Shivam SehgalS
Shivam Sehgal
@Shivam Sehgal
  • Camera Server Aborts
    Shivam SehgalS Shivam Sehgal
    voxl camera server is aborting itself, what can be the issue. I was running my ros package on the drone and also using ros mpa package and then suddenly all the topics vanished.
    when I restarted the drone the camera starts for some time and them stops showing stalled missing.
    I am running tof at 15 fps also tried running at 5 but still the same issue. hires and tracking at default fps that it is configured with.
    voxl2:/$ voxl-version
    system-image: 1.7.1-M0054-14.1a-perf-nightly-20231025
    kernel:       #1 SMP PREEMPT Thu Oct 26 03:25:38 UTC 2023 4.19.125
    hw version:   M0054
    voxl-suite:   1.1.2
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.1/binary-arm64/
    Last Updated: 2023-03-02 12:59:10
    WARNING: repo file has changed since last update,
    	packages may have originated from a different repo
    List:
    	libmodal-cv                 0.4.0
    	libmodal-exposure           0.1.0
    	libmodal-journal            0.2.2
    	libmodal-json               0.4.3
    	libmodal-pipe               2.9.2
    	libqrb5165-io               0.4.2
    	libvoxl-cci-direct          0.2.1
    	libvoxl-cutils              0.1.1
    	mv-voxl                     0.1-r0
    	qrb5165-bind                0.1-r0
    	qrb5165-dfs-server          0.2.0
    	qrb5165-imu-server          1.0.1
    	qrb5165-rangefinder-server  0.1.1
    	qrb5165-slpi-test-sig       01-r0
    	qrb5165-system-tweaks       0.2.3
    	qrb5165-tflite              2.8.0-2
    	voxl-bind-spektrum          0.1.0
    	voxl-camera-calibration     0.5.3
    	voxl-camera-server          1.8.9.1
    	voxl-configurator           0.4.8
    	voxl-cpu-monitor            0.4.7
    	voxl-docker-support         1.3.0
    	voxl-elrs                   0.1.3
    	voxl-esc                    1.3.7
    	voxl-feature-tracker        0.3.2
    	voxl-flow-server            0.3.3
    	voxl-gphoto2-server         0.0.10
    	voxl-jpeg-turbo             2.1.3-5
    	voxl-lepton-server          1.2.0
    	voxl-libgphoto2             0.0.4
    	voxl-libuvc                 1.0.7
    	voxl-logger                 0.3.5
    	voxl-mavcam-manager         0.5.3
    	voxl-mavlink                0.1.1
    	voxl-mavlink-server         1.3.2
    	voxl-modem                  1.0.8
    	voxl-mongoose               7.7.0-1
    	voxl-mpa-to-ros             0.3.7
    	voxl-mpa-tools              1.1.3
    	voxl-neopixel-manager       0.0.3
    	voxl-opencv                 4.5.5-2
    	voxl-portal                 0.6.3
    	voxl-px4                    1.14.0-2.0.63
    	voxl-px4-imu-server         0.1.2
    	voxl-px4-params             0.3.3
    	voxl-qvio-server            1.0.0
    	voxl-remote-id              0.0.9
    	voxl-streamer               0.7.4
    	voxl-suite                  1.1.2
    	voxl-tag-detector           0.0.4
    	voxl-tflite-server          0.3.1
    	voxl-utils                  1.3.3
    	voxl-uvc-server             0.1.6
    	voxl-vision-hub             1.7.3
    	voxl2-system-image          1.7.1-r0
    	voxl2-wlan                  1.0-r0
    voxl2:/$ voxl-camera-server
    detected system image 1.7.1
    using new imx214 defaults
    configuration for 3 cameras:
    cam #0
        sensor type:         pmd-tof
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 5
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           224
        pre_height:          1557
        en_raw_preview:      1
        en_small_video:      0
        small_video_width:   -1
        small_video_height:  -1
        en_large_video:      0
        large_video_width:   -1
        large_video_height:  -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             off
        standby_enabled:     0
        decimator:           5
        independent_exposure:0
    cam #1
        sensor type:         imx214
        isEnabled:           1
        camId:               1
