  3. How to set up a static IP in RB5
rb5
17 Posts 4 Posters 4.0k Views 3 Watching
    @Roberto There is a bug with the QCOM SOM where the wlan0 interface's MAC address isn't static, which affects using static IPs in ways that usually work on other hardware. We have an open ticket with QCOM to fix this issue. One thing to try is: https://www.howtogeek.com/118337/stupid-geek-tricks-change-your-ip-address-from-the-command-line-in-linux/
    The solution may require creating a custom startup script.
    RobertoR Offline
    RobertoR Offline
    Roberto
    wrote on last edited by Roberto
    @tom Thank you
    But perhaps i did something wrong creating a script:
    vi /etc/sudoers.d/mystatic-ip.sh
    Content of mystatic-ip.sh file:
    #!/bin/bash
    sudo ifconfig wlan0 192.168.178.201 netmask 255.255.255.0
    sudo route add default gw 192.168.178.1 wlan0
    Then i created a service:
    vi /etc/systemd/system/mystatic-ip.service
    Content of mystatic-ip.service file:
    [Unit]
    Description=My static IP
    [Service]
    ExecStart=/etc/sudoers.D/mystatic-ip.sh start
    [Install]
    WantedBy=multi-user.target
    To enable this service when startup I did:
    systemctl enable mystatic-ip
    I don't know what I did wrong. Could you please help me?
    Robert
    Roberto Calvi
      @Roberto When you run the script manually outside of the service file does it work?
      RobertoR 1 Reply Last reply
        RobertoR Offline
        RobertoR Offline
        Roberto
        Thank you for reply, yes If I run:
        works, but if I restart RB5 the script does not do his work, perhaps a chmod is needed?
        Roberto Calvi
        • RobertoR Roberto
          @Roberto It's probably a timing thing. Your service file doesn't have any dependencies so it gets run immediately on startup. Then a different service comes along and changes everything. Ideally you specify the service that is doing that as a dependency so you know yours will run after it. Just to debug you could add a big sleep before the commands and see if that solves the issue.
            RobertoR Offline
            RobertoR Offline
            Roberto
            Thank you for help, what would you suggest? Perhaps a delay in the script or something similar?
            how do you suggest to do the startup log? and how could this sequence be organized correctly?
            Do you have a RB5 to test? Thank you for any help
            Roberto Calvi
              @Roberto The "dumb" way to do it is to just put a sleep at the start of mystatic-ip.sh and gradually decrease the length to find the quickest sleep that works.
              Otherwise you'd have to reference another service in an "After" section to tell the service to start after the stated one
              Example:
              [Unit]
              After=wlan_daemon.service
              I know on VOXL wlan_daemon.service can be referenced, not positive whether it is on RB5 as well
              RobertoR 2 Replies Last reply
                Example:
                [Unit]
                RobertoR Offline
                RobertoR Offline
                Roberto
                #9
                RESOLVED: Thanks to @Eric-Katzfey & @tom
                1. First create a script:
                Content of mystatic-ip.sh script:
                #!/bin/bash
                1. Create a service:
                Content of mystatic-ip.service file (that starts after wlan daemon):
                [Unit]
                [Service]
                ExecStart=/etc/sudoers.d/mystatic-ip.sh start
                [Install]
                To enable this service when the RB5 boots:
                Reboot and you will have a static IP!
                Roberto Calvi
                • RobertoR Roberto
                  #!/bin/bash
                  [Unit]
                  [Service]
                  [Install]
                  RobertoR Offline
                  RobertoR Offline
                  Roberto
                  #10
                  NOT RESOLVED 😖 @Eric-Katzfey & @tom
                  Works on Reboot but not if I turn RB5 OFF wait a wile and afterwards I turn it ON
                  Sometimes work and sometimes doesn't
                  Somebody could please help me?
