  3. ESC Issue On SDK 1.0.0
18 Posts 5 Posters 3.0k Views 3 Watching
  • John Nomikos 0J Offline
    John Nomikos 0
    Good afternoon,
    I am having an issue where I cannot get ESC to work and props to spin on 1.0.0. When I am on 0.9, the blue indicator light on the ESC flashes and I am able to spin props. Once I upgrade to 1.0.0, the light does not flash anymore and I cannot spin props.
    Is there something I need to do to setup the ESC on 1.0.0?
    Thank you for the help,
    John Nomikos.
    John Nomikos 0J 1 Reply Last reply
    • John Nomikos 0J John Nomikos 0
      Good afternoon,
      John Nomikos.
      John Nomikos 0
      voxl2:/$ px4-qshell modalai_esc
      INFO  [qshell] Send cmd: 'modalai_esc'
      INFO  [qshell] cmd returned with: 1
      INFO  [qshell] qshell return value timestamp: 315219591, local time: 315220325
      ERROR [qshell] Command failed
      voxl2:/$ px4-listener esc_status
      TOPIC: esc_status
       esc_status
          timestamp: 12877338 (321.160156 seconds ago)
          counter: 0
          esc_count: 4
          esc_connectiontype: 1
          esc_online_flags: 0
          esc_armed_flags: 0
        esc[0] (esc_report):
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          esc_voltage: 0.00000
          esc_current: 0.00000
          esc_temperature: 0.00000
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          actuator_function: 0
          esc_power: 0
        esc[1] (esc_report):
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
        esc[2] (esc_report):
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
        esc[3] (esc_report):
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
        esc[4] (esc_report):
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
        esc[5] (esc_report):
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
        esc[6] (esc_report):
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
        esc[7] (esc_report):
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
        TOPIC: esc_status
         esc_status
            counter: 0
            esc_count: 4
            esc_online_flags: 0
            esc_armed_flags: 0
            timestamp: 0
            esc_errorcount: 0
            esc_rpm: 0
            failures: 0
            esc_address: 0
            esc_cmdcount: 0
            esc_state: 0
            esc_power: 0
            timestamp: 0
            esc_errorcount: 0
            esc_rpm: 0
            failures: 0
            esc_address: 0
            esc_cmdcount: 0
            esc_state: 0
            esc_power: 0
            timestamp: 0
            esc_errorcount: 0
            esc_rpm: 0
            failures: 0
            esc_address: 0
            esc_cmdcount: 0
            esc_state: 0
            esc_power: 0
            timestamp: 0
            esc_errorcount: 0
            esc_rpm: 0
            failures: 0
            esc_address: 0
            esc_cmdcount: 0
            esc_state: 0
            esc_power: 0
            timestamp: 0
            esc_errorcount: 0
            esc_rpm: 0
            failures: 0
            esc_address: 0
            esc_cmdcount: 0
            esc_state: 0
            esc_power: 0
            timestamp: 0
            esc_errorcount: 0
            esc_rpm: 0
            failures: 0
            esc_address: 0
            esc_cmdcount: 0
            esc_state: 0
            esc_power: 0
            timestamp: 0
            esc_errorcount: 0
            esc_rpm: 0
            failures: 0
            esc_address: 0
            esc_cmdcount: 0
            esc_state: 0
            esc_power: 0
            timestamp: 0
            esc_errorcount: 0
            esc_rpm: 0
            failures: 0
            esc_address: 0
            esc_cmdcount: 0
            esc_state: 0
            esc_power: 0
        @John-Nomikos-0 What do you get with voxl-esc scan?
          John Nomikos 0
          wrote on last edited by John Nomikos 0
          @tom
          It does seem to be detecting the ESCs with that command.
          Strange that the blue light does not blink and spinning is not working on 1.0.0
          Here is the output:
          voxl2:/$ voxl-esc scan
          enabling bridge
          detected voxl-px4 is enabled
          Removed /etc/systemd/system/multi-user.target.wants/voxl-px4.service.
          detected voxl-px4 is running, stopping it now
          bridge enabled
          [GCC 8.4.0]
          Found voxl-esc tools bin version: 1.2
          VOXL Platform: M0054
          Detected VOXL2 M0054 or M0104!
