    voxl2 mini build
    1209
    • tiralonghipolT
      tiralonghipol
      hi,
      after setting up the docker, updated the submodules and followed the guidelines as described here,
      I build and flash the firmware on my voxl2 mini board
      then I stop the voxl-px4 service and when I
      voxl-px4 -d
      I get the following error:
      voxl2-mini:/$ voxl-px4 -d
      Found DSP signature file
      [INFO] Disabling daemon mode
      GPS=AUTODETECT
      RC=CRSF_RAW
      ESC=VOXL_ESC
      POWER MANAGER=NONE
      DISTANCE SENSOR=NONE
      OSD=DISABLE
      DAEMON_MODE=DISABLE
      SENSOR_CAL=ACTUAL
      EXTRA STEPS:
      ERROR [muorb] SLPI: Hit maximum number of threads
      ERROR [muorb] Test timed out waiting for response
      px4: symbol lookup error: px4: undefined symbol: fc_sensor_get_time_offset
      PX4 branch voxl-dev, commit 98e2c064459509
      This is with everything default without touching any code except the px4.conf file
      Any idea?
        Eric Katzfey ModalAI Team @tiralonghipol
        @tiralonghipol I would do systemctl disable voxl-px4 then power cycle the board and then on next log in do voxl-px4 -d.
        tiralonghipolT 1 Reply Last reply Reply Quote 1
        • tiralonghipolT
          tiralonghipol @Eric Katzfey
          I thought about it as well, it does not seem to have an effect
          anything else I could try? I am scanning the commits to see if this symbol was introduced as some point
            @tiralonghipol Oh, sorry, didn't scroll down and see that message. Latest dev is incompatible with SDK 1.1.2. You need updated libfc-sensor installed (Can be found here: http://voxl-packages.modalai.com/dists/qrb5165/staging/binary-arm64/libfc-sensor_1.0.5_arm64.deb) and ideally latest modalai-slpi installed as well (Can be found here: http://voxl-packages.modalai.com/dists/qrb5165/staging/binary-arm64/modalai-slpi_1.1.12_arm64.deb). These will all be together in the next SDK release.
            • tiralonghipolT
              you are the best! that worked! hurra!
              for anyone bumping into the same issue:
              adb shell into voxl2 mini
              wget http://voxl-packages.modalai.com/dists/qrb5165/staging/binary-arm64/modalai-slpi_1.1.12_arm64.deb
              dpkg -i modalai-slpi_1.1.12_arm64.deb
              wget http://voxl-packages.modalai.com/dists/qrb5165/staging/binary-arm64/libfc-sensor_1.0.5_arm64.deb
              dpkg -i libfc-sensor_1.0.5_arm64.deb
              into the docker:
              ./clean.sh
              ./build.sh
              into voxl-px4/px4-firmware/
              /boards/modalai/voxl2/scripts/install-voxl.sh
              tadaaa
              • tiralonghipolT
                tiralonghipol @tiralonghipol
                hei Eric! I thought you would like to see some results (LINK HERE). voxl2 mini + 4in1 mini esc, amazing products!
                we submitted to ICUAS2024, more details in case the paper gets accepted
                Eric KatzfeyE tomT 2 Replies Last reply Reply Quote 1
                  @tiralonghipol Hey, that's really cool! Thanks for sharing!
                    tom admin @tiralonghipol
                    @tiralonghipol This is awesome, great work!
                    • tiralonghipolT
                      tiralonghipol @tom
                      @tom @Eric-Katzfey
                      Thank you guys!! More to come eheh
                      • D Denver Bennett referenced this topic on
