  3. Questions regarding RB5 5G drone
rb5
27 Posts 4 Posters 8.0k Views 2 Watching
  • Chad SweetC Chad Sweet
    The RTSP streaming capabilities will heavily depend on network capacity. The QRB5165 is capable of encoding 8k30, but that is a lot of bandwidth.
    To configure different streaming capabilities, disable the rb5-streamer service and use gstreamer on your own. The rb5-streamer app was based off of the code found here
    M Offline
    M Offline
    MJ
    @Chad-Sweet Thank you, will try this soon.
    • M MJ
      @RichieRich
      Thank you for your excellent advice.
      I will try to explain my current configuration. For local testing and configuration I'm using ADB and local WLAN. For final application I would like to use 5G network.
      Of course, I need VPN (and will use OpenVPN) to provide connection between the ground station and the drone. For OpenVPN server I'm using some Mikrotik appliance configured to provide fixed, predefined IP addresses to GC and the drone.
      Ground Control always receives 192.168.88.20
      Drone always receives 192.168.88.21
      Both are mutually "visible" and can communicate. This is working without issues.
      In regard to your first question, here is the result of
      sh-4.4# px4-versions
      modalai-slpi/unknown,now 1.0-6 arm64 [installed]
      px4-rb5-flight/unknown,now 1.4-6 arm64 [installed]
      px4-support/unknown,now 1.0-4 arm64 [installed]
      libfc-sensor/unknown,now 1.0-2 arm64 [installed]
      1.0.5-M0052-9.1-perf
      Here is the result of ifconfig on the drone. wwan0 is the 5G connection, tun0 is the OpenVPN connection tunnel.
      sh-4.4# ifconfig
      bond0: flags=5123<UP,BROADCAST,MASTER,MULTICAST> mtu 1500
      ether 7a:19:6d:34:23:5d txqueuelen 1000 (Ethernet)
      RX packets 0 bytes 0 (0.0 B)
      RX errors 0 dropped 0 overruns 0 frame 0
      TX packets 0 bytes 0 (0.0 B)
      TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
      dummy0: flags=195<UP,BROADCAST,RUNNING,NOARP> mtu 1500
      inet6 fe80::98d0:c594:6a01:f80a prefixlen 64 scopeid 0x20<link>
      ether d6:41:ed:11:b0:d3 txqueuelen 1000 (Ethernet)
      TX packets 13 bytes 3394 (3.3 KB)
      lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
      inet 127.0.0.1 netmask 255.0.0.0
      inet6 ::1 prefixlen 128 scopeid 0x10<host>
      loop txqueuelen 1000 (Local Loopback)
      RX packets 60750 bytes 10831838 (10.8 MB)
      TX packets 60750 bytes 10831838 (10.8 MB)
      tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500
      inet 192.168.88.21 netmask 255.255.255.0 destination 192.168.88.21
      inet6 fe80::b41d:2608:5fb4:fcc5 prefixlen 64 scopeid 0x20<link>
      unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 100 (UNSPEC)
      RX packets 59 bytes 7414 (7.4 KB)
      TX packets 96 bytes 18438 (18.4 KB)
      wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
      ether 00:03:7f:12:a2:e9 txqueuelen 3000 (Ethernet)
      wwan0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1430
      inet 10.194.65.175 netmask 255.255.255.224 destination 10.194.65.175
      unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 1000 (UNSPEC)
      RX packets 14127 bytes 18472229 (18.4 MB)
      TX packets 1408 bytes 110804 (110.8 KB)
      TX errors 7 dropped 0 overruns 0 carrier 0 collisions 0
      I have placed following configuration in /etc/systemd/system/rb5-net-check.service
      [Unit]
      Description=rb5-net-check
      #After=sscrpcd.service ---> this is commented
      After=openvpn.service ---> I wait for openvpn to start
      Requires=sscrpcd.service
      [Service]
      Type=oneshot
      ExecStart=/usr/bin/rb5-net-check tun0 192.168
      RemainAfterExit=yes
      [Install]
      WantedBy=multi-user.target
      Also I have added the IP 192.168.88.20 to the /etc/modalai/qgc-ip.cfg.
      The result of
      sh-4.4# rb5-net-check tun0
      192.168.88.21
      is as expected, ok.
      But I have issue with PX4. I am not sure what to do here (also the blue LEDs do not blink, as it was before the update).
      sh-4.4# systemctl status rb5-px4-start
      ● rb5-px4-start.service - rb5-px4-start
      Loaded: loaded (/etc/systemd/system/rb5-px4-start.service; enabled; vendor pr
      Active: failed (Result: exit-code) since Wed 2022-03-30 18:58:41 UTC; 4min 46
      Process: 2671 ExecStart=/bin/bash -c PATH=/usr/bin m0052-px4 -d (code=exited,
      Main PID: 2671 (code=exited, status=134)
      sh-4.4# systemctl enable rb5-px4-start
      Active: failed (Result: exit-code) since Wed 2022-03-30 18:58:41 UTC; 5min ag
      Mar 30 18:58:33 qrb5165-rb5 systemd[1]: Started rb5-px4-start.