          Sending library name request: libslpi_uart_bridge_slpi.so
          INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 250000
          INFO: Detected protocol: firmware
          INFO: Additional Information:
          INFO: ---------------------
          	Board      : version 31: ModalAi 4-in-1 ESC V2 RevB (M0049)
          	UID        : 0x2032353450415714003E004A
          	Firmware   : version   34, hash 833243c0
          	Bootloader : version  183, hash 0a80a32a
          	UID        : 0x20323534504157140042002B
          	UID        : 0x20323534504157140042002E
          	UID        : 0x203235345041571400420034
          successfully pinged ESCs
          disabling bridge
          re-enabling voxl-px4
          Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
          restarting voxl-px4
          bridge disabled
            @tom
            Here is the output:
            enabling bridge
            bridge enabled
            [GCC 8.4.0]
            disabling bridge
            restarting voxl-px4
            bridge disabled
            John Nomikos 0
            @tom
            I found that doing voxl-esc spin is working.
            Testing on actuators tab on QGC does not.
            Also tried to do "px4-qshell commander arm -f" and it successfully armed and showed it was flying, but props are not spinning
            wilkinsafW Eric KatzfeyE 2 Replies Last reply
              @tom
              wilkinsafW Offline
              wilkinsafW Offline
              wilkinsaf
              To clear things up.
              The ESC is not working when we arm. It does not spin with "actuators" tab.
              The ESC only spins a motor when we issue a "voxl-esc" on the command line
              • wilkinsafW wilkinsaf
                To clear things up.
                @wilkinsaf Please post the settings of all of the MODAL_IO_* parameters. E.g. px4-param show MODAL_IO_*
                  John Nomikos 0
                  @Eric-Katzfey here are the params. Let me know if you need anything else.
                  voxl2:/$ px4-param show MODAL_IO_*
                  Symbols: x = used, + = saved, * = unsaved
                  x + MODAL_IO_BAUD [508,1061] : 2000000
                  x + MODAL_IO_CONFIG [509,1062] : 1
                  x + MODAL_IO_FUNC1 [510,1063] : 101
                  x + MODAL_IO_FUNC2 [511,1064] : 104
                  x + MODAL_IO_FUNC3 [512,1065] : 102
                  x + MODAL_IO_FUNC4 [513,1066] : 103
                  x   MODAL_IO_MODE [514,1067] : 0
                  x   MODAL_IO_REV [515,1068] : 0
                  x   MODAL_IO_RPM_MAX [516,1069] : 15000
                  x + MODAL_IO_RPM_MIN [517,1070] : 3000
                  x   MODAL_IO_SDIR1 [518,1071] : 0
                  x   MODAL_IO_SDIR2 [519,1072] : 0
                  x   MODAL_IO_SDIR3 [520,1073] : 0
                  x   MODAL_IO_SDIR4 [521,1074] : 0
                  x   MODAL_IO_T_COSP [522,1075] : 0.9900
                  x   MODAL_IO_T_DEAD [523,1076] : 20
                  x   MODAL_IO_T_EXPO [524,1077] : 35
                  x   MODAL_IO_T_MINF [525,1078] : 0.1500
                  x   MODAL_IO_T_PERC [526,1079] : 90
                  x + MODAL_IO_VLOG [527,1080] : 1
                   799/2092 parameters used.
                    @John-Nomikos-0 Okay, I don't see anything obviously wrong with those. Can you arm the drone and collect a log?
                      @tom
                      @John-Nomikos-0 When you arm you are using the -f flag to force it. What happens if you don't use the force flag? Does it give you some errors?
                      wilkinsafW 1 Reply Last reply
                        wilkinsafW Offline
                        wilkinsafW Offline
                        wilkinsaf
                        @Eric-Katzfey John left to go home, but popped into the other room to run this
                        I keep on getting a failsafe activated the MOMENT we try and arm.
