  3. ESC Issue On SDK 1.0.0
voxl-2
18 Posts 5 Posters 3.2k Views 3 Watching
  • John Nomikos 0J John Nomikos 0
    Good afternoon,
    I am having an issue where I cannot get ESC to work and props to spin on 1.0.0. When I am on 0.9, the blue indicator light on the ESC flashes and I am able to spin props. Once I upgrade to 1.0.0, the light does not flash anymore and I cannot spin props.
    Is there something I need to do to setup the ESC on 1.0.0?
    Thank you for the help,
    John Nomikos.
    John Nomikos 0J Offline
    John Nomikos 0
    voxl2:/$ px4-qshell modalai_esc
    INFO  [qshell] Send cmd: 'modalai_esc'
    INFO  [qshell] cmd returned with: 1
    INFO  [qshell] qshell return value timestamp: 315219591, local time: 315220325
    ERROR [qshell] Command failed
    voxl2:/$ px4-listener esc_status
    TOPIC: esc_status
     esc_status
        timestamp: 12877338 (321.160156 seconds ago)
        counter: 0
        esc_count: 4
        esc_connectiontype: 1
        esc_online_flags: 0
        esc_armed_flags: 0
      esc[0] (esc_report):
        timestamp: 0
        esc_errorcount: 0
        esc_rpm: 0
        esc_voltage: 0.00000
        esc_current: 0.00000
        esc_temperature: 0.00000
        failures: 0
        esc_address: 0
        esc_cmdcount: 0
        esc_state: 0
        actuator_function: 0
        esc_power: 0
      esc[1] (esc_report):
        timestamp: 0
        esc_errorcount: 0
        esc_rpm: 0
        failures: 0
        esc_address: 0
        esc_cmdcount: 0
        esc_state: 0
        esc_power: 0
      esc[2] (esc_report):
        timestamp: 0
        esc_errorcount: 0
        esc_rpm: 0
        failures: 0
        esc_address: 0
        esc_cmdcount: 0
        esc_state: 0
        esc_power: 0
      esc[3] (esc_report):
        timestamp: 0
        esc_errorcount: 0
        esc_rpm: 0
        failures: 0
        esc_address: 0
        esc_cmdcount: 0
        esc_state: 0
        esc_power: 0
      esc[4] (esc_report):
        timestamp: 0
        esc_errorcount: 0
        esc_rpm: 0
        failures: 0
        esc_address: 0
        esc_cmdcount: 0
        esc_state: 0
        esc_power: 0
      esc[5] (esc_report):
        timestamp: 0
        esc_errorcount: 0
        esc_rpm: 0
        failures: 0
        esc_address: 0
        esc_cmdcount: 0
        esc_state: 0
        esc_power: 0
      esc[6] (esc_report):
        timestamp: 0
        esc_errorcount: 0
        esc_rpm: 0
        failures: 0
        esc_address: 0
        esc_cmdcount: 0
        esc_state: 0
        esc_power: 0
      esc[7] (esc_report):
        timestamp: 0
        esc_errorcount: 0
        esc_rpm: 0
        failures: 0
        esc_address: 0
        esc_cmdcount: 0
        esc_state: 0
        esc_power: 0
      TOPIC: esc_status
       esc_status
          counter: 0
          esc_count: 4
          esc_online_flags: 0
          esc_armed_flags: 0
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
          timestamp: 0
          esc_errorcount: 0
          esc_rpm: 0
          failures: 0
          esc_address: 0
          esc_cmdcount: 0
          esc_state: 0
          esc_power: 0
      @John-Nomikos-0 What do you get with voxl-esc scan?
      John Nomikos 0J 1 Reply Last reply
        John Nomikos 0
        wrote on last edited by John Nomikos 0
        It does seem to be detecting the ESCs with that command.