      Mar 30 18:58:41 qrb5165-rb5 bash[2671]: terminate called after throwing an insta
      Mar 30 18:58:41 qrb5165-rb5 bash[2671]: what(): FATAL: could not find sensors
      Mar 30 18:58:41 qrb5165-rb5 bash[2671]: /usr/bin/m0052-px4: line 18: 2672 Abort
      Mar 30 18:58:41 qrb5165-rb5 systemd[1]: rb5-px4-start.service: Main process exit
      Mar 30 18:58:41 qrb5165-rb5 systemd[1]: rb5-px4-start.service: Failed with resul
      When I start the QGroundControl, I can receive the video from the drone without any issues (as it is independent from CC link).
      Could you provide some idea how to debug and resolve the issues with PX4? Many thanks!
      M Offline
      M Offline
      MJ
      wrote on last edited by MJ
      Since some text was missing, I have attached the complete dump here:
      root@qrb5165-rb5:~# systemctl status rb5-px4-start
      Loaded: loaded (/etc/systemd/system/rb5-px4-start.service; enabled; vendor preset: enabled)
      Active: failed (Result: exit-code) since Wed 2022-03-30 21:14:17 UTC; 11min ago
      Main PID: 2320 (code=exited, status=134)
      Mar 30 21:14:08 qrb5165-rb5 systemd[1]: Started rb5-px4-start.
      Mar 30 21:14:17 qrb5165-rb5 bash[2320]: terminate called after throwing an instance of 'std::runtime_error'
      Mar 30 21:14:17 qrb5165-rb5 bash[2320]: what(): FATAL: could not find sensors QMI service
      Mar 30 21:14:17 qrb5165-rb5 bash[2320]: /usr/bin/m0052-px4: line 18: 2321 Aborted px4 $DAEMON -s /etc/modalai/full-m0052.config
      Mar 30 21:14:17 qrb5165-rb5 systemd[1]: rb5-px4-start.service: Main process exited, code=exited, status=134/n/a
      Mar 30 21:14:17 qrb5165-rb5 systemd[1]: rb5-px4-start.service: Failed with result 'exit-code'.
      Here is the full-m0052.config (unedited, from January 2022)
      https://pastebin.com/j5WNgF5Q
      • M MJ
        @MJ Can you disable the startup service? systemctl disable rb5-px4-start and then reboot. Then, adb into the RB5 and launch px4 from the command line m0052-px4 and paste the output of that here. That should tell us more information about what is going wrong.
        M 1 Reply Last reply
          M Offline
          M Offline
          MJ
          Please find the output here:
          root@qrb5165-rb5:~# m0052-px4
          ______  __   __    ___
          | ___ \ \ \ / /   /   |
          | |_/ /  \ V /   / /| |
          |  __/   /   \  / /_| |
          | |     / /^\ \ \___  |
          \_|     \/   \/     |_/
          px4 starting.
          INFO  [px4] Calling startup script: /bin/sh /etc/modalai/full-m0052.config 0
          /usr/bin/m0052-px4: line 18:  5180 Aborted                 px4 $DAEMON -s /etc/modalai/full-m0052.config
          I tried this several times, every time exact the same message.
          • M MJ
            ______  __   __    ___
            | ___ \ \ \ / /   /   |
            | |_/ /  \ V /   / /| |
            |  __/   /   \  / /_| |
            | |     / /^\ \ \___  |
            \_|     \/   \/     |_/
            px4 starting.
            @MJ There should be a program called ssc_sensor_info. Can you run that and paste the output of that here? Also the output of ls -l /usr/lib/libs*?
