  3. Questions regarding RB5 5G drone
rb5
27 Posts 4 Posters 8.0k Views 2 Watching
    @MJ There should be a program called ssc_sensor_info. Can you run that and paste the output of that here? Also the output of ls -l /usr/lib/libs*?
    M Offline
    M Offline
    MJ
    sh-4.4# ls -l /usr/lib/libs*
    -rw-r--r-- 1 root root     4010 Oct 27  2015 /usr/lib/libsafe_iop.a
    lrwxrwxrwx 1 root root       18 Oct 27  2015 /usr/lib/libsafe_iop.so -> libsafe_iop.so.0.3
    lrwxrwxrwx 1 root root       18 Oct 27  2015 /usr/lib/libsafe_iop.so.0 -> libsafe_iop.so.0.3
    -rw-r--r-- 1 root root     9976 Oct 27  2015 /usr/lib/libsafe_iop.so.0.3
    -rwxr-xr-x 1 root root   231664 Dec  6 21:46 /usr/lib/libsdsprpc.so
    lrwxrwxrwx 1 root root       22 Dec  6 21:59 /usr/lib/libsensorslog.so -> libsensorslog.so.1.0.0
    lrwxrwxrwx 1 root root       22 Dec  6 21:59 /usr/lib/libsensorslog.so.1 -> libsensorslog.so.1.0.0
    -rwxr-xr-x 1 root root     5648 Dec  6 21:47 /usr/lib/libsensorslog.so.1.0.0
    -rwxr-xr-x 1 root root    42840 Dec  6 21:49 /usr/lib/libsimple_selectors.so
    lrwxrwxrwx 1 root root       19 Dec  6 21:59 /usr/lib/libsns_api.so -> libsns_api.so.0.0.0
    lrwxrwxrwx 1 root root       19 Dec  6 21:59 /usr/lib/libsns_api.so.0 -> libsns_api.so.0.0.0
    -rwxr-xr-x 1 root root    22104 Dec  6 21:47 /usr/lib/libsns_api.so.0.0.0
    lrwxrwxrwx 1 root root       35 Dec  6 21:59 /usr/lib/libsns_direct_channel_stub.so -> libsns_direct_channel_stub.so.1.0.0
    lrwxrwxrwx 1 root root       35 Dec  6 21:59 /usr/lib/libsns_direct_channel_stub.so.1 -> libsns_direct_channel_stub.so.1.0.0
    -rwxr-xr-x 1 root root     9880 Dec  6 21:47 /usr/lib/libsns_direct_channel_stub.so.1.0.0
    lrwxrwxrwx 1 root root       28 Dec  6 21:59 /usr/lib/libsns_fastRPC_util.so -> libsns_fastRPC_util.so.1.0.0
    lrwxrwxrwx 1 root root       28 Dec  6 21:59 /usr/lib/libsns_fastRPC_util.so.1 -> libsns_fastRPC_util.so.1.0.0
    -rwxr-xr-x 1 root root     9880 Dec  6 21:47 /usr/lib/libsns_fastRPC_util.so.1.0.0
    lrwxrwxrwx 1 root root       29 Dec  6 21:59 /usr/lib/libsns_registry_skel.so -> libsns_registry_skel.so.1.0.0
    lrwxrwxrwx 1 root root       29 Dec  6 21:59 /usr/lib/libsns_registry_skel.so.1 -> libsns_registry_skel.so.1.0.0
    -rwxr-xr-x 1 root root     9952 Dec  6 21:47 /usr/lib/libsns_registry_skel.so.1.0.0
    lrwxrwxrwx 1 root root       18 Dec  6 21:59 /usr/lib/libsnsapi.so -> libsnsapi.so.1.0.0
    lrwxrwxrwx 1 root root       18 Dec  6 21:59 /usr/lib/libsnsapi.so.1 -> libsnsapi.so.1.0.0
    -rw-r--r-- 1 root root 12163280 Sep 28  2021 /usr/lib/libsnsapi.so.1.0.0
    lrwxrwxrwx 1 root root       22 Dec  6 21:59 /usr/lib/libsnsdiaglog.so -> libsnsdiaglog.so.1.0.0
    lrwxrwxrwx 1 root root       22 Dec  6 21:59 /usr/lib/libsnsdiaglog.so.1 -> libsnsdiaglog.so.1.0.0
    -rwxr-xr-x 1 root root    22256 Dec  6 21:47 /usr/lib/libsnsdiaglog.so.1.0.0
    lrwxrwxrwx 1 root root       18 Dec  6 21:59 /usr/lib/libsparse.so.0 -> libsparse.so.0.0.0
    -rwxr-xr-x 1 root root    30584 Dec  6 21:46 /usr/lib/libsparse.so.0.0.0
    lrwxrwxrwx 1 root root       15 Dec  6 21:59 /usr/lib/libssc.so -> libssc.so.1.0.0
