  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. ESC Issue On SDK 1.0.0
18 Posts 5 Posters 2.7k Views 3 Watching
  • John Nomikos 0J John Nomikos 0
    It does seem to be detecting the ESCs with that command.
    Strange that the blue light does not blink and spinning is not working on 1.0.0
    Here is the output:
    voxl2:/$ voxl-esc scan
    enabling bridge
    detected voxl-px4 is enabled
    Removed /etc/systemd/system/multi-user.target.wants/voxl-px4.service.
    detected voxl-px4 is running, stopping it now
    bridge enabled
    [GCC 8.4.0]
    VOXL Platform: M0054
    Detected VOXL2 M0054 or M0104!
    Sending library name request: libslpi_uart_bridge_slpi.so
    INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 250000
    INFO: Additional Information:
    INFO: ---------------------
    	Board      : version 31: ModalAi 4-in-1 ESC V2 RevB (M0049)
    	UID        : 0x2032353450415714003E004A
    	Firmware   : version   34, hash 833243c0
    	Bootloader : version  183, hash 0a80a32a
    	UID        : 0x20323534504157140042002B
    	UID        : 0x20323534504157140042002E
    	UID        : 0x203235345041571400420034
    successfully pinged ESCs
    disabling bridge
    re-enabling voxl-px4
    Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
    restarting voxl-px4
    bridge disabled
    John Nomikos 0J Offline
    John Nomikos 0
    I found that doing voxl-esc spin is working.
    Testing on actuators tab on QGC does not.
    Also tried to do "px4-qshell commander arm -f" and it successfully armed and showed it was flying, but props are not spinning
    wilkinsafW Eric KatzfeyE 2 Replies Last reply
      wilkinsafW Offline
      wilkinsafW Offline
      wilkinsaf
      To clear things up.
      The ESC is not working when we arm. It does not spin with "actuators" tab.
      The ESC only spins a motor when we issue a "voxl-esc" on the command line
      • wilkinsafW wilkinsaf
        To clear things up.
        @wilkinsaf Please post the settings of all of the MODAL_IO_* parameters. E.g. px4-param show MODAL_IO_*
        John Nomikos 0J 1 Reply Last reply
          John Nomikos 0
          @Eric-Katzfey here are the params. Let me know if you need anything else.
          voxl2:/$ px4-param show MODAL_IO_*
          Symbols: x = used, + = saved, * = unsaved
          x + MODAL_IO_BAUD [508,1061] : 2000000
          x + MODAL_IO_CONFIG [509,1062] : 1
          x + MODAL_IO_FUNC1 [510,1063] : 101
          x + MODAL_IO_FUNC2 [511,1064] : 104
          x + MODAL_IO_FUNC3 [512,1065] : 102
          x + MODAL_IO_FUNC4 [513,1066] : 103
          x   MODAL_IO_MODE [514,1067] : 0
          x   MODAL_IO_REV [515,1068] : 0
          x   MODAL_IO_RPM_MAX [516,1069] : 15000
          x + MODAL_IO_RPM_MIN [517,1070] : 3000
          x   MODAL_IO_SDIR1 [518,1071] : 0
          x   MODAL_IO_SDIR2 [519,1072] : 0
          x   MODAL_IO_SDIR3 [520,1073] : 0
          x   MODAL_IO_SDIR4 [521,1074] : 0
          x   MODAL_IO_T_COSP [522,1075] : 0.9900
          x   MODAL_IO_T_DEAD [523,1076] : 20
          x   MODAL_IO_T_EXPO [524,1077] : 35
          x   MODAL_IO_T_MINF [525,1078] : 0.1500
          x   MODAL_IO_T_PERC [526,1079] : 90
          x + MODAL_IO_VLOG [527,1080] : 1
           799/2092 parameters used.
            @John-Nomikos-0 Okay, I don't see anything obviously wrong with those. Can you arm the drone and collect a log?
