advertising remote topic vehicle_acceleration
                            INFO [uORB] Advertising remote topic vehicle_angular_velocity
                            INFO [uORB] Advertising remote topic sensor_combined
                            INFO [uORB] Advertising remote topic vehicle_air_data
                            INFO [uORB] Advertising remote topic vehicle_gps_position
                            INFO [uORB] Advertising remote topic vehicle_magnetometer
                            INFO [uORB] Advertising remote topic sensor_preflight_mag
                            INFO [uORB] Advertising remote topic vehicle_imu
                            INFO [uORB] Advertising remote topic vehicle_imu_status
                            INFO [muorb] SLPI: Ok executing command: sensors start
                            INFO [uORB] Advertising remote topic sensors_status_mag
                            INFO [qshell] qshell return value timestamp: 67434965, local time: 67437421
                            INFO [uORB] Advertising remote topic sensors_status_baro
                            INFO [qshell] Send cmd: 'ekf2 start'
                            INFO [muorb] SLPI: qshell gotten: ekf2 start
                            INFO [muorb] SLPI: arg0 = 'ekf2'
                            INFO [uORB] Advertising remote topic vehicle_attitude
                            INFO [uORB] Advertising remote topic vehicle_local_position
                            INFO [uORB] Advertising remote topic estimator_event_flags
                            INFO [uORB] Advertising remote topic estimator_innovation_test_ratios
                            INFO [uORB] Advertising remote topic estimator_innovation_variances
                            INFO [uORB] Advertising remote topic estimator_innovations
                            INFO [uORB] Advertising remote topic estimator_sensor_bias
                            INFO [uORB] Advertising remote topic estimator_states
                            INFO [uORB] Advertising remote topic estimator_status_flags
                            INFO [muorb] SLPI: Ok executing command: ekf2 start
                            INFO [qshell] qshell return value timestamp: 67750482, local time: 67753672
                            INFO [uORB] Advertising remote topic ekf2_timestamps
                            INFO [uORB] Advertising remote topic vehicle_odometry
                            INFO [uORB] Advertising remote topic estimator_aid_src_baro_hgt
                            INFO [uORB] Advertising remote topic estimator_aid_src_fake_pos
                            INFO [uORB] Advertising remote topic estimator_aid_src_fake_hgt
                            INFO [uORB] Advertising remote topic estimator_aid_src_mag_heading
                            INFO [uORB] Advertising remote topic estimator_aid_src_gravity
                            INFO [qshell] Send cmd: 'mc_pos_control start'
                            INFO [muorb] SLPI: qshell gotten: mc_pos_control start
                            INFO [muorb] SLPI: arg0 = 'mc_pos_control'
                            INFO [uORB] Advertising remote topic takeoff_status
                            INFO [muorb] SLPI: Ok executing command: mc_pos_control start
                            INFO [qshell] qshell return value timestamp: 67859638, local time: 67861554
                            INFO [qshell] Send cmd: 'mc_att_control start'
                            INFO [muorb] SLPI: qshell gotten: mc_att_control start
                            INFO [muorb] SLPI: arg0 = 'mc_att_control'
                            INFO [muorb] SLPI: Ok executing command: mc_att_control start
                            INFO [qshell] qshell return value timestamp: 67918747, local time: 67920290
                            INFO [qshell] Send cmd: 'mc_rate_control start'
                            INFO [muorb] SLPI: qshell gotten: mc_rate_control start
                            INFO [muorb] SLPI: arg0 = 'mc_rate_control'
                            INFO [uORB] Advertising remote topic rate_ctrl_status
                            INFO [muorb] SLPI: Ok executing command: mc_rate_control start
                            INFO [qshell] qshell return value timestamp: 68027813, local time: 68030404
                            INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start'
                            INFO [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
                            INFO [muorb] SLPI: arg0 = 'mc_hover_thrust_estimator'
                            INFO [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
                            INFO [qshell] qshell return value timestamp: 68087592, local time: 68089224
                            INFO [qshell] Send cmd: 'mc_autotune_attitude_control start'
                            INFO [muorb] SLPI: qshell gotten: mc_autotune_attitude_control start
                            INFO [muorb] SLPI: arg0 = 'mc_autotune_attitude_control'
                            INFO [uORB] Advertising remote topic autotune_attitude_control_status
                            INFO [muorb] SLPI: Ok executing command: mc_autotune_attitude_control start
                            INFO [qshell] qshell return value timestamp: 68137157, local time: 68138847
                            INFO [qshell] Send cmd: 'land_detector start multicopter'
                            INFO [muorb] SLPI: qshell gotten: land_detector start multicopter
                            INFO [muorb] SLPI: arg0 = 'land_detector'
                            INFO [muorb] SLPI: arg2 = 'multicopter'
                            INFO [muorb] SLPI: Ok executing command: land_detector start multicopter
                            INFO [qshell] qshell return value timestamp: 68188877, local time: 68189722
                            INFO [uORB] Advertising remote topic vehicle_land_detected
                            INFO [qshell] Send cmd: 'manual_control start'
                            INFO [muorb] SLPI: qshell gotten: manual_control start
                            INFO [muorb] SLPI: arg0 = 'manual_control'
                            INFO [muorb] SLPI: Ok executing command: manual_control start
                            INFO [uORB] Advertising remote topic manual_control_setpoint
