  3. ADB Connecting Issue with VOXL2 Board
voxl-2
35 Posts 6 Posters 9.8k Views 3 Watching
    @dlee What OS are you running on your host PC? (We recommend Ubuntu 18)
    • dleeD dlee
      @Adrian-Hidalgo The board went through the whole flashing procedure. I checked the voxl-suite is running. So I did my works. But after reboot, voxl2 adb couldn't connet to my companion pc.
      Adrian HidalgoA Offline
      Adrian Hidalgo
      @dlee what's the output if you type
      lsusb
      dleeD 1 Reply Last reply
        lsusb
        dleeD Offline
        dleeD Offline
        dlee
        wrote on last edited by dlee
        @Adrian-Hidalgo This is the output.
        @tom And I am using ubuntu 20.04. It worked before well.
        • dleeD dlee
          @dlee This is with VOXL2 powered and plugged in via. USB-C? Are you running Ubuntu natively or in a VM?
            dleeD Offline
            dleeD Offline
            dlee
            @tom Yepp, powered by power adapter. ADB connected by USB-C. Ubuntu natively, not VM.
              wrote on last edited by tom
              #11
              @dlee What do you see come through when you run dmesg -wH, then plug in power and USB to VOXL2.
              It also doesn't hurt to try a different port on your host PC, i.e. going from USB3 to USB2
                dleeD Offline
                dleeD Offline
                dlee
                @tom Nothing changed. I did USB-C and USB-B(3.0), already.
                  @dlee If nothing changed it's likely a cable or port issue. If there's LEDs going on VOXL2 when powered then it is booting.
                    dleeD Offline
                    dleeD Offline
                    dlee
                    @tom I changed port and cables. It didn't work, too. I tried everything.
                      @dlee Is it detected when forced into emergency boot mode via. the switch? Or can you force it into fastboot via. the button?
                        dleeD Offline
                        dleeD Offline
                        dlee
                        @tom I did flashing and QDL, again. Re-flashing was successful. But when I reboot it, connection problem occur. I checked status using dmesg -wH and lsusb. This is the output.
                        lsusb
                        Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                        Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                        Bus 002 Device 018: ID 05c6:901d Qualcomm, Inc. QUSB_BULK_SN:73AD68FF
                        Bus 001 Device 003: ID 0c45:6a09 Microdia Integrated_Webcam_HD
                        Bus 001 Device 002: ID 8087:0029 Intel Corp.
                        dmesg -wH
                        [Feb 7 10:07] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
                        [  +9.642102] wlp4s0: deauthenticating from e6:f5:32:36:39:23 by local choice (Reason: 3=DEAUTH_LEAVING)
                        [Feb 7 10:08] wlp4s0: authenticate with 5e:5b:69:67:36:b5
                        [  +0.007679] wlp4s0: send auth to 5e:5b:69:67:36:b5 (try 1/3)
                        [  +0.149577] wlp4s0: authenticate with 5e:5b:69:67:36:b5
                        [  +0.000009] wlp4s0: send auth to 5e:5b:69:67:36:b5 (try 1/3)
                        [  +0.002812] wlp4s0: authenticated
                        [  +0.006113] wlp4s0: associate with 5e:5b:69:67:36:b5 (try 1/3)
                        [  +0.006320] wlp4s0: RX AssocResp from 5e:5b:69:67:36:b5 (capab=0x431 status=0 aid=2)
                        [  +0.021818] wlp4s0: associated
                        [  +0.086613] wlp4s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 5e:5b:69:67:36:b5
                        [  +0.072842] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
                        [Feb 7 10:09] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
                        [Feb 7 10:17] usb 2-1: USB disconnect, device number 9
                        [Feb 7 10:19] xhci_hcd 0000:05:00.3: Timeout while waiting for setup device command
                        [  +5.375225] xhci_hcd 0000:05:00.3: Timeout while waiting for setup device command
                        [  +0.207982] usb 2-1: device not accepting address 10, error -62
                        [ +11.183109] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 12 using xhci_hcd
                        [  +0.025567] usb 2-1: New USB device found, idVendor=05c6, idProduct=901d, bcdDevice= 0.00
                        [  +0.000008] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                        [  +0.000002] usb 2-1: Product: QUSB_BULK_SN:73AD68FF
                        [  +0.000002] usb 2-1: Manufacturer: Qualcomm CDMA Technologies MSM
                        [  +0.000001] usb 2-1: SerialNumber: 8cc63c2c
                        [Feb 7 10:20] usb 2-1: USB disconnect, device number 12
                        [ +19.466698] xhci_hcd 0000:05:00.3: Timeout while waiting for setup device command
                        [  +5.375457] xhci_hcd 0000:05:00.3: Timeout while waiting for setup device command
                        [  +0.207938] usb 2-1: device not accepting address 13, error -62
                        [ +11.099012] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 15 using xhci_hcd
                        [  +0.026684] usb 2-1: New USB device found, idVendor=05c6, idProduct=901d, bcdDevice= 0.00
                        [  +0.000013] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                        [  +0.000005] usb 2-1: Product: QUSB_BULK_SN:73AD68FF
                        [  +0.000003] usb 2-1: Manufacturer: Qualcomm CDMA Technologies MSM
                        [  +0.000003] usb 2-1: SerialNumber: 8cc63c2c
                        [Feb 7 10:22] usb 2-1: USB disconnect, device number 15
                        [ +25.073739] xhci_hcd 0000:05:00.3: Timeout while waiting for setup device command
                        [  +5.375419] xhci_hcd 0000:05:00.3: Timeout while waiting for setup device command
                        [  +0.208126] usb 2-1: device not accepting address 16, error -62
                          @dlee Are you able to force it into fastboot with the button?
                            dleeD Offline
                            dleeD Offline
                            dlee
                            @tom I can use fastboot mode above the board.
                            And I got a different problem another voxl2 board (I have 3 of voxl2 boards) video link. When I connected board to my companion pc using adb cable, the connection is maintained for a very short time and disconnected. Do you know about this problem?
                              @dlee I haven't seen that behavior before. Try adb kill-server then adb shell again
                                dleeD Offline
                                dleeD Offline
                                dlee
                                @tom Same. Anyway, can I do something using fastboot?
                                  @dlee Yes, that is how the system image is flashed, which is required after a QDL flash. See here: https://docs.modalai.com/platform-releases/#4-run-install-script
                                  The install script can be run while the board is in fastboot mode. Look for it with fastboot devices
                                    dleeD Offline
                                    dleeD Offline
                                    dlee
                                    #22
                                    @tom I already did QDL flash.
                                    This is what I did.
                                    1. QDL flash
                                    2. Voxl2 flash using fastboot mode
                                    3. Connect to the voxl-suite
                                    4. After I reboot, adb shell didn't work.
                                      error: no devices/emulators found.
                                    I tried many times of this from 1 to 4.
                                      @dlee In that case I would RMA it as that is not normal behavior: https://www.modalai.com/pages/rma
                                      • dleeD Offline
                                        dleeD Offline
                                        dlee
                                        @tom One more question. Since we have three VOXL2 boards behaving the same way can we buy one RMA (PCB) diagnostic for all three boards or do we have to purchase a RMA (PCB) diagnostic for each board that is faulty?
                                        Thanks.
                                          @dlee I didn't realize all 3 were exhibiting this behavior, if that's the case something else is going on.
                                          What system image and voxl-suite are you flashing on top of the QDL image? Are you loading or running anything else on top of that??