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          0
        pre_width:           640
        pre_height:          480
        en_raw_preview:      0
        en_small_video:      1
        small_video_width:   1024
        small_video_height:  768
        en_large_video:      1
        large_video_width:   4208
        large_video_height:  3120
        en_snapshot:         1
        snap_width:          4208
        snap_height:         3120
        ae_mode:             isp
        standby_enabled:     0
        decimator:           1
    cam #2
        sensor type:         ov7251
        isEnabled:           1
        camId:               2
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        standby_enabled:     0
        decimator:           1
    GPS server Connected
    Starting Camera: tof (id #0)
    Using gain limits min: 54 max: 8000
    Starting Camera: hires (id #1)
    Using gain limits min: 54 max: 431
    WARNING: Port Def 0:
    	Count Min: 8
    	Count Actual: 16
    	Buffers Contiguous: Yes
    	Buffer Alignment: 0
    WARNING: Port Def 1:
    	Count Min: 4
    	Count Actual: 16
    	Buffers Contiguous: No
    	Buffer Alignment: 0
    	Count Min: 8
    	Count Actual: 16
    	Buffer Alignment: 0
    	Count Min: 4
    	Count Actual: 16
    	Buffer Alignment: 0
    Starting Camera: tracking (id #2)
    Using gain limits min: 54 max: 3451
    setting ov7251 BLC register for cam id 2
    ------ voxl-camera-server: Started 3 of 3 cameras
    Aborted
  • Starling drone shut down mid flight
    @tom @Alex-Kushleyev
    I corrected everything and it seemed to work for a minute there then again adb connection broke.
    I disconnect the cameras and I am able to adb but with the cameras it does work for like 10 seconds and then the connection breaks.
    @tom thanks I had opened the board so I did not notice it, only if I had assemble I would have noticed it.
    Thank you so much it worked!
    @tom I was able to get the camera board out thank you but ...
    When I again add the 2 new camera boards with out the camera's attached it works I can adb into the board, but as soon as any camera is added I cannot adb into the board.
    I am using 2 new boards and 2 new camera's tracking and hires it seems like the issue is something else what can I do?
    @Jeremy-Schmidt So I don't need heat or any special tool for it I can directly remove by hand?
    @Alex-Kushleyev It's a form to send my drone for repair, can't I repair it myself? I have already ordered all the parts required. I just need to understand how to remove the glue.
  • Calibration FIles
    @Zachary-Lowell-0 Hi Zach,
    I wanted to clarify my concern regarding calibration files. I understand that many sensors, like cameras or IMUs, can be calibrated individually, so why do people often ask for calibration files tied to a specific serial number? ( I guess these might be the intrinsic parameters for the cameras)
    For context, I had updated a couple of my drones, and now I’m concerned about whether I might have overwritten or used incorrect parameters during the updates. Could you explain when calibration files are critical?
    Thanks,
    Shivam
  • Calibration FIles
    Hi I have 4 starling drones, would it be possible for me to get the original calibration files?
    M23000001FM
    M2100000J5D
    M23000001FK
    M22000006HK
  • Unstable Flight (local Position Estimate Error)
    @Moderator any advice?
    @Alex-Kushleyev Yes Alex, it's glued to the board. Sorry, how can I connect with RMA department?
    @Alex-Kushleyev any update?
    How can can I remove the 2 in 1 camera board?
  • HITL voxl2 from docker image
    @Shivam-Sehgal Never mind I was able to make it work by interchanging the tx - rx wires.
    Is there a specific implementation of starling drone with all it's sensors?
    I am trying to do HITL using voxl2
    Below is output of vol-services and voxl-version
    voxl2:~$ voxl-inspect-services
    Scanning services...
