  3. Drone losing position / crashing in Offboard mode
vio
35 Posts 2 Posters 9.5k Views 1 Watching
    @Jetson-Nano Interesting. Can you share the log from that flight?
    Jetson NanoJ Offline
    Jetson Nano
    Veteran
    Hey @Eric-Katzfey, here are the logs for the flight test.
    https://review.px4.io/plot_app?log=9b6a7c2c-2bf4-43f7-8182-ac3efe2b4655
    In this flight test, I set the offboard mode to trajectory and did the flight test
    https://review.px4.io/plot_app?log=65f0b03a-11a5-409e-b2ca-1fe2a36cc088
    In this flight test, I changed the offboard mode to figure_eight and still the result is same, it goes very close to ground at 0,0,0 and hovers there.
    • Jetson NanoJ Jetson Nano
      @Jetson-Nano I'm guessing that you don't have an odometry mavlink stream setup so the Cube Orange isn't sending out vehicle odometry mavlink packets that the offboard mode needs.
        Jetson Nano
        Veteran
        @Eric-Katzfey How do I setup that?
          @Jetson-Nano I would recommend reading through the PX4 documentataion on Mavlink messaging. It discusses how to enable streams. https://docs.px4.io/v1.14/en/middleware/mavlink.html
            Jetson Nano
            Veteran
            Thank you @Eric-Katzfey , I'll check and get back if needed anything.
              @Jetson-Nano The command would be something like mavlink stream -r 30 -s ODOMETRY -u 14556 and would be added to one of the startup files.
                Jetson Nano
                Veteran
                @Eric-Katzfey The documentation explains how to send custom mavlink messages, but odometry is not a custom message and isn't it streamed by default in your forked PX4?
                  @Jetson-Nano The command is the same regardless of whether the message is custom or not. Another thing you can do is enable some of the debug flags available with voxl-vision-hub to see things like which mavlink messages it is receiving and which mavlink messages it is sending out. There are a variety of flags to choose from and that would help to figure out what is going wrong.
                    Jetson Nano
                    Veteran
                    @Eric-Katzfey This is what I am getting when I run vision hub with debug
                    voxl_visionion-hub -d
                    Enabling recv debugging for localhost UDP port from ROS
                    loading our own config file
                    config_file_version:        1
                    MAVROS / MAVSDK
                    en_localhost_mavlink_udp    0
                    VIO
                    en_vio:                     1
                    vio_pipe:                   qvio
                    secondary_vio_pipe:         ov
                    vio_warmup_s:               3.000000
                    send_odom_while_failed:     1
                    MISC FEATURES
                    horizon_cal_tolerance:      0.500000
                    OFFBOARD MODE
                    offboard_mode:              trajectory
                    follow_tag_id:              0
                    figure_eight_move_home:     1
                    robot_radius:               0.300000
                    collision_sampling_dt:      0.100000
                    max_lookahead_distance:     1.000000
                    FIXED FRAME RELOCALIZATION
                    en_tag_fixed_frame:         0
                    fixed_frame_filter_len:     5
                    COLLISION PREVENTION (VOA)
                    en_voa:                     1
                    voa_upper_bound_m:          -0.150000
                    voa_lower_bound_m:          0.150000
                    voa_memory_s:               1.000000
                    voa_max_pc_per_fusion:      100
                    voa_pie_min_dist_m:         0.250000
                    voa_pie_max_dist_m:         20.000000
                    voa_pie_under_trim_m:       1.000000
                    voa_pie_threshold:          3
                    voa_pie_slices:             36
                    voa_pie_bin_depth_m:        0.150000
                    voa_send_rate_hz:           20.000000
                    voa_input #0
                        enabled:            1
                        type:               point_cloud
                        input_pipe:         dfs_point_cloud
                        frame:              stereo_l
                        max_depth:          8.000000
                        min_depth:          0.300000
                        cell_size:          0.080000
                        threshold:          4
                        x_fov_deg:          68.000000
                        y_fov_deg:          56.000000
                        conf_cutoff:        0
                    voa_input #1
                        enabled:            1
                        type:               point_cloud
                        input_pipe:         stereo_front_pc
                        frame:              stereo_front_l
                        max_depth:          8.000000
                        min_depth:          0.300000
                        cell_size:          0.080000
                        threshold:          4
                        conf_cutoff:        0
                    voa_input #2
                        enabled:            1
                        type:               point_cloud
                        input_pipe:         stereo_rear_pc
                        frame:              stereo_rear_l
                        max_depth:          8.000000
                        min_depth:          0.300000
                        cell_size:          0.080000
