    Drone losing position / crashing in Offboard mode
    GPS-denied Navigation (VIO)
    3126
    • Jetson NanoJ
      Jetson Nano
      I am trying to run GPS denied navigation using VIO. My hardware setup is
      Flight Controller: CubeOrange
      PX4 version: v1.14.3 (Stable)
      Companion Computer: VOXL 2
      I am trying to use offbaord mode and do navigation, but the problem I am facing is, whenever I switch to offboard, the drone crashes, and it is always in only one direction. It always tilts to the rear left of the drone and falls down.
      Initially I used an optical flow sensor for position hold, later I tried position hold only with external vision and position hold is very good, I can navigate seamlessly around using RC in position hold only with external vision, I tried fusing both EV and OF, position hold was good, but the offboard problem is there even with both EV and OF fused together.
      I have attached the logs below for your reference.
      https://review.px4.io/plot_app?log=e4c9f0f3-df81-4d49-94f0-a9d5b06037c1
      I have switched to offboard mode twice, one is near 6:54:00 and another time is around 7:11:00 for the above log.
      https://review.px4.io/plot_app?log=52346209-bb6a-46c0-9eb4-426c1c93c620
      For this log, I have switched to offboard at 1:30:00
      @Eric-Katzfey @James-Strawson Can you please help me with this? Thank you.
      I have already asked in the PX4 forum, and they said that the setpoint is set to 0,0,0. How do I change it so that the setpoint updates with current position and is not 0,0,0?
      When I do listener for setpoint in mavlink console this is what I get
      nsh> listener vehicle_local_position_setpoint
      TOPIC: vehicle_local_position_setpoint
      timestamp: 299285198 (0.006456 seconds ago)
      x: nan
      y: nan
      z: nan
      vx: nan
      vy: nan
      vz: nan
      acceleration: [0.00000, 0.00000, 100.00000]
      thrust: [-0.00000, -0.00000, -0.00100]
      yaw: -1.56113
      yawspeed: 0.00000
        Eric Katzfey ModalAI Team @Jetson Nano
        @Jetson-Nano What is figure_eight_move_home set to in your configuration file for voxl-vision-hub (/etc/modalai/voxl-vision-hub.conf)?
        • Jetson NanoJ
          Jetson Nano @Eric Katzfey
          @Eric-Katzfey It is set to true.
          I have a starling and have verified the parameter with that system also.
            @Jetson-Nano So the figure eight works fine on the Starling? But not on the drone with the Cube Orange using VOXL 2 as a companion computer? What if you takeoff straight up, hover at about 7 or 8 feet altitude, then go into offboard mode. Does it still do the same thing? Is the drone with the Cube Orange much larger than the Starling?
            • Jetson NanoJ
              @Eric-Katzfey The test I'll do and let you know, but the drone with cube orange is bigger than Starling and the extrinsics for the drone has been changed with respect to the modified build's CG.
              • Jetson NanoJ
                Jetson Nano @Jetson Nano
                Hey @Eric-Katzfey , I tested it in all directions and the drone is going towards the home, but not to 0,0,1.5 but it's going down to 0,0,0. Wherever I take off and navigate and then switch to offboard, it'll try to go to 0,0,0. I tested it with 1m and 2m altitude and still the same. I also tested it right above the origin, it went straight down.
                  @Jetson-Nano I'm not sure why it would do that on Cube Orange. It almost seems like it is doing RTL instead of starting the figure eight. The Starling is running our fork of PX4, not standard PX4. You could build our fork and try it on the Cube Orange to see if that makes a difference.
                  • Jetson NanoJ
                    @Eric-Katzfey Can I download the PX4 which is built for VOXL and upload it in Cube?
                      @Jetson-Nano No, you would need to download the source and build it yourself.
                      • Jetson NanoJ
                        @Eric-Katzfey I tried using the modalai forked repo in the cube and this is the outcome, when I switch to offboard it is still going to home but not like crashing how it was previously, but goes near home and hovers very close to the ground, and I get autopilot disengaged and switches to land mode and lands.
