  2. VOXL SDK and Software
  3. Docker daemon fails to start on voxl
40 Posts 11 Posters 26.5k Views 5 Watching
    @José-Quintanilla What is not working? Did you run voxl-configure-docker-support.sh?
    José QuintanillaJ Offline
    José Quintanilla
    @tom That's the line that doesnt let me run, my done say: voxl-configure-docker-support.sh: command not found
      @José-Quintanilla What release do you have installed, what does voxl-version say?
      José QuintanillaJ 1 Reply Last reply
        José Quintanilla
        @tom If I recall is the 0.9 version
          @José-Quintanilla When you get a chance post the output of voxl-version. Also what hardware are you on?
          José QuintanillaJ 2 Replies Last reply
            José Quintanilla
            @tom I confirm that is the voxl 0.9 version on a m500 hardware im using a voxl flight
              @José-Quintanilla I was asking because that command also lists installed packages, try without the .sh: voxl-configure-docker-support
                José Quintanilla
                @tom voxl:/$ voxl-version
                system-image: 4.0.0
                kernel: #1 SMP PREEMPT Thu Oct 13 17:57:05 UTC 2022 3.18.71-perf
                hw version: VOXL
                voxl-suite: 0.9.4
                Packages:
                Repo: http://voxl-packages.modalai.com/dists/apq8096/sdk-0.9/binary-arm64/
                Last Updated: stat: cannot stat '/var/lib/opkg/lists/modalai': No such file or directory
                List:
                apq8096-dfs-server 0.3.1
                apq8096-imu-server 1.0.3
                apq8096-libpng 1.6.38-1
                apq8096-system-tweaks 0.1.3
                apq8096-tflite 2.8.3-1
                libapq8096-io 0.6.0
                libmodal-cv 0.2.3
                libmodal-exposure 0.0.7
                libmodal-journal 0.2.1
                libmodal-json 0.4.3
                libmodal-pipe 2.6.0
                libvoxl-cci-direct 0.1.5
                libvoxl-cutils 0.1.1
                voxl-camera-calibration 0.2.3
                voxl-camera-server 1.3.5
                voxl-cpu-monitor 0.3.0
                voxl-docker-support 1.2.4
                voxl-gphoto2-server 0.0.10
                voxl-jpeg-turbo 2.1.3-4
                voxl-libgphoto2 0.0.4
                voxl-libuvc 1.0.7
                voxl-logger 0.3.4
                voxl-mavlink 0.1.0
                voxl-mavlink-server 0.2.0
                voxl-modem 0.16.1
                voxl-mongoose 7.7.0-1
                voxl-mpa-to-ros 0.3.6
                voxl-mpa-tools 0.7.6
                voxl-opencv 4.5.5-1
                voxl-portal 0.4.2
                voxl-qvio-server 0.8.2
                voxl-streamer 0.4.1
                voxl-suite 0.9.4
                voxl-system-image 4.0-r0
                voxl-tag-detector 0.0.4
                voxl-tflite-server 0.3.1
                voxl-utils 1.2.2
                voxl-uvc-server 0.1.3
                voxl-vision-px4 1.4.0
                voxl-vpn 0.0.6
                voxl:/$
                  José Quintanilla
                  @tom I think I need to use the command with the .sh, I'm following this guide https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk-python
                  and the command you want me to do is referring to this guide: https://docs.modalai.com/docker-on-voxl/
                    @José-Quintanilla Its the exact same command, the name was just slightly changed since that page was written.
                      José Quintanilla
                      @tom Ohh, well thanks, I didn't knew that, thank you
                      • A Offline
                        amitga
                        Just to add to this post: I had similar problems with platform image 3.8 (clean install + wipe).
                        Deleting the /data/network/files didn't help.
                        I noticed in the systemctl status docker-daemon that there is were various network related errors, probably in the absense of a valid internet connection (VOXL was configured as AP).
                        For example: Error getting v2 registry: Get https://registry-1.docker.io/v2/: x509: certificate has expired or is not yet valid" and "HTTP Error" err="No such image: hello-world:latest" statusCode=404.
                        After connecting the VOXL to a Wifi router with internet access and rebooting, it seems like the daemon is able to run on boot without issues.
                        Is this how its supposed to work? Can't a new VOXL install be successful without internet connection ?
                        • Y Offline
                          Y Offline
                          Yonim
                          switch to wifi station mode - https://docs.modalai.com/wifi-setup/
                          It fixed for me
                          • M memeliner787 referenced this topic on
