  3. Starling 2 Max for indoor use in Japan: radio options, prop guards and payload mounting
3 Posts 2 Posters 53 Views 1 Watching
  • Y Offline
    Y Offline
    y_yoshihara
    wrote last edited by
    Hardware: Starling 2 Max (C28 / Wi-Fi) - evaluating before purchase. We do not own one yet, so there is no software version or log to share.
    Hello ModalAI team,
    We are evaluating the Starling 2 Max for indoor, GPS-denied autonomous flight research in Japan. Sales kindly pointed us to this forum for technical questions. We would appreciate any guidance on the following:
    1. Wi-Fi (-M36 option)
      • What is the exact model of the Wi-Fi module/dongle included with the -M36 option?
      • Can VOXL 2 use a different USB Wi-Fi adapter? If so, which chipsets/drivers are supported? (Radio equipment used in Japan must be certified under Japanese radio law, so we may need to use a locally certified adapter.)
    2. RC receiver
      The product page shows that every configuration includes an ELRS 915 MHz receiver (-T8). The 915 MHz band cannot be used for this purpose in Japan.
      • Can the Starling 2 Max be flown with no RC receiver at all, for example manual control from QGroundControl over Wi-Fi plus autonomous offboard missions? Are there any PX4 settings we should change for this (e.g. RC loss failsafe)?
      • Alternatively, can we replace it with a 2.4 GHz ELRS receiver or an S.BUS receiver (e.g. Futaba)? Which port and parameters should we use?
    3. Propeller guards
      • Are official propeller guards or a protective cage available for the Starling 2 Max (180 mm propellers)?
      • If not, are CAD/STEP files of the frame or arms available, so that we can design 3D-printed guards? How much extra weight would you expect the drone to handle without re-tuning?
    4. Payload mounting
      We plan to carry a sensor of about 100-300 g.
      • Are there mounting holes or a recommended mounting point on the frame (we understand the mass should be close to the center)?
      • What power outputs are available for a payload (voltage and maximum current)?
      • Can the payload communicate with VOXL 2 over USB or UART?
      • What flight time can we expect with about 300 g of payload?
    5. Lead time
      The product page says "Expected to ship within 60 business days." Is this the current lead time for the C28 / Wi-Fi configuration?
    Thank you very much for your help.
    Y 1 Reply Last reply
    • Eric KatzfeyE Offline
      Regarding RC receiver, yes you can fly without it. You can use a joystick via QGC instead. Or, you can just fly missions that don't require any RC input. You should be able to swap in a 2.4 GHz receiver. VOXL2 has no support for S.BUS so make sure it has a standard 4 wire UART. Just use the same port that the current ELRS receiver is connected to. You shouldn't have to change any parameters.
      • Y y_yoshihara
        Hello ModalAI team,
        2. RC receiver
        3. Propeller guards
        4. Payload mounting
        5. Lead time
        Y Offline
        Y Offline
        y_yoshihara
        Thank you very much, Eric. That answers our question about the RC receiver.
        If we remove the ELRS receiver and fly with a QGC joystick over Wi-Fi, is there anything we should set for the case where the Wi-Fi/QGC link is lost (for example, a GCS loss failsafe such as land or hold)?
        We would also be grateful for any information on the remaining points:
        1. Wi-Fi (-M36): What is the model of the included Wi-Fi dongle? Can VOXL 2 use another USB Wi-Fi adapter, and if so, which chipsets/drivers are supported? (In Japan we need a radio that is certified under Japanese radio law.)
        2. Propeller guards: Are official guards or a cage available for the Starling 2 Max? If not, are CAD/STEP files of the frame or arms available so we can design 3D-printed guards?
        3. Payload (about 100-300 g): Is there a recommended mounting point or mounting holes on the frame? What power output is available for a payload (voltage and maximum current)? And roughly what flight time should we expect with 300 g?
        4. Lead time: Is "ships within 60 business days" still the current lead time for the C28 / Wi-Fi configuration?
        Thank you again for your help.
