  3. Starling V2 voxl-configure-mpa fails to execute voxl-esc setup_starling_v2 and voxl-elrs --scan
17 Posts 5 Posters 3.8k Views 2 Watching
  • Erik PriestE Offline
    Erik Priest
    I had originally posted this in the Software Development topic in the forum however, I realized that it was the wrong location for this question so I have deleted the old topic and moved it over here.
    VOXL VERSION:
    system-image: 1.6.2-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Fri May 19 22:19:33 UTC 2023 4.19.125
    hw version:   M0054
    voxl-suite:   1.0.0
    I am experiencing an issue with the VOXL 2 Starling V2 when I run the voxl-configure-mpa command I get the following output:
    executing: voxl-esc setup_starling_v2
    enabling bridge
    detected voxl-px4 is enabled
    Removed /etc/systemd/system/multi-user.target.wants/voxl-px4.service.
    detected voxl-px4 is running, stopping it now
    bridge enabled
    [INFO] Scanning for ESC...
    Error calling voxl_uart_init
    [ERROR] Unknown board detected:
    disabling bridge
    re-enabling voxl-px4
    Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
    restarting voxl-px4
    bridge disabled
    EXITING VOXL-ESC WITH ERROR
    FAILED TO EXECUTE: voxl-esc setup_starling_v2
    And
    executing: voxl-elrs --scan
      File "/usr/bin/voxl-elrs", line 718, in <module>
        exit(scan())
      File "/usr/bin/voxl-elrs", line 468, in scan
        sw_version = get_version()
      File "/usr/bin/voxl-elrs", line 456, in get_version
        get_device_info()
      File "/usr/bin/voxl-elrs", line 273, in get_device_info
        bytes_read = int(result.stdout.decode().split("\n")[-3])
    ValueError: invalid literal for int() with base 10: 'Sending library name request: libslpi_uart_bridge_slpi.so'
    FAILED TO EXECUTE: voxl-elrs --scan
    Additionally each time it seems that the Starling_V2.params have to be reloaded despite being set in the previous voxl-configure-mpa run:
    The following parameters about to be loaded differ from those currently loaded:
    	NAME    		CURRENT    	NEW
    [1]	CBRK_IO_SAFETY    	N/A		22027
    [2]	CBRK_SUPPLY_CHK    	N/A		894281
    [3]	COM_CPU_MAX    		N/A		-1
    [4]	COM_OF_LOSS_T    	N/A		3.0
    [5]	NAV_ACC_RAD    		N/A		2.0
    [6]	GPS_UBX_DYNMODEL    	N/A		6
    [7]	RTL_RETURN_ALT    	N/A		30
    [8]	RTL_DESCEND_ALT    	N/A		10
    [9]	IMU_GYRO_RATEMAX    	N/A		800
    [10]	SYS_AUTOSTART    	N/A		4001
    [11]	MAV_TYPE    		N/A		2
    [12]	SENS_BOARD_ROT    	N/A		0
    [13]	BAT1_N_CELLS    	N/A		2
    [14]	BAT1_R_INTERNAL    	N/A		0.025
    [15]	BAT1_CAPACITY    	N/A		2900