                            INFO [qshell] qshell return value timestamp: 68237903, local time: 68239705
                            INFO [qshell] Send cmd: 'control_allocator start'
                            INFO [muorb] SLPI: qshell gotten: control_allocator start
                            INFO [muorb] SLPI: arg0 = 'control_allocator'
                            INFO [uORB] Advertising remote topic control_allocator_status
                            INFO [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
                            INFO [uORB] Advertising remote topic actuator_motors
                            INFO [uORB] Advertising remote topic actuator_servos
                            INFO [uORB] Advertising remote topic actuator_servos_trim
                            INFO [muorb] SLPI: Ok executing command: control_allocator start
                            INFO [qshell] qshell return value timestamp: 68577984, local time: 68579385
                            INFO [qshell] Send cmd: 'rc_update start'
                            INFO [muorb] SLPI: qshell gotten: rc_update start
                            INFO [muorb] SLPI: arg0 = 'rc_update'
                            INFO [muorb] SLPI: Ok executing command: rc_update start
                            INFO [qshell] qshell return value timestamp: 68873945, local time: 68874998
                            INFO [qshell] Send cmd: 'commander start'
                            INFO [muorb] SLPI: qshell gotten: commander start
                            INFO [muorb] SLPI: arg0 = 'commander'
                            INFO [muorb] SLPI: Creating pthread commander
                            INFO [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097641
                            INFO [uORB] Advertising remote topic led_control
                            INFO [muorb] SLPI: LED: open /dev/led0 failed (22)
                            INFO [muorb] SLPI: Ok executing command: commander start
                            INFO [uORB] Advertising remote topic tune_control
                            INFO [qshell] qshell return value timestamp: 69104924, local time: 69107190
                            INFO [uORB] Advertising remote topic event
                            INFO [uORB] Advertising remote topic health_report
                            INFO [uORB] Advertising remote topic failsafe_flags
                            INFO [uORB] Advertising remote topic actuator_armed
                            INFO [uORB] Advertising remote topic vehicle_control_mode
                            INFO [uORB] Advertising remote topic vehicle_thrust_setpoint
                            INFO [uORB] Advertising remote topic vehicle_torque_setpoint
                            INFO [uORB] Advertising remote topic vehicle_rates_setpoint
                            INFO [uORB] Advertising remote topic vehicle_status
                            INFO [uORB] Advertising remote topic failure_detector_status
                            INFO [uORB] Advertising remote topic vehicle_local_position_setpoint
                            INFO [uORB] Advertising remote topic vehicle_attitude_setpoint
                            INFO [qshell] Send cmd: 'commander mode manual'
                            INFO [muorb] SLPI: qshell gotten: commander mode manual
                            INFO [muorb] SLPI: arg1 = 'mode'
                            INFO [muorb] SLPI: arg2 = 'manual'
                            INFO [uORB] Advertising remote topic vehicle_command
                            INFO [muorb] SLPI: Ok executing command: commander mode manual
                            INFO [qshell] qshell return value timestamp: 69148498, local time: 69150136
                            INFO [uORB] Advertising remote topic vehicle_command_ack
                            INFO [uORB] Marking DeviceNode(vehicle_attitude_setpoint) as advertised in process_remote_topic
                            INFO [qshell] Send cmd: 'param_set_selector start'
                            INFO [muorb] SLPI: qshell gotten: param_set_selector start
                            INFO [muorb] SLPI: arg0 = 'param_set_selector'
                            INFO [muorb] SLPI: Ok executing command: param_set_selector start
                            INFO [qshell] qshell return value timestamp: 69186104, local time: 69187696
                            INFO [qshell] Send cmd: 'flight_mode_manager start'
                            INFO [muorb] SLPI: qshell gotten: flight_mode_manager start
                            INFO [muorb] SLPI: arg0 = 'flight_mode_manager'
                            INFO [uORB] Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
                            INFO [muorb] SLPI: Ok executing command: flight_mode_manager start
                            INFO [qshell] qshell return value timestamp: 69346243, local time: 69347753
                            INFO [uORB] Advertising remote topic actuator_controls_status_0
                            INFO [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
                            INFO [muorb] SLPI: Advertising remote topic transponder_report
                            INFO [muorb] SLPI: Advertising remote topic rtl_time_estimate
                            INFO [muorb] SLPI: Advertising remote topic position_setpoint_triplet
                            INFO [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
                            INFO [muorb] SLPI: Advertising remote topic telemetry_status
                            INFO [mavlink] partner IP: 127.0.0.1
                            INFO [muorb] SLPI: Advertising remote topic vehicle_visual_odometry
                            INFO [muorb] SLPI: Advertising remote topic obstacle_distance
                            INFO [muorb] SLPI: Advertising remote topic offboard_control_mode
                            INFO [muorb] SLPI: Advertising remote topic timesync_status
                            INFO [uORB] Advertising remote topic estimator_aid_src_ev_hgt
                            INFO [uORB] Advertising remote topic estimator_aid_src_ev_pos
                            INFO [uORB] Advertising remote topic estimator_aid_src_ev_vel