    lrwxrwxrwx 1 root root       15 Dec  6 21:59 /usr/lib/libssc.so.1 -> libssc.so.1.0.0
    -rwxr-xr-x 1 root root    91992 Dec  6 21:47 /usr/lib/libssc.so.1.0.0
    -rwxr-xr-x 1 root root     9992 Dec  6 21:46 /usr/lib/libssc_default_listener.so
    lrwxrwxrwx 1 root root       15 Dec  6 22:00 /usr/lib/libssd.so -> libssd.so.1.0.0
    lrwxrwxrwx 1 root root       15 Dec  6 22:00 /usr/lib/libssd.so.1 -> libssd.so.1.0.0
    -rwxr-xr-x 1 root root     9896 Dec  6 21:47 /usr/lib/libssd.so.1.0.0
    -rwxr-xr-x 1 root root    46864 Dec  6 21:49 /usr/lib/libstats_calculator_portable.so
    lrwxrwxrwx 1 root root       19 Feb 28  2018 /usr/lib/libstonith.so.1 -> libstonith.so.1.0.0
    -rw-r--r-- 1 root root    26480 Feb 28  2018 /usr/lib/libstonith.so.1.0.0
    -rwxr-xr-x 1 root root    51240 Dec  6 21:47 /usr/lib/libstreamparser.so
    lrwxrwxrwx 1 root root       16 Dec  6 21:59 /usr/lib/libsync.so.0 -> libsync.so.0.0.0
    -rwxr-xr-x 1 root root     9904 Dec  6 21:46 /usr/lib/libsync.so.0.0.0
    -rwxr-xr-x 1 root root    26456 Dec  6 21:46 /usr/lib/libsynx.so
    lrwxrwxrwx 1 root root       20 Dec  6 21:59 /usr/lib/libsysutils.so.0 -> libsysutils.so.0.0.0
    -rwxr-xr-x 1 root root    34728 Dec  6 21:46 /usr/lib/libsysutils.so.0.0.0
    sh-4.4# ssc_sensor_info
    ssc_sensor_info v1.7
    sh-4.4#
    • M MJ
      sh-4.4#
      @MJ Your library listing looks reasonable. But ssc_sensor_info should dump a bunch of information about all of the sensors it sees so there is definitely something wrong there.
      M 1 Reply Last reply
        M Offline
        M Offline
        MJ
        Yes...any ideas what to do now? Thanks!
        • M MJ
          @MJ We are discussing internally...
          • M MJ
            #14
            @MJ What do you get when you enter ps aux | grep ssc or ps aux | grep sensor?
            • M MJ
              @MJ Can your reflash the system image? https://docs.modalai.com/Qualcomm-Flight-RB5-system-image/. It will delete everything on your board so backup any important data before doing this. If ssc_sensor_info doesn't report all of the sensors then px4 will never work as it relies on that ability.
              M 2 Replies Last reply
                M Offline
                M Offline
                MJ
                sh-4.4# ps aux | grep ssc
                system    1273  1.0  0.0   2068  1260 ?        Ss   20:16   0:02 /usr/bin/sscrpcd sensorspd
                root      3764  0.0  0.0   2708   648 pts/0    S<+  20:20   0:00 grep ssc
                sh-4.4#
                sh-4.4# ps aux | grep sensor
                system    1273  0.9  0.0   2068  1260 ?        Ss   20:16   0:02 /usr/bin/sscrpcd sensorspd
                sensors   1281  0.0  0.0 186552  5896 ?        Ssl  20:16   0:00 /usr/bin/sensors.qti
                root      4196  0.0  0.0   2708   620 pts/0    S<+  20:21   0:00 grep sensor
                sh-4.4#
                  M Offline
                  M Offline
                  MJ
                  Will try to re-flash within a day or two, so I'll get back to you with the updates.