    [16]	BAT1_V_CHARGED    	N/A		4.0
    [17]	BAT1_V_EMPTY    	N/A		2.9
    [18]	BAT_LOW_THR    		N/A		0.15
    [19]	BAT_CRIT_THR    	N/A		0.10
    [20]	BAT_EMERGEN_THR    	N/A		0.05
    [21]	MPC_THR_HOVER    	N/A		0.35
    [22]	THR_MDL_FAC    		N/A		0.9
    [23]	MODAL_IO_RPM_MAX    	N/A		15000
    [24]	MODAL_IO_RPM_MIN    	N/A		3000
    [25]	MODAL_IO_FUNC1    	N/A		101
    [26]	MODAL_IO_FUNC2    	N/A		104
    [27]	MODAL_IO_FUNC3    	N/A		102
    [28]	MODAL_IO_FUNC4    	N/A		103
    [29]	MODAL_IO_SDIR1    	N/A		0
    [30]	MODAL_IO_SDIR2    	N/A		0
    [31]	MODAL_IO_SDIR3    	N/A		0
    [32]	MODAL_IO_SDIR4    	N/A		0
    [33]	MODAL_IO_BAUD    	N/A		2000000
    [34]	MODAL_IO_CONFIG    	N/A		1
    [35]	MODAL_IO_MODE    	N/A		0
    [36]	MODAL_IO_REV    	N/A		0
    [37]	MODAL_IO_T_COSP    	N/A		0.990000009536743164
    [38]	MODAL_IO_T_DEAD    	N/A		20
    [39]	MODAL_IO_T_EXPO    	N/A		35
    [40]	MODAL_IO_T_MINF    	N/A		0.150000005960464478
    [41]	MODAL_IO_T_PERC    	N/A		90
    [42]	MODAL_IO_VLOG    	N/A		1
    [43]	MC_BAT_SCALE_EN    	N/A		0
    [44]	EKF2_IMU_POS_X    	N/A		0.0157
    [45]	EKF2_IMU_POS_Y    	N/A		0.0078
    [46]	EKF2_IMU_POS_Z    	N/A		-0.0180
    [47]	EKF2_EV_POS_X    	N/A		0.0
    [48]	EKF2_EV_POS_Y    	N/A		0.0
    [49]	EKF2_EV_POS_Z    	N/A		0.0
    [50]	CA_AIRFRAME    		N/A		0
    [51]	CA_ROTOR_COUNT    	N/A		4
    [52]	CA_ROTOR0_PX    	N/A		0.085
    [53]	CA_ROTOR0_PY    	N/A		0.0625
    [54]	CA_ROTOR1_PX    	N/A		-0.085
    [55]	CA_ROTOR1_PY    	N/A		-0.0625
    [56]	CA_ROTOR2_PX    	N/A		0.085
    [57]	CA_ROTOR2_PY    	N/A		-0.0625
    [58]	CA_ROTOR3_PX    	N/A		-0.085
    [59]	CA_ROTOR3_PY    	N/A		0.0625
    [60]	CA_ROTOR0_AX    	N/A		0.0
    [61]	CA_ROTOR0_AY    	N/A		0.0
    [62]	CA_ROTOR1_AX    	N/A		0.0
    [63]	CA_ROTOR1_AY    	N/A		0.0
    [64]	CA_ROTOR2_AX    	N/A		0.0
    [65]	CA_ROTOR2_AY    	N/A		0.0
    [66]	CA_ROTOR3_AX    	N/A		0.0
    [67]	CA_ROTOR3_AY    	N/A		0.0
    [68]	CA_ROTOR0_KM    	N/A		0.05
    [69]	CA_ROTOR1_KM    	N/A		0.05
    [70]	CA_ROTOR2_KM    	N/A		-0.05
    [71]	CA_ROTOR3_KM    	N/A		-0.05
    [72]	MOT_SLEW_MAX    	N/A		0.0
    [73]	IMU_DGYRO_CUTOFF    	N/A		80.0
    [74]	IMU_ACCEL_CUTOFF    	N/A		80.0
    [75]	IMU_GYRO_CUTOFF    	N/A		150.0
    [76]	IMU_GYRO_DNF_EN    	N/A		1
    [77]	IMU_GYRO_DNF_HMC    	N/A		3
    [78]	IMU_GYRO_DNF_BW    	N/A		15
    [79]	MC_AIRMODE    		N/A		0
    [80]	MC_PITCH_P    		N/A		12.0
    [81]	MC_PITCHRATE_P    	N/A		0.08
    [82]	MC_PITCHRATE_I    	N/A		0.15
    [83]	MC_PITCHRATE_D    	N/A		0.0006
    [84]	MC_PITCHRATE_K    	N/A		1.0
    [85]	MC_ROLL_P    		N/A		12.0
