  3. Drone losing position / crashing in Offboard mode
vio
35 Posts 2 Posters 9.0k Views 1 Watching
    @Jetson-Nano The command would be something like mavlink stream -r 30 -s ODOMETRY -u 14556 and would be added to one of the startup files.
    Jetson NanoJ Offline
    Jetson Nano
    Veteran
    @Eric-Katzfey The documentation explains how to send custom mavlink messages, but odometry is not a custom message and isn't it streamed by default in your forked PX4?
    • Jetson NanoJ Jetson Nano
      @Jetson-Nano The command is the same regardless of whether the message is custom or not. Another thing you can do is enable some of the debug flags available with voxl-vision-hub to see things like which mavlink messages it is receiving and which mavlink messages it is sending out. There are a variety of flags to choose from and that would help to figure out what is going wrong.
        Jetson Nano
        Veteran
        @Eric-Katzfey This is what I am getting when I run vision hub with debug
        voxl_visionion-hub -d
        Enabling recv debugging for localhost UDP port from ROS
        loading our own config file
        config_file_version:        1
        MAVROS / MAVSDK
        en_localhost_mavlink_udp    0
        VIO
        en_vio:                     1
        vio_pipe:                   qvio
        secondary_vio_pipe:         ov
        vio_warmup_s:               3.000000
        send_odom_while_failed:     1
        MISC FEATURES
        horizon_cal_tolerance:      0.500000
        OFFBOARD MODE
        offboard_mode:              trajectory
        follow_tag_id:              0
        figure_eight_move_home:     1
        robot_radius:               0.300000
        collision_sampling_dt:      0.100000
        max_lookahead_distance:     1.000000
        FIXED FRAME RELOCALIZATION
        en_tag_fixed_frame:         0
        fixed_frame_filter_len:     5
        COLLISION PREVENTION (VOA)
        en_voa:                     1
        voa_upper_bound_m:          -0.150000
        voa_lower_bound_m:          0.150000
        voa_memory_s:               1.000000
        voa_max_pc_per_fusion:      100
        voa_pie_min_dist_m:         0.250000
        voa_pie_max_dist_m:         20.000000
        voa_pie_under_trim_m:       1.000000
        voa_pie_threshold:          3
        voa_pie_slices:             36
        voa_pie_bin_depth_m:        0.150000
        voa_send_rate_hz:           20.000000
        voa_input #0
            enabled:            1
            type:               point_cloud
            input_pipe:         dfs_point_cloud
            frame:              stereo_l
            max_depth:          8.000000
            min_depth:          0.300000
            cell_size:          0.080000
            threshold:          4
            x_fov_deg:          68.000000
            y_fov_deg:          56.000000
            conf_cutoff:        0
        voa_input #1
            enabled:            1
            type:               point_cloud
            input_pipe:         stereo_front_pc
            frame:              stereo_front_l
            max_depth:          8.000000
            min_depth:          0.300000
            cell_size:          0.080000
            threshold:          4
            conf_cutoff:        0
        voa_input #2
            enabled:            1
            type:               point_cloud
            input_pipe:         stereo_rear_pc
            frame:              stereo_rear_l
            max_depth:          8.000000
            min_depth:          0.300000
            cell_size:          0.080000
            threshold:          4
            conf_cutoff:        0
        voa_input #3
            enabled:            1
            type:               tof
            input_pipe:         tof
            frame:              tof
            max_depth:          6.000000
            min_depth:          0.150000
            cell_size:          0.080000
            threshold:          3
            x_fov_deg:          106.500000
            y_fov_deg:          85.099998
            conf_cutoff:        125
        voa_input #4
            enabled:            1
            type:               rangefinder
            input_pipe:         rangefinders
            frame:              body
            max_depth:          8.000000
            min_depth:          0.300000
            cell_size:          0.080000
            threshold:          4
            conf_cutoff:        0
        loading horizon cal file
        existing instance of voxl-vision-hub found, attempting to stop it
        starting geometry module
        starting autopilot monitor
        starting mavlink IO
        Waiting to connect to voxl-mavlink-server
        starting fixed pose input
        starting vio manager
        Connected to VIO pipe: qvio
        Geometry module updating to use imu: imu_apps for VIO
        new T imu wrt body:
         0.0907  -0.0060  -0.0295
        new R imu to body:
         1.0000  -0.0000   0.0000
         0.0000   1.0000  -0.0000
         0.0000   0.0000   1.0000
        done updating transforms to use imu: imu_apps