                        I can not seem to get more than this message. I am going to manually run voxl-px4 to see if I can get better output
                          wilkinsafW Offline
                          wilkinsafW Offline
                          wilkinsaf
                          Here is the output from voxl-px4 once we requested to arm
                          INFO  [muorb] SLPI: Advertising remote topic ping
                          WARN  [uORB] orb_advertise_multi: failed to set queue size
                          INFO  [uORB] Marking DeviceNode(mavlink_log) as advertised in process_remote_topic
                          INFO  [muorb] SLPI: Armed by external command
                          INFO  [logger] Start file log (type: full)
                          INFO  [logger] [logger] /data/px4/log/2023-03-02/12_59_17.ulg
                          INFO  [logger] Opened full log file: /data/px4/log/2023-03-02/12_59_17.ulg
                          WARN  [mavlink] Event dropped (37, 65526)
                          INFO  [muorb] SLPI: Advertising remote topic logger_status
                          WARN  [mavlink] Dropped 65489 events (seq=65526)
                          INFO  [muorb] SLPI: Failsafe activated
                          INFO  [muorb] SLPI: Disarmed by failsafe
                          INFO  [uORB] Marking DeviceNode(parameter_server_set_value_request) as advertised in process_remote_topic
                          WARN  [mavlink] Event dropped (65527, 37)
                          WARN  [mavlink] Dropped 28 events (seq=37)
                          INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_value_response) as advertised in process_remote_t
                          INFO  [logger] closed logfile, bytes written: 221550
                            @wilkinsaf Okay, that's not very useful. Definitely going to have to figure out a way to make PX4 provide an actual reason. Our ESC guru Alex thinks that the older ESC firmware you have defaults to a different baudrate than we are expecting in SDK 1.0.0 PX4. So he will respond later with the ESC parameter change that will allow them to have the same baudrate.
                              wilkinsafW Offline
                              wilkinsafW Offline
                              wilkinsaf
                              wrote on last edited by wilkinsaf
                              #14
                              @Eric-Katzfey Thanks Eric.
                              I imagine we are going to have to connect the ESC to FTDI to laptop. Or is it possible to change this on VOXL2 terminal.
                                wilkinsafW Offline
                                wilkinsafW Offline
                                wilkinsaf
                                I guess Alex will know that. Thanks!
                                  @wilkinsaf You should be able to do it directly on VOXL2 with voxl-esc.
                                    @wilkinsaf @John-Nomikos-0
                                    Based on your description of the problem (when you switch from SDK 0.9 to 1.0.0, the ESCs start responding), it sounds like a mismatch in the UART baud rate in ESC and PX4 params. When going from 0.9 to 1.0.0 we have changed the baud rate for ESCs in PX4 params from 250K to 2M. Accordingly, we have updated the ESC params to 2M as well (ESC firmware and params are part of voxl-esc package). However, since you did not perform an ESC firmware / param update, your ESC is still running at 250K baud rate, but the latest PX4 is expecting 2Mbit.
                                    From your output of esc scan, this is confirmed:
                                    You have several options:
                                    • Change your PX4 param MODAL_IO_BAUD from 2000000 to 250000 in order to match what your ESC is currently using
                                    • Update the ESC firmware and params while the ESC is connected to VOXL2 (with SDK 1.0.0 installed, which will have the latest voxl-esc package with latest firmware and params). Please see this post about updating firmware and params: https://forum.modalai.com/topic/2509/voxl-2-mini-with-mini-4-in-1-esc-no-battery-information/5 . Please note that if you are currently using non-standard ESC params, you will need to make a few updates to them in order to make them compatible with the latest parameter files. If that is the case, let me know, i can help.
                                      John Nomikos 0
                                      @Alex-Kushleyev
                                      Confirmed, changing the MODAL_IO_BAUD to 250000 fixed the problem for me. Thank you so much for the help!
