  3. How to set up a static IP in RB5
rb5
17 Posts 4 Posters 4.2k Views 3 Watching
  • RobertoR Offline
    RobertoR Offline
    Roberto
    I would like to set a static IP.
    I thought that maybe in UBUNTU you could set it as follows:
    sudo vi /etc/dhcpcd.conf
    I tried with the WiFi network wlan0 and set an IP compatible with my network: 192.168.178.201
    # on the server to actually work
    option rapid_commit
    # A list of options to request from the DHCP server
    option domain_name_servers, domain_name, domain_search, host_name
    option classless_static_routes
    # Most distributions have NTP support.
    option ntp_servers
    # Respect the network MTU. This is applied to DHCP routes.
    option interface_mtu
    # A ServerID is required by RFC2131.
    require dhcp_server_identifier
    # Generate Stable Private IPv6 Addresses instead of hardware based ones
    slaac private
    # ==== Test of static IP configuration: ======
    interface wlan0
    static ip_address=192.168.178.201/24
    static routers=192.168.178.1
    static domain_name_servers=8.8.8.8
    But when I turn RB5 off and on again sometimes it works with right static IP 192.168.178.201 and sometimes with a random IP, I don't know what I did wrong. Could you please help me?
    Robert
    Roberto Calvi
    • tomT Offline
      @Roberto There is a bug with the QCOM SOM where the wlan0 interface's MAC address isn't static, which affects using static IPs in ways that usually work on other hardware. We have an open ticket with QCOM to fix this issue. One thing to try is: https://www.howtogeek.com/118337/stupid-geek-tricks-change-your-ip-address-from-the-command-line-in-linux/
      The solution may require creating a custom startup script.
      RobertoR 1 Reply Last reply
        RobertoR Offline
        RobertoR Offline
        Roberto
        wrote on last edited by Roberto
        @tom Thank you
        But perhaps i did something wrong creating a script:
        vi /etc/sudoers.d/mystatic-ip.sh
        Content of mystatic-ip.sh file:
        #!/bin/bash
        sudo ifconfig wlan0 192.168.178.201 netmask 255.255.255.0
        sudo route add default gw 192.168.178.1 wlan0
        Then i created a service:
        vi /etc/systemd/system/mystatic-ip.service
        Content of mystatic-ip.service file:
        [Unit]
        Description=My static IP
        [Service]
        ExecStart=/etc/sudoers.D/mystatic-ip.sh start
        [Install]
        WantedBy=multi-user.target
        To enable this service when startup I did:
        systemctl enable mystatic-ip
        Robert
        Roberto Calvi
        • tomT Offline
          @Roberto When you run the script manually outside of the service file does it work?
            RobertoR Offline
            RobertoR Offline
            Roberto
            @tom
            Thank you for reply, yes If I run:
            works, but if I restart RB5 the script does not do his work, perhaps a chmod is needed?
            Roberto Calvi
            • RobertoR Roberto
              @tom
              @Roberto It's probably a timing thing. Your service file doesn't have any dependencies so it gets run immediately on startup. Then a different service comes along and changes everything. Ideally you specify the service that is doing that as a dependency so you know yours will run after it. Just to debug you could add a big sleep before the commands and see if that solves the issue.
                RobertoR Offline
                RobertoR Offline
                Roberto
                @Eric-Katzfey
                Thank you for help, what would you suggest? Perhaps a delay in the script or something similar?
                how do you suggest to do the startup log? and how could this sequence be organized correctly?
                Do you have a RB5 to test? Thank you for any help
                Roberto Calvi
                • tomT Offline
                  @Roberto The "dumb" way to do it is to just put a sleep at the start of mystatic-ip.sh and gradually decrease the length to find the quickest sleep that works.
                  Otherwise you'd have to reference another service in an "After" section to tell the service to start after the stated one
                  Example:
                  [Unit]
                  After=wlan_daemon.service
                  I know on VOXL wlan_daemon.service can be referenced, not positive whether it is on RB5 as well
                  RobertoR 2 Replies Last reply
                    Example:
                    [Unit]
                    RobertoR Offline
                    RobertoR Offline
                    Roberto
                    #9
                    RESOLVED: Thanks to @Eric-Katzfey & @tom
                    1. First create a script:
                    Content of mystatic-ip.sh script:
                    #!/bin/bash
                    1. Create a service:
                    Content of mystatic-ip.service file (that starts after wlan daemon):
                    [Unit]
                    [Service]
                    ExecStart=/etc/sudoers.d/mystatic-ip.sh start
                    [Install]
                    To enable this service when the RB5 boots:
                    Reboot and you will have a static IP!
