  3. GPS not working
GPS not working
sentinel
49 Posts 7 Posters 32.5k Views 4 Watching
    @JustinDev23 This is the closest to what you're looking for: https://docs.modalai.com/voxl-px4-developer-guide/
    J Offline
    J Offline
    JustinDev23
    @tom Thanks! Looks like what i needed.
      @andremoura The GPS unit will come up and get a fix on it's own after it has been powered on so that doesn't indicate anything about the health of the connection to the flight controller. If the result of px4-listener sensor_gps is never published then there is likely a problem with your connection to the GPS unit. The GPS driver on VOXL2 runs on the DSP, not on the applications processor so you have to use qshell to interact with it. So, for status, you would use px4-qshell gps status. Have you made any changes to the Sentinel hardware or is it exactly the same as it was shipped?
      Captain 7thC Offline
      Captain 7th
      @Eric-Katzfey I have the same issue. I tried the method that you mentioned, not only voxl-px4 is not working now, but also I got this error:
      INFO [muorb] SLPI: muorb aggregator thread running
      INFO [muorb] muorb protobuf initalize method succeeded
      INFO [muorb] succesfully did ADVERTISE_TEST_TYPE
      INFO [muorb] SLPI: Creating pthread test_MUORB
      INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
      INFO [muorb] succesfully did SUBSCRIBE_TEST_TYPE
      INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
      INFO [muorb] succesfully did TOPIC_TEST_TYPE
      INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
      INFO [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
      INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
      INFO [muorb] muorb test passed
      INFO [muorb] SLPI: Advertising remote topic log_message
      | ___ \ \ \ / / / |
      | |/ / \ V / / /| |
      | __/ / \ / /
      | | / /^\ \ ___ |
      _| / / |_/
      px4 starting.
      INFO [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
      INFO [parameters] Starting param sync THREAD
      GPS: HOLYBRO
      RC: SPEKTRUM
      OSD: DISABLE
      EXTRA STEPS:
      INFO [muorb] SLPI: Starting param sync THREAD
      Running on M0054
      INFO [muorb] SLPI: before starting the qshell_entry task
      INFO [muorb] SLPI: Creating pthread qshell
      INFO [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
      INFO [muorb] SLPI: qshell entry.....
      INFO [muorb] SLPI: after starting the qshell_entry task
      INFO [muorb] SLPI: Init app map initialized
      INFO [param] selected parameter default file /data/px4/param/parameters
      INFO [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
      INFO [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
      INFO [muorb] SLPI: Advertising remote topic parameter_update
      INFO [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to
      INFO [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
      INFO [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to
      INFO [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
      INFO [parameters] BSON document size 3022 bytes, decoded 3022 bytes (INT32:43, FLOAT:98)
      INFO [logger] logger started (mode=all)
      INFO [qshell] Send cmd: 'icm42688p start -s'
      INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
      INFO [muorb] SLPI: qshell gotten: icm42688p start -s
      INFO [muorb] SLPI: arg0 = 'icm42688p'
      INFO [muorb] SLPI: arg1 = 'start'
      INFO [muorb] SLPI: arg2 = '-s'
      INFO [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
      INFO [uORB] Advertising remote topic sensor_accel
      INFO [uORB] Advertising remote topic sensor_gyro
      INFO [muorb] SLPI: ICM42688P::probe successful!