     voxl-camera-server       |  Enabled  | Not Running |
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.0%
     voxl-dfs-server          | Disabled  | Not Running |
     voxl-feature-tracker     | Disabled  | Not Running |
     voxl-flow-server         | Disabled  | Not Running |
     voxl-imu-server          | Disabled  | Not Running |
     voxl-mavcam-manager      | Disabled  | Not Running |
     voxl-mavlink-server      |  Enabled  |   Running   |     0.5%
     voxl-microdds-agent      |  Enabled  |   Running   |     0.4%
     voxl-neopixel-manager    | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     0.1%
     voxl-px4-imu-server      | Disabled  | Not Running |
     voxl-px4                 | Disabled  | Not Running |
     voxl-qvio-server         | Disabled  | Not Running |
     voxl-rangefinder-server  | Disabled  | Not Running |
     voxl-softap              | Disabled  | Not Running |
     voxl-streamer            |  Enabled  |   Running   |     0.1%
     voxl-tag-detector        |  Enabled  |   Running   |     0.0%
     voxl-tflite-server       |  Enabled  |   Running   |     0.1%
     voxl-vision-hub          |  Enabled  |   Running   |     0.4%
    voxl2:~$ voxl-version
    hw version:   M0054
    voxl-suite:   1.1.2
    Packages:
    Last Updated: 2024-05-07 06:01:21
    List:
    	libmodal-cv                 0.4.0
    	libmodal-json               0.4.3
    	libmodal-pipe               2.9.2
    	libqrb5165-io               0.4.2
    	mv-voxl                     0.1-r0
    	qrb5165-bind                0.1-r0
    	voxl-elrs                   0.1.3
    	voxl-esc                    1.3.7
    	voxl-libuvc                 1.0.7
    	voxl-logger                 0.3.5
    	voxl-mavlink                0.1.1
    	voxl-microdds-agent         2.4.1-0
    	voxl-modem                  1.0.8
    	voxl-mpa-to-ros2            0.0.2
    	voxl-opencv                 4.5.5-2
    	voxl-portal                 0.6.3
    	voxl-ros2-foxy              0.0.1
    	voxl-streamer               0.7.4
    	voxl-suite                  1.1.2
    	voxl-tflite-server          0.3.2
    	voxl-utils                  1.3.3
    	voxl2-wlan                  1.0-r0
    I followed the docker setup, ran the docker. Gazebo launches with this output.
    (base) swarm_researchers@swarm-Alienware-Aurora-R16:~$ docker run --rm -it --net=host --privileged -e DISPLAY=$DISPLAY -v /dev/input:/dev/input:rw -v /tmp/.X11-unix:/tmp/.X11-unix:ro voxl-gazebo-docker ./run_gazebo.bash
    GAZEBO_PLUGIN_PATH :/usr/workspace/voxl2_hitl_gazebo
    GAZEBO_MODEL_PATH :/usr/workspace/voxl2_hitl_gazebo/models
    LD_LIBRARY_PATH :/usr/workspace/voxl2_hitl_gazebo/build
    Warning [parser.cc:833] XML Attribute[version] in element[sdf] not defined in SDF, ignoring.
    Opened serial device /dev/ttyUSB0
    I adb shell onto voxl2 and run voxl-px4-hitl.
    voxl2:/$ voxl-px4-hitl
    Found DSP signature file
    INFO  [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
    INFO  [px4] assuming working directory is rootfs, no symlinks needed.
    INFO  [muorb] Got muorb init command
    Got topic data before configuration complete
    INFO  [muorb] SLPI: muorb aggregator thread running
    INFO  [muorb] muorb protobuf initalize method succeeded
    INFO  [muorb] succesfully did ADVERTISE_TEST_TYPE
    INFO  [muorb] SLPI: Creating pthread test_MUORB
    INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
    INFO  [muorb] succesfully did SUBSCRIBE_TEST_TYPE
    INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
    INFO  [muorb] succesfully did TOPIC_TEST_TYPE
    INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
    INFO  [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
    INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
    INFO  [muorb] muorb test passed
    ______  __   __    ___
    | ___ \ \ \ / /   /   |
    | |_/ /  \ V /   / /| |
    |  __/   /   \  / /_| |
    | |     / /^\ \ \___  |
    \_|     \/   \/     |_/
    px4 starting.
    INFO  [px4] startup script: /bin/sh /usr/bin/voxl-px4-hitl-start 0
    INFO  [muorb] SLPI: Advertising remote topic log_message
    INFO  [parameters] Starting param sync THREAD
    Running on M0054
    INFO  [muorb] SLPI: Starting param sync THREAD
    INFO  [muorb] SLPI: before starting the qshell_entry task
    INFO  [muorb] SLPI: Creating pthread qshell
    INFO  [muorb] SLPI: qshell entry.....
    INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
    INFO  [muorb] SLPI: Init app map initialized
    INFO  [muorb] SLPI: after starting the qshell_entry task
    INFO  [param] selected parameter default file /data/px4/param/hitl_parameters
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
    INFO  [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Advertising remote topic parameter_update
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to
    INFO  [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to
    INFO  [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
    INFO  [parameters] BSON document size 1620 bytes, decoded 1620 bytes (INT32:41, FLOAT:36)
    INFO  [logger] logger started (mode=all)
    INFO  [logger] Start file log (type: full)
    INFO  [logger] [logger] /data/px4/log/2024-10-23/16_58_03.ulg
    INFO  [muorb] SLPI: Advertising remote topic mavlink_log
    INFO  [logger] Opened full log file: /data/px4/log/2024-10-23/16_58_03.ulg
    INFO  [muorb] SLPI: Advertising remote topic event
    INFO  [muorb] SLPI: Advertising remote topic logger_status
    INFO  [qshell] Send cmd: 'sensors start -h'
    INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    INFO  [muorb] SLPI: qshell gotten: sensors start -h
    INFO  [muorb] SLPI:   arg0 = 'sensors'
    INFO  [muorb] SLPI:   arg1 = 'start'
    INFO  [muorb] SLPI:   arg2 = '-h'
    INFO  [uORB] Advertising remote topic sensor_selection
    INFO  [uORB] Advertising remote topic sensors_status_imu
    INFO  [uORB] Advertising remote topic vehicle_acceleration
    INFO  [uORB] Advertising remote topic vehicle_angular_velocity
    INFO  [uORB] Advertising remote topic sensor_combined
    INFO  [uORB] Advertising remote topic vehicle_air_data
    INFO  [uORB] Advertising remote topic vehicle_gps_position
    INFO  [uORB] Advertising remote topic vehicle_magnetometer
    INFO  [uORB] Advertising remote topic sensor_preflight_mag
    INFO  [muorb] SLPI: Ok executing command: sensors start -h
    INFO  [uORB] Advertising remote topic qshell_retval
    INFO  [qshell] qshell return value timestamp: 3280312226, local time: 3280315844
    INFO  [muorb] SLPI: qshell gotten: ekf2 start
    INFO  [muorb] SLPI:   arg0 = 'ekf2'
    INFO  [qshell] Send cmd: 'ekf2 start'
    INFO  [uORB] Advertising remote topic vehicle_attitude
    INFO  [uORB] Advertising remote topic vehicle_local_position
    INFO  [uORB] Advertising remote topic estimator_event_flags
    INFO  [uORB] Advertising remote topic estimator_innovation_test_ratios
    INFO  [uORB] Advertising remote topic estimator_innovation_variances
    INFO  [uORB] Advertising remote topic estimator_innovations
    INFO  [uORB] Advertising remote topic estimator_sensor_bias
    INFO  [uORB] Advertising remote topic estimator_states
    INFO  [uORB] Advertising remote topic estimator_status_flags
    INFO  [muorb] SLPI: Ok executing command: ekf2 start
    INFO  [qshell] qshell return value timestamp: 3280586205, local time: 3280590513
    INFO  [qshell] Send cmd: 'mc_pos_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_pos_control start
    INFO  [muorb] SLPI:   arg0 = 'mc_pos_control'
    INFO  [uORB] Advertising remote topic takeoff_status
    INFO  [muorb] SLPI: Ok executing command: mc_pos_control start
    INFO  [qshell] qshell return value timestamp: 3280705576, local time: 3280706809
    INFO  [qshell] Send cmd: 'mc_att_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_att_control start
    INFO  [muorb] SLPI:   arg0 = 'mc_att_control'
    INFO  [muorb] SLPI: Ok executing command: mc_att_control start
    INFO  [qshell] qshell return value timestamp: 3280759599, local time: 3280761703
    INFO  [qshell] Send cmd: 'mc_rate_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_rate_control start
    INFO  [muorb] SLPI:   arg0 = 'mc_rate_control'
    INFO  [uORB] Advertising remote topic rate_ctrl_status
    INFO  [muorb] SLPI: Ok executing command: mc_rate_control start
    INFO  [qshell] qshell return value timestamp: 3280865439, local time: 3280867108
    INFO  [qshell] Send cmd: 'mc_hover_thrust_estimator start'
