<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Starling 2 Max for indoor use in Japan: radio options, prop guards and payload mounting]]></title><description><![CDATA[<p dir="auto"><strong>Hardware:</strong> Starling 2 Max (C28 / Wi-Fi) - evaluating before purchase. We do not own one yet, so there is no software version or log to share.</p>
<p dir="auto">Hello ModalAI team,</p>
<p dir="auto">We are evaluating the Starling 2 Max for indoor, GPS-denied autonomous flight research in Japan. Sales kindly pointed us to this forum for technical questions. We would appreciate any guidance on the following:</p>
<ol>
<li>
<p dir="auto">Wi-Fi (-M36 option)</p>
<ul>
<li>What is the exact model of the Wi-Fi module/dongle included with the -M36 option?</li>
<li>Can VOXL 2 use a different USB Wi-Fi adapter? If so, which chipsets/drivers are supported? (Radio equipment used in Japan must be certified under Japanese radio law, so we may need to use a locally certified adapter.)</li>
</ul>
</li>
<li>
<p dir="auto">RC receiver<br />
The product page shows that every configuration includes an ELRS 915 MHz receiver (-T8). The 915 MHz band cannot be used for this purpose in Japan.</p>
<ul>
<li>Can the Starling 2 Max be flown with no RC receiver at all, for example manual control from QGroundControl over Wi-Fi plus autonomous offboard missions? Are there any PX4 settings we should change for this (e.g. RC loss failsafe)?</li>
<li>Alternatively, can we replace it with a 2.4 GHz ELRS receiver or an S.BUS receiver (e.g. Futaba)? Which port and parameters should we use?</li>
</ul>
</li>
<li>
<p dir="auto">Propeller guards</p>
<ul>
<li>Are official propeller guards or a protective cage available for the Starling 2 Max (180 mm propellers)?</li>
<li>If not, are CAD/STEP files of the frame or arms available, so that we can design 3D-printed guards? How much extra weight would you expect the drone to handle without re-tuning?</li>
</ul>
</li>
<li>
<p dir="auto">Payload mounting<br />
We plan to carry a sensor of about 100-300 g.</p>
<ul>
<li>Are there mounting holes or a recommended mounting point on the frame (we understand the mass should be close to the center)?</li>
<li>What power outputs are available for a payload (voltage and maximum current)?</li>
<li>Can the payload communicate with VOXL 2 over USB or UART?</li>
<li>What flight time can we expect with about 300 g of payload?</li>
</ul>
</li>
<li>
<p dir="auto">Lead time<br />
The product page says "Expected to ship within 60 business days." Is this the current lead time for the C28 / Wi-Fi configuration?</p>
</li>
</ol>
<p dir="auto">Thank you very much for your help.</p>
]]></description><link>https://forum.modalai.com/topic/5530/starling-2-max-for-indoor-use-in-japan-radio-options-prop-guards-and-payload-mounting</link><generator>RSS for Node</generator><lastBuildDate>Fri, 30 Oct 2026 22:43:57 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5530.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Oct 2026 01:50:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Starling 2 Max for indoor use in Japan: radio options, prop guards and payload mounting on Fri, 30 Oct 2026 17:05:19 GMT]]></title><description><![CDATA[<p dir="auto">Regarding RC receiver, yes you can fly without it. You can use a joystick via QGC instead. Or, you can just fly missions that don't require any RC input. You should be able to swap in a 2.4 GHz receiver. VOXL2 has no support for S.BUS so make sure it has a standard 4 wire UART. Just use the same port that the current ELRS receiver is connected to. You shouldn't have to change any parameters.</p>
]]></description><link>https://forum.modalai.com/post/27003</link><guid isPermaLink="true">https://forum.modalai.com/post/27003</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Fri, 30 Oct 2026 17:05:19 GMT</pubDate></item></channel></rss>