        from AP msgid:  30 sysid:  1 compid:  1
        Detected Autopilot Mavlink SYSID 1
        starting tag manager
        starting voa manager
        starting horizon cal module
        Connected to VOA input pipe: tof
        starting offboard trajectory
        Init complete
        Trajectory Monitor connected to voa pointcloud
        from AP msgid:   0 sysid:  1 compid:  1
        requesting autopilot_version
        from AP msgid: 148 sysid:  1 compid:  1
        Detected autopilot version: 1.14.0
        from AP msgid:  77 sysid:  1 compid:  1
        from AP msgid:  31 sysid:  1 compid:  1
        from AP msgid: 253 sysid:  1 compid:  1
        from AP msgid: 410 sysid:  1 compid:  1
        from AP msgid:  83 sysid:  1 compid:  1
        from AP msgid:  74 sysid:  1 compid:  1
        from AP msgid: 147 sysid:  1 compid:  1
        from AP msgid: 230 sysid:  1 compid:  1
        from AP msgid:  42 sysid:  1 compid:  1
        from AP msgid: 411 sysid:  1 compid:  1
        from AP msgid: 141 sysid:  1 compid:  1
        from AP msgid: 245 sysid:  1 compid:  1
        from AP msgid:  32 sysid:  1 compid:  1
        from AP msgid: 12901 sysid:  1 compid:  1
        from AP msgid:  29 sysid:  1 compid:  1
        from AP msgid:  36 sysid:  1 compid:  1
        from AP msgid:   1 sysid:  1 compid:  1
        from AP msgid: 380 sysid:  1 compid:  1
        from AP msgid:   8 sysid:  1 compid:  1
        from AP msgid:   4 sysid:  1 compid:  1
        from AP msgid:  85 sysid:  1 compid:  1
          MAVROS / MAVSDK
          VIO
          en_vio:                     1
          vio_pipe:                   qvio
          MISC FEATURES
          OFFBOARD MODE
          follow_tag_id:              0
          en_voa:                     1
          voa_pie_slices:             36
          voa_input #0
              enabled:            1
              type:               point_cloud
              frame:              stereo_l
              max_depth:          8.000000
              min_depth:          0.300000
              cell_size:          0.080000
              threshold:          4
              conf_cutoff:        0
          voa_input #1
              enabled:            1
              type:               point_cloud
              max_depth:          8.000000
              min_depth:          0.300000
              cell_size:          0.080000
              threshold:          4
              conf_cutoff:        0
          voa_input #2
              enabled:            1
              type:               point_cloud
              max_depth:          8.000000
              min_depth:          0.300000
              cell_size:          0.080000
              threshold:          4
              conf_cutoff:        0
          voa_input #3
              enabled:            1
              type:               tof
              input_pipe:         tof
              frame:              tof
              max_depth:          6.000000
              min_depth:          0.150000
              cell_size:          0.080000
              threshold:          3
              conf_cutoff:        125
          voa_input #4
              enabled:            1
              type:               rangefinder
              frame:              body
              max_depth:          8.000000
              min_depth:          0.300000
              cell_size:          0.080000
              threshold:          4
              conf_cutoff:        0
          starting mavlink IO
          new T imu wrt body:
          new R imu to body:
          Init complete
          Jetson Nano
          Veteran
          #21
          @Eric-Katzfey when I do
          voxl-inspect-mavlink mavlink_onboard
          I am getting
          and in mavlink console when I stream Odometry message as you said I am getting no output
          when I used -d instead of -u it shows device not running. I tried with different ports
            I am getting
            Jetson Nano
            Veteran
            Hey @Eric-Katzfey , I think I solved it. I got the odometry stream to VOXL2 from Cube. I had to run
            mavlink stream -r 30 -s ODOMETRY -d /dev/ttyS0
            after this I got odometry stream on the
              @Jetson-Nano Great! And is that now allowing you to run the figure 8?
                Jetson Nano
                Veteran
                @Eric-Katzfey I haven't done the flight test. I'll do the flight test and get back to you.
                  Jetson Nano
                  Veteran
                  @Eric-Katzfey , I did the flight test and it works fine. Thank you.
                  But there is a problem, when I am checked 1st time it worked fine, later after a reboot and once again I ran the Mavlink Odometry stream, the terminal was lagging. The terminal with the output of voxl-inspect-mavlink mavlink_onboard this is lagging. The Odometry Hz was somewhere around 5 - 10, all the output in the terminal was lagging, so I though it was some WiFi issue and again tested offboard mode, but this time the drone went back to home.
