  3. Drone losing position / crashing in Offboard mode
vio
35 Posts 2 Posters 9.5k Views 1 Watching
  • Jetson NanoJ Jetson Nano
    @Eric-Katzfey The test I'll do and let you know, but the drone with cube orange is bigger than Starling and the extrinsics for the drone has been changed with respect to the modified build's CG.
    Jetson NanoJ Offline
    Jetson Nano
    Veteran
    Hey @Eric-Katzfey , I tested it in all directions and the drone is going towards the home, but not to 0,0,1.5 but it's going down to 0,0,0. Wherever I take off and navigate and then switch to offboard, it'll try to go to 0,0,0. I tested it with 1m and 2m altitude and still the same. I also tested it right above the origin, it went straight down.
      @Jetson-Nano I'm not sure why it would do that on Cube Orange. It almost seems like it is doing RTL instead of starting the figure eight. The Starling is running our fork of PX4, not standard PX4. You could build our fork and try it on the Cube Orange to see if that makes a difference.
        Jetson Nano
        Veteran
        @Eric-Katzfey Can I download the PX4 which is built for VOXL and upload it in Cube?
          @Jetson-Nano No, you would need to download the source and build it yourself.
            Jetson Nano
            Veteran
            @Eric-Katzfey I tried using the modalai forked repo in the cube and this is the outcome, when I switch to offboard it is still going to home but not like crashing how it was previously, but goes near home and hovers very close to the ground, and I get autopilot disengaged and switches to land mode and lands.
              @Jetson-Nano Interesting. Can you share the log from that flight?
                Jetson Nano
                Veteran
                Hey @Eric-Katzfey, here are the logs for the flight test.
                https://review.px4.io/plot_app?log=9b6a7c2c-2bf4-43f7-8182-ac3efe2b4655
                In this flight test, I set the offboard mode to trajectory and did the flight test
                https://review.px4.io/plot_app?log=65f0b03a-11a5-409e-b2ca-1fe2a36cc088
                In this flight test, I changed the offboard mode to figure_eight and still the result is same, it goes very close to ground at 0,0,0 and hovers there.
                  @Jetson-Nano I'm guessing that you don't have an odometry mavlink stream setup so the Cube Orange isn't sending out vehicle odometry mavlink packets that the offboard mode needs.
                    Jetson Nano
                    Veteran
                    @Eric-Katzfey How do I setup that?
                      @Jetson-Nano I would recommend reading through the PX4 documentataion on Mavlink messaging. It discusses how to enable streams. https://docs.px4.io/v1.14/en/middleware/mavlink.html
                        Jetson Nano
                        Veteran
                        Thank you @Eric-Katzfey , I'll check and get back if needed anything.
                          @Jetson-Nano The command would be something like mavlink stream -r 30 -s ODOMETRY -u 14556 and would be added to one of the startup files.
                            Jetson Nano
                            Veteran
                            @Eric-Katzfey The documentation explains how to send custom mavlink messages, but odometry is not a custom message and isn't it streamed by default in your forked PX4?
                              @Jetson-Nano The command is the same regardless of whether the message is custom or not. Another thing you can do is enable some of the debug flags available with voxl-vision-hub to see things like which mavlink messages it is receiving and which mavlink messages it is sending out. There are a variety of flags to choose from and that would help to figure out what is going wrong.