        Strange that the blue light does not blink and spinning is not working on 1.0.0
        Here is the output:
        voxl2:/$ voxl-esc scan
        enabling bridge
        detected voxl-px4 is enabled
        Removed /etc/systemd/system/multi-user.target.wants/voxl-px4.service.
        detected voxl-px4 is running, stopping it now
        bridge enabled
        [GCC 8.4.0]
        VOXL Platform: M0054
        Detected VOXL2 M0054 or M0104!
        Sending library name request: libslpi_uart_bridge_slpi.so
        INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 250000
        INFO: Additional Information:
        INFO: ---------------------
        	Board      : version 31: ModalAi 4-in-1 ESC V2 RevB (M0049)
        	UID        : 0x2032353450415714003E004A
        	Firmware   : version   34, hash 833243c0
        	Bootloader : version  183, hash 0a80a32a
        	UID        : 0x20323534504157140042002B
        	UID        : 0x20323534504157140042002E
        	UID        : 0x203235345041571400420034
        successfully pinged ESCs
        disabling bridge
        re-enabling voxl-px4
        Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
        restarting voxl-px4
        bridge disabled
          Here is the output:
          enabling bridge
          bridge enabled
          [GCC 8.4.0]
          disabling bridge
          restarting voxl-px4
          bridge disabled
          John Nomikos 0
          I found that doing voxl-esc spin is working.
          Testing on actuators tab on QGC does not.
          Also tried to do "px4-qshell commander arm -f" and it successfully armed and showed it was flying, but props are not spinning
          wilkinsafW Eric KatzfeyE 2 Replies Last reply
            wilkinsafW Offline
            wilkinsafW Offline
            wilkinsaf
            To clear things up.
            The ESC is not working when we arm. It does not spin with "actuators" tab.
            The ESC only spins a motor when we issue a "voxl-esc" on the command line
            • wilkinsafW wilkinsaf
              To clear things up.
              @wilkinsaf Please post the settings of all of the MODAL_IO_* parameters. E.g. px4-param show MODAL_IO_*
                John Nomikos 0
                @Eric-Katzfey here are the params. Let me know if you need anything else.
                voxl2:/$ px4-param show MODAL_IO_*
                Symbols: x = used, + = saved, * = unsaved
                x + MODAL_IO_BAUD [508,1061] : 2000000
                x + MODAL_IO_CONFIG [509,1062] : 1
                x + MODAL_IO_FUNC1 [510,1063] : 101
                x + MODAL_IO_FUNC2 [511,1064] : 104
                x + MODAL_IO_FUNC3 [512,1065] : 102
                x + MODAL_IO_FUNC4 [513,1066] : 103
                x   MODAL_IO_MODE [514,1067] : 0
                x   MODAL_IO_REV [515,1068] : 0
                x   MODAL_IO_RPM_MAX [516,1069] : 15000
                x + MODAL_IO_RPM_MIN [517,1070] : 3000
                x   MODAL_IO_SDIR1 [518,1071] : 0
                x   MODAL_IO_SDIR2 [519,1072] : 0
                x   MODAL_IO_SDIR3 [520,1073] : 0
                x   MODAL_IO_SDIR4 [521,1074] : 0
                x   MODAL_IO_T_COSP [522,1075] : 0.9900
                x   MODAL_IO_T_DEAD [523,1076] : 20
                x   MODAL_IO_T_EXPO [524,1077] : 35
                x   MODAL_IO_T_MINF [525,1078] : 0.1500
                x   MODAL_IO_T_PERC [526,1079] : 90
                x + MODAL_IO_VLOG [527,1080] : 1
                 799/2092 parameters used.
                  @John-Nomikos-0 Okay, I don't see anything obviously wrong with those. Can you arm the drone and collect a log?
                    @John-Nomikos-0 When you arm you are using the -f flag to force it. What happens if you don't use the force flag? Does it give you some errors?
                    wilkinsafW 1 Reply Last reply
                      wilkinsafW Offline
                      wilkinsafW Offline
                      wilkinsaf
                      @Eric-Katzfey John left to go home, but popped into the other room to run this
                      I keep on getting a failsafe activated the MOMENT we try and arm.
