  3. Pinout Description of Image Sensor 4k High-resolution for VOXL (MSU-M0024)
19 Posts 3 Posters 3.3k Views 1 Watching
  • Hung PhamH Offline
    Hung PhamH Offline
    Hung Pham
    wrote on last edited by Hung Pham
    I dont see description of connector J1
    Please share to me description and type of connector J1
    alt text
    Thank you!!
    VinnyV 1 Reply Last reply
    • Hung PhamH Hung Pham
      alt text
      Thank you!!
      VinnyV Offline
      VinnyV Offline
      Vinny
      wrote on last edited by Vinny
      Hi @Hung-Pham
      Here is a generic link for it:
      https://octopart.com/search?q=AXT436124¤cy=USD&specs=0
      They are hard to get so we sell these and the mates if you need them for your designs.
      https://www.modalai.com/collections/oem-components/products/oem-axt336124
      https://www.modalai.com/collections/oem-components/products/oem-axt436124
      Please note we are starting to design this connector out of our ecosystem on future products as it has been hard to source reliably, but we will continue to support existing designs or customers that have designed it in.
      Hope this helps.
      ModeratorM 1 Reply Last reply
      • VinnyV Vinny
        Hi @Hung-Pham
        Hope this helps.
        As @Vinny points out, this module is not recommended for new designs
        We definitely recommend looking into the modules that use micro-coax, like those found at https://modalai.com/m0173
          Hung PhamH Offline
          Hung Pham
          Thank you @Moderator and @Vinny
          I have some question:
          1. Can you send me the power consumption of the camera?
          2. Logic level voltage of pin CAM0_RST0_N?
          3. Where can I find detailed documentation for the camera?
          Thank you for your support!
            VinnyV Offline
            VinnyV Offline
            Vinny
            Hi @Hung-Pham
              M0024 is an IMX214:
              All signals on our camera ports are 1.8V CMOS. We explain that here: https://docs.modalai.com/voxl2-connectors/#connector-callouts
              What else are you looking for? This may help: https://docs.modalai.com/image-sensors/
            Hung PhamH 2 Replies Last reply
            • VinnyV Vinny
              Hi @Hung-Pham
                M0024 is an IMX214:
              Hung PhamH Offline
              Hung PhamH Offline
              Hung Pham
              Hi @Vinny
              Thank you for your information.
              • VinnyV Vinny
                Hi @Hung-Pham
                  M0024 is an IMX214:
                Hung PhamH Offline
                Hung PhamH Offline
                Hung Pham
                @Vinny Hi Vinny,
                Can I use to CSI 2 Lane for Full HD 240fps?
                Please, Let me know.
                Thank you!
                  @Vinny Hi Vinny,
                  Thank you!
                  VinnyV Offline
                  VinnyV Offline
                  Vinny
                  HI @Hung-Pham
                  Pretty sure that is not possible on a 2-Lane interface.
                  Here is my rough homemade calculator I use to determine things like that:
                  With that fast of a frame rate, you need a 4-Lane port.
                  And, running at 2.5Gbps requires VERY short flexes, likely less than 50mm.
                  So, if we run it at 2Gbps, we are still at 4 lanes and this is much more stable:
                  But, all of this is moot if the SW does not support it. We cannot offer infinite flexibility of resolutions and frame rates. Please review this section in detail to see what combination of sensors and resolution are supported: https://docs.modalai.com/camera-video/
                  Hope this helped!
                  Hung PhamH 1 Reply Last reply
                  • VinnyV Vinny
                    HI @Hung-Pham
                    Hope this helped!
                    Hung PhamH Offline
                    Hung PhamH Offline
                    Hung Pham
                    @Vinny Thank you for your information!
                      Hung PhamH Offline
                      Hung Pham
                      Hi @Vinny ,
                      I have a problem with sensor IMX-412, part number M0107.
                      I am connect camera M0107 sensor IMX412 with RB5 SoM and it not detect I2C of camera.
                      Can you help me?
                      Please. Tell me know, should I connect pin MCLK0_BUFF, CAM_FLASH, CAM_SYNC_0 on the SoM RB5
                      Hope good news from you!
                      Thank you!
                        Hi @Vinny ,
                        Can you help me?
                        Thank you!
                        VinnyV Offline
                        VinnyV Offline
                        Vinny
                        Hi @Hung-Pham
                        Can you please share more details of your setup?
                        Pictures, hardware components, and other relevant configuration will help along with versions of all your SW using "voxl-version". From there we can see if I can help, or I need to pull in someone from SW team.
                        Are you using ModalAI based RB5 platform? We do not maintain third party support of other RB5 platforms.
                        As a reminder, here are our supported camera configs: https://docs.modalai.com/voxl2-supported-architectures/
                        • VinnyV Vinny
                          Hi @Hung-Pham
                          Hung PhamH Offline
                          Hung PhamH Offline
                          Hung Pham
                          @Vinny ,
                          And I have any question:
                          • what is the frequency of pin CAM_MCLK0_BUFF?
                          • Can I change the frequency of pin CAM_MCLK0_BUFF?
                          Thank you!
                            @Vinny ,
                            Thank you!
                            VinnyV Offline
                            VinnyV Offline
                            Vinny
                            @Hung-Pham said in Pinout Description of Image Sensor 4k High-resolution for VOXL (MSU-M0024):
                            Thank you!
                            Most MCLKs are 24MHz.
                            No, unless you build the kernel on your own. It is not something we will be able to do by default. However, a few customers have contracted with us to do custom driver work.
                              Hung PhamH Offline
                              Hung Pham
                              Hi @Vinny ,
                              Have a nice day!
                              I have a problem. My customer want to know specs of sensor MSU-M0107 as: sensor address, EEPROM address,... You can see exam in the image attached below
                              Thank you!
                                Hi @Vinny ,
                                Have a nice day!
                                Thank you!
                                VinnyV Offline
                                VinnyV Offline
                                Vinny
                                Hi @Hung-Pham
                                None of our image sensors have an EEPROM on them.
                                However, the I2C device address of the IMX412 on M0107 is 0x1Ah
                                Hope this helps!
                                Vinny
                                • VinnyV Vinny
                                  Hi @Hung-Pham
                                  Hope this helps!
                                  Vinny
                                  Hung PhamH Offline
                                  Hung PhamH Offline
                                  Hung Pham
                                  @Vinny
                                  All information clear!
                                  • VinnyV Vinny
                                    Hi @Hung-Pham
                                    Hope this helps!
                                    Vinny
                                    Hung PhamH Offline
                                    Hung PhamH Offline
                                    Hung Pham
                                    @Vinny
                                    Hello Vinny,
                                    Can you give me the operating temperature of module IMX412
                                    https://www.modalai.com/products/msu-m0107?variant=45747768557872
                                    Thank you!
                                      @Vinny
                                      Hello Vinny,
                                      Thank you!
                                      VinnyV Offline
                                      VinnyV Offline
                                      Vinny
                                      Hi @Hung-Pham
                                      All of our products are 0-70C, unless we state otherwise.
                                      Vinny
                                      • VinnyV Vinny
                                        Hi @Hung-Pham
                                        Vinny
                                        Hung PhamH Offline
                                        Hung PhamH Offline
                                        Hung Pham
                                        @Vinny
                                        As per the parameters you provided, this sensor cannot operate at temperatures below 0 degrees Celsius.
                                        Thank you!
