  2. VOXL SDK and Software
  3. Docker daemon fails to start on voxl
40 Posts 11 Posters 27.0k Views 5 Watching
  • S shlee853
    @kiprock thank you for your reply
    I’ll try it
    S Offline
    S Offline
    shlee853
    @shlee853
    Great!
    I resolved this problem as you mentioned.
    yocto:/$ rm /data/network/files/local-kv.db
    yocto:/$ voxl-configure-docker-support.sh
    Stopping original docker service
    Enabling our own services docker-start & docker-prepare
    starting docker-start.service
    loading hello-world docker image
    successfully loaded hello-world
    starting docker-prepare service
    Created symlink from /etc/systemd/system/default.target.wants/docker-autorun.service to /etc/systemd/system/docker-autorun.service.
    done configuring voxl-docker-support
    • K kiprock
      did the trick. Thanks for providing that missing piece of data!
      LucasWL Offline
      LucasWL Offline
      LucasW
      @kiprock Thank you for this, that also solved the issue in my case.
      To be a little more cautious, I simply renamed the existing file, which forced the generation of a new one when running the configuration script voxl-configure-docker-support.sh:
      voxl:/data/network/files$ mv local-kv.db local-kv_DISABLED.db
      • modaltbM modaltb
        What do you see after running voxl-configure-docker.sh ?
        Should be something like:
        yocto:/# voxl-configure-docker-support.sh
        José QuintanillaJ Offline
        José Quintanilla
        @modaltb I have a problem, after I write that line, the drone display a message that says: voxl:/$ voxl-configure-docker-suport.sh
        bash: voxl-configure-docker-suport.sh: command not found
        voxl:/$
        • tomT Offline
          @José-Quintanilla Looks like you spelled it wrong
          • tomT Offline
            @José-Quintanilla You can use [TAB] after you start writing a command to auto-fill
            José QuintanillaJ 2 Replies Last reply
              José Quintanilla
              @tom I think it worked, thanks
                José Quintanilla
                wrote on last edited by José Quintanilla
                #27
                @tom It wasn't that, because I need that especific line on my VOXL to work, so I can use properly the sdk
                • tomT Offline
                  @José-Quintanilla What is not working? Did you run voxl-configure-docker-support.sh?
                  José QuintanillaJ 1 Reply Last reply
                    José Quintanilla
                    @tom That's the line that doesnt let me run, my done say: voxl-configure-docker-support.sh: command not found
                    • tomT Offline
                      @José-Quintanilla What release do you have installed, what does voxl-version say?
                        José Quintanilla
                        @tom If I recall is the 0.9 version
                        • tomT Offline
                          @José-Quintanilla When you get a chance post the output of voxl-version. Also what hardware are you on?
                            José Quintanilla
                            @tom I confirm that is the voxl 0.9 version on a m500 hardware im using a voxl flight
                            • tomT Offline
                              @José-Quintanilla I was asking because that command also lists installed packages, try without the .sh: voxl-configure-docker-support
                                José Quintanilla
                                @tom voxl:/$ voxl-version
                                system-image: 4.0.0
                                kernel: #1 SMP PREEMPT Thu Oct 13 17:57:05 UTC 2022 3.18.71-perf
                                hw version: VOXL
                                voxl-suite: 0.9.4
                                Packages:
                                Repo: http://voxl-packages.modalai.com/dists/apq8096/sdk-0.9/binary-arm64/
                                Last Updated: stat: cannot stat '/var/lib/opkg/lists/modalai': No such file or directory
                                List:
                                apq8096-dfs-server 0.3.1
                                apq8096-imu-server 1.0.3
                                apq8096-libpng 1.6.38-1
                                apq8096-system-tweaks 0.1.3
                                apq8096-tflite 2.8.3-1
                                libapq8096-io 0.6.0
                                libmodal-cv 0.2.3
                                libmodal-exposure 0.0.7
                                libmodal-journal 0.2.1
                                libmodal-json 0.4.3
                                libmodal-pipe 2.6.0
                                libvoxl-cci-direct 0.1.5
                                libvoxl-cutils 0.1.1
                                voxl-camera-calibration 0.2.3
                                voxl-camera-server 1.3.5
                                voxl-cpu-monitor 0.3.0
                                voxl-docker-support 1.2.4
                                voxl-gphoto2-server 0.0.10
                                voxl-jpeg-turbo 2.1.3-4
                                voxl-libgphoto2 0.0.4
                                voxl-libuvc 1.0.7
                                voxl-logger 0.3.4
                                voxl-mavlink 0.1.0
                                voxl-mavlink-server 0.2.0
                                voxl-modem 0.16.1
                                voxl-mongoose 7.7.0-1
                                voxl-mpa-to-ros 0.3.6
                                voxl-mpa-tools 0.7.6
                                voxl-opencv 4.5.5-1
                                voxl-portal 0.4.2
                                voxl-qvio-server 0.8.2
                                voxl-streamer 0.4.1
                                voxl-suite 0.9.4
                                voxl-system-image 4.0-r0
                                voxl-tag-detector 0.0.4
                                voxl-tflite-server 0.3.1
                                voxl-utils 1.2.2
                                voxl-uvc-server 0.1.3
                                voxl-vision-px4 1.4.0
                                voxl-vpn 0.0.6
                                voxl:/$
                                  José Quintanilla
                                  @tom I think I need to use the command with the .sh, I'm following this guide https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk-python
                                  and the command you want me to do is referring to this guide: https://docs.modalai.com/docker-on-voxl/
                                  • tomT Offline
                                    @José-Quintanilla Its the exact same command, the name was just slightly changed since that page was written.
                                      José Quintanilla
                                      @tom Ohh, well thanks, I didn't knew that, thank you
                                      • A Offline
                                        amitga
                                        Just to add to this post: I had similar problems with platform image 3.8 (clean install + wipe).
                                        Deleting the /data/network/files didn't help.
                                        I noticed in the systemctl status docker-daemon that there is were various network related errors, probably in the absense of a valid internet connection (VOXL was configured as AP).
                                        For example: Error getting v2 registry: Get https://registry-1.docker.io/v2/: x509: certificate has expired or is not yet valid" and "HTTP Error" err="No such image: hello-world:latest" statusCode=404.
                                        After connecting the VOXL to a Wifi router with internet access and rebooting, it seems like the daemon is able to run on boot without issues.
                                        Is this how its supposed to work? Can't a new VOXL install be successful without internet connection ?
                                        • Y Offline
                                          Y Offline
                                          Yonim
                                          switch to wifi station mode - https://docs.modalai.com/wifi-setup/
                                          It fixed for me
                                          • M memeliner787 referenced this topic on