    INFO  [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
    INFO  [muorb] SLPI:   arg0 = 'mc_hover_thrust_estimator'
    INFO  [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
    INFO  [qshell] qshell return value timestamp: 3280906031, local time: 3280907747
    INFO  [qshell] Send cmd: 'mc_autotune_attitude_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_autotune_attitude_control start
    INFO  [muorb] SLPI:   arg0 = 'mc_autotune_attitude_control'
    INFO  [uORB] Advertising remote topic autotune_attitude_control_status
    INFO  [muorb] SLPI: Ok executing command: mc_autotune_attitude_control start
    INFO  [qshell] qshell return value timestamp: 3280944959, local time: 3280946333
    INFO  [qshell] Send cmd: 'land_detector start multicopter'
    INFO  [muorb] SLPI: qshell gotten: land_detector start multicopter
    INFO  [muorb] SLPI:   arg0 = 'land_detector'
    INFO  [muorb] SLPI:   arg2 = 'multicopter'
    INFO  [muorb] SLPI: Ok executing command: land_detector start multicopter
    INFO  [qshell] qshell return value timestamp: 3280986143, local time: 3280988769
    INFO  [qshell] Send cmd: 'manual_control start'
    INFO  [muorb] SLPI: qshell gotten: manual_control start
    INFO  [muorb] SLPI:   arg0 = 'manual_control'
    INFO  [uORB] Advertising remote topic vehicle_land_detected
    INFO  [muorb] SLPI: Ok executing command: manual_control start
    INFO  [uORB] Advertising remote topic manual_control_setpoint
    INFO  [qshell] qshell return value timestamp: 3281037294, local time: 3281039572
    INFO  [muorb] SLPI: qshell gotten: control_allocator start
    INFO  [muorb] SLPI:   arg0 = 'control_allocator'
    INFO  [qshell] Send cmd: 'control_allocator start'
    INFO  [uORB] Advertising remote topic control_allocator_status
    INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
    INFO  [uORB] Advertising remote topic actuator_motors
    INFO  [uORB] Advertising remote topic actuator_servos
    INFO  [uORB] Advertising remote topic actuator_servos_trim
    INFO  [muorb] SLPI: Ok executing command: control_allocator start
    INFO  [qshell] qshell return value timestamp: 3281289624, local time: 3281291468
    INFO  [qshell] Send cmd: 'rc_update start'
    INFO  [muorb] SLPI: qshell gotten: rc_update start
    INFO  [muorb] SLPI:   arg0 = 'rc_update'
    INFO  [muorb] SLPI: Ok executing command: rc_update start
    INFO  [qshell] qshell return value timestamp: 3281573754, local time: 3281575359
    INFO  [muorb] SLPI: qshell gotten: commander start -h
    INFO  [muorb] SLPI:   arg0 = 'commander'
    INFO  [muorb] SLPI: Creating pthread commander
    INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097647
    INFO  [qshell] Send cmd: 'commander start -h'
    INFO  [uORB] Advertising remote topic led_control
    INFO  [muorb] SLPI: Ok executing command: commander start -h
    INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
    INFO  [uORB] Advertising remote topic tune_control
    INFO  [qshell] qshell return value timestamp: 3281758211, local time: 3281760473
    INFO  [muorb] SLPI: orb_advertise_multi: failed to set queue size
    INFO  [muorb] SLPI: Preflight Fail: Accel Sensor 0 missing
    INFO  [muorb] SLPI: Preflight Fail: barometer 0 missing
    INFO  [muorb] SLPI: Preflight Fail: ekf2 missing data
    INFO  [muorb] SLPI: Preflight Fail: Gyro Sensor 0 missing
    INFO  [muorb] SLPI: Preflight Fail: Compass Sensor 0 missing
    INFO  [uORB] Advertising remote topic health_report
    INFO  [uORB] Advertising remote topic failsafe_flags
    INFO  [uORB] Advertising remote topic actuator_armed
    INFO  [uORB] Advertising remote topic vehicle_control_mode
    INFO  [uORB] Advertising remote topic vehicle_status
    INFO  [uORB] Advertising remote topic failure_detector_status
    INFO  [qshell] Send cmd: 'commander mode posctl'
    INFO  [muorb] SLPI: qshell gotten: commander mode posctl
    INFO  [muorb] SLPI:   arg1 = 'mode'
    INFO  [muorb] SLPI:   arg2 = 'posctl'
    INFO  [uORB] Advertising remote topic vehicle_command
    INFO  [muorb] SLPI: Ok executing command: commander mode posctl
