  3. voxl-streamer client repetitive connect/disconnect
63 Posts 3 Posters 37.8k Views 3 Watching
    @wilkinsaf Sorry, it was setup as private. I changed it to public. Can you try again?
    wilkinsafW Offline
    wilkinsafW Offline
    wilkinsaf
    @Eric-Katzfey Will it remain public?
    • wilkinsafW wilkinsaf
      @wilkinsaf Yes, it will remain public. Did you get a chance to see if the changes worked?
      wilkinsafW 2 Replies Last reply
        wilkinsafW Offline
        wilkinsafW Offline
        wilkinsaf
        @Eric-Katzfey Testing out today
          wilkinsafW Offline
          wilkinsafW Offline
          wilkinsaf
          We seem to be having trouble finding the camera now which is weird. I wonder if we need to specifically download and install the drivers?
            @wilkinsaf No, you shouldn't need any drivers. Any USB device should be listed with lsusb, even without any specific drivers. Does it show up when plugged into a regular Linux computer?
            wilkinsafW 1 Reply Last reply
              wilkinsafW Offline
              wilkinsafW Offline
              wilkinsaf
              @Eric-Katzfey Yes, we have hardwired it into a computer before. We have seen the stream using ffmpeg on VOXL as well. We just can not seem to get voxl-streamer to work with it
                @wilkinsaf If you unplug the camera from Voxl does anything disappear from the lsusb list?
                  wilkinsafW Offline
                  wilkinsafW Offline
                  wilkinsaf
                  #35
                  Yes, the top 3 entries in lsusb screenshots above are all cameras. I can unplug those one by one and see them disappear.
                  Would it matter if we have 2 UVC cameras?
                    @wilkinsaf Just try one at a time for now. And when you plug the camera in do you see a new /dev/videoX entry appear?
                      @wilkinsaf Also, were you able to get the ordering information for these cameras? If they aren't too expensive I would like to order at least one of them to test against.
                      wilkinsafW 3 Replies Last reply
                        wilkinsafW Offline
                        wilkinsafW Offline
                        wilkinsaf
                        Yes, let me try one at a time now.
                        Here are the two cameras
                        4de39b51-2708-4707-a1fe-d67161270aa3-image.png ![0_1640728100493_PXL_20211228_214717072.jpg](Uploading 100%)
                        1. Banggood URL
                        2. Blue Robotics URL
                          wilkinsafW Offline
                          wilkinsafW Offline
                          wilkinsaf
                          Good news, I was able to get voxl-uvc-server to spin up with one usb camera connected.
                          However, I am getting this issue from voxl-streamer
                          Seems like I need to figure out the frame size and set the correct one. Let me play around with that now
                            wilkinsafW Offline
                            wilkinsafW Offline
                            wilkinsaf
                            @Eric-Katzfey Doesn't look to be frame size as the "sizes" seem non-deterministic
                              @wilkinsaf Great, that's some progress! What about if you try the other camera? Not sure why the frame length is different. For a given resolution and frame format that number should be a constant. (e.g. 640 x 480 x 2).
                                wilkinsafW Offline
                                wilkinsafW Offline
                                wilkinsaf
                                Good suggestion. Let me try that.
                                Check out the length when uvc server fires up
                                Got frame callback! frame_format = 3, width = 640, height = 480, length = 613376, ptr = 0
                                interesting
                                  @wilkinsaf You can try modifying this line in voxl-uvc-server: https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server/-/blob/dev/src/main.c#L83
                                  Make it read: .size_bytes = 614400, \
                                  Then rebuild it and try again.
                                    wilkinsafW Offline
                                    wilkinsafW Offline
                                    wilkinsaf
                                    #44
                                    @Eric-Katzfey Sounds good.
                                    The other camera is giving me this error
                                    The one I compiled could not find the device at all
                                      @wilkinsaf Perhaps you are working on master branch? The latest and greatest (The one you should be using) is the dev branch.
                                        1. Banggood URL
                                        @wilkinsaf Thanks! I'm going to order them so that I can have them as part of our normal USB UVC camera test suite.
                                          wilkinsafW Offline
                                          wilkinsafW Offline
                                          wilkinsaf
                                          @Eric-Katzfey Thanks Eric!
                                          I switched to dev branch (slightly embarrassing as you told me to switch to dev) and pull
                                          voxl:~/voxl-uvc-server(dev)$ git pull origin dev
                                          From https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server
                                           * branch            dev        -> FETCH_HEAD
                                          Already up-to-date.
                                          I made sure to install the correct libuvc ipk
                                          voxl:~$ opkg install libuvc_1.0.2_202112182223.ipk
                                          Collected errors:
                                          * opkg_prepare_file_for_install: Refusing to load file 'libuvc_1.0.2_202112182223.ipk' as it matches the installed version of libuvc (1.0.2).
                                          I then built the voxl-uvc-server, ran Makefile, and tried to run