      INFO [muorb] SLPI: on SPI bus 1
      INFO [muorb] SLPI: >>> ICM42688P this: 3176e460
      INFO [muorb] SLPI: icm42688p #0 on SPI bus 1
      INFO [muorb] SLPI:
      INFO [muorb] SLPI: Ok executing command: icm42688p start -s
      INFO [uORB] Advertising remote topic qshell_retval
      INFO [qshell] qshell return value timestamp: 63895427, local time: 63898740
      INFO [muorb] SLPI: Register interrupt b21d3164 e620e69c 3176e460
      INFO [uORB] Advertising remote topic sensor_gyro_fifo
      INFO [uORB] Advertising remote topic sensor_accel_fifo
      INFO [uORB] Advertising remote topic imu_server
      INFO [qshell] Send cmd: 'icp101xx start -I -b 5'
      INFO [muorb] SLPI: qshell gotten: icp101xx start -I -b 5
      INFO [muorb] SLPI: arg0 = 'icp101xx'
      INFO [muorb] SLPI: arg2 = '-I'
      INFO [muorb] SLPI: arg3 = '-b'
      INFO [muorb] SLPI: arg4 = '5'
      INFO [muorb] SLPI: *** I2C Device ID 0xb76329 12018473
      INFO [muorb] SLPI: icp101xx #0 on I2C bus 5
      INFO [muorb] SLPI: address 0x63
      INFO [muorb] SLPI:
      INFO [muorb] SLPI: Ok executing command: icp101xx start -I -b 5
      INFO [qshell] qshell return value timestamp: 64943196, local time: 64943952
      Starting Holybro magnetometer
      INFO [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
      INFO [muorb] SLPI: arg0 = 'ist8310'
      INFO [muorb] SLPI: arg2 = '-R'
      INFO [muorb] SLPI: arg3 = '10'
      INFO [muorb] SLPI: arg4 = '-X'
      INFO [muorb] SLPI: arg5 = '-b'
      INFO [muorb] SLPI: arg6 = '1'
      INFO [muorb] SLPI: *** I2C Device ID 0x60e09 396809
      INFO [muorb] SLPI: ist8310 #0 on I2C bus 1
      INFO [muorb] SLPI: (external)
      INFO [muorb] SLPI: address 0xE
      INFO [muorb] SLPI: rotation 10
      INFO [muorb] SLPI:
      INFO [muorb] SLPI: Ok executing command: ist8310 start -R 10 -X -b 1
      INFO [qshell] qshell return value timestamp: 64990484, local time: 64992712
      INFO [qshell] Send cmd: 'gps start'
      INFO [muorb] SLPI: qshell gotten: gps start
      INFO [muorb] SLPI: arg0 = 'gps'
      INFO [muorb] SLPI: Creating pthread gps
      INFO [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097648
      INFO [muorb] SLPI: Ok executing command: gps start
      INFO [qshell] qshell return value timestamp: 65023088, local time: 65025096
      Starting Holybro LED driver
      INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
      INFO [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
      INFO [muorb] SLPI: arg0 = 'rgbled_ncp5623c'
      INFO [muorb] SLPI: arg2 = '-X'
      INFO [muorb] SLPI: arg4 = '1'
      INFO [muorb] SLPI: arg5 = '-f'
      INFO [muorb] SLPI: arg6 = '400'
      INFO [muorb] SLPI: arg7 = '-a'
      INFO [muorb] SLPI: arg8 = '56'
      INFO [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
      INFO [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
      INFO [muorb] SLPI: address 0x38
      INFO [muorb] SLPI:
      INFO [muorb] SLPI: Ok executing command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
      INFO [qshell] qshell return value timestamp: 65062554, local time: 65063907
      INFO [uORB] Advertising remote topic sensor_mag
      INFO [qshell] Send cmd: 'modal_io start'
      INFO [muorb] SLPI: qshell gotten: modal_io start
      INFO [muorb] SLPI: arg0 = 'modal_io'
      INFO [uORB] Advertising remote topic actuator_outputs
      INFO [uORB] Advertising remote topic sensor_baro
      INFO [muorb] SLPI: Ok executing command: modal_io start
      INFO [muorb] SLPI: Opened UART ESC device
      INFO [qshell] qshell return value timestamp: 65169377, local time: 65171079
      INFO [uORB] Advertising remote topic actuator_outputs_debug
      INFO [uORB] Advertising remote topic esc_status
      Starting Spektrum RC
      INFO [qshell] Send cmd: 'spektrum_rc start'
      INFO [muorb] SLPI: qshell gotten: spektrum_rc start
      INFO [muorb] SLPI: arg0 = 'spektrum_rc'
      INFO [muorb] SLPI: Creating pthread spektrum_rc_main
