  3. Drone losing position / crashing in Offboard mode
vio
35 Posts 2 Posters 8.9k Views 1 Watching
  • Jetson NanoJ Jetson Nano
    @Eric-Katzfey This is what I am getting when I run vision hub with debug
    voxl_visionion-hub -d
    Enabling recv debugging for localhost UDP port from ROS
    loading our own config file
    config_file_version:        1
    MAVROS / MAVSDK
    en_localhost_mavlink_udp    0
    localhost_udp_port_number:  14551
    VIO
    en_vio:                     1
    vio_pipe:                   qvio
    secondary_vio_pipe:         ov
    en_reset_vio_if_initialized_inverted: 1
    vio_warmup_s:               3.000000
    send_odom_while_failed:     1
    MISC FEATURES
    horizon_cal_tolerance:      0.500000
    OFFBOARD MODE
    offboard_mode:              trajectory
    follow_tag_id:              0
    figure_eight_move_home:     1
    robot_radius:               0.300000
    collision_sampling_dt:      0.100000
    max_lookahead_distance:     1.000000
    FIXED FRAME RELOCALIZATION
    en_tag_fixed_frame:         0
    fixed_frame_filter_len:     5
    COLLISION PREVENTION (VOA)
    en_voa:                     1
    voa_upper_bound_m:          -0.150000
    voa_lower_bound_m:          0.150000
    voa_memory_s:               1.000000
    voa_max_pc_per_fusion:      100
    voa_pie_min_dist_m:         0.250000
    voa_pie_max_dist_m:         20.000000
    voa_pie_under_trim_m:       1.000000
    voa_pie_threshold:          3
    voa_pie_slices:             36
    voa_pie_bin_depth_m:        0.150000
    voa_send_rate_hz:           20.000000
    voa_input #0
        enabled:            1
        type:               point_cloud
        input_pipe:         dfs_point_cloud
        frame:              stereo_l
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        x_fov_deg:          68.000000
        y_fov_deg:          56.000000
        conf_cutoff:        0
    voa_input #1
        enabled:            1
        type:               point_cloud
        input_pipe:         stereo_front_pc
        frame:              stereo_front_l
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    voa_input #2
        enabled:            1
        type:               point_cloud
        input_pipe:         stereo_rear_pc
        frame:              stereo_rear_l
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    voa_input #3
        enabled:            1
        type:               tof
        input_pipe:         tof
        frame:              tof
        max_depth:          6.000000
        min_depth:          0.150000
        cell_size:          0.080000
        threshold:          3
        x_fov_deg:          106.500000
        y_fov_deg:          85.099998
        conf_cutoff:        125
    voa_input #4
        enabled:            1
        type:               rangefinder
        input_pipe:         rangefinders
        frame:              body
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    loading extrinsics config file
    loading horizon cal file
    existing instance of voxl-vision-hub found, attempting to stop it
    starting geometry module
    starting autopilot monitor
    starting mavlink IO
    Waiting to connect to voxl-mavlink-server
    Connected to voxl-mavlink-server
    starting fixed pose input
    starting vio manager
    Connected to VIO pipe: qvio
    Geometry module updating to use imu: imu_apps for VIO
    new T imu wrt body:
     0.0907  -0.0060  -0.0295
    new R imu to body:
     1.0000  -0.0000   0.0000
     0.0000   1.0000  -0.0000
     0.0000   0.0000   1.0000
    done updating transforms to use imu: imu_apps
    from AP msgid:  30 sysid:  1 compid:  1
    Detected Autopilot Mavlink SYSID 1
    starting tag manager
    starting voa manager
    starting horizon cal module
    Connected to VOA input pipe: tof
    starting offboard trajectory
    Init complete
    Trajectory Monitor connected to voa pointcloud
    from AP msgid:   0 sysid:  1 compid:  1
    requesting autopilot_version
    from AP msgid: 148 sysid:  1 compid:  1
    Detected autopilot version: 1.14.0
    from AP msgid:  77 sysid:  1 compid:  1
    from AP msgid:  31 sysid:  1 compid:  1
    from AP msgid: 253 sysid:  1 compid:  1
    from AP msgid: 410 sysid:  1 compid:  1
    from AP msgid:  83 sysid:  1 compid:  1
    from AP msgid:  74 sysid:  1 compid:  1
    from AP msgid: 147 sysid:  1 compid:  1
    from AP msgid: 230 sysid:  1 compid:  1
    from AP msgid:  42 sysid:  1 compid:  1
    from AP msgid: 411 sysid:  1 compid:  1
    from AP msgid: 141 sysid:  1 compid:  1
    from AP msgid: 245 sysid:  1 compid:  1
    from AP msgid:  32 sysid:  1 compid:  1
    from AP msgid: 12901 sysid:  1 compid:  1
    from AP msgid:  29 sysid:  1 compid:  1
    from AP msgid:  36 sysid:  1 compid:  1
    from AP msgid:   1 sysid:  1 compid:  1
    from AP msgid: 380 sysid:  1 compid:  1
    from AP msgid:   8 sysid:  1 compid:  1
    from AP msgid:   4 sysid:  1 compid:  1
    from AP msgid:  85 sysid:  1 compid:  1
    Jetson NanoJ Offline
    Jetson Nano
    Veteran
    #21
    @Eric-Katzfey when I do
    voxl-inspect-mavlink mavlink_onboard
    I am getting
    and in mavlink console when I stream Odometry message as you said I am getting no output
    when I used -d instead of -u it shows device not running. I tried with different ports
      I am getting
      Jetson Nano
      Veteran
      Hey @Eric-Katzfey , I think I solved it. I got the odometry stream to VOXL2 from Cube. I had to run
      mavlink stream -r 30 -s ODOMETRY -d /dev/ttyS0
      after this I got odometry stream on the
        @Jetson-Nano Great! And is that now allowing you to run the figure 8?