                        threshold:          4
                        conf_cutoff:        0
                    voa_input #3
                        enabled:            1
                        type:               tof
                        input_pipe:         tof
                        frame:              tof
                        max_depth:          6.000000
                        min_depth:          0.150000
                        cell_size:          0.080000
                        threshold:          3
                        x_fov_deg:          106.500000
                        y_fov_deg:          85.099998
                        conf_cutoff:        125
                    voa_input #4
                        enabled:            1
                        type:               rangefinder
                        input_pipe:         rangefinders
                        frame:              body
                        max_depth:          8.000000
                        min_depth:          0.300000
                        cell_size:          0.080000
                        threshold:          4
                        conf_cutoff:        0
                    loading horizon cal file
                    existing instance of voxl-vision-hub found, attempting to stop it
                    starting geometry module
                    starting autopilot monitor
                    starting mavlink IO
                    Waiting to connect to voxl-mavlink-server
                    starting fixed pose input
                    starting vio manager
                    Connected to VIO pipe: qvio
                    Geometry module updating to use imu: imu_apps for VIO
                    new T imu wrt body:
                     0.0907  -0.0060  -0.0295
                    new R imu to body:
                     1.0000  -0.0000   0.0000
                     0.0000   1.0000  -0.0000
                     0.0000   0.0000   1.0000
                    done updating transforms to use imu: imu_apps
                    from AP msgid:  30 sysid:  1 compid:  1
                    Detected Autopilot Mavlink SYSID 1
                    starting tag manager
                    starting voa manager
                    starting horizon cal module
                    Connected to VOA input pipe: tof
                    starting offboard trajectory
                    Init complete
                    Trajectory Monitor connected to voa pointcloud
                    from AP msgid:   0 sysid:  1 compid:  1
                    requesting autopilot_version
                    from AP msgid: 148 sysid:  1 compid:  1
                    Detected autopilot version: 1.14.0
                    from AP msgid:  77 sysid:  1 compid:  1
                    from AP msgid:  31 sysid:  1 compid:  1
                    from AP msgid: 253 sysid:  1 compid:  1
                    from AP msgid: 410 sysid:  1 compid:  1
                    from AP msgid:  83 sysid:  1 compid:  1
                    from AP msgid:  74 sysid:  1 compid:  1
                    from AP msgid: 147 sysid:  1 compid:  1
                    from AP msgid: 230 sysid:  1 compid:  1
                    from AP msgid:  42 sysid:  1 compid:  1
                    from AP msgid: 411 sysid:  1 compid:  1
                    from AP msgid: 141 sysid:  1 compid:  1
                    from AP msgid: 245 sysid:  1 compid:  1
                    from AP msgid:  32 sysid:  1 compid:  1
                    from AP msgid: 12901 sysid:  1 compid:  1
                    from AP msgid:  29 sysid:  1 compid:  1
                    from AP msgid:  36 sysid:  1 compid:  1
                    from AP msgid:   1 sysid:  1 compid:  1
                    from AP msgid: 380 sysid:  1 compid:  1
                    from AP msgid:   8 sysid:  1 compid:  1
                    from AP msgid:   4 sysid:  1 compid:  1
                    from AP msgid:  85 sysid:  1 compid:  1
                      MAVROS / MAVSDK
                      VIO
                      en_vio:                     1
                      vio_pipe:                   qvio
                      MISC FEATURES
                      OFFBOARD MODE
                      follow_tag_id:              0
                      en_voa:                     1
                      voa_pie_slices:             36
                      voa_input #0
                          enabled:            1
                          type:               point_cloud
                          frame:              stereo_l
                          max_depth:          8.000000
                          min_depth:          0.300000
                          cell_size:          0.080000
                          threshold:          4
                          conf_cutoff:        0
                      voa_input #1
                          enabled:            1
                          type:               point_cloud
                          max_depth:          8.000000
                          min_depth:          0.300000
                          cell_size:          0.080000
                          threshold:          4
                          conf_cutoff:        0
                      voa_input #2
                          enabled:            1
                          type:               point_cloud
                          max_depth:          8.000000
                          min_depth:          0.300000
                          cell_size:          0.080000
                          threshold:          4
                          conf_cutoff:        0