      INFO [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097645
      INFO [muorb] SLPI: Ok executing command: spektrum_rc start
      INFO [qshell] qshell return value timestamp: 66215910, local time: 66216633
      INFO [qshell] Send cmd: 'voxlpm start -X -b 2'
      INFO [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
      INFO [muorb] SLPI: arg0 = 'voxlpm'
      INFO [muorb] SLPI: arg4 = '2'
      INFO [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
      INFO [muorb] SLPI: Set i2c address 0x6a, fd 3
      INFO [muorb] SLPI: Set i2c address 0x44, fd 3
      INFO [uORB] Advertising remote topic battery_status
      INFO [muorb] SLPI: voxlpm #0 on I2C bus 2
      INFO [muorb] SLPI: address 0x44
      INFO [muorb] SLPI:
      INFO [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
      INFO [uORB] Advertising remote topic power_monitor
      INFO [qshell] qshell return value timestamp: 67272854, local time: 67275718
      INFO [qshell] Send cmd: 'sensors start'
      INFO [muorb] SLPI: qshell gotten: sensors start
      INFO [muorb] SLPI: arg0 = 'sensors'
      INFO [uORB] Advertising remote topic sensor_selection
      INFO [uORB] Advertising remote topic sensors_status_imu
      INFO [uORB] Advertising remote topic vehicle_acceleration
      INFO [uORB] Advertising remote topic vehicle_angular_velocity
      INFO [uORB] Advertising remote topic sensor_combined
      INFO [uORB] Advertising remote topic vehicle_air_data
      INFO [uORB] Advertising remote topic vehicle_gps_position
      INFO [uORB] Advertising remote topic vehicle_magnetometer
      INFO [uORB] Advertising remote topic sensor_preflight_mag
      INFO [uORB] Advertising remote topic vehicle_imu
      INFO [uORB] Advertising remote topic vehicle_imu_status
      INFO [muorb] SLPI: Ok executing command: sensors start
      INFO [uORB] Advertising remote topic sensors_status_mag
      INFO [qshell] qshell return value timestamp: 67434965, local time: 67437421
      INFO [uORB] Advertising remote topic sensors_status_baro
      INFO [qshell] Send cmd: 'ekf2 start'
      INFO [muorb] SLPI: qshell gotten: ekf2 start
      INFO [muorb] SLPI: arg0 = 'ekf2'
      INFO [uORB] Advertising remote topic vehicle_attitude
      INFO [uORB] Advertising remote topic vehicle_local_position
      INFO [uORB] Advertising remote topic estimator_event_flags
      INFO [uORB] Advertising remote topic estimator_innovation_test_ratios
      INFO [uORB] Advertising remote topic estimator_innovation_variances
      INFO [uORB] Advertising remote topic estimator_innovations
      INFO [uORB] Advertising remote topic estimator_sensor_bias
      INFO [uORB] Advertising remote topic estimator_states
      INFO [uORB] Advertising remote topic estimator_status_flags
      INFO [muorb] SLPI: Ok executing command: ekf2 start
      INFO [qshell] qshell return value timestamp: 67750482, local time: 67753672
      INFO [uORB] Advertising remote topic ekf2_timestamps
      INFO [uORB] Advertising remote topic vehicle_odometry
      INFO [uORB] Advertising remote topic estimator_aid_src_baro_hgt
      INFO [uORB] Advertising remote topic estimator_aid_src_fake_pos
      INFO [uORB] Advertising remote topic estimator_aid_src_fake_hgt
      INFO [uORB] Advertising remote topic estimator_aid_src_mag_heading
      INFO [uORB] Advertising remote topic estimator_aid_src_gravity
      INFO [qshell] Send cmd: 'mc_pos_control start'
      INFO [muorb] SLPI: qshell gotten: mc_pos_control start
      INFO [muorb] SLPI: arg0 = 'mc_pos_control'
      INFO [uORB] Advertising remote topic takeoff_status
      INFO [muorb] SLPI: Ok executing command: mc_pos_control start
      INFO [qshell] qshell return value timestamp: 67859638, local time: 67861554
      INFO [qshell] Send cmd: 'mc_att_control start'
      INFO [muorb] SLPI: qshell gotten: mc_att_control start
      INFO [muorb] SLPI: arg0 = 'mc_att_control'
      INFO [muorb] SLPI: Ok executing command: mc_att_control start