                                Jetson Nano
                                Veteran
                                @Eric-Katzfey This is what I am getting when I run vision hub with debug
                                voxl_visionion-hub -d
                                Enabling recv debugging for localhost UDP port from ROS
                                loading our own config file
                                config_file_version:        1
                                MAVROS / MAVSDK
                                en_localhost_mavlink_udp    0
                                VIO
                                en_vio:                     1
                                vio_pipe:                   qvio
                                secondary_vio_pipe:         ov
                                vio_warmup_s:               3.000000
                                send_odom_while_failed:     1
                                MISC FEATURES
                                horizon_cal_tolerance:      0.500000
                                OFFBOARD MODE
                                offboard_mode:              trajectory
                                follow_tag_id:              0
                                figure_eight_move_home:     1
                                robot_radius:               0.300000
                                collision_sampling_dt:      0.100000
                                max_lookahead_distance:     1.000000
                                FIXED FRAME RELOCALIZATION
                                en_tag_fixed_frame:         0
                                fixed_frame_filter_len:     5
                                COLLISION PREVENTION (VOA)
                                en_voa:                     1
                                voa_upper_bound_m:          -0.150000
                                voa_lower_bound_m:          0.150000
                                voa_memory_s:               1.000000
                                voa_max_pc_per_fusion:      100
                                voa_pie_min_dist_m:         0.250000
                                voa_pie_max_dist_m:         20.000000
                                voa_pie_under_trim_m:       1.000000
                                voa_pie_threshold:          3
                                voa_pie_slices:             36
                                voa_pie_bin_depth_m:        0.150000
                                voa_send_rate_hz:           20.000000
                                voa_input #0
                                    enabled:            1
                                    type:               point_cloud
                                    input_pipe:         dfs_point_cloud
                                    frame:              stereo_l
                                    max_depth:          8.000000
                                    min_depth:          0.300000
                                    cell_size:          0.080000
                                    threshold:          4
                                    x_fov_deg:          68.000000
                                    y_fov_deg:          56.000000
                                    conf_cutoff:        0
                                voa_input #1
                                    enabled:            1
                                    type:               point_cloud
                                    input_pipe:         stereo_front_pc
                                    frame:              stereo_front_l
                                    max_depth:          8.000000
                                    min_depth:          0.300000
                                    cell_size:          0.080000
                                    threshold:          4
                                    conf_cutoff:        0
                                voa_input #2
                                    enabled:            1
                                    type:               point_cloud
                                    input_pipe:         stereo_rear_pc
                                    frame:              stereo_rear_l
                                    max_depth:          8.000000
                                    min_depth:          0.300000
                                    cell_size:          0.080000
                                    threshold:          4
                                    conf_cutoff:        0
                                voa_input #3
                                    enabled:            1
                                    type:               tof
                                    input_pipe:         tof
                                    frame:              tof
                                    max_depth:          6.000000
                                    min_depth:          0.150000
                                    cell_size:          0.080000
                                    threshold:          3
                                    x_fov_deg:          106.500000
                                    y_fov_deg:          85.099998
                                    conf_cutoff:        125
                                voa_input #4
                                    enabled:            1
                                    type:               rangefinder
                                    input_pipe:         rangefinders
                                    frame:              body
                                    max_depth:          8.000000
                                    min_depth:          0.300000
                                    cell_size:          0.080000
                                    threshold:          4
                                    conf_cutoff:        0
                                loading horizon cal file
                                existing instance of voxl-vision-hub found, attempting to stop it
                                starting geometry module
                                starting autopilot monitor
                                starting mavlink IO
                                Waiting to connect to voxl-mavlink-server
                                starting fixed pose input
                                starting vio manager
                                Connected to VIO pipe: qvio
                                Geometry module updating to use imu: imu_apps for VIO
                                new T imu wrt body:
                                 0.0907  -0.0060  -0.0295
                                new R imu to body:
                                 1.0000  -0.0000   0.0000
                                 0.0000   1.0000  -0.0000
                                 0.0000   0.0000   1.0000
                                done updating transforms to use imu: imu_apps
                                from AP msgid:  30 sysid:  1 compid:  1
                                Detected Autopilot Mavlink SYSID 1
                                starting tag manager
                                starting voa manager
                                starting horizon cal module
                                Connected to VOA input pipe: tof
                                starting offboard trajectory
                                Init complete
                                Trajectory Monitor connected to voa pointcloud
                                from AP msgid:   0 sysid:  1 compid:  1
                                requesting autopilot_version
                                from AP msgid: 148 sysid:  1 compid:  1
                                Detected autopilot version: 1.14.0
                                from AP msgid:  77 sysid:  1 compid:  1
