  3. Drone losing position / crashing in Offboard mode
vio
35 Posts 2 Posters 9.0k Views 1 Watching
  • Jetson NanoJ Jetson Nano
    Hey @Eric-Katzfey, here are the logs for the flight test.
    https://review.px4.io/plot_app?log=9b6a7c2c-2bf4-43f7-8182-ac3efe2b4655
    In this flight test, I set the offboard mode to trajectory and did the flight test
    https://review.px4.io/plot_app?log=65f0b03a-11a5-409e-b2ca-1fe2a36cc088
    In this flight test, I changed the offboard mode to figure_eight and still the result is same, it goes very close to ground at 0,0,0 and hovers there.
    @Jetson-Nano I'm guessing that you don't have an odometry mavlink stream setup so the Cube Orange isn't sending out vehicle odometry mavlink packets that the offboard mode needs.
      Jetson NanoJ Offline
      Jetson Nano
      Veteran
      @Eric-Katzfey How do I setup that?
        @Jetson-Nano I would recommend reading through the PX4 documentataion on Mavlink messaging. It discusses how to enable streams. https://docs.px4.io/v1.14/en/middleware/mavlink.html
          Jetson Nano
          Veteran
          Thank you @Eric-Katzfey , I'll check and get back if needed anything.
            @Jetson-Nano The command would be something like mavlink stream -r 30 -s ODOMETRY -u 14556 and would be added to one of the startup files.
              Jetson Nano
              Veteran
              @Eric-Katzfey The documentation explains how to send custom mavlink messages, but odometry is not a custom message and isn't it streamed by default in your forked PX4?
                @Jetson-Nano The command is the same regardless of whether the message is custom or not. Another thing you can do is enable some of the debug flags available with voxl-vision-hub to see things like which mavlink messages it is receiving and which mavlink messages it is sending out. There are a variety of flags to choose from and that would help to figure out what is going wrong.
                  Jetson Nano
                  Veteran
                  @Eric-Katzfey This is what I am getting when I run vision hub with debug
                  voxl_visionion-hub -d
                  Enabling recv debugging for localhost UDP port from ROS
                  loading our own config file
                  config_file_version:        1
                  MAVROS / MAVSDK
                  en_localhost_mavlink_udp    0
                  VIO
                  en_vio:                     1
                  vio_pipe:                   qvio
                  secondary_vio_pipe:         ov
                  vio_warmup_s:               3.000000
                  send_odom_while_failed:     1
                  MISC FEATURES
                  horizon_cal_tolerance:      0.500000
                  OFFBOARD MODE
                  offboard_mode:              trajectory
                  follow_tag_id:              0
                  figure_eight_move_home:     1
                  robot_radius:               0.300000
                  collision_sampling_dt:      0.100000
                  max_lookahead_distance:     1.000000
                  FIXED FRAME RELOCALIZATION
                  en_tag_fixed_frame:         0
                  fixed_frame_filter_len:     5
                  COLLISION PREVENTION (VOA)
                  en_voa:                     1
                  voa_upper_bound_m:          -0.150000
                  voa_lower_bound_m:          0.150000
                  voa_memory_s:               1.000000
                  voa_max_pc_per_fusion:      100
                  voa_pie_min_dist_m:         0.250000
                  voa_pie_max_dist_m:         20.000000
                  voa_pie_under_trim_m:       1.000000
                  voa_pie_threshold:          3
                  voa_pie_slices:             36
                  voa_pie_bin_depth_m:        0.150000
                  voa_send_rate_hz:           20.000000
                  voa_input #0
                      enabled:            1
                      type:               point_cloud
                      input_pipe:         dfs_point_cloud
                      frame:              stereo_l
                      max_depth:          8.000000
                      min_depth:          0.300000
                      cell_size:          0.080000
                      threshold:          4
                      x_fov_deg:          68.000000
                      y_fov_deg:          56.000000
                      conf_cutoff:        0
                  voa_input #1
                      enabled:            1
                      type:               point_cloud
                      input_pipe:         stereo_front_pc
                      frame:              stereo_front_l
                      max_depth:          8.000000
                      min_depth:          0.300000
                      cell_size:          0.080000
                      threshold:          4
                      conf_cutoff:        0
                  voa_input #2
                      enabled:            1
                      type:               point_cloud
                      input_pipe:         stereo_rear_pc
                      frame:              stereo_rear_l
                      max_depth:          8.000000
                      min_depth:          0.300000
                      cell_size:          0.080000
                      threshold:          4
                      conf_cutoff:        0
                  voa_input #3
                      enabled:            1
                      type:               tof
                      input_pipe:         tof
                      frame:              tof
                      max_depth:          6.000000
                      min_depth:          0.150000
                      cell_size:          0.080000
                      threshold:          3
                      x_fov_deg:          106.500000
                      y_fov_deg:          85.099998
                      conf_cutoff:        125
                  voa_input #4
                      enabled:            1
                      type:               rangefinder
                      input_pipe:         rangefinders
                      frame:              body
                      max_depth:          8.000000
                      min_depth:          0.300000
