<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Starling D0005 &#x2F; VOXL 2 M0054-2 still stuck in Qualcomm 900e after QDL reflash]]></title><description><![CDATA[<p dir="auto">I am trying to recover a Starling D0005 with a VOXL 2 M0054-2.</p>
<p dir="auto">The board previously worked normally over ADB, but it now always shows up as:</p>
<pre><code class="language-text">05c6:900e Qualcomm QUSB_BULK
VOXL USB serial: c1abd993
Qualcomm serial: D3323EEF
<p dir="auto">I have SW2 set to OFF and have performed several full power cycles, but the board never appears in ADB or Fastboot.</p>
<p dir="auto">Before the failure, <code>voxl-version</code> reported:</p>
<pre><code class="language-text">hw_platform: M0054
mach.var: 1.2.0
<p dir="auto">Based on that, I used the documented QDL recovery image for the Starling D0005 / M0054-2:</p>
<pre><code class="language-text">2024-02-09-1.7.4-M0054-2
<p dir="auto">The QDL process completed successfully. Sahara and Firehose communication worked, and the tool programmed the full image, which was approximately 3.2 GiB. The board then reset and re-enumerated.</p>
<p dir="auto">However, after removing power, setting SW2 back to OFF, and booting normally, it returned to the same <code>05c6:900e</code> state.</p>
<p dir="auto">I was also able to capture a read-only Qualcomm Sahara crash dump. It is approximately 8.1 GiB and contains four 2 GiB DDR regions, along with OCIMEM, PIMEM, reset data, and PMIC metadata. I have not uploaded it publicly because it may have sensitive memory contents.</p>
<p dir="auto">Has anyone encountered this before?</p>
<p dir="auto">Does a persistent <code>900e</code> state after a successful flash with the correct M0054-2 image usually indicate a hardware failure?<br />
Is there another recovery procedure I should try before contacting ModalAI for repair or an RMA?</p>
]]></description><link>https://forum.modalai.com/topic/5341/starling-d0005-voxl-2-m0054-2-still-stuck-in-qualcomm-900e-after-qdl-reflash</link><generator>RSS for Node</generator><lastBuildDate>Fri, 24 Jul 2026 17:14:30 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5341.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Jul 2026 17:18:23 GMT</pubDate><ttl>60</ttl></channel></rss>