                  So I rebooted the system and again ran the mavlink stream and waited for sometime until the lag in the voxl terminal is not there anymore, then when I tested offboard it was fine. I tried both figure eight and trajectory, both worked fine. I will attach the logs, can you please tell what might have caused the lag?
                  https://logs.px4.io/plot_app?log=93fb987f-c326-4d5d-89bb-2771bcacb3fc
                  https://logs.px4.io/plot_app?log=593bdb7b-7ce5-45f5-b183-2d0914015162
                  https://logs.px4.io/plot_app?log=3d8e8bd4-ec6e-4bcf-beea-741dff891ff9
                  https://logs.px4.io/plot_app?log=d33b6610-af39-4006-b90e-d1fdaad75da7
                  https://logs.px4.io/plot_app?log=b1ac6a04-0e1a-4049-bc27-dfe9a25224a8
                    Jetson Nano
                    Veteran
                    And I have one more question @Eric-Katzfey , I have to start the mavlink stream everytime. Is there a way to start the mavlink stream as soon the system is powered on?
                      @Jetson-Nano Yes, there is a way to do that. Probably best to consult the PX4 documentation or ask on the PX4 forum for best way to do that on a Cube Orange.
                        Jetson Nano
                        Veteran
                        @Eric-Katzfey What about the previous question I asked?
                          @Jetson-Nano I really don't know what would cause that lag. You say it goes away if you wait awhile. How long do you have to wait for that to happen? And what is the baud rate of the UART that connects the CUBE Orange to VOXL 2? It's possible that the UART has too much data going over it and needs a higher baudrate.
                            Jetson Nano
                            Veteran
                            @Eric-Katzfey The baudrate is 921600, sometimes I'll have to wait for more than 5 minutes and sometimes within seconds it will be ready to fly with required Hz
                              @Jetson-Nano Part of the startup sequence when running with QGC or MP is to upload a full set of parameters. There are hundreds of parameters and this can take quite a while to complete. While this is happening the serial link is inundated with PARAM_VALUE mavlink messages. Once that has been completed then the link will have much less traffic. While it is laggy you can look at the mavlink console and see if it is receiving those PARAM_VALUE messages. That is a possible reason.
                              • Jetson NanoJ Jetson Nano referenced this topic on
                                Jetson Nano
                                Veteran
                                #32
                                @Eric-Katzfey I'm currently integrating VOXL2 with Flight Core V2.
                                PX4 version: v1.14.3 (from modalAI fork)
                                I am trying to use offboard mode and do figure-eight, but the problem I'm facing is, whenever I switch to offboard, the drone sometimes moves randomly.
                                Once I reboot the FC once and start flying from same position, and then switching to offboard, I observe that the drone does figure 8, but loses height sequentially and drifts over the ground and crashes after a few cycles.
                                For height estimation, I rely on using a Rangefinder.
                                Also, when I run,
                                I'm not able to observe, the #331 ODOMETRY message.
                                  Also, when I run,
                                  @Jetson-Nano What happens if you don't use the rangefinder? If VIO is working then you get the height from that.
                                    Jetson Nano
                                    Veteran
                                    @Eric-Katzfey Thanks for reverting back.
                                    I had tried earlier disabling the Rangefinder and relying only on VIO.
                                    VIO works fine in feature rich environment, when it crosses low-feature environment, there is a random motion of system which could observed serving the main reason for using external Rangefinder.
                                    Also, height estimation goes off even if the drone does figure-eight within offboard, height estimation goes off.
                                    Is there any way I can view the #331 ODOMETRY message being pushed from FC to Compute?
                                      Jetson Nano
                                      Veteran
                                      #35
                                      Hey @Eric-Katzfey I was able to solve it. I was able to shift the drone to offboard-mode, the drone doesn't drift away. In voxl-vision-hub, I have the set the parameter to figure_eight.
                                      I'm getting the stream to VOXL2 from Flight Core v2. I had to run it on 2 different ports.
                                      mavlink stream -r 30 -s ODOMETRY -d /dev/ttyS4
                                      mavlink stream -r 30 -s ODOMETRY -d /dev/ttyS6
                                      But I'm getting the #331 odometry message when using only ttyS6 port.
                                      Now the drone is able to figure_eight loop without loosing height estimates.