              M Offline
              M Offline
              MJ
              sh-4.4# ls -l /usr/lib/libs*
              -rw-r--r-- 1 root root     4010 Oct 27  2015 /usr/lib/libsafe_iop.a
              lrwxrwxrwx 1 root root       18 Oct 27  2015 /usr/lib/libsafe_iop.so -> libsafe_iop.so.0.3
              lrwxrwxrwx 1 root root       18 Oct 27  2015 /usr/lib/libsafe_iop.so.0 -> libsafe_iop.so.0.3
              -rw-r--r-- 1 root root     9976 Oct 27  2015 /usr/lib/libsafe_iop.so.0.3
              -rwxr-xr-x 1 root root   231664 Dec  6 21:46 /usr/lib/libsdsprpc.so
              lrwxrwxrwx 1 root root       22 Dec  6 21:59 /usr/lib/libsensorslog.so -> libsensorslog.so.1.0.0
              lrwxrwxrwx 1 root root       22 Dec  6 21:59 /usr/lib/libsensorslog.so.1 -> libsensorslog.so.1.0.0
              -rwxr-xr-x 1 root root     5648 Dec  6 21:47 /usr/lib/libsensorslog.so.1.0.0
              -rwxr-xr-x 1 root root    42840 Dec  6 21:49 /usr/lib/libsimple_selectors.so
              lrwxrwxrwx 1 root root       19 Dec  6 21:59 /usr/lib/libsns_api.so -> libsns_api.so.0.0.0
              lrwxrwxrwx 1 root root       19 Dec  6 21:59 /usr/lib/libsns_api.so.0 -> libsns_api.so.0.0.0
              -rwxr-xr-x 1 root root    22104 Dec  6 21:47 /usr/lib/libsns_api.so.0.0.0
              lrwxrwxrwx 1 root root       35 Dec  6 21:59 /usr/lib/libsns_direct_channel_stub.so -> libsns_direct_channel_stub.so.1.0.0
              lrwxrwxrwx 1 root root       35 Dec  6 21:59 /usr/lib/libsns_direct_channel_stub.so.1 -> libsns_direct_channel_stub.so.1.0.0
              -rwxr-xr-x 1 root root     9880 Dec  6 21:47 /usr/lib/libsns_direct_channel_stub.so.1.0.0
              lrwxrwxrwx 1 root root       28 Dec  6 21:59 /usr/lib/libsns_fastRPC_util.so -> libsns_fastRPC_util.so.1.0.0
              lrwxrwxrwx 1 root root       28 Dec  6 21:59 /usr/lib/libsns_fastRPC_util.so.1 -> libsns_fastRPC_util.so.1.0.0
              -rwxr-xr-x 1 root root     9880 Dec  6 21:47 /usr/lib/libsns_fastRPC_util.so.1.0.0
              lrwxrwxrwx 1 root root       29 Dec  6 21:59 /usr/lib/libsns_registry_skel.so -> libsns_registry_skel.so.1.0.0
              lrwxrwxrwx 1 root root       29 Dec  6 21:59 /usr/lib/libsns_registry_skel.so.1 -> libsns_registry_skel.so.1.0.0
              -rwxr-xr-x 1 root root     9952 Dec  6 21:47 /usr/lib/libsns_registry_skel.so.1.0.0
              lrwxrwxrwx 1 root root       18 Dec  6 21:59 /usr/lib/libsnsapi.so -> libsnsapi.so.1.0.0
              lrwxrwxrwx 1 root root       18 Dec  6 21:59 /usr/lib/libsnsapi.so.1 -> libsnsapi.so.1.0.0
              -rw-r--r-- 1 root root 12163280 Sep 28  2021 /usr/lib/libsnsapi.so.1.0.0
              lrwxrwxrwx 1 root root       22 Dec  6 21:59 /usr/lib/libsnsdiaglog.so -> libsnsdiaglog.so.1.0.0
              lrwxrwxrwx 1 root root       22 Dec  6 21:59 /usr/lib/libsnsdiaglog.so.1 -> libsnsdiaglog.so.1.0.0
              -rwxr-xr-x 1 root root    22256 Dec  6 21:47 /usr/lib/libsnsdiaglog.so.1.0.0
              lrwxrwxrwx 1 root root       18 Dec  6 21:59 /usr/lib/libsparse.so.0 -> libsparse.so.0.0.0
              -rwxr-xr-x 1 root root    30584 Dec  6 21:46 /usr/lib/libsparse.so.0.0.0
              lrwxrwxrwx 1 root root       15 Dec  6 21:59 /usr/lib/libssc.so -> libssc.so.1.0.0
              lrwxrwxrwx 1 root root       15 Dec  6 21:59 /usr/lib/libssc.so.1 -> libssc.so.1.0.0
              -rwxr-xr-x 1 root root    91992 Dec  6 21:47 /usr/lib/libssc.so.1.0.0
              -rwxr-xr-x 1 root root     9992 Dec  6 21:46 /usr/lib/libssc_default_listener.so
              lrwxrwxrwx 1 root root       15 Dec  6 22:00 /usr/lib/libssd.so -> libssd.so.1.0.0
              lrwxrwxrwx 1 root root       15 Dec  6 22:00 /usr/lib/libssd.so.1 -> libssd.so.1.0.0
              -rwxr-xr-x 1 root root     9896 Dec  6 21:47 /usr/lib/libssd.so.1.0.0
              -rwxr-xr-x 1 root root    46864 Dec  6 21:49 /usr/lib/libstats_calculator_portable.so
              lrwxrwxrwx 1 root root       19 Feb 28  2018 /usr/lib/libstonith.so.1 -> libstonith.so.1.0.0
              -rw-r--r-- 1 root root    26480 Feb 28  2018 /usr/lib/libstonith.so.1.0.0
              -rwxr-xr-x 1 root root    51240 Dec  6 21:47 /usr/lib/libstreamparser.so
              lrwxrwxrwx 1 root root       16 Dec  6 21:59 /usr/lib/libsync.so.0 -> libsync.so.0.0.0
              -rwxr-xr-x 1 root root     9904 Dec  6 21:46 /usr/lib/libsync.so.0.0.0
              -rwxr-xr-x 1 root root    26456 Dec  6 21:46 /usr/lib/libsynx.so
              lrwxrwxrwx 1 root root       20 Dec  6 21:59 /usr/lib/libsysutils.so.0 -> libsysutils.so.0.0.0
              -rwxr-xr-x 1 root root    34728 Dec  6 21:46 /usr/lib/libsysutils.so.0.0.0
              sh-4.4# ssc_sensor_info
              ssc_sensor_info v1.7
              sh-4.4#
              • M MJ
                sh-4.4#
                @MJ Your library listing looks reasonable. But ssc_sensor_info should dump a bunch of information about all of the sensors it sees so there is definitely something wrong there.