                    M Offline
                    M Offline
                    MJ
                    • M Offline
                      M Offline
                      MJ
                      wrote on last edited by MJ
                      #19
                      Re-flash solved all the previous issues.
                      But still I'm unable to arm the unit.
                      Following instruction provided here
                      https://docs.modalai.com/Qualcomm-Flight-RB5-user-guide-first-flight/
                      doesn't help as I receive GPS and AHRS errors (while the unit is placed under open and clear sky).
                      Regarding the GPS, I receive the "GPS accuracy too low" (while receiving 10-12 satellites).
                      What could be the cause of these errors?
                      Also is the GPS necessary to at least test the motors?
                      Is it possible to fly without the GPS?
                      • ? Offline
                        Hi @MJ ,
                        Check to see if you have your outdoor parameters correctly set: https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/tree/master/helpers/rb5
                        Sometimes the ekf2 aid mask is still set to 280.
                        You can arm the drone without GPS by setting COM_ARM_WO_GPS to 1.
                        • ? Offline
                          Also, are the GPS LEDs illuminating? There should be the main one which should go from blue to green when it's ready. And a small one flashing on the side that shows a GPS lock.
                          • ? A Former User
                            M Offline
                            M Offline
                            MJ
                            #22
                            @RichieRich
                            I have made following changes (WO_GPS to 1 and EFK2_AID_MASK to 1 and to 0)
                            but now I receive following error:
                            The main GPS LED (blue) slowly blinks, but only in blue color.
                            The FIX LED has short blinks in blue color.
                            Could you please advise what to do?
                            • M Offline
                              M Offline
                              MJ
                              #23
                              Also when I go to QGC - Vehicle setup - Safety, I get this error
                              • M Offline
                                M Offline
                                MJ
                                When EFK2_AID_MASK is set to 1, following errors occur:
                                I emphasize that drone is under clear and sunny sky
                                • ? A Former User
                                  M Offline
                                  M Offline
                                  MJ
                                  @RichieRich
                                  Are there any updates or suggestions regarding above mentioned issues? Thanks!
                                  • ? Offline
                                    #26
                                    EKF2_AID_MASK should be set to 1 for GPS.
                                    Have you set CP_DIST > 0? From the warning, it looks like you have the avoidance system on and it may be seeing something. d5e4c765-1797-4451-bee6-abf63c356689-image.png
                                    How are you mounting the GPS unit? Just an un-modified RB5 with mast? I assume you're outdoors with a clear view of the sky. In some cases, interference will throw that error. Setting COM_ARM_WO_GPS will always allow you to arm despite GPS errors. If you still can't arm, there's usualy another issue, maybe as stated above that the obstacle avoidance system is enabled. Another place to check is in QGC under safeties to ensure the avoidance system is disabled.
                                    Againg for the GPS< Flashing blue, means it's still waiting for the GPS to be fully ready. Small blue LED on the side will flash blue showing a lock.
                                    You can also try opening up the GPS check values or disabling some checks. For instance you can open up ekf2_req_sacc from 0.5 to about 0.75.
                                    There's also the GPS check you can experiment with to see what exactly the error is to get to ready (most likely interference). You can try turning off bit 4 for instance. Your mask is currently set to the default 245 or 11110101.
                                    • ? A Former User
                                      M Offline
                                      M Offline
                                      MJ
                                      #27
                                      @RichieRich
                                      GPS unit is mounted by default (as it comes with RB5 5G drone), mast is locked in vertical postion.
                                      Turning EKF2_REQ_SACC to 0,75 provided no errors from GPS.
                                      Obstacle avoidance was also disabled, so we managed to fly.
                                      But I'm still a bit confused why the obstacle avoidance gives error, since the drone was placed on the ground (concrete pavement), no obstacles within few meters, while the minimum distance was set to only 1 m. But this is current setup that works:
                                      Many thanks for your help. We'll try to figure this out and provide info in a few days.
