  3. Issues with Microhard connection and VOXL 2
Scheduled Pinned Locked Moved ESCs, Sensors and Accessories
microhard
28 Posts 5 Posters 8.8k Views 1 Watching
  • ? Offline
      @aimseis Can you post a picture of your setup?
      ModeratorM 1 Reply Last reply
      • ? A Former User
        [[topic:post-is-deleted]]
        @aimseis which operating system is your PC running? If it's Linux, can you type lsusb ?
        ? 1 Reply Last reply
        • ModeratorM Moderator
          • ? A Former User
            @aimseis You likely have to install a LAN7500 driver on your windows machine
              • ? A Former User
                @aimseis We can only really help with support on linux, I specifically recommend with Ubuntu 22.04.
                  • ? A Former User
                    @aimseis
                    1. The voxl-modem service doesn't need to keep running for the entire time. All it does is a run a few initialization steps and then exits, so that's not an issue.
                    2. I'll get someone from the hardware team to comment
                    VinnyV 1 Reply Last reply
                      @aimseis
                      wrote on last edited by Vinny
                      #15
                      @tom said in Issues with Microhard connection and VOXL 2:
                      @aimseis
                      1. I'll get someone from the hardware team to comment
                      Per Microhard the ABS max of the 5V rail is +10% consistent with USB specs, so 5.5V.
                      Anything above that will risk damage to your device.
                      There are other components on our M0048 design that will be damaged at 6V.
                      What voltage did you apply to this board @aimseis ?
                      ? 2 Replies Last reply
                      • VinnyV Vinny
                        @aimseis
                        • VinnyV Vinny
                          @aimseis
                          • ? A Former User
                            Hi @aimseis
                            When you use a plug-in board with Voxl or Voxl2, they and the plug-in board manage the input 5V and other voltages so all you need is to provide the correct power module to your Voxl or Voxl2, and the rest is handled.
                            I'm not able to provide answers on shipping time as I am in Hardware Engineering, not shipping/production. Sorry.
                            • ? Offline
                              • ? A Former User
                                @aimseis Are you able to ping the voxl from your pc over the Microhard network?
                                  #21
                                  • ? A Former User
                                    • ? A Former User
                                      @aimseis If you can't ping the voxl's IP address from your pc you won't be able to access portal
                                        • ? A Former User