                  M Offline
                  M Offline
                  MJ
                  Yes...any ideas what to do now? Thanks!
                  • M MJ
                    @MJ We are discussing internally...
                    • M MJ
                      #14
                      @MJ What do you get when you enter ps aux | grep ssc or ps aux | grep sensor?
                      • M MJ
                        @MJ Can your reflash the system image? https://docs.modalai.com/Qualcomm-Flight-RB5-system-image/. It will delete everything on your board so backup any important data before doing this. If ssc_sensor_info doesn't report all of the sensors then px4 will never work as it relies on that ability.
                        M 2 Replies Last reply
                          M Offline
                          M Offline
                          MJ
                          sh-4.4# ps aux | grep ssc
                          system    1273  1.0  0.0   2068  1260 ?        Ss   20:16   0:02 /usr/bin/sscrpcd sensorspd
                          root      3764  0.0  0.0   2708   648 pts/0    S<+  20:20   0:00 grep ssc
                          sh-4.4#
                          sh-4.4# ps aux | grep sensor
                          system    1273  0.9  0.0   2068  1260 ?        Ss   20:16   0:02 /usr/bin/sscrpcd sensorspd
                          sensors   1281  0.0  0.0 186552  5896 ?        Ssl  20:16   0:00 /usr/bin/sensors.qti
                          root      4196  0.0  0.0   2708   620 pts/0    S<+  20:21   0:00 grep sensor
                          sh-4.4#
                            M Offline
                            M Offline
                            MJ
                            Will try to re-flash within a day or two, so I'll get back to you with the updates.
                              M Offline
                              M Offline
                              MJ
                              • M Offline
                                M Offline
                                MJ
                                #19
                                Re-flash solved all the previous issues.
                                But still I'm unable to arm the unit.
                                Following instruction provided here
                                https://docs.modalai.com/Qualcomm-Flight-RB5-user-guide-first-flight/
                                doesn't help as I receive GPS and AHRS errors (while the unit is placed under open and clear sky).
                                Regarding the GPS, I receive the "GPS accuracy too low" (while receiving 10-12 satellites).
                                What could be the cause of these errors?
                                Also is the GPS necessary to at least test the motors?
                                Is it possible to fly without the GPS?
                                • ? Offline
                                  Hi @MJ ,
                                  Check to see if you have your outdoor parameters correctly set: https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/tree/master/helpers/rb5
                                  Sometimes the ekf2 aid mask is still set to 280.
                                  You can arm the drone without GPS by setting COM_ARM_WO_GPS to 1.
                                  • ? Offline
                                    Also, are the GPS LEDs illuminating? There should be the main one which should go from blue to green when it's ready. And a small one flashing on the side that shows a GPS lock.
                                    • ? A Former User
                                      M Offline
                                      M Offline
                                      MJ
                                      #22
                                      @RichieRich
                                      I have made following changes (WO_GPS to 1 and EFK2_AID_MASK to 1 and to 0)
                                      but now I receive following error:
                                      The main GPS LED (blue) slowly blinks, but only in blue color.
                                      The FIX LED has short blinks in blue color.
                                      Could you please advise what to do?
                                      • M Offline
                                        M Offline
                                        MJ
                                        #23
                                        Also when I go to QGC - Vehicle setup - Safety, I get this error
                                        • M Offline
                                          M Offline
                                          MJ
                                          When EFK2_AID_MASK is set to 1, following errors occur:
                                          I emphasize that drone is under clear and sunny sky