          Jetson Nano
          Veteran
          @Eric-Katzfey I haven't done the flight test. I'll do the flight test and get back to you.
            Jetson Nano
            Veteran
            @Eric-Katzfey , I did the flight test and it works fine. Thank you.
            But there is a problem, when I am checked 1st time it worked fine, later after a reboot and once again I ran the Mavlink Odometry stream, the terminal was lagging. The terminal with the output of voxl-inspect-mavlink mavlink_onboard this is lagging. The Odometry Hz was somewhere around 5 - 10, all the output in the terminal was lagging, so I though it was some WiFi issue and again tested offboard mode, but this time the drone went back to home.
            So I rebooted the system and again ran the mavlink stream and waited for sometime until the lag in the voxl terminal is not there anymore, then when I tested offboard it was fine. I tried both figure eight and trajectory, both worked fine. I will attach the logs, can you please tell what might have caused the lag?
            https://logs.px4.io/plot_app?log=93fb987f-c326-4d5d-89bb-2771bcacb3fc
            https://logs.px4.io/plot_app?log=593bdb7b-7ce5-45f5-b183-2d0914015162
            https://logs.px4.io/plot_app?log=3d8e8bd4-ec6e-4bcf-beea-741dff891ff9
            https://logs.px4.io/plot_app?log=d33b6610-af39-4006-b90e-d1fdaad75da7
            https://logs.px4.io/plot_app?log=b1ac6a04-0e1a-4049-bc27-dfe9a25224a8
              Jetson Nano
              Veteran
              And I have one more question @Eric-Katzfey , I have to start the mavlink stream everytime. Is there a way to start the mavlink stream as soon the system is powered on?
                @Jetson-Nano Yes, there is a way to do that. Probably best to consult the PX4 documentation or ask on the PX4 forum for best way to do that on a Cube Orange.
                  Jetson Nano
                  Veteran
                  @Eric-Katzfey What about the previous question I asked?
                    @Jetson-Nano I really don't know what would cause that lag. You say it goes away if you wait awhile. How long do you have to wait for that to happen? And what is the baud rate of the UART that connects the CUBE Orange to VOXL 2? It's possible that the UART has too much data going over it and needs a higher baudrate.
                      Jetson Nano
                      Veteran
                      @Eric-Katzfey The baudrate is 921600, sometimes I'll have to wait for more than 5 minutes and sometimes within seconds it will be ready to fly with required Hz
                        @Jetson-Nano Part of the startup sequence when running with QGC or MP is to upload a full set of parameters. There are hundreds of parameters and this can take quite a while to complete. While this is happening the serial link is inundated with PARAM_VALUE mavlink messages. Once that has been completed then the link will have much less traffic. While it is laggy you can look at the mavlink console and see if it is receiving those PARAM_VALUE messages. That is a possible reason.
                        • Jetson NanoJ Jetson Nano referenced this topic on
                          Jetson Nano
                          Veteran
                          #32
                          @Eric-Katzfey I'm currently integrating VOXL2 with Flight Core V2.
                          PX4 version: v1.14.3 (from modalAI fork)
                          I am trying to use offboard mode and do figure-eight, but the problem I'm facing is, whenever I switch to offboard, the drone sometimes moves randomly.
                          Once I reboot the FC once and start flying from same position, and then switching to offboard, I observe that the drone does figure 8, but loses height sequentially and drifts over the ground and crashes after a few cycles.
                          For height estimation, I rely on using a Rangefinder.
                          Also, when I run,
                          I'm not able to observe, the #331 ODOMETRY message.
                            Also, when I run,
                            @Jetson-Nano What happens if you don't use the rangefinder? If VIO is working then you get the height from that.
                              Jetson Nano
                              Veteran
                              @Eric-Katzfey Thanks for reverting back.
                              I had tried earlier disabling the Rangefinder and relying only on VIO.
                              VIO works fine in feature rich environment, when it crosses low-feature environment, there is a random motion of system which could observed serving the main reason for using external Rangefinder.
                              Also, height estimation goes off even if the drone does figure-eight within offboard, height estimation goes off.
                              Is there any way I can view the #331 ODOMETRY message being pushed from FC to Compute?
                                Jetson Nano
                                Veteran
                                #35
                                Hey @Eric-Katzfey I was able to solve it. I was able to shift the drone to offboard-mode, the drone doesn't drift away. In voxl-vision-hub, I have the set the parameter to figure_eight.
                                I'm getting the stream to VOXL2 from Flight Core v2. I had to run it on 2 different ports.
                                mavlink stream -r 30 -s ODOMETRY -d /dev/ttyS4
                                mavlink stream -r 30 -s ODOMETRY -d /dev/ttyS6
                                But I'm getting the #331 odometry message when using only ttyS6 port.
                                Now the drone is able to figure_eight loop without loosing height estimates.
