    Unable to setup VIO on external flight controller
    vio external fc position-mode voxl2
    • KevinChanK
      KevinChan
      Unable to setup VIO on external flight controller.
      I have set up and received Mavlink odometry message from Voxl 2.
      I have also set up the EKF2_AID_MASK value to 280.
      But I am still unable to switch to position mode with the error code "check for position estimate"
      POSITION_TARGET_LOCAL_NED xyz values are nan.
      What am I missing?
      Thank you~
      • Chad SweetC
        Chad Sweet ModalAI Team
        In our troubleshooting VIO guide here, it says:
        If LOCAL_POSITION_NED and MAVLink Odometry message are reading 0 for X and Y after movement of the robot, it is likely PX4’s EKF2 is set to require a magnetomter to initialize.
        PX4 1.12 and later have the following parameters which enable using VIO without a magnetometer:
        ## disable mag
        SYS_HAS_MAG	0
        EKF2_MAG_TYPE	5
        KevinChanK 1 Reply Last reply Reply Quote 0
        • KevinChanK
          KevinChan
          @Chad-Sweet said in Unable to setup VIO on external flight controller:
          EKF2_MAG_TYPE 5
          I have set both parameters.
          I have also set EKF2_HGT_MODE to vision.
          And it's still not working 😞
          In fact, LOCAL_POSITION_NED is nowhere to be found in mavlink, only POSITION_TARGET_LOCAL_NED, are they the same?
          I am currently using PX4 1.13.3
          Thank you for your swift reply~
          • KevinChanK
            KevinChan @Chad Sweet
            @Chad-Sweet After about a week of debugging, turns out external flight controller only works on the older version of firmware, VOXL2 Platform 0.9.
            Instead of the newest one VOXL2 Platform 1.3.1-0.8 or VOXL2 Platform 1.2.1-0.7.
            PLEASE state it in your documentation!
            I initially need to install the 1.2 version since I need to communicate with VOXL2 IO
            Thank you
            • Chad SweetC
              Thank you for bringing this to our attention. There could be a regression. Our latest platform image is 0.9.5 which corresponds to system image 1.5.5 . Can you please help clarify which version you found not to work? Maybe there is a mismatch with what you are trying to achieve?
              https://docs.modalai.com/voxl2-system-image/#155-platform-release-095
              • KevinChanK
                @Chad-Sweet Platform 1.3.1-0.8 and Platform 1.2.1-0.7 doesn't work, 0.9.5 works. Didn't try 0.9
                  tom admin
                  @KevinChan 0.9.5 is the newest, 0.9 is second newest, 1.3.1-0.8 (0.8) is super old. We changed our naming scheme some time ago so I can understand the confusion
