  3. voxl2 mini build
voxl2 mini build
9 Posts 3 Posters 2.0k Views 3 Watching
  • tiralonghipolT Offline
    tiralonghipol
    wrote on last edited by tiralonghipol
    hi,
    after setting up the docker, updated the submodules and followed the guidelines as described here,
    I build and flash the firmware on my voxl2 mini board
    then I stop the voxl-px4 service and when I
    voxl-px4 -d
    I get the following error:
    voxl2-mini:/$ voxl-px4 -d
    Found DSP signature file
    [INFO] Disabling daemon mode
    GPS=AUTODETECT
    RC=CRSF_RAW
    ESC=VOXL_ESC
    POWER MANAGER=NONE
    DISTANCE SENSOR=NONE
    OSD=DISABLE
    DAEMON_MODE=DISABLE
    SENSOR_CAL=ACTUAL
    EXTRA STEPS:
    INFO  [muorb] SLPI: Creating pthread test_MUORB
    ERROR [muorb] SLPI: Hit maximum number of threads
    ERROR [muorb] Test timed out waiting for response
    px4: symbol lookup error: px4: undefined symbol: fc_sensor_get_time_offset
    PX4 branch voxl-dev, commit 98e2c064459509
    This is with everything default without touching any code except the px4.conf file
    Any idea?
    • tiralonghipolT tiralonghipol
      hi,
      voxl-px4 -d
      GPS=AUTODETECT
      RC=CRSF_RAW
      ESC=VOXL_ESC
      POWER MANAGER=NONE
      OSD=DISABLE
      DAEMON_MODE=DISABLE
      SENSOR_CAL=ACTUAL
      EXTRA STEPS:
      Any idea?
      Eric KatzfeyE Online
      @tiralonghipol I would do systemctl disable voxl-px4 then power cycle the board and then on next log in do voxl-px4 -d.
      tiralonghipolT 1 Reply Last reply
        tiralonghipol
        @Eric-Katzfey
        I thought about it as well, it does not seem to have an effect
        anything else I could try? I am scanning the commits to see if this symbol was introduced as some point
          @Eric-Katzfey
          @tiralonghipol Oh, sorry, didn't scroll down and see that message. Latest dev is incompatible with SDK 1.1.2. You need updated libfc-sensor installed (Can be found here: http://voxl-packages.modalai.com/dists/qrb5165/staging/binary-arm64/libfc-sensor_1.0.5_arm64.deb) and ideally latest modalai-slpi installed as well (Can be found here: http://voxl-packages.modalai.com/dists/qrb5165/staging/binary-arm64/modalai-slpi_1.1.12_arm64.deb). These will all be together in the next SDK release.
            tiralonghipol
            @Eric-Katzfey
            you are the best! that worked! hurra!
            for anyone bumping into the same issue:
            adb shell into voxl2 mini
            wget http://voxl-packages.modalai.com/dists/qrb5165/staging/binary-arm64/modalai-slpi_1.1.12_arm64.deb
            dpkg -i modalai-slpi_1.1.12_arm64.deb
            wget http://voxl-packages.modalai.com/dists/qrb5165/staging/binary-arm64/libfc-sensor_1.0.5_arm64.deb
            dpkg -i libfc-sensor_1.0.5_arm64.deb
            into the docker:
            ./clean.sh
            ./build.sh
            into voxl-px4/px4-firmware/
            /boards/modalai/voxl2/scripts/install-voxl.sh
            tadaaa
              @Eric-Katzfey
              into the docker:
              ./clean.sh
              ./build.sh
              tadaaa
              tiralonghipol
              @Eric-Katzfey
              hei Eric! I thought you would like to see some results (LINK HERE). voxl2 mini + 4in1 mini esc, amazing products!
              we submitted to ICUAS2024, more details in case the paper gets accepted
              Eric KatzfeyE tomT 2 Replies Last reply
                @Eric-Katzfey
                @tiralonghipol Hey, that's really cool! Thanks for sharing!
                  @Eric-Katzfey
                  @tiralonghipol This is awesome, great work!
                    tiralonghipol
                    @tom @Eric-Katzfey
                    Thank you guys!! More to come eheh
                    • D Denver Bennett referenced this topic on
