  3. Pinout Description of Image Sensor 4k High-resolution for VOXL (MSU-M0024)
19 Posts 3 Posters 3.2k Views 1 Watching
  • Hung PhamH Offline
    Hung PhamH Offline
    Hung Pham
    Hi @Vinny ,
    I have a problem with sensor IMX-412, part number M0107.
    I am connect camera M0107 sensor IMX412 with RB5 SoM and it not detect I2C of camera.
    Can you help me?
    Please. Tell me know, should I connect pin MCLK0_BUFF, CAM_FLASH, CAM_SYNC_0 on the SoM RB5
    Hope good news from you!
    Thank you!
    VinnyV 1 Reply Last reply
    • Hung PhamH Hung Pham
      Hi @Vinny ,
      Can you help me?
      Thank you!
      Hi @Hung-Pham
      Can you please share more details of your setup?
      Pictures, hardware components, and other relevant configuration will help along with versions of all your SW using "voxl-version". From there we can see if I can help, or I need to pull in someone from SW team.
      Are you using ModalAI based RB5 platform? We do not maintain third party support of other RB5 platforms.
      As a reminder, here are our supported camera configs: https://docs.modalai.com/voxl2-supported-architectures/
      Hung PhamH 1 Reply Last reply
      • VinnyV Vinny
        Hi @Hung-Pham
        Hung PhamH Offline
        Hung PhamH Offline
        Hung Pham
        @Vinny ,
        Thank you for your information.
        And I have any question:
        • what is the frequency of pin CAM_MCLK0_BUFF?
        • Can I change the frequency of pin CAM_MCLK0_BUFF?
        Thank you!
          @Vinny ,
          Thank you!
          @Hung-Pham said in Pinout Description of Image Sensor 4k High-resolution for VOXL (MSU-M0024):
          Thank you!
          Most MCLKs are 24MHz.
          No, unless you build the kernel on your own. It is not something we will be able to do by default. However, a few customers have contracted with us to do custom driver work.
            Hung PhamH Offline
            Hung Pham
            Hi @Vinny ,
            Have a nice day!
            I have a problem. My customer want to know specs of sensor MSU-M0107 as: sensor address, EEPROM address,... You can see exam in the image attached below
            Thank you!
              Hi @Vinny ,
              Have a nice day!
              Thank you!
              Hi @Hung-Pham
              None of our image sensors have an EEPROM on them.
              However, the I2C device address of the IMX412 on M0107 is 0x1Ah
              Hope this helps!
              Hung PhamH 2 Replies Last reply
              • VinnyV Vinny
                Hi @Hung-Pham
                Hope this helps!
                Hung PhamH Offline
                Hung PhamH Offline
                Hung Pham
                @Vinny
                Thank you for your information!
                All information clear!
                • VinnyV Vinny
                  Hi @Hung-Pham
                  Hope this helps!
                  Hung PhamH Offline
                  Hung PhamH Offline
                  Hung Pham
                  @Vinny
                  Hello Vinny,
                  Can you give me the operating temperature of module IMX412
                  https://www.modalai.com/products/msu-m0107?variant=45747768557872
                  Thank you!
                    @Vinny
                    Hello Vinny,
                    Thank you!
                    Hi @Hung-Pham
                    All of our products are 0-70C, unless we state otherwise.
                    • VinnyV Vinny
                      Hi @Hung-Pham
                      Hung PhamH Offline
                      Hung PhamH Offline
                      Hung Pham
                      @Vinny
                      As per the parameters you provided, this sensor cannot operate at temperatures below 0 degrees Celsius.
                      Thank you!