                  Roberto Calvi
                    Example:
                    [Unit]
                    RobertoR Offline
                    RobertoR Offline
                    Roberto
                    @tom & @Eric-Katzfey
                    List of services: (command to show active services)
                    systemctl list-units --type=service
                    Some services are down like:
                    ● dnsmasq.service loaded failed failed dnsmasq - A lightweight DHCP and caching DNS server
                    ● lunch-make-scripts.service loaded failed failed lunch make scripts
                    ● mystatic-ip.service loaded failed failed My static IP
                    Roberto Calvi
                    • RobertoR Roberto
                      @Roberto We will take a look and see if we can put together a solution over the next few days.
                        @Roberto This combo consistently works for me:
                        sh-4.4# cat /usr/bin/rb5-wifi-static-ip.sh
                        #!/bin/bash
                        # wait for wlan0 to get it's initial IP from router
                        rb5-net-check wlan0 192.168
                        # set new IP
                        sudo ifconfig wlan0 192.168.1.150 netmask 255.255.255.0
                        sudo route add default gw 192.168.1.1 wlan0
                        sh-4.4# cat /etc/systemd/system/rb5-wifi-static-ip.service
                        [Unit]
                        Description=WLAN0 Static IP Service
                        [Service]
                        ExecStart=/usr/bin/rb5-wifi-static-ip.sh
                        [Install]
                        Basically adding the rb5-net-check call which waits for wlan0 to get an initial valid IP before proceeding.
                          @Roberto Or a slightly cleaner solution would be to keep your same script and just have the service depend on the rb5-net-check.service that is already enabled by default if you're running PX4:
                          [Unit]
                          After=rb5-net-check.service
                          [Service]
                          [Install]
                            [Unit]
                            [Service]
                            [Install]
                            RobertoR Offline
                            RobertoR Offline
                            Roberto
                            #15
                            FINALLY SOLVED: Thanks to @tom
                            (added chmod and complete procedure for other users)
                            vi /usr/bin/rb5-wifi-static-ip.sh
                            Content of rb5-wifi-static-ip.sh script (with sample IP):
                            #!/bin/bash
                            rb5_net='192.168'
                            drone_IP='192.168.178.201'
                            router_IP='192.168.178.1'
                            netmask_IP='255.255.255.0'
                            network_interface='wlan0'
                            # wait for wlan to get it's initial IP from router
                            rb5-net-check $network_interface $rb5_net
                            # set new IP
                            sudo ifconfig $network_interface $drone_IP netmask $netmask_IP
                            sudo route add default gw $router_IP $network_interface
                            1. Give permission to script (if not, will give you message "Permission denied"):
                            chmod u+x /usr/bin/rb5-wifi-static-ip.sh
                            vi /etc/systemd/system/rb5-wifi-static-ip.service
                            Content of rb5-wifi-static-ip.service file:
                            [Unit]
                            [Service]
                            [Install]
                            1. Enable this service when RB5 boots:
                            systemctl enable rb5-wifi-static-ip.service
                            Restart RB5 and you will have a static IP!
                            Roberto Calvi
                              @Roberto Thanks for your patience with this, I will make sure this script / service makes it into our next SDK release as well.
                              • M Offline
                                M Offline
                                mrawding
                                If anyone else is interested - I found a way to enable static ip's for ethernet and wlan interfaces.
                                You'll need to install a file like below under /etc/systemd/systetem/ and run the following commands:
                                systemctl enable ipconfig.service
                                systemctl disable dhcpcd.service
                                [Unit]
                                Description=A description for your custom service goes here
                                Requires=systemd-networkd.service
                                After=systemd-networkd-wait-online.service
                                [Service]
                                Type=simple
                                ExecStartPre=/bin/sleep 10
                                ExecStart=/bin/systemctl restart systemd-networkd.service
                                [Install]
                                You'll also need to add this file under /etc/systemd/network/wlan0.network
                                [Match]
                                Name=wlan0
                                [Network]
                                Address=192.168.0.169/24
                                #DHCP=yes
                                Simply installing this service will allow most routers to keep the rb5 address the same when assigning IPs for a lease. Just comment #Address and uncomment DHCP to use dhcp.
                                You will also need to make sure to add the gatway to the routing table:
                                this is best to be configured as a oneshot service where the service has the field Requires=ipconfig.service