                          @Jetson-Nano Interesting. Can you share the log from that flight?
                          • Jetson NanoJ
                            Hey @Eric-Katzfey, here are the logs for the flight test.
                            https://review.px4.io/plot_app?log=9b6a7c2c-2bf4-43f7-8182-ac3efe2b4655
                            In this flight test, I set the offboard mode to trajectory and did the flight test
                            https://review.px4.io/plot_app?log=65f0b03a-11a5-409e-b2ca-1fe2a36cc088
                            In this flight test, I changed the offboard mode to figure_eight and still the result is same, it goes very close to ground at 0,0,0 and hovers there.
                              @Jetson-Nano I'm guessing that you don't have an odometry mavlink stream setup so the Cube Orange isn't sending out vehicle odometry mavlink packets that the offboard mode needs.
                              • Jetson NanoJ
                                @Eric-Katzfey How do I setup that?
                                  @Jetson-Nano I would recommend reading through the PX4 documentataion on Mavlink messaging. It discusses how to enable streams. https://docs.px4.io/v1.14/en/middleware/mavlink.html
                                  • Jetson NanoJ
                                    Thank you @Eric-Katzfey , I'll check and get back if needed anything.
                                      @Jetson-Nano The command would be something like mavlink stream -r 30 -s ODOMETRY -u 14556 and would be added to one of the startup files.
                                      • Jetson NanoJ
                                        @Eric-Katzfey The documentation explains how to send custom mavlink messages, but odometry is not a custom message and isn't it streamed by default in your forked PX4?
                                          @Jetson-Nano The command is the same regardless of whether the message is custom or not. Another thing you can do is enable some of the debug flags available with voxl-vision-hub to see things like which mavlink messages it is receiving and which mavlink messages it is sending out. There are a variety of flags to choose from and that would help to figure out what is going wrong.
                                          • Jetson NanoJ
                                            @Eric-Katzfey This is what I am getting when I run vision hub with debug
                                            voxl_visionion-hub -d
                                            Enabling recv debugging for localhost UDP port from ROS
                                            loading our own config file
                                            config_file_version:        1
                                            MAVROS / MAVSDK
                                            en_localhost_mavlink_udp    0
                                            VIO
                                            en_vio:                     1
                                            vio_pipe:                   qvio
                                            secondary_vio_pipe:         ov
                                            vio_warmup_s:               3.000000
                                            send_odom_while_failed:     1
                                            MISC FEATURES
                                            horizon_cal_tolerance:      0.500000
                                            OFFBOARD MODE
                                            offboard_mode:              trajectory
                                            follow_tag_id:              0
                                            figure_eight_move_home:     1
                                            robot_radius:               0.300000
                                            collision_sampling_dt:      0.100000
                                            max_lookahead_distance:     1.000000
                                            FIXED FRAME RELOCALIZATION
                                            en_tag_fixed_frame:         0
                                            fixed_frame_filter_len:     5
                                            COLLISION PREVENTION (VOA)
                                            en_voa:                     1
                                            voa_upper_bound_m:          -0.150000
                                            voa_lower_bound_m:          0.150000
                                            voa_memory_s:               1.000000
                                            voa_max_pc_per_fusion:      100
                                            voa_pie_min_dist_m:         0.250000
                                            voa_pie_max_dist_m:         20.000000
                                            voa_pie_under_trim_m:       1.000000
                                            voa_pie_threshold:          3
                                            voa_pie_slices:             36
                                            voa_pie_bin_depth_m:        0.150000
                                            voa_send_rate_hz:           20.000000
                                            voa_input #0
                                                enabled:            1
                                                type:               point_cloud
                                                input_pipe:         dfs_point_cloud
                                                frame:              stereo_l
                                                max_depth:          8.000000
                                                min_depth:          0.300000
                                                cell_size:          0.080000
                                                threshold:          4
                                                x_fov_deg:          68.000000
                                                y_fov_deg:          56.000000
                                                conf_cutoff:        0
                                            voa_input #1
                                                enabled:            1
                                                type:               point_cloud
                                                input_pipe:         stereo_front_pc
                                                frame:              stereo_front_l
                                                max_depth:          8.000000
                                                min_depth:          0.300000