    INFO  [qshell] qshell return value timestamp: 3281789206, local time: 3281789998
    INFO  [uORB] Advertising remote topic vehicle_command_ack
    INFO  [qshell] Send cmd: 'load_mon start'
    INFO  [muorb] SLPI: qshell gotten: load_mon start
    INFO  [muorb] SLPI:   arg0 = 'load_mon'
    INFO  [muorb] SLPI: Ok executing command: load_mon start
    INFO  [uORB] Advertising remote topic cpuload
    INFO  [qshell] qshell return value timestamp: 3281817661, local time: 3281818749
    INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
    INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
    INFO  [qshell] Send cmd: 'flight_mode_manager start'
    INFO  [uORB] Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
    INFO  [qshell] qshell return value timestamp: 3281917546, local time: 3281919416
    INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
    INFO  [muorb] SLPI: Advertising remote topic transponder_report
    INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
    INFO  [muorb] SLPI: Advertising remote topic position_setpoint_triplet
    INFO  [qshell] Send cmd: 'pwm_out_sim start -m hil'
    INFO  [muorb] SLPI: qshell gotten: pwm_out_sim start -m hil
    INFO  [muorb] SLPI:   arg0 = 'pwm_out_sim'
    INFO  [muorb] SLPI:   arg2 = '-m'
    INFO  [muorb] SLPI:   arg3 = 'hil'
    INFO  [uORB] Advertising remote topic actuator_outputs
    INFO  [muorb] SLPI: Ok executing command: pwm_out_sim start -m hil
    INFO  [uORB] Advertising remote topic actuator_outputs_sim
    INFO  [qshell] qshell return value timestamp: 3283106378, local time: 3283108095
    INFO  [qshell] Send cmd: 'dsp_hitl start -g -m'
    INFO  [muorb] SLPI: qshell gotten: dsp_hitl start -g -m
    INFO  [muorb] SLPI:   arg0 = 'dsp_hitl'
    INFO  [muorb] SLPI:   arg2 = '-g'
    INFO  [muorb] SLPI:   arg3 = '-m'
    INFO  [muorb] SLPI: Creating pthread dsp_hitl__main
    INFO  [muorb] SLPI: Successfully created px4 task PX4_dsp_hitl__main with tid 2097645
    INFO  [muorb] SLPI: Ok executing command: dsp_hitl start -g -m
    ERROR [muorb] SLPI: Port is open: 0
    INFO  [uORB] Advertising remote topic sensor_accel
    INFO  [uORB] Advertising remote topic sensor_gyro
    INFO  [muorb] SLPI: Got 5 from orb_subscribe
    INFO  [qshell] qshell return value timestamp: 3283136557, local time: 3283138431
    INFO  [uORB] Advertising remote topic esc_status
    INFO  [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
    INFO  [muorb] SLPI: Advertising remote topic telemetry_status
    INFO  [mavlink] partner IP: 127.0.0.1
    INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
    INFO  [muorb] SLPI: Advertising remote topic timesync_status
    INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
    INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
    INFO  [uORB] Advertising remote topic vehicle_imu
    INFO  [uORB] Advertising remote topic vehicle_imu_status
    INFO  [muorb] SLPI: Too many arming check events (1, 14 > 14). Not reporting all
    INFO  [muorb] SLPI: Preflight Fail: No valid data from Accel 0
    INFO  [muorb] SLPI: Preflight Fail: No valid data from Gyro 0
    INFO  [microdds_client] synchronized with time offset 1729699404643157us
    INFO  [muorb] SLPI: Marking DeviceNode(timesync_status) as advertised in process_remote_topic
    INFO  [microdds_client] successfully created rt/fmu/out/failsafe_flags data writer, topic id: 80
    INFO  [microdds_client] successfully created rt/fmu/out/position_setpoint_triplet data writer, topic id: 159
    INFO  [microdds_client] successfully created rt/fmu/out/timesync_status data writer, topic id: 200
    INFO  [microdds_client] successfully created rt/fmu/out/vehicle_control_mode data writer, topic id: 223
    INFO  [microdds_client] successfully created rt/fmu/out/vehicle_status data writer, topic id: 240
    INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
    INFO  [px4] Startup script returned successfully
    pxh>
    **Also, when I run voxl-px-hitl the drone model sinks under asphalt, am I doing something wrong, do I need to change the model inside run_gazebo.bash.