                      cell_size:          0.080000
                      threshold:          4
                      conf_cutoff:        0
                  loading horizon cal file
                  existing instance of voxl-vision-hub found, attempting to stop it
                  starting geometry module
                  starting autopilot monitor
                  starting mavlink IO
                  Waiting to connect to voxl-mavlink-server
                  starting fixed pose input
                  starting vio manager
                  Connected to VIO pipe: qvio
                  Geometry module updating to use imu: imu_apps for VIO
                  new T imu wrt body:
                   0.0907  -0.0060  -0.0295
                  new R imu to body:
                   1.0000  -0.0000   0.0000
                   0.0000   1.0000  -0.0000
                   0.0000   0.0000   1.0000
                  done updating transforms to use imu: imu_apps
                  from AP msgid:  30 sysid:  1 compid:  1
                  Detected Autopilot Mavlink SYSID 1
                  starting tag manager
                  starting voa manager
                  starting horizon cal module
                  Connected to VOA input pipe: tof
                  starting offboard trajectory
                  Init complete
                  Trajectory Monitor connected to voa pointcloud
                  from AP msgid:   0 sysid:  1 compid:  1
                  requesting autopilot_version
                  from AP msgid: 148 sysid:  1 compid:  1
                  Detected autopilot version: 1.14.0
                  from AP msgid:  77 sysid:  1 compid:  1
                  from AP msgid:  31 sysid:  1 compid:  1
                  from AP msgid: 253 sysid:  1 compid:  1
                  from AP msgid: 410 sysid:  1 compid:  1
                  from AP msgid:  83 sysid:  1 compid:  1
                  from AP msgid:  74 sysid:  1 compid:  1
                  from AP msgid: 147 sysid:  1 compid:  1
                  from AP msgid: 230 sysid:  1 compid:  1
                  from AP msgid:  42 sysid:  1 compid:  1
                  from AP msgid: 411 sysid:  1 compid:  1
                  from AP msgid: 141 sysid:  1 compid:  1
                  from AP msgid: 245 sysid:  1 compid:  1
                  from AP msgid:  32 sysid:  1 compid:  1
                  from AP msgid: 12901 sysid:  1 compid:  1
                  from AP msgid:  29 sysid:  1 compid:  1
                  from AP msgid:  36 sysid:  1 compid:  1
                  from AP msgid:   1 sysid:  1 compid:  1
                  from AP msgid: 380 sysid:  1 compid:  1
                  from AP msgid:   8 sysid:  1 compid:  1
                  from AP msgid:   4 sysid:  1 compid:  1
                  from AP msgid:  85 sysid:  1 compid:  1
                    MAVROS / MAVSDK
                    VIO
                    en_vio:                     1
                    vio_pipe:                   qvio
                    MISC FEATURES
                    OFFBOARD MODE
                    follow_tag_id:              0
                    en_voa:                     1
                    voa_pie_slices:             36
                    voa_input #0
                        enabled:            1
                        type:               point_cloud
                        frame:              stereo_l
                        max_depth:          8.000000
                        min_depth:          0.300000
                        cell_size:          0.080000
                        threshold:          4
                        conf_cutoff:        0
                    voa_input #1
                        enabled:            1
                        type:               point_cloud
                        max_depth:          8.000000
                        min_depth:          0.300000
                        cell_size:          0.080000
                        threshold:          4
                        conf_cutoff:        0
                    voa_input #2
                        enabled:            1
                        type:               point_cloud
                        max_depth:          8.000000
                        min_depth:          0.300000
                        cell_size:          0.080000
                        threshold:          4
                        conf_cutoff:        0
                    voa_input #3
                        enabled:            1
                        type:               tof
                        input_pipe:         tof
                        frame:              tof
                        max_depth:          6.000000
                        min_depth:          0.150000
                        cell_size:          0.080000
                        threshold:          3
                        conf_cutoff:        125
                    voa_input #4
                        enabled:            1
                        type:               rangefinder
                        frame:              body
                        max_depth:          8.000000
                        min_depth:          0.300000
                        cell_size:          0.080000
                        threshold:          4
                        conf_cutoff:        0
                    starting mavlink IO
                    new T imu wrt body:
                    new R imu to body:
                    Init complete
                    Jetson Nano
                    Veteran
                    #21
                    @Eric-Katzfey when I do
                    voxl-inspect-mavlink mavlink_onboard
                    I am getting
                    and in mavlink console when I stream Odometry message as you said I am getting no output
                    when I used -d instead of -u it shows device not running. I tried with different ports
                      I am getting
                      Jetson Nano
                      Veteran
                      Hey @Eric-Katzfey , I think I solved it. I got the odometry stream to VOXL2 from Cube. I had to run
                      mavlink stream -r 30 -s ODOMETRY -d /dev/ttyS0
                      after this I got odometry stream on the
                        @Jetson-Nano Great! And is that now allowing you to run the figure 8?