      INFO [qshell] qshell return value timestamp: 67918747, local time: 67920290
      INFO [qshell] Send cmd: 'mc_rate_control start'
      INFO [muorb] SLPI: qshell gotten: mc_rate_control start
      INFO [muorb] SLPI: arg0 = 'mc_rate_control'
      INFO [uORB] Advertising remote topic rate_ctrl_status
      INFO [muorb] SLPI: Ok executing command: mc_rate_control start
      INFO [qshell] qshell return value timestamp: 68027813, local time: 68030404
      INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start'
      INFO [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
      INFO [muorb] SLPI: arg0 = 'mc_hover_thrust_estimator'
      INFO [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
      INFO [qshell] qshell return value timestamp: 68087592, local time: 68089224
      INFO [qshell] Send cmd: 'mc_autotune_attitude_control start'
      INFO [muorb] SLPI: qshell gotten: mc_autotune_attitude_control start
      INFO [muorb] SLPI: arg0 = 'mc_autotune_attitude_control'
      INFO [uORB] Advertising remote topic autotune_attitude_control_status
      INFO [muorb] SLPI: Ok executing command: mc_autotune_attitude_control start
      INFO [qshell] qshell return value timestamp: 68137157, local time: 68138847
      INFO [qshell] Send cmd: 'land_detector start multicopter'
      INFO [muorb] SLPI: qshell gotten: land_detector start multicopter
      INFO [muorb] SLPI: arg0 = 'land_detector'
      INFO [muorb] SLPI: arg2 = 'multicopter'
      INFO [muorb] SLPI: Ok executing command: land_detector start multicopter
      INFO [qshell] qshell return value timestamp: 68188877, local time: 68189722
      INFO [uORB] Advertising remote topic vehicle_land_detected
      INFO [qshell] Send cmd: 'manual_control start'
      INFO [muorb] SLPI: qshell gotten: manual_control start
      INFO [muorb] SLPI: arg0 = 'manual_control'
      INFO [muorb] SLPI: Ok executing command: manual_control start
      INFO [uORB] Advertising remote topic manual_control_setpoint
      INFO [qshell] qshell return value timestamp: 68237903, local time: 68239705
      INFO [qshell] Send cmd: 'control_allocator start'
      INFO [muorb] SLPI: qshell gotten: control_allocator start
      INFO [muorb] SLPI: arg0 = 'control_allocator'
      INFO [uORB] Advertising remote topic control_allocator_status
      INFO [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
      INFO [uORB] Advertising remote topic actuator_motors
      INFO [uORB] Advertising remote topic actuator_servos
      INFO [uORB] Advertising remote topic actuator_servos_trim
      INFO [muorb] SLPI: Ok executing command: control_allocator start
      INFO [qshell] qshell return value timestamp: 68577984, local time: 68579385
      INFO [qshell] Send cmd: 'rc_update start'
      INFO [muorb] SLPI: qshell gotten: rc_update start
      INFO [muorb] SLPI: arg0 = 'rc_update'
      INFO [muorb] SLPI: Ok executing command: rc_update start
      INFO [qshell] qshell return value timestamp: 68873945, local time: 68874998
      INFO [qshell] Send cmd: 'commander start'
      INFO [muorb] SLPI: qshell gotten: commander start
      INFO [muorb] SLPI: arg0 = 'commander'
      INFO [muorb] SLPI: Creating pthread commander
      INFO [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097641
      INFO [uORB] Advertising remote topic led_control
      INFO [muorb] SLPI: LED: open /dev/led0 failed (22)
      INFO [muorb] SLPI: Ok executing command: commander start
      INFO [uORB] Advertising remote topic tune_control
      INFO [qshell] qshell return value timestamp: 69104924, local time: 69107190
      INFO [uORB] Advertising remote topic event
      INFO [uORB] Advertising remote topic health_report
      INFO [uORB] Advertising remote topic failsafe_flags
      INFO [uORB] Advertising remote topic actuator_armed
      INFO [uORB] Advertising remote topic vehicle_control_mode
      INFO [uORB] Advertising remote topic vehicle_thrust_setpoint
      INFO [uORB] Advertising remote topic vehicle_torque_setpoint