    [86]	MC_ROLLRATE_P    	N/A		0.065
    [87]	MC_ROLLRATE_I    	N/A		0.15
    [88]	MC_ROLLRATE_D    	N/A		0.0005
    [89]	MC_ROLLRATE_K    	N/A		1.0
    [90]	MC_YAW_P    		N/A		2.8
    [91]	MC_YAWRATE_P    	N/A		0.15
    [92]	MC_YAWRATE_I    	N/A		0.5
    [93]	MC_YAWRATE_D    	N/A		0.0
    [94]	MC_YAWRATE_K    	N/A		1.0
    [95]	MC_ROLLRATE_MAX    	N/A		150.0
    [96]	MC_PITCHRATE_MAX    	N/A		150.0
    [97]	MC_YAWRATE_MAX    	N/A		150.0
    [98]	MPC_POS_MODE    	N/A		4
    [99]	MPC_YAW_EXPO    	N/A		0.30
    [100]	MPC_XY_MAN_EXPO    	N/A		0.45
    [101]	MPC_Z_MAN_EXPO    	N/A		0.10
    [102]	MPC_ACC_HOR    		N/A		3.0
    [103]	MPC_JERK_MAX    	N/A		40.0
    [104]	MPC_TILTMAX_AIR    	N/A		30.0
    [105]	MPC_ACC_HOR_MAX    	N/A		6.0
    [106]	MPC_ACC_UP_MAX    	N/A		3.0
    [107]	MPC_ACC_DOWN_MAX    	N/A		3.0
    [108]	MPC_VEL_MANUAL    	N/A		3.0
    [109]	MPC_XY_VEL_MAX    	N/A		3.0
    [110]	MPC_XY_CRUISE    	N/A		3.0
    [111]	MPC_Z_VEL_MAX_DN    	N/A		1.0
    [112]	MPC_Z_VEL_MAX_UP    	N/A		1.0
    [113]	MPC_LAND_SPEED    	N/A		1.0
    [114]	MPC_THR_MAX    		N/A		0.70
    [115]	MPC_THR_MIN    		N/A		0.08
    [116]	MPC_MANTHR_MIN    	N/A		0.08
    [117]	MPC_XY_P    		N/A		3.50
    [118]	MPC_XY_VEL_P_ACC    	N/A		3.00
    [119]	MPC_XY_VEL_I_ACC    	N/A		0.10
    [120]	MPC_XY_VEL_D_ACC    	N/A		0.00
    [121]	MPC_Z_P    		N/A		5.0
    [122]	MPC_Z_VEL_P_ACC    	N/A		8.0
    [123]	MPC_Z_VEL_I_ACC    	N/A		2.0
    [124]	MPC_Z_VEL_D_ACC    	N/A		0currently.0
    [125]	MPC_TKO_RAMP_T    	N/A		2.00
    [126]	MPC_TKO_SPEED    	N/A		1.50
    [127]	COM_SPOOLUP_TIME    	N/A		1.0
    [128]	LNDMC_ROT_MAX    	N/A		30.0
    [129]	COM_DISARM_LAND    	N/A		0.1
    [130]	COM_DISARM_PRFLT    	N/A		20
    [INFO] Setting params...
    [INFO] Px4 parameter configuration successful!
    What I have done to fix the issue:
    • apt update && apt upgrade
    • disabled voxl-px4 and rebooted before running voxl-configure-mpa again and same result
    I'm not sure how to fix this issue and would appreciate any help. I am concerned that if I attempt to fly the drone it will fail due to the configuration failing.
    *Side Note: QGroundControl also does not work
    Edit 1:
    My post has been partially answered by this post https://forum.modalai.com/topic/2805/voxl-configure-mpa-failled-on-voxl-esc-step as they are experiencing the same issues I am having at each step. However, in addition to their problem the voxl-elrs --scan does not work for me. However the cables look like they are all present based on the provided diagram https://docs.modalai.com/images/starling-v2/D0005-compute-wiring-d.jpg.