              @John-Nomikos-0 When you arm you are using the -f flag to force it. What happens if you don't use the force flag? Does it give you some errors?
              wilkinsafW 1 Reply Last reply
                wilkinsafW Offline
                wilkinsafW Offline
                wilkinsaf
                @Eric-Katzfey John left to go home, but popped into the other room to run this
                I keep on getting a failsafe activated the MOMENT we try and arm.
                I can not seem to get more than this message. I am going to manually run voxl-px4 to see if I can get better output
                  wilkinsafW Offline
                  wilkinsafW Offline
                  wilkinsaf
                  Here is the output from voxl-px4 once we requested to arm
                  INFO  [muorb] SLPI: Advertising remote topic ping
                  WARN  [uORB] orb_advertise_multi: failed to set queue size
                  INFO  [uORB] Marking DeviceNode(mavlink_log) as advertised in process_remote_topic
                  INFO  [muorb] SLPI: Armed by external command
                  INFO  [logger] Start file log (type: full)
                  INFO  [logger] [logger] /data/px4/log/2023-03-02/12_59_17.ulg
                  INFO  [logger] Opened full log file: /data/px4/log/2023-03-02/12_59_17.ulg
                  WARN  [mavlink] Event dropped (37, 65526)
                  INFO  [muorb] SLPI: Advertising remote topic logger_status
                  WARN  [mavlink] Dropped 65489 events (seq=65526)
                  INFO  [muorb] SLPI: Failsafe activated
                  INFO  [muorb] SLPI: Disarmed by failsafe
                  INFO  [uORB] Marking DeviceNode(parameter_server_set_value_request) as advertised in process_remote_topic
                  WARN  [mavlink] Event dropped (65527, 37)
                  WARN  [mavlink] Dropped 28 events (seq=37)
                  INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_value_response) as advertised in process_remote_t
                  INFO  [logger] closed logfile, bytes written: 221550
                    @wilkinsaf Okay, that's not very useful. Definitely going to have to figure out a way to make PX4 provide an actual reason. Our ESC guru Alex thinks that the older ESC firmware you have defaults to a different baudrate than we are expecting in SDK 1.0.0 PX4. So he will respond later with the ESC parameter change that will allow them to have the same baudrate.
                      wilkinsafW Offline
                      wilkinsafW Offline
                      wilkinsaf
                      #14
                      @Eric-Katzfey Thanks Eric.
                      I imagine we are going to have to connect the ESC to FTDI to laptop. Or is it possible to change this on VOXL2 terminal.
                        wilkinsafW Offline
                        wilkinsafW Offline
                        wilkinsaf
                        I guess Alex will know that. Thanks!
                          @wilkinsaf You should be able to do it directly on VOXL2 with voxl-esc.
                            @wilkinsaf @John-Nomikos-0
                            Based on your description of the problem (when you switch from SDK 0.9 to 1.0.0, the ESCs start responding), it sounds like a mismatch in the UART baud rate in ESC and PX4 params. When going from 0.9 to 1.0.0 we have changed the baud rate for ESCs in PX4 params from 250K to 2M. Accordingly, we have updated the ESC params to 2M as well (ESC firmware and params are part of voxl-esc package). However, since you did not perform an ESC firmware / param update, your ESC is still running at 250K baud rate, but the latest PX4 is expecting 2Mbit.
                            From your output of esc scan, this is confirmed:
                            You have several options:
                            • Change your PX4 param MODAL_IO_BAUD from 2000000 to 250000 in order to match what your ESC is currently using
                            • Update the ESC firmware and params while the ESC is connected to VOXL2 (with SDK 1.0.0 installed, which will have the latest voxl-esc package with latest firmware and params). Please see this post about updating firmware and params: https://forum.modalai.com/topic/2509/voxl-2-mini-with-mini-4-in-1-esc-no-battery-information/5 . Please note that if you are currently using non-standard ESC params, you will need to make a few updates to them in order to make them compatible with the latest parameter files. If that is the case, let me know, i can help.
                              John Nomikos 0
                              Confirmed, changing the MODAL_IO_BAUD to 250000 fixed the problem for me. Thank you so much for the help!