    I think am using the correct cable, mentioned in one of the post. Is there a way to check the cable.**
    @Shivam-Sehgal
    I was able to start the imu_px4. I did just a simple take off and landing manually through rc controller in position mode.
    imu_px4 has following vibrations(look at the max values)
    Noise values are RMS values in units of m/s2 and rad/s.
    Value in parenthesis are the max values recorded since the start.
    Values in RED are high (>5.00m/s2 or >0.50rad/s).
    Values in YELLOW are okay (>2.00m/s2 or >0.20rad/s).
    Values in GREEN are great!
     Accl (X) | Accl (Y) | Accl (Z) |  Gyro (X)  |  Gyro (Y)  |  Gyro (Z)
    0.01(31.54) 0.01(10.40) 0.01(30.38) 0.003(0.625) 0.003(1.548) 0.002(0.210)
    imu_app has following vibrations(look at the max values)
    0.00(4.32) 0.00(2.31) 0.00(7.96) 0.001(0.330) 0.000(0.491) 0.000(0.101)
    Why are vibrations much worse on imu_px4, did I do something wrong?
    @tom said in Unstable Flight (local Position Estimate Error):
    imu_server start
    Thanks it worked.
    How can update the extrinsic.conf file for imu_px4?
    @Alex-Kushleyev I was able to point out maybe it's the hires camera that's the issue. I don't know why but I was singly able to run all other camera's but not the hires camera.
    What defect should I look for?
    Also, while doing all that I broke the tracking camera's connector and the 2 in 1 camera boards. I will be ordering those. How can I remove the 2 in 1 camera board from the voxl2 board?
    @Alex-Kushleyev I hope this clears somethings out, its confusing for me too.
    no it does not boot now with all the camera's plugged in original physical connections.
    It was not about the physical connections, but when the camera service started then the connection broke.
    First I shifted the physical connections of the camera's as mentioned above, after which I could boot but the hires and tracking camera did not work or start. (https://forum.modalai.com/post/19383)
    Then restored the original physical connnections, set the voxl-configure-camera to it original configuration it's shipped with and then restarted the voxl-camera-server.
    When I started the service this the output of it, after this output the adb and ssh connection broke and I was unable to connection to the voxl2 board.
    cam #0
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 5
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           224
        pre_height:          1557
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             off
        standby_enabled:     0
        decimator:           5
    cam #1
        sensor type:         imx214
        isEnabled:           1
        camId:               1
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          0
        pre_width:           640
        pre_height:          480
        en_raw_preview:      0
        en_small_video:      1
        en_large_video:      1
        en_snapshot:         1
        snap_width:          4208
        snap_height:         3120
        ae_mode:             isp
        standby_enabled:     0
        decimator:           1
    cam #2
        sensor type:         ov7251
        isEnabled:           1
        camId:               2
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        standby_enabled:     0
        decimator:           1
    	Count Min: 8
    	Count Actual: 16
    	Buffer Alignment: 0
    	Count Min: 4
    	Count Actual: 16
    	Buffer Alignment: 0
    	Count Min: 8
    	Count Actual: 16
    	Buffer Alignment: 0
    	Count Min: 4
    	Count Actual: 16
    	Buffer Alignment: 0
    @Zachary-Lowell-0 I started the imu_px4 server, but then again on inspecting it I just see the units no values.
    @Zachary-Lowell-0 I did test SDK 1.3 but the ros2 package I had built for my application does not work as I want it to in that SDK version you can refer this question https://forum.modalai.com/topic/3775/tof-sensor-quailty-down-after-upgrading-to-voxl-1-3?_=1729870030812 for that.
    how can I leverage the imu_px4 instead of imu_apps, I have been trying to find some resource to do that but I could not. When I do voxl-inspect-imu imu_px4 I don't see it, it shows waiting for server at.
    how do I set it up.
    @Shivam-Sehgal Turns out I have high imu vibrations, I was able to get it down by tightening the bolts properly but still there is high vibration in z - 8-9 and x -3-4. how can I find the cause of vibrations.
    The motor seems to be correctly mounted and propellers are clean and not damaged.
