  3. Pinout Description of Image Sensor 4k High-resolution for VOXL (MSU-M0024)
19 Posts 3 Posters 3.3k Views 1 Watching
  • Hung PhamH Hung Pham
    @Vinny Hi Vinny,
    Can I use to CSI 2 Lane for Full HD 240fps?
    Please, Let me know.
    Thank you!
    HI @Hung-Pham
    Pretty sure that is not possible on a 2-Lane interface.
    Here is my rough homemade calculator I use to determine things like that:
    With that fast of a frame rate, you need a 4-Lane port.
    And, running at 2.5Gbps requires VERY short flexes, likely less than 50mm.
    So, if we run it at 2Gbps, we are still at 4 lanes and this is much more stable:
    But, all of this is moot if the SW does not support it. We cannot offer infinite flexibility of resolutions and frame rates. Please review this section in detail to see what combination of sensors and resolution are supported: https://docs.modalai.com/camera-video/
    Hope this helped!
    Hung PhamH 1 Reply Last reply
    • VinnyV Vinny
      HI @Hung-Pham
      Hope this helped!
      Hung PhamH Offline
      Hung PhamH Offline
      Hung Pham
      @Vinny Thank you for your information!
      • Hung PhamH Offline
        Hung PhamH Offline
        Hung Pham
        Hi @Vinny ,
        I have a problem with sensor IMX-412, part number M0107.
        I am connect camera M0107 sensor IMX412 with RB5 SoM and it not detect I2C of camera.
        Can you help me?
        Please. Tell me know, should I connect pin MCLK0_BUFF, CAM_FLASH, CAM_SYNC_0 on the SoM RB5
        Hope good news from you!
        Thank you!
        VinnyV 1 Reply Last reply
          Hi @Vinny ,
          Can you help me?
          Thank you!
          Hi @Hung-Pham
          Can you please share more details of your setup?
          Pictures, hardware components, and other relevant configuration will help along with versions of all your SW using "voxl-version". From there we can see if I can help, or I need to pull in someone from SW team.
          Are you using ModalAI based RB5 platform? We do not maintain third party support of other RB5 platforms.
          As a reminder, here are our supported camera configs: https://docs.modalai.com/voxl2-supported-architectures/
          • VinnyV Vinny
            Hi @Hung-Pham
            Hung PhamH Offline
            Hung PhamH Offline
            Hung Pham
            @Vinny ,
            Thank you for your information.
            And I have any question:
            • what is the frequency of pin CAM_MCLK0_BUFF?
            • Can I change the frequency of pin CAM_MCLK0_BUFF?
            Thank you!
              @Vinny ,
              Thank you!
              @Hung-Pham said in Pinout Description of Image Sensor 4k High-resolution for VOXL (MSU-M0024):
              Thank you!
              Most MCLKs are 24MHz.
              No, unless you build the kernel on your own. It is not something we will be able to do by default. However, a few customers have contracted with us to do custom driver work.
                Hung PhamH Offline
                Hung Pham
                Hi @Vinny ,
                Have a nice day!
                I have a problem. My customer want to know specs of sensor MSU-M0107 as: sensor address, EEPROM address,... You can see exam in the image attached below
                Thank you!
                  Hi @Vinny ,
                  Have a nice day!
                  Thank you!
                  Hi @Hung-Pham
                  None of our image sensors have an EEPROM on them.
                  However, the I2C device address of the IMX412 on M0107 is 0x1Ah
                  Hope this helps!
                  Hung PhamH 2 Replies Last reply
                  • VinnyV Vinny
                    Hi @Hung-Pham
                    Hope this helps!
                    Hung PhamH Offline
                    Hung PhamH Offline
                    Hung Pham
                    @Vinny
                    All information clear!
                    • VinnyV Vinny
                      Hi @Hung-Pham
                      Hope this helps!
                      Hung PhamH Offline
                      Hung PhamH Offline
                      Hung Pham
                      @Vinny
                      Hello Vinny,
                      Can you give me the operating temperature of module IMX412
                      https://www.modalai.com/products/msu-m0107?variant=45747768557872
                      Thank you!
                        @Vinny
                        Hello Vinny,
                        Thank you!
                        Hi @Hung-Pham
                        All of our products are 0-70C, unless we state otherwise.
                        • VinnyV Vinny
                          Hi @Hung-Pham
                          Hung PhamH Offline
                          Hung PhamH Offline
                          Hung Pham
                          @Vinny
                          As per the parameters you provided, this sensor cannot operate at temperatures below 0 degrees Celsius.
                          Thank you!