                                from AP msgid:  31 sysid:  1 compid:  1
                                from AP msgid: 253 sysid:  1 compid:  1
                                from AP msgid: 410 sysid:  1 compid:  1
                                from AP msgid:  83 sysid:  1 compid:  1
                                from AP msgid:  74 sysid:  1 compid:  1
                                from AP msgid: 147 sysid:  1 compid:  1
                                from AP msgid: 230 sysid:  1 compid:  1
                                from AP msgid:  42 sysid:  1 compid:  1
                                from AP msgid: 411 sysid:  1 compid:  1
                                from AP msgid: 141 sysid:  1 compid:  1
                                from AP msgid: 245 sysid:  1 compid:  1
                                from AP msgid:  32 sysid:  1 compid:  1
                                from AP msgid: 12901 sysid:  1 compid:  1
                                from AP msgid:  29 sysid:  1 compid:  1
                                from AP msgid:  36 sysid:  1 compid:  1
                                from AP msgid:   1 sysid:  1 compid:  1
                                from AP msgid: 380 sysid:  1 compid:  1
                                from AP msgid:   8 sysid:  1 compid:  1
                                from AP msgid:   4 sysid:  1 compid:  1
                                from AP msgid:  85 sysid:  1 compid:  1
                                  MAVROS / MAVSDK
                                  VIO
                                  en_vio:                     1
                                  vio_pipe:                   qvio
                                  MISC FEATURES
                                  OFFBOARD MODE
                                  follow_tag_id:              0
                                  en_voa:                     1
                                  voa_pie_slices:             36
                                  voa_input #0
                                      enabled:            1
                                      type:               point_cloud
                                      frame:              stereo_l
                                      max_depth:          8.000000
                                      min_depth:          0.300000
                                      cell_size:          0.080000
                                      threshold:          4
                                      conf_cutoff:        0
                                  voa_input #1
                                      enabled:            1
                                      type:               point_cloud
                                      max_depth:          8.000000
                                      min_depth:          0.300000
                                      cell_size:          0.080000
                                      threshold:          4
                                      conf_cutoff:        0
                                  voa_input #2
                                      enabled:            1
                                      type:               point_cloud
                                      max_depth:          8.000000
                                      min_depth:          0.300000
                                      cell_size:          0.080000
                                      threshold:          4
                                      conf_cutoff:        0
                                  voa_input #3
                                      enabled:            1
                                      type:               tof
                                      input_pipe:         tof
                                      frame:              tof
                                      max_depth:          6.000000
                                      min_depth:          0.150000
                                      cell_size:          0.080000
                                      threshold:          3
                                      conf_cutoff:        125
                                  voa_input #4
                                      enabled:            1
                                      type:               rangefinder
                                      frame:              body
                                      max_depth:          8.000000
                                      min_depth:          0.300000
                                      cell_size:          0.080000
                                      threshold:          4
                                      conf_cutoff:        0
                                  starting mavlink IO
                                  new T imu wrt body:
                                  new R imu to body:
                                  Init complete
                                  Jetson Nano
                                  Veteran
                                  #21
                                  @Eric-Katzfey when I do
                                  voxl-inspect-mavlink mavlink_onboard
                                  I am getting
                                  and in mavlink console when I stream Odometry message as you said I am getting no output
                                  when I used -d instead of -u it shows device not running. I tried with different ports
                                    I am getting
                                    Jetson Nano
                                    Veteran
                                    Hey @Eric-Katzfey , I think I solved it. I got the odometry stream to VOXL2 from Cube. I had to run
                                    mavlink stream -r 30 -s ODOMETRY -d /dev/ttyS0
                                    after this I got odometry stream on the
                                      @Jetson-Nano Great! And is that now allowing you to run the figure 8?
                                        Jetson Nano
                                        Veteran
                                        @Eric-Katzfey I haven't done the flight test. I'll do the flight test and get back to you.
                                          Jetson Nano
                                          Veteran
                                          @Eric-Katzfey , I did the flight test and it works fine. Thank you.
                                          But there is a problem, when I am checked 1st time it worked fine, later after a reboot and once again I ran the Mavlink Odometry stream, the terminal was lagging. The terminal with the output of voxl-inspect-mavlink mavlink_onboard this is lagging. The Odometry Hz was somewhere around 5 - 10, all the output in the terminal was lagging, so I though it was some WiFi issue and again tested offboard mode, but this time the drone went back to home.
                                          So I rebooted the system and again ran the mavlink stream and waited for sometime until the lag in the voxl terminal is not there anymore, then when I tested offboard it was fine. I tried both figure eight and trajectory, both worked fine. I will attach the logs, can you please tell what might have caused the lag?
                                          https://logs.px4.io/plot_app?log=93fb987f-c326-4d5d-89bb-2771bcacb3fc
                                          https://logs.px4.io/plot_app?log=593bdb7b-7ce5-45f5-b183-2d0914015162
                                          https://logs.px4.io/plot_app?log=3d8e8bd4-ec6e-4bcf-beea-741dff891ff9
                                          https://logs.px4.io/plot_app?log=d33b6610-af39-4006-b90e-d1fdaad75da7
                                          https://logs.px4.io/plot_app?log=b1ac6a04-0e1a-4049-bc27-dfe9a25224a8
