  3. Unable to setup VIO on external flight controller
vioexternal fcposition-modevoxl2
7 Posts 3 Posters 2.6k Views 3 Watching
  • KevinChanK Offline
    KevinChanK Offline
    KevinChan
    Unable to setup VIO on external flight controller.
    I have set up and received Mavlink odometry message from Voxl 2.
    I have also set up the EKF2_AID_MASK value to 280.
    But I am still unable to switch to position mode with the error code "check for position estimate"
    POSITION_TARGET_LOCAL_NED xyz values are nan.
    What am I missing?
    Thank you~
      In our troubleshooting VIO guide here, it says:
      If LOCAL_POSITION_NED and MAVLink Odometry message are reading 0 for X and Y after movement of the robot, it is likely PX4’s EKF2 is set to require a magnetomter to initialize.
      PX4 1.12 and later have the following parameters which enable using VIO without a magnetometer:
      ## disable mag
      SYS_HAS_MAG	0
      EKF2_MAG_TYPE	5
      KevinChanK 1 Reply Last reply
        KevinChanK Offline
        KevinChan
        wrote on last edited by KevinChan
        @Chad-Sweet said in Unable to setup VIO on external flight controller:
        EKF2_MAG_TYPE 5
        I have set both parameters.
        I have also set EKF2_HGT_MODE to vision.
        And it's still not working 😞
        In fact, LOCAL_POSITION_NED is nowhere to be found in mavlink, only POSITION_TARGET_LOCAL_NED, are they the same?
        I am currently using PX4 1.13.3
        Thank you for your swift reply~
        • Chad SweetC Chad Sweet
          ## disable mag
          SYS_HAS_MAG	0
          EKF2_MAG_TYPE	5
          KevinChanK Offline
          KevinChanK Offline
          KevinChan
          @Chad-Sweet After about a week of debugging, turns out external flight controller only works on the older version of firmware, VOXL2 Platform 0.9.
          Instead of the newest one VOXL2 Platform 1.3.1-0.8 or VOXL2 Platform 1.2.1-0.7.
          PLEASE state it in your documentation!
          I initially need to install the 1.2 version since I need to communicate with VOXL2 IO
          Thank you
            Thank you for bringing this to our attention. There could be a regression. Our latest platform image is 0.9.5 which corresponds to system image 1.5.5 . Can you please help clarify which version you found not to work? Maybe there is a mismatch with what you are trying to achieve?
            https://docs.modalai.com/voxl2-system-image/#155-platform-release-095
              KevinChanK Offline
              KevinChanK Offline
              KevinChan
              @Chad-Sweet Platform 1.3.1-0.8 and Platform 1.2.1-0.7 doesn't work, 0.9.5 works. Didn't try 0.9
              • tomT Online
                tomT Online
                @KevinChan 0.9.5 is the newest, 0.9 is second newest, 1.3.1-0.8 (0.8) is super old. We changed our naming scheme some time ago so I can understand the confusion