      INFO [uORB] Advertising remote topic vehicle_rates_setpoint
      INFO [uORB] Advertising remote topic vehicle_status
      INFO [uORB] Advertising remote topic failure_detector_status
      INFO [uORB] Advertising remote topic vehicle_local_position_setpoint
      INFO [uORB] Advertising remote topic vehicle_attitude_setpoint
      INFO [qshell] Send cmd: 'commander mode manual'
      INFO [muorb] SLPI: qshell gotten: commander mode manual
      INFO [muorb] SLPI: arg1 = 'mode'
      INFO [muorb] SLPI: arg2 = 'manual'
      INFO [uORB] Advertising remote topic vehicle_command
      INFO [muorb] SLPI: Ok executing command: commander mode manual
      INFO [qshell] qshell return value timestamp: 69148498, local time: 69150136
      INFO [uORB] Advertising remote topic vehicle_command_ack
      INFO [uORB] Marking DeviceNode(vehicle_attitude_setpoint) as advertised in process_remote_topic
      INFO [qshell] Send cmd: 'param_set_selector start'
      INFO [muorb] SLPI: qshell gotten: param_set_selector start
      INFO [muorb] SLPI: arg0 = 'param_set_selector'
      INFO [muorb] SLPI: Ok executing command: param_set_selector start
      INFO [qshell] qshell return value timestamp: 69186104, local time: 69187696
      INFO [qshell] Send cmd: 'flight_mode_manager start'
      INFO [muorb] SLPI: qshell gotten: flight_mode_manager start
      INFO [muorb] SLPI: arg0 = 'flight_mode_manager'
      INFO [uORB] Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
      INFO [muorb] SLPI: Ok executing command: flight_mode_manager start
      INFO [qshell] qshell return value timestamp: 69346243, local time: 69347753
      INFO [uORB] Advertising remote topic actuator_controls_status_0
      INFO [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
      INFO [muorb] SLPI: Advertising remote topic transponder_report
      INFO [muorb] SLPI: Advertising remote topic rtl_time_estimate
      INFO [muorb] SLPI: Advertising remote topic position_setpoint_triplet
      INFO [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
      INFO [muorb] SLPI: Advertising remote topic telemetry_status
      INFO [mavlink] partner IP: 127.0.0.1
      INFO [muorb] SLPI: Advertising remote topic vehicle_visual_odometry
      INFO [muorb] SLPI: Advertising remote topic obstacle_distance
      INFO [muorb] SLPI: Advertising remote topic offboard_control_mode
      INFO [muorb] SLPI: Advertising remote topic timesync_status
      INFO [uORB] Advertising remote topic estimator_aid_src_ev_hgt
      INFO [uORB] Advertising remote topic estimator_aid_src_ev_pos
      INFO [uORB] Advertising remote topic estimator_aid_src_ev_vel
      INFO [uORB] Advertising remote topic estimator_aid_src_ev_yaw
      INFO [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
      INFO [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
      INFO [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
      INFO [px4] Startup script returned successfully
      INFO [muorb] SLPI: u-blox firmware version: SPG 3.01
      INFO [muorb] SLPI: u-blox protocol version: 18.00
      INFO [muorb] SLPI: u-blox module: NEO-M8N-0
      INFO [uORB] Advertising remote topic sensor_gps
      INFO [muorb] SLPI: Advertising remote topic ping
      INFO [uORB] Advertising remote topic mavlink_log
      INFO [muorb] SLPI: Connection to ground station lost
      INFO [muorb] SLPI: GCS connection regained
      WARN [uORB] orb_advertise_multi: failed to set queue size
        @andremoura Okay, that's not very useful. Let's try something else. First of all can you post the contents of the file /etc/systemd/system/voxl-px4.service? Then, stop the service from autostarting voxl-px4 with the commands systemctl disable voxl-px4 and sync. Then reboot the drone. When you adb back in to the drone you can run voxl-inspect-services to verify that voxl-px4 isn't running. Then you can start voxl-px4 manually from the command line with voxl-px4 and then post all of the output from that.