                                                cell_size:          0.080000
                                                threshold:          4
                                                conf_cutoff:        0
                                            voa_input #2
                                                enabled:            1
                                                type:               point_cloud
                                                input_pipe:         stereo_rear_pc
                                                frame:              stereo_rear_l
                                                max_depth:          8.000000
                                                min_depth:          0.300000
                                                cell_size:          0.080000
                                                threshold:          4
                                                conf_cutoff:        0
                                            voa_input #3
                                                enabled:            1
                                                type:               tof
                                                input_pipe:         tof
                                                frame:              tof
                                                max_depth:          6.000000
                                                min_depth:          0.150000
                                                cell_size:          0.080000
                                                threshold:          3
                                                x_fov_deg:          106.500000
                                                y_fov_deg:          85.099998
                                                conf_cutoff:        125
                                            voa_input #4
                                                enabled:            1
                                                type:               rangefinder
                                                input_pipe:         rangefinders
                                                frame:              body
                                                max_depth:          8.000000
                                                min_depth:          0.300000
                                                cell_size:          0.080000
                                                threshold:          4
                                                conf_cutoff:        0
                                            loading horizon cal file
                                            existing instance of voxl-vision-hub found, attempting to stop it
                                            starting geometry module
                                            starting autopilot monitor
                                            starting mavlink IO
                                            Waiting to connect to voxl-mavlink-server
                                            starting fixed pose input
                                            starting vio manager
                                            Connected to VIO pipe: qvio
                                            Geometry module updating to use imu: imu_apps for VIO
                                            new T imu wrt body:
                                             0.0907  -0.0060  -0.0295
                                            new R imu to body:
                                             1.0000  -0.0000   0.0000
                                             0.0000   1.0000  -0.0000
                                             0.0000   0.0000   1.0000
                                            done updating transforms to use imu: imu_apps
                                            from AP msgid:  30 sysid:  1 compid:  1
                                            Detected Autopilot Mavlink SYSID 1
                                            starting tag manager
                                            starting voa manager
                                            starting horizon cal module
                                            Connected to VOA input pipe: tof
                                            starting offboard trajectory
                                            Init complete
                                            Trajectory Monitor connected to voa pointcloud
                                            from AP msgid:   0 sysid:  1 compid:  1
                                            requesting autopilot_version
                                            from AP msgid: 148 sysid:  1 compid:  1
                                            Detected autopilot version: 1.14.0
                                            from AP msgid:  77 sysid:  1 compid:  1
                                            from AP msgid:  31 sysid:  1 compid:  1
                                            from AP msgid: 253 sysid:  1 compid:  1
                                            from AP msgid: 410 sysid:  1 compid:  1
                                            from AP msgid:  83 sysid:  1 compid:  1
                                            from AP msgid:  74 sysid:  1 compid:  1
                                            from AP msgid: 147 sysid:  1 compid:  1
                                            from AP msgid: 230 sysid:  1 compid:  1
                                            from AP msgid:  42 sysid:  1 compid:  1
                                            from AP msgid: 411 sysid:  1 compid:  1
                                            from AP msgid: 141 sysid:  1 compid:  1
                                            from AP msgid: 245 sysid:  1 compid:  1
                                            from AP msgid:  32 sysid:  1 compid:  1
                                            from AP msgid: 12901 sysid:  1 compid:  1
                                            from AP msgid:  29 sysid:  1 compid:  1
                                            from AP msgid:  36 sysid:  1 compid:  1
                                            from AP msgid:   1 sysid:  1 compid:  1
                                            from AP msgid: 380 sysid:  1 compid:  1
                                            from AP msgid:   8 sysid:  1 compid:  1
                                            from AP msgid:   4 sysid:  1 compid:  1
                                            from AP msgid:  85 sysid:  1 compid:  1
