  3. voxl-streamer client repetitive connect/disconnect
63 Posts 3 Posters 37.8k Views 3 Watching
  • wilkinsafW wilkinsaf
    @Eric-Katzfey Sorry for being such a pain, but it seems like this repo keeps moving.
    I went to https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server
    but got this
    I keep searching around for the repo, but can not find it
    @wilkinsaf Sorry, it was setup as private. I changed it to public. Can you try again?
    wilkinsafW 2 Replies Last reply
      wilkinsafW Offline
      wilkinsafW Offline
      wilkinsaf
      @Eric-Katzfey Got it, thank you!
      Will download and play with
        wilkinsafW Offline
        wilkinsafW Offline
        wilkinsaf
        @Eric-Katzfey Will it remain public?
          @wilkinsaf Yes, it will remain public. Did you get a chance to see if the changes worked?
            wilkinsafW Offline
            wilkinsafW Offline
            wilkinsaf
            @Eric-Katzfey Testing out today
              wilkinsafW Offline
              wilkinsafW Offline
              wilkinsaf
              We seem to be having trouble finding the camera now which is weird. I wonder if we need to specifically download and install the drivers?
                @wilkinsaf No, you shouldn't need any drivers. Any USB device should be listed with lsusb, even without any specific drivers. Does it show up when plugged into a regular Linux computer?
                wilkinsafW 1 Reply Last reply
                  wilkinsafW Offline
                  wilkinsafW Offline
                  wilkinsaf
                  @Eric-Katzfey Yes, we have hardwired it into a computer before. We have seen the stream using ffmpeg on VOXL as well. We just can not seem to get voxl-streamer to work with it
                    @wilkinsaf If you unplug the camera from Voxl does anything disappear from the lsusb list?
                      wilkinsafW Offline
                      wilkinsafW Offline
                      wilkinsaf
                      #35
                      Yes, the top 3 entries in lsusb screenshots above are all cameras. I can unplug those one by one and see them disappear.
                      Would it matter if we have 2 UVC cameras?
                        @wilkinsaf Just try one at a time for now. And when you plug the camera in do you see a new /dev/videoX entry appear?
                          @wilkinsaf Also, were you able to get the ordering information for these cameras? If they aren't too expensive I would like to order at least one of them to test against.
                          wilkinsafW 3 Replies Last reply
                            wilkinsafW Offline
                            wilkinsafW Offline
                            wilkinsaf
                            Yes, let me try one at a time now.
                            Here are the two cameras
                            4de39b51-2708-4707-a1fe-d67161270aa3-image.png ![0_1640728100493_PXL_20211228_214717072.jpg](Uploading 100%)
                            1. Banggood URL
                            2. Blue Robotics URL
                              wilkinsafW Offline
                              wilkinsafW Offline
                              wilkinsaf
                              Good news, I was able to get voxl-uvc-server to spin up with one usb camera connected.
                              However, I am getting this issue from voxl-streamer
                              Seems like I need to figure out the frame size and set the correct one. Let me play around with that now
                                wilkinsafW Offline
                                wilkinsafW Offline
                                wilkinsaf
                                @Eric-Katzfey Doesn't look to be frame size as the "sizes" seem non-deterministic
                                  @wilkinsaf Great, that's some progress! What about if you try the other camera? Not sure why the frame length is different. For a given resolution and frame format that number should be a constant. (e.g. 640 x 480 x 2).
                                    wilkinsafW Offline
                                    wilkinsafW Offline
                                    wilkinsaf
                                    Good suggestion. Let me try that.
                                    Check out the length when uvc server fires up
                                    Got frame callback! frame_format = 3, width = 640, height = 480, length = 613376, ptr = 0
                                    interesting
                                      @wilkinsaf You can try modifying this line in voxl-uvc-server: https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server/-/blob/dev/src/main.c#L83
                                      Make it read: .size_bytes = 614400, \
                                      Then rebuild it and try again.
                                        wilkinsafW Offline
                                        wilkinsafW Offline
                                        wilkinsaf
                                        #44
                                        @Eric-Katzfey Sounds good.
                                        The other camera is giving me this error
                                        The one I compiled could not find the device at all
                                          @wilkinsaf Perhaps you are working on master branch? The latest and greatest (The one you should be using) is the dev branch.
