Starling D0005 / VOXL 2 M0054-2 still stuck in Qualcomm 900e after QDL reflash
I am trying to recover a Starling D0005 with a VOXL 2 M0054-2.
The board previously worked normally over ADB, but it now always shows up as:
05c6:900e Qualcomm QUSB_BULK VOXL USB serial: c1abd993 Qualcomm serial: D3323EEFI have SW2 set to OFF and have performed several full power cycles, but the board never appears in ADB or Fastboot.
Before the failure,
voxl-versionreported:hw_platform: M0054 mach.var: 1.2.0Based on that, I used the documented QDL recovery image for the Starling D0005 / M0054-2:
2024-02-09-1.7.4-M0054-2The QDL process completed successfully. Sahara and Firehose communication worked, and the tool programmed the full image, which was approximately 3.2 GiB. The board then reset and re-enumerated.
However, after removing power, setting SW2 back to OFF, and booting normally, it returned to the same
05c6:900estate.I was also able to capture a read-only Qualcomm Sahara crash dump. It is approximately 8.1 GiB and contains four 2 GiB DDR regions, along with OCIMEM, PIMEM, reset data, and PMIC metadata. I have not uploaded it publicly because it may have sensitive memory contents.
Has anyone encountered this before?
Does a persistent
900estate after a successful flash with the correct M0054-2 image usually indicate a hardware failure?
Is there another recovery procedure I should try before contacting ModalAI for repair or an RMA? -
Hi @alraj,
05c6:900e QUSB_BULK is not EDL (that is 9008). It is the SoC crash-dump mode, so the board is attempting to boot and failing before the OS comes up. Since Sahara/Firehose completed with the correct M0054-2 image, the flash contents are unlikely to be the problem. In past cases a board that returns to 900e after a successful QDL has not been recoverable by reflashing (https://forum.modalai.com/topic/1468 and https://forum.modalai.com/topic/3263), and a similar Sentinel case came back from RMA as a damaged main board (https://forum.modalai.com/topic/2131).
Two things worth ruling out first. Pull the VOXL 2 out of the drone and boot it bare with every camera and add-on disconnected, since a mis-seated camera connector produced this same 900e state once (https://forum.modalai.com/topic/3230). Then re-check the steps at https://docs.modalai.com/voxl2-unbricking/#if-the-device-still-shows-900e-or-boot-loops-after-a-successful-flash and repeat the flash once.
If it still comes back as 900e, an RMA is the next step: https://www.modalai.com/pages/rma. Include the serial number and QDL log. Keep the crash dump private, support can request it if needed.
@alex-kushleyev @ModalAI-Team . Could you guys help me with this? thank you!
Hi @alraj,
T tom has marked this topic as solved