                      voa_input #3
                          enabled:            1
                          type:               tof
                          input_pipe:         tof
                          frame:              tof
                          max_depth:          6.000000
                          min_depth:          0.150000
                          cell_size:          0.080000
                          threshold:          3
                          conf_cutoff:        125
                      voa_input #4
                          enabled:            1
                          type:               rangefinder
                          frame:              body
                          max_depth:          8.000000
                          min_depth:          0.300000
                          cell_size:          0.080000
                          threshold:          4
                          conf_cutoff:        0
                      starting mavlink IO
                      new T imu wrt body:
                      new R imu to body:
                      Init complete
                      Jetson Nano
                      Veteran
                      #21
                      @Eric-Katzfey when I do
                      voxl-inspect-mavlink mavlink_onboard
                      I am getting
                      and in mavlink console when I stream Odometry message as you said I am getting no output
                      when I used -d instead of -u it shows device not running. I tried with different ports
                        I am getting
                        Jetson Nano
                        Veteran
                        Hey @Eric-Katzfey , I think I solved it. I got the odometry stream to VOXL2 from Cube. I had to run
                        mavlink stream -r 30 -s ODOMETRY -d /dev/ttyS0
                        after this I got odometry stream on the
                          @Jetson-Nano Great! And is that now allowing you to run the figure 8?
                            Jetson Nano
                            Veteran
                            @Eric-Katzfey I haven't done the flight test. I'll do the flight test and get back to you.
                              Jetson Nano
                              Veteran
                              @Eric-Katzfey , I did the flight test and it works fine. Thank you.
                              But there is a problem, when I am checked 1st time it worked fine, later after a reboot and once again I ran the Mavlink Odometry stream, the terminal was lagging. The terminal with the output of voxl-inspect-mavlink mavlink_onboard this is lagging. The Odometry Hz was somewhere around 5 - 10, all the output in the terminal was lagging, so I though it was some WiFi issue and again tested offboard mode, but this time the drone went back to home.
                              So I rebooted the system and again ran the mavlink stream and waited for sometime until the lag in the voxl terminal is not there anymore, then when I tested offboard it was fine. I tried both figure eight and trajectory, both worked fine. I will attach the logs, can you please tell what might have caused the lag?
                              https://logs.px4.io/plot_app?log=93fb987f-c326-4d5d-89bb-2771bcacb3fc
                              https://logs.px4.io/plot_app?log=593bdb7b-7ce5-45f5-b183-2d0914015162
                              https://logs.px4.io/plot_app?log=3d8e8bd4-ec6e-4bcf-beea-741dff891ff9
                              https://logs.px4.io/plot_app?log=d33b6610-af39-4006-b90e-d1fdaad75da7
                              https://logs.px4.io/plot_app?log=b1ac6a04-0e1a-4049-bc27-dfe9a25224a8
                                Jetson Nano
                                Veteran
                                And I have one more question @Eric-Katzfey , I have to start the mavlink stream everytime. Is there a way to start the mavlink stream as soon the system is powered on?
                                  @Jetson-Nano Yes, there is a way to do that. Probably best to consult the PX4 documentation or ask on the PX4 forum for best way to do that on a Cube Orange.
                                    Jetson Nano
                                    Veteran
                                    @Eric-Katzfey What about the previous question I asked?
                                      @Jetson-Nano I really don't know what would cause that lag. You say it goes away if you wait awhile. How long do you have to wait for that to happen? And what is the baud rate of the UART that connects the CUBE Orange to VOXL 2? It's possible that the UART has too much data going over it and needs a higher baudrate.
                                        Jetson Nano
                                        Veteran
                                        @Eric-Katzfey The baudrate is 921600, sometimes I'll have to wait for more than 5 minutes and sometimes within seconds it will be ready to fly with required Hz
                                          @Jetson-Nano Part of the startup sequence when running with QGC or MP is to upload a full set of parameters. There are hundreds of parameters and this can take quite a while to complete. While this is happening the serial link is inundated with PARAM_VALUE mavlink messages. Once that has been completed then the link will have much less traffic. While it is laggy you can look at the mavlink console and see if it is receiving those PARAM_VALUE messages. That is a possible reason.
                                          • Jetson NanoJ Jetson Nano referenced this topic on
