  3. Odometry - PX4 is NOT Getting VIO Data - QGroundControl
vio
5 Posts 4 Posters 1.5k Views 2 Watching
  • Adriano Del Pino LinoA Offline
    Hi guys, how are you doing?
    Check this out, please:
    • Problem: VIO odometry data does not showing up into PX4 QGroundControl.
    • Drone: Sentinel, SDK: 1.1.3 was 0.95, Sensors removed: Rear Stereo, GPS and 5G. Sensor installed: TOF. Reconfigured and recalibrated.
    • Services: voxl-inspect-qvio is showing perfect, also vox-portal, many features in the tracking camera;
    EKF2_AID_MASK configured as (https://docs.modalai.com/sentinel-user-guide-using-vio/#flying-with-vio)
    Questions:
    1. Should the odometry message continue to appear into PX4 QGroundControl in SDK version 1.1.3 like here ?
      https://docs.modalai.com/sentinel-user-guide-using-vio/#sentinel-vio
    2. Confirm that EKF2_AID_MASK must be configured in SDK 1.1.3 version. I would like this confirmation because this parameter is in version 1.12 of px4, but it does not appear in 1.14 PX4 modalAI gitlab.
      Source: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/tree/master/params?ref_type=heads
    • Adriano Del Pino LinoA Adriano Del Pino Lino
      Questions:
      @Adriano-Del-Pino-Lino Can you run voxl-configure-px4-params -w and navigate to v1.14/EKF2_helpers/ and load the indoor_vio params? Then reboot and see if anything changes
      Adriano Del Pino LinoA 1 Reply Last reply
        Hi @tom,
        The problem still there, without odometry.
        Could you answer those questions, please.
        I would like to understand if in any current version of Sentinel (SDK 1.1.3) the odometry message in QGroundControl should continue to appear.
        Adriano Lino
          Hi @tom,
          Adriano Lino
          @Adriano-Del-Pino-Lino Please reference this other post: https://forum.modalai.com/topic/3341/odometry-message/2
            Jetson NanoJ Offline
            Jetson Nano
            Veteran