                      I can not seem to get more than this message. I am going to manually run voxl-px4 to see if I can get better output
                        wilkinsafW Offline
                        wilkinsafW Offline
                        wilkinsaf
                        Here is the output from voxl-px4 once we requested to arm
                        INFO  [muorb] SLPI: Advertising remote topic ping
                        WARN  [uORB] orb_advertise_multi: failed to set queue size
                        INFO  [uORB] Marking DeviceNode(mavlink_log) as advertised in process_remote_topic
                        INFO  [muorb] SLPI: Armed by external command
                        INFO  [logger] Start file log (type: full)
                        INFO  [logger] [logger] /data/px4/log/2023-03-02/12_59_17.ulg
                        INFO  [logger] Opened full log file: /data/px4/log/2023-03-02/12_59_17.ulg
                        WARN  [mavlink] Event dropped (37, 65526)
                        INFO  [muorb] SLPI: Advertising remote topic logger_status
                        WARN  [mavlink] Dropped 65489 events (seq=65526)
                        INFO  [muorb] SLPI: Failsafe activated
                        INFO  [muorb] SLPI: Disarmed by failsafe
                        INFO  [uORB] Marking DeviceNode(parameter_server_set_value_request) as advertised in process_remote_topic
                        WARN  [mavlink] Event dropped (65527, 37)
                        WARN  [mavlink] Dropped 28 events (seq=37)
                        INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_value_response) as advertised in process_remote_t
                        INFO  [logger] closed logfile, bytes written: 221550
                          @wilkinsaf Okay, that's not very useful. Definitely going to have to figure out a way to make PX4 provide an actual reason. Our ESC guru Alex thinks that the older ESC firmware you have defaults to a different baudrate than we are expecting in SDK 1.0.0 PX4. So he will respond later with the ESC parameter change that will allow them to have the same baudrate.
                            wilkinsafW Offline
                            wilkinsafW Offline
                            wilkinsaf
                            #14
                            @Eric-Katzfey Thanks Eric.
                            I imagine we are going to have to connect the ESC to FTDI to laptop. Or is it possible to change this on VOXL2 terminal.
                              wilkinsafW Offline
                              wilkinsafW Offline
                              wilkinsaf
                              I guess Alex will know that. Thanks!
                                @wilkinsaf You should be able to do it directly on VOXL2 with voxl-esc.
                                  @wilkinsaf @John-Nomikos-0
                                  Based on your description of the problem (when you switch from SDK 0.9 to 1.0.0, the ESCs start responding), it sounds like a mismatch in the UART baud rate in ESC and PX4 params. When going from 0.9 to 1.0.0 we have changed the baud rate for ESCs in PX4 params from 250K to 2M. Accordingly, we have updated the ESC params to 2M as well (ESC firmware and params are part of voxl-esc package). However, since you did not perform an ESC firmware / param update, your ESC is still running at 250K baud rate, but the latest PX4 is expecting 2Mbit.
                                  From your output of esc scan, this is confirmed:
                                  You have several options:
                                  • Change your PX4 param MODAL_IO_BAUD from 2000000 to 250000 in order to match what your ESC is currently using
                                  • Update the ESC firmware and params while the ESC is connected to VOXL2 (with SDK 1.0.0 installed, which will have the latest voxl-esc package with latest firmware and params). Please see this post about updating firmware and params: https://forum.modalai.com/topic/2509/voxl-2-mini-with-mini-4-in-1-esc-no-battery-information/5 . Please note that if you are currently using non-standard ESC params, you will need to make a few updates to them in order to make them compatible with the latest parameter files. If that is the case, let me know, i can help.
                                    John Nomikos 0
                                    Confirmed, changing the MODAL_IO_BAUD to 250000 fixed the problem for me. Thank you so much for the help!
