    Unstable Flight (local Position Estimate Error)
    Questions by Product
    1028
    • Shivam SehgalS
      Shivam Sehgal
      Drone Info:
      Starling Drone, Voxl SDK Version: 1.1.2
      I had a starling drone, which was not flying properly. I was changing into failsafe mode and I was unable to control it in position mode. I thought one of the motors is damages so I replaced it. After that it works a bit better but still goes into failsafe mode again and again.
      I have 2 log files
      log1
      log2
      Also, I am able to control it well in manual mode.
      Can you help me with this?
      Shivam SehgalS 1 Reply Last reply Reply Quote 0
      • Shivam SehgalS
        Shivam Sehgal @Shivam Sehgal
        @Shivam-Sehgal Turns out I have high imu vibrations, I was able to get it down by tightening the bolts properly but still there is high vibration in z - 8-9 and x -3-4. how can I find the cause of vibrations.
        The motor seems to be correctly mounted and propellers are clean and not damaged.
        • Zachary Lowell 0Z
          Zachary Lowell 0 ModalAI Team
          @Shivam-Sehgal Any reason why you are on SDK 1.1.2 and not the most recent 1.3.5?
          My guess is there is some vibrations coming from somewhere causing a lot of noise in the imu causing qvio to feed bad data to the drone. One thing you could try doing is leveragin the imu_px4 instead of imu_apps for qvio which would make qvio act accordingly if manual flight seems to be stable.
          Zach
          Shivam SehgalS 2 Replies Last reply Reply Quote 0
          • Shivam SehgalS
            Shivam Sehgal @Zachary Lowell 0
            @Zachary-Lowell-0 I did test SDK 1.3 but the ros2 package I had built for my application does not work as I want it to in that SDK version you can refer this question https://forum.modalai.com/topic/3775/tof-sensor-quailty-down-after-upgrading-to-voxl-1-3?_=1729870030812 for that.
            how can I leverage the imu_px4 instead of imu_apps, I have been trying to find some resource to do that but I could not. When I do voxl-inspect-imu imu_px4 I don't see it, it shows waiting for server at.
            how do I set it up.
            • Shivam SehgalS
              @Zachary-Lowell-0 I started the imu_px4 server, but then again on inspecting it I just see the units no values.
                tom admin @Shivam Sehgal
                @Shivam-Sehgal voxl-px4-imu-server is targeted toward RB5 and not VOXL 2 as RB5 only has one IMU.
                If you'd like to start the px4 driver for the DSP IMU you can do the following:
                In /usr/bin/voxl-px4-start, add the line imu_server start
                Then if you restart voxl-px4 and voxl-px4-imu-server you will see data populate
                • Shivam SehgalS
                  Shivam Sehgal @tom
                  @tom said in Unstable Flight (local Position Estimate Error):
                  imu_server start
                  Thanks it worked.
                  How can update the extrinsic.conf file for imu_px4?
                  • Shivam SehgalS
                    @Shivam-Sehgal
                    I was able to start the imu_px4. I did just a simple take off and landing manually through rc controller in position mode.
                    imu_px4 has following vibrations(look at the max values)
                    Noise values are RMS values in units of m/s2 and rad/s.
                    Value in parenthesis are the max values recorded since the start.
                    Values in RED are high (>5.00m/s2 or >0.50rad/s).
                    Values in YELLOW are okay (>2.00m/s2 or >0.20rad/s).
                    Values in GREEN are great!
                     Accl (X) | Accl (Y) | Accl (Z) |  Gyro (X)  |  Gyro (Y)  |  Gyro (Z)
                    0.01(31.54) 0.01(10.40) 0.01(30.38) 0.003(0.625) 0.003(1.548) 0.002(0.210)
                    imu_app has following vibrations(look at the max values)
                    0.00(4.32) 0.00(2.31) 0.00(7.96) 0.001(0.330) 0.000(0.491) 0.000(0.101)
                    Why are vibrations much worse on imu_px4, did I do something wrong?
                    • Shivam SehgalS
                      @Moderator any advice?
