  3. voxl-streamer client repetitive connect/disconnect
63 Posts 3 Posters 35.2k Views 3 Watching
    @wilkinsaf There is a new version of libuvc available at http://voxl-packages.modalai.com/dev/libuvc_1.0.2_202112182223.ipk with the changes. If you rebuild the dev branch of voxl-uvc-server and install build deps from dev you should pick up the new libuvc. Then you can rebuild and test with your camera.
    wilkinsafW Offline
    wilkinsafW Offline
    wilkinsaf
    @Eric-Katzfey will post results after run
      @wilkinsaf Project is here: https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server
      wilkinsafW Offline
      wilkinsafW Offline
      wilkinsaf
      @Eric-Katzfey Sorry for being such a pain, but it seems like this repo keeps moving.
      I went to https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server
      but got this
      I keep searching around for the repo, but can not find it
      • wilkinsafW wilkinsaf
        but got this
        @wilkinsaf Sorry, it was setup as private. I changed it to public. Can you try again?
        wilkinsafW 2 Replies Last reply
          wilkinsafW Offline
          wilkinsafW Offline
          wilkinsaf
          @Eric-Katzfey Got it, thank you!
          Will download and play with
            wilkinsafW Offline
            wilkinsafW Offline
            wilkinsaf
            @Eric-Katzfey Will it remain public?
              @wilkinsaf Yes, it will remain public. Did you get a chance to see if the changes worked?
                wilkinsafW Offline
                wilkinsafW Offline
                wilkinsaf
                @Eric-Katzfey Testing out today
                  wilkinsafW Offline
                  wilkinsafW Offline
                  wilkinsaf
                  We seem to be having trouble finding the camera now which is weird. I wonder if we need to specifically download and install the drivers?
                    @wilkinsaf No, you shouldn't need any drivers. Any USB device should be listed with lsusb, even without any specific drivers. Does it show up when plugged into a regular Linux computer?
                    wilkinsafW 1 Reply Last reply
                      wilkinsafW Offline
                      wilkinsafW Offline
                      wilkinsaf
                      @Eric-Katzfey Yes, we have hardwired it into a computer before. We have seen the stream using ffmpeg on VOXL as well. We just can not seem to get voxl-streamer to work with it
                        @wilkinsaf If you unplug the camera from Voxl does anything disappear from the lsusb list?
                          wilkinsafW Offline
                          wilkinsafW Offline
                          wilkinsaf
                          #35
                          Yes, the top 3 entries in lsusb screenshots above are all cameras. I can unplug those one by one and see them disappear.
                          Would it matter if we have 2 UVC cameras?
                            @wilkinsaf Just try one at a time for now. And when you plug the camera in do you see a new /dev/videoX entry appear?
                              @wilkinsaf Also, were you able to get the ordering information for these cameras? If they aren't too expensive I would like to order at least one of them to test against.
                              wilkinsafW 3 Replies Last reply
                                wilkinsafW Offline
                                wilkinsafW Offline
                                wilkinsaf
                                Yes, let me try one at a time now.
                                Here are the two cameras
                                4de39b51-2708-4707-a1fe-d67161270aa3-image.png ![0_1640728100493_PXL_20211228_214717072.jpg](Uploading 100%)
                                1. Banggood URL
                                2. Blue Robotics URL
                                  wilkinsafW Offline
                                  wilkinsafW Offline
                                  wilkinsaf
                                  Good news, I was able to get voxl-uvc-server to spin up with one usb camera connected.
                                  However, I am getting this issue from voxl-streamer
                                  Seems like I need to figure out the frame size and set the correct one. Let me play around with that now
                                    wilkinsafW Offline
                                    wilkinsafW Offline
                                    wilkinsaf
                                    @Eric-Katzfey Doesn't look to be frame size as the "sizes" seem non-deterministic
                                      @wilkinsaf Great, that's some progress! What about if you try the other camera? Not sure why the frame length is different. For a given resolution and frame format that number should be a constant. (e.g. 640 x 480 x 2).
                                        wilkinsafW Offline
                                        wilkinsafW Offline
                                        wilkinsaf
                                        Good suggestion. Let me try that.
                                        Check out the length when uvc server fires up
                                        Got frame callback! frame_format = 3, width = 640, height = 480, length = 613376, ptr = 0
                                        interesting
                                          @wilkinsaf You can try modifying this line in voxl-uvc-server: https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server/-/blob/dev/src/main.c#L83
                                          Make it read: .size_bytes = 614400, \
                                          Then rebuild it and try again.