                            INFO [uORB] Advertising remote topic estimator_aid_src_ev_yaw
                            INFO [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
                            INFO [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
                            INFO [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
                            INFO [px4] Startup script returned successfully
                            INFO [muorb] SLPI: u-blox firmware version: SPG 3.01
                            INFO [muorb] SLPI: u-blox protocol version: 18.00
                            INFO [muorb] SLPI: u-blox module: NEO-M8N-0
                            INFO [uORB] Advertising remote topic sensor_gps
                            INFO [muorb] SLPI: Advertising remote topic ping
                            INFO [uORB] Advertising remote topic mavlink_log
                            INFO [muorb] SLPI: Connection to ground station lost
                            INFO [muorb] SLPI: GCS connection regained
                            WARN [uORB] orb_advertise_multi: failed to set queue size
                              @andremoura Okay, that's not very useful. Let's try something else. First of all can you post the contents of the file /etc/systemd/system/voxl-px4.service? Then, stop the service from autostarting voxl-px4 with the commands systemctl disable voxl-px4 and sync. Then reboot the drone. When you adb back in to the drone you can run voxl-inspect-services to verify that voxl-px4 isn't running. Then you can start voxl-px4 manually from the command line with voxl-px4 and then post all of the output from that.
                              Captain 7th
                              I tried this method, but it still is not working! Here is the console:
                              ______  __   __    ___
                              | ___ \ \ \ / /   /   |
                              | |_/ /  \ V /   / /| |
                              |  __/   /   \  / /_| |
                              | |     / /^\ \ \___  |
                              \_|     \/   \/     |_/
                              px4 starting.
                              GPS: HOLYBRO
                              RC: SPEKTRUM
                              OSD: DISABLE
                              EXTRA STEPS:
                              Running on M0054
                              INFO  [muorb] SLPI:
                              INFO  [muorb] SLPI:
                              INFO  [muorb] SLPI:
                              INFO  [muorb] SLPI:
                              INFO  [muorb] SLPI:
                              • Captain 7thC Captain 7th
                                ______  __   __    ___
                                | ___ \ \ \ / /   /   |
                                | |_/ /  \ V /   / /| |
                                |  __/   /   \  / /_| |
                                | |     / /^\ \ \___  |
                                \_|     \/   \/     |_/
                                px4 starting.
                                GPS: HOLYBRO
                                RC: SPEKTRUM
                                OSD: DISABLE
                                EXTRA STEPS:
                                Running on M0054
                                INFO  [muorb] SLPI:
                                INFO  [muorb] SLPI:
                                INFO  [muorb] SLPI:
                                INFO  [muorb] SLPI:
                                INFO  [muorb] SLPI:
                                @Captain-7th Are you saying that the GPS is not working? I don't see anything in the included logs to indicate that GPS is not working.
                                Captain 7thC 1 Reply Last reply
                                  Captain 7th
                                  @Eric-Katzfey Dear Eric,
                                  The log shows that the voxl-px4 is does not get completed and it crashes after a while:
                                  what are these errors? after these messages, I couldn't run again the voxl-px4 again! so I decided the follow this way:
                                  After reading some posts, I decided to upgrade the SDK version to the latest. I tried to upgrade the SDK from 1.0.0 to 1.3.0. Then running "apt update && apt upgrade"
                                  Then, followed some hints from you that you mentioned in some other post. I found the /usr/bin/voxl-px4-start file and added these commands at the end of the file:
                                  1. qshell gps stop
                                  2. /bin/sleep 1
                                  3. qshell gps start -b 9600
                                  Then, in my browser (HTTP://ip.address), it shows 255 satellites, but the GPS is still blinking in red color (should it be blue color?) Also, I checked the QGS app, it does not show the number of satellites and the drone location on the map. (I am in an indoor env, but I put the drone very close to the open window.)
                                    1. qshell gps stop
                                    2. /bin/sleep 1
                                    @Captain-7th The connection to ground station has nothing to do with GPS. That is probably something related to your wireless network link. So I still don't see why you think GPS wasn't working.
                                      Captain 7th
                                      @Eric-Katzfey Could you please tell me when the GPS is working, should it start blinking blue or red? Currently, mine is red! Please also let me know how I can check my GPS is working properly or not.
                                        @Captain-7th That LED is a general PX4 status LED. If it is red it could indicate any number of different problems. It is not specifically tied to the GPS.
                                          Captain 7th
                                          @Eric-Katzfey Thanks for the reply. Can you guide me on how can I check what are the problems?
                                          Also, I have a wifi problem. Can you help me with that? My question is here: https://forum.modalai.com/topic/3600/how-to-set-up-the-voxl-wifi-station-mode-for-hidden-networks?_=1719998452051