                          Jetson Nano
                          Veteran
                          @Eric-Katzfey I haven't done the flight test. I'll do the flight test and get back to you.
                            Jetson Nano
                            Veteran
                            @Eric-Katzfey , I did the flight test and it works fine. Thank you.
                            But there is a problem, when I am checked 1st time it worked fine, later after a reboot and once again I ran the Mavlink Odometry stream, the terminal was lagging. The terminal with the output of voxl-inspect-mavlink mavlink_onboard this is lagging. The Odometry Hz was somewhere around 5 - 10, all the output in the terminal was lagging, so I though it was some WiFi issue and again tested offboard mode, but this time the drone went back to home.
                            So I rebooted the system and again ran the mavlink stream and waited for sometime until the lag in the voxl terminal is not there anymore, then when I tested offboard it was fine. I tried both figure eight and trajectory, both worked fine. I will attach the logs, can you please tell what might have caused the lag?
                            https://logs.px4.io/plot_app?log=93fb987f-c326-4d5d-89bb-2771bcacb3fc
                            https://logs.px4.io/plot_app?log=593bdb7b-7ce5-45f5-b183-2d0914015162
                            https://logs.px4.io/plot_app?log=3d8e8bd4-ec6e-4bcf-beea-741dff891ff9
                            https://logs.px4.io/plot_app?log=d33b6610-af39-4006-b90e-d1fdaad75da7
                            https://logs.px4.io/plot_app?log=b1ac6a04-0e1a-4049-bc27-dfe9a25224a8
                              Jetson Nano
                              Veteran
                              And I have one more question @Eric-Katzfey , I have to start the mavlink stream everytime. Is there a way to start the mavlink stream as soon the system is powered on?
                                @Jetson-Nano Yes, there is a way to do that. Probably best to consult the PX4 documentation or ask on the PX4 forum for best way to do that on a Cube Orange.
                                  Jetson Nano
                                  Veteran
                                  @Eric-Katzfey What about the previous question I asked?
                                    @Jetson-Nano I really don't know what would cause that lag. You say it goes away if you wait awhile. How long do you have to wait for that to happen? And what is the baud rate of the UART that connects the CUBE Orange to VOXL 2? It's possible that the UART has too much data going over it and needs a higher baudrate.
                                      Jetson Nano
                                      Veteran
                                      @Eric-Katzfey The baudrate is 921600, sometimes I'll have to wait for more than 5 minutes and sometimes within seconds it will be ready to fly with required Hz
                                        @Jetson-Nano Part of the startup sequence when running with QGC or MP is to upload a full set of parameters. There are hundreds of parameters and this can take quite a while to complete. While this is happening the serial link is inundated with PARAM_VALUE mavlink messages. Once that has been completed then the link will have much less traffic. While it is laggy you can look at the mavlink console and see if it is receiving those PARAM_VALUE messages. That is a possible reason.
                                        • Jetson NanoJ Jetson Nano referenced this topic on
                                          Jetson Nano
                                          Veteran
                                          #32
                                          @Eric-Katzfey I'm currently integrating VOXL2 with Flight Core V2.
                                          PX4 version: v1.14.3 (from modalAI fork)
                                          I am trying to use offboard mode and do figure-eight, but the problem I'm facing is, whenever I switch to offboard, the drone sometimes moves randomly.
                                          Once I reboot the FC once and start flying from same position, and then switching to offboard, I observe that the drone does figure 8, but loses height sequentially and drifts over the ground and crashes after a few cycles.
                                          For height estimation, I rely on using a Rangefinder.
                                          Also, when I run,
                                          I'm not able to observe, the #331 ODOMETRY message.