                    Roberto Calvi
                    • RobertoR Roberto
                      #!/bin/bash
                      [Unit]
                      [Service]
                      [Install]
                      RobertoR Offline
                      RobertoR Offline
                      Roberto
                      #10
                      NOT RESOLVED 😖 @Eric-Katzfey & @tom
                      Works on Reboot but not if I turn RB5 OFF wait a wile and afterwards I turn it ON
                      Sometimes work and sometimes doesn't
                      Somebody could please help me?
                      Roberto Calvi
                        Example:
                        [Unit]
                        RobertoR Offline
                        RobertoR Offline
                        Roberto
                        @tom & @Eric-Katzfey
                        List of services: (command to show active services)
                        systemctl list-units --type=service
                        Some services are down like:
                        ● dnsmasq.service loaded failed failed dnsmasq - A lightweight DHCP and caching DNS server
                        ● lunch-make-scripts.service loaded failed failed lunch make scripts
                        ● mystatic-ip.service loaded failed failed My static IP
                        Roberto Calvi
                        • RobertoR Roberto
                          @Roberto We will take a look and see if we can put together a solution over the next few days.
                          • tomT Offline
                            @Roberto This combo consistently works for me:
                            sh-4.4# cat /usr/bin/rb5-wifi-static-ip.sh
                            #!/bin/bash
                            # wait for wlan0 to get it's initial IP from router
                            rb5-net-check wlan0 192.168
                            # set new IP
                            sudo ifconfig wlan0 192.168.1.150 netmask 255.255.255.0
                            sudo route add default gw 192.168.1.1 wlan0
                            sh-4.4# cat /etc/systemd/system/rb5-wifi-static-ip.service
                            [Unit]
                            Description=WLAN0 Static IP Service
                            [Service]
                            ExecStart=/usr/bin/rb5-wifi-static-ip.sh
                            [Install]
                            Basically adding the rb5-net-check call which waits for wlan0 to get an initial valid IP before proceeding.
                            • tomT Offline
                              @Roberto Or a slightly cleaner solution would be to keep your same script and just have the service depend on the rb5-net-check.service that is already enabled by default if you're running PX4:
                              [Unit]
                              After=rb5-net-check.service
                              [Service]
                              [Install]
                                [Unit]
                                [Service]
                                [Install]
                                RobertoR Offline
                                RobertoR Offline
                                Roberto
                                #15
                                FINALLY SOLVED: Thanks to @tom
                                (added chmod and complete procedure for other users)
                                vi /usr/bin/rb5-wifi-static-ip.sh
                                Content of rb5-wifi-static-ip.sh script (with sample IP):
                                #!/bin/bash
                                rb5_net='192.168'
                                drone_IP='192.168.178.201'
                                router_IP='192.168.178.1'
                                netmask_IP='255.255.255.0'
                                network_interface='wlan0'
                                # wait for wlan to get it's initial IP from router
                                rb5-net-check $network_interface $rb5_net
                                # set new IP
                                sudo ifconfig $network_interface $drone_IP netmask $netmask_IP
                                sudo route add default gw $router_IP $network_interface
                                1. Give permission to script (if not, will give you message "Permission denied"):
                                chmod u+x /usr/bin/rb5-wifi-static-ip.sh
                                vi /etc/systemd/system/rb5-wifi-static-ip.service
                                Content of rb5-wifi-static-ip.service file:
                                [Unit]
                                [Service]
                                [Install]
                                1. Enable this service when RB5 boots:
                                systemctl enable rb5-wifi-static-ip.service
                                Restart RB5 and you will have a static IP!
                                Roberto Calvi
                                • tomT Offline
                                  @Roberto Thanks for your patience with this, I will make sure this script / service makes it into our next SDK release as well.
                                  • M Offline
                                    M Offline
                                    mrawding
                                    If anyone else is interested - I found a way to enable static ip's for ethernet and wlan interfaces.
                                    You'll need to install a file like below under /etc/systemd/systetem/ and run the following commands:
                                    systemctl enable ipconfig.service
                                    systemctl disable dhcpcd.service
                                    [Unit]
                                    Description=A description for your custom service goes here
                                    Requires=systemd-networkd.service
                                    After=systemd-networkd-wait-online.service
                                    [Service]
                                    Type=simple
                                    ExecStartPre=/bin/sleep 10
                                    ExecStart=/bin/systemctl restart systemd-networkd.service
                                    [Install]
                                    You'll also need to add this file under /etc/systemd/network/wlan0.network
                                    [Match]
                                    Name=wlan0
                                    [Network]
                                    Address=192.168.0.169/24
                                    #DHCP=yes
                                    Simply installing this service will allow most routers to keep the rb5 address the same when assigning IPs for a lease. Just comment #Address and uncomment DHCP to use dhcp.
                                    You will also need to make sure to add the gatway to the routing table:
                                    this is best to be configured as a oneshot service where the service has the field Requires=ipconfig.service