        Captain 7th
        I tried this method, but it still is not working! Here is the console:
        ______  __   __    ___
        | ___ \ \ \ / /   /   |
        | |_/ /  \ V /   / /| |
        |  __/   /   \  / /_| |
        | |     / /^\ \ \___  |
        \_|     \/   \/     |_/
        px4 starting.
        GPS: HOLYBRO
        RC: SPEKTRUM
        OSD: DISABLE
        EXTRA STEPS:
        Running on M0054
        INFO  [muorb] SLPI:
        INFO  [muorb] SLPI:
        INFO  [muorb] SLPI:
        INFO  [muorb] SLPI:
        INFO  [muorb] SLPI:
        • Captain 7thC Captain 7th
          ______  __   __    ___
          | ___ \ \ \ / /   /   |
          | |_/ /  \ V /   / /| |
          |  __/   /   \  / /_| |
          | |     / /^\ \ \___  |
          \_|     \/   \/     |_/
          px4 starting.
          GPS: HOLYBRO
          RC: SPEKTRUM
          OSD: DISABLE
          EXTRA STEPS:
          Running on M0054
          INFO  [muorb] SLPI:
          INFO  [muorb] SLPI:
          INFO  [muorb] SLPI:
          INFO  [muorb] SLPI:
          INFO  [muorb] SLPI:
          @Captain-7th Are you saying that the GPS is not working? I don't see anything in the included logs to indicate that GPS is not working.
          Captain 7thC 1 Reply Last reply
            Captain 7th
            @Eric-Katzfey Dear Eric,
            The log shows that the voxl-px4 is does not get completed and it crashes after a while:
            what are these errors? after these messages, I couldn't run again the voxl-px4 again! so I decided the follow this way:
            After reading some posts, I decided to upgrade the SDK version to the latest. I tried to upgrade the SDK from 1.0.0 to 1.3.0. Then running "apt update && apt upgrade"
            Then, followed some hints from you that you mentioned in some other post. I found the /usr/bin/voxl-px4-start file and added these commands at the end of the file:
            1. qshell gps stop
            2. /bin/sleep 1
            3. qshell gps start -b 9600
            Then, in my browser (HTTP://ip.address), it shows 255 satellites, but the GPS is still blinking in red color (should it be blue color?) Also, I checked the QGS app, it does not show the number of satellites and the drone location on the map. (I am in an indoor env, but I put the drone very close to the open window.)
              1. qshell gps stop
              2. /bin/sleep 1
              @Captain-7th The connection to ground station has nothing to do with GPS. That is probably something related to your wireless network link. So I still don't see why you think GPS wasn't working.
                Captain 7th
                @Eric-Katzfey Could you please tell me when the GPS is working, should it start blinking blue or red? Currently, mine is red! Please also let me know how I can check my GPS is working properly or not.
                  @Captain-7th That LED is a general PX4 status LED. If it is red it could indicate any number of different problems. It is not specifically tied to the GPS.
                    Captain 7th
                    @Eric-Katzfey Thanks for the reply. Can you guide me on how can I check what are the problems?
                    Also, I have a wifi problem. Can you help me with that? My question is here: https://forum.modalai.com/topic/3600/how-to-set-up-the-voxl-wifi-station-mode-for-hidden-networks?_=1719998452051
                      @Captain-7th Please check the new forum post where you ask all these questions again.