    • Erik PriestE Erik Priest
      VOXL VERSION:
      hw version:   M0054
      voxl-suite:   1.0.0
      enabling bridge
      bridge enabled
      disabling bridge
      restarting voxl-px4
      bridge disabled
      And
          exit(scan())
          get_device_info()
      	NAME    		CURRENT    	NEW
      [11]	MAV_TYPE    		N/A		2
      Edit 1:
      @Erik-Priest I would recommend trying a "factory flash" of the SDK:
      cd voxl2_SDK_1.0.0
      cd system-image
      ./flash-system-image.sh -f
      cd ..
      cd voxl-suite
      ./offline-install.sh
      adb shell
      This will lose your calibration files but i can provide them to you
      Erik PriestE 1 Reply Last reply
        cd voxl2_SDK_1.0.0
        cd system-image
        cd ..
        cd voxl-suite
        adb shell
        Erik Priest
        @tom I have preformed the tasks and everything successfully ran. Where can I find the configuration files, is it available on the same download page as the sdk download?
          @Erik-Priest If you provide me the serial number of your Starling I can provide them to you. The serial number should be located on the bottom of the frame and will be in the form M2X00000XXX
            Erik Priest
            @tom The serial number is M2100000FT2, let know if its better to send as a private message if possible.
              @Erik-Priest I'll send you an email to your address on file with the forum.
              Riccardo FranceschiniR 1 Reply Last reply
              • S smilon referenced this topic on
                Riccardo FranceschiniR Offline
                Hi @tom, we are facing a similar problem on two boards that we have, and we solved the issue by following your suggestions. However, we no longer have the calibration files. Would it be possible to also obtain the calibration files? The serials are : M2100000J2R and M22000003EV
                • Riccardo FranceschiniR Riccardo Franceschini referenced this topic on
                  @Riccardo-Franceschini We store calibration data by the serial number of the drone itself not the serial number of the voxl2 board. Can you send me the serial numbers of the drone themselves? I believe on starling they are on the bottom of the frame.
                  V 1 Reply Last reply
                    V Offline
                    V Offline
                    Vin
                    Hi @tom ,
                    We are having similar issue with Starling, problem contacting ESC.
                    Multiple flash with different SDK version all successful, can run spin which does spin all motors, however cannot arm from controller
                    Model number: M23000001JV
                    • V Vin
                      Hi @tom ,
                      V Offline
                      V Offline
                      Vin
                      Screenshot from 2024-01-13 00-11-01.png Screenshot from 2024-01-13 00-10-38.png
                      • V Vin
                        @Vin make sure you stop PX4 before running the voxl-esc tools directly. Can you please confirm that you did it?
                        You can check if px4 is running:
                        systemctl is-active voxl-px4
                        stop px4:
                        systemctl stop voxl-px4
                          stop px4:
                          V Offline
                          V Offline
                          Vin
                          Thanks @Alex-Kushleyev,
                          The issue with voxl-esc as you have indicated was to do with voxl-px4 and would resolve by stopping voxl-p4.
                          There was some sort of partition layout being in correct so ended up doing full wipe and thus RC would not ARM due to calibration required.
                          As /data/ partition gets wiped out along with all the factory calibration files.
                          Ended up doing Calibration as described here
                          https://docs.modalai.com/px4-calibrate-sensors/
                          Now RC can talk and ARM.
                          Are these files available somewhere to reset back to factory state?
                          • V Vin
                            wrote on last edited by tom
                            #13
                            @Vin If you can provide the serial number of your Starling (located on bottom of frame, in form MXX00000XXX) I can provide you your cam cal files
                              V Offline
                              V Offline
                              Vin
                              Thanks @tom
                              Serial Number: M23000001JV
                              Do we know what are the right propellers for Starling drone.
                              From what I could make out would it be Mavic-Mini-2-Propellers-Set 4726
                              Trying to get back to a state where position hold is stable
                              tomT 2 Replies Last reply
                              • V Vin
                                Thanks @tom
                                @Vin I emailed you your cam cal file to the email address associated with your forum account.
                                • V Vin
                                  Thanks @tom
                                  @Vin You can purchase replacement propellers here: https://www.modalai.com/products/starling-propellers-set-of-4?_pos=3&_sid=b428d2f80&_ss=r
                                    V Offline
                                    V Offline
                                    Vin
                                    Thanks @tom much appreciated. Received the file.
                                    Was following the instructions as mentioned here https://docs.modalai.com/calibrate-cameras/ for better understanding of calibration files.
