    Setup issues with the Voxl 2 Mini with Hires and Tracking Cameras
    VOXL 2 Mini
    1377
    • Nicholas HansenN
      Nicholas Hansen
      I have the Voxl2 mini with the IMX214 Hires sensor and the Tracking camera kit. I have them connect as pictured in the setup page here (https://docs.modalai.com/voxl2-mini-image-sensors/#mdk-m0104-1-c4---hires-tracking)
      When I try to test the camera server I have not gotten any data from the streamer. I have updated to the most recent sdk. I have also tried with the cameras connected to J6 and re configured the camIDs all across the 4 with no luck. Any ideas to point me in the right direct for trouble-shooting this would be greatly appreciated
      voxl2-mini:/$ voxl-camera-server
      GPS server Connected
      configuration for 2 cameras:
      cam #0
      sensor type: imx214
      isEnabled: 1
      camId: 3
      camId2: -1
      fps: 30
      en_preview:          0
      pre_width:           640
      pre_height:          480
      pre_format:          nv21
      en_small_video:      1
      small_video_width:   1024
      small_video_height:  768
      en_large_video:      1
      large_video_width:   4096
      large_video_height:  2160
      en_snapshot:         1
      snap_width:          4160
      snap_height:         3120
      ae_mode:             isp
      standby_enabled:     0
      decimator:           1
      independent_exposure:0
      cam #1
      sensor type: ov7251
      isEnabled: 1
      camId: 2
      camId2: -1
      fps: 30
      en_preview:          1
      pre_width:           640
      pre_height:          480
      pre_format:          raw8
      en_small_video:      0
      small_video_width:   -1
      small_video_height:  -1
      en_large_video:      0
      large_video_width:   -1
      large_video_height:  -1
      en_snapshot:         0
      snap_width:          -1
      snap_height:         -1
      ae_mode:             lme_msv
      standby_enabled:     0
      decimator:           1
      Starting Camera: hires
      Segmentation fault:
      Fault thread: voxl-camera-ser(tid: 2452)
      Fault address: 0x567278c6cc
      Address not mapped.
      Segmentation fault
      Nicholas HansenN 1 Reply Last reply Reply Quote 1
      • Nicholas HansenN
        Nicholas Hansen @Nicholas Hansen
        @Nicholas-Hansen I got a new duplex board assuming that was the issue, and still have the same errors.
        • R
          ramarao
          I am also getting the same fault/error messages from camera server. Would like to know if the issue has been resolved.
          • ModeratorM
            Moderator ModalAI Team @ramarao
            Please run voxl-camera-server -d and voxl-camera-server -l and take a picture of your setup
            T 1 Reply Last reply Reply Quote 0
            • T
              Trinadh
              @Moderator , Hi i am also getting the same issue . and done the thing as you mentioned please check the pictures the error was not cleared.Screenshot from 2023-10-26 11-42-49.png Screenshot from 2023-10-26 11-43-36.png Screenshot from 2023-10-26 11-47-52.png ![IMG20231026114600.jpg](Request Entity Too Large) ![IMG20231026114611.jpg](Request Entity Too Large) ![IMG20231026114623.jpg](Request Entity Too Large)
              • T
                Trinadh @Moderator
                  tom admin @Trinadh
                  @Trinadh Try voxl-camera-server -d 0
                    tom admin @tom
                    @tom but it looks like you're using the wrong port. You should be using J7 not J6, take a closer look at the docs page you linked.
                    • T
                      Trinadh @tom
                      @tom Hi Tom, thank for the input, we have placed the board and camera as per the VOXL document. and the command you specified is also been checked the result was the same.
                      For reference I am Placing the Camera connection given in VOXL Document9781094e-7c6d-495e-b501-3519eacd8f6c-image.png
                      We have placed the camera modules as per picture.
                      • T
                        Trinadh @Trinadh
                        @Trinadh The issue is clear by using the below commands.
                        camera-server-config-helper hires:imx214:0 tracking0:ov7251:1
                        voxl-camera-server -d 3
                        • LucaVertiqL
                          LucaVertiq
                          I am having these same issues. I'm on voxl suite 1.1.0. Voxl camera server shows 0 cameras connected. When I use dmesg right after I get this: 56fd6d22-d63c-4478-a07c-bcc3379c6b2c-image.png
                          My setup is as shown here:
                          https://docs.modalai.com/images/voxl2-mini/MDK-M0104-1-C4-b.jpg
                          And I've used
                          For configuration.
                          Am I doing something obviously wrong?
