  2. VOXL Dev Drones
  3. Starling & Starling 2
  4. Starling D0005 / VOXL 2 M0054-2 still stuck in Qualcomm 900e after QDL reflash
2 Posts 1 Posters 115 Views 1 Watching
  • A Offline
    alraj
    wrote last edited by
    I am trying to recover a Starling D0005 with a VOXL 2 M0054-2.
    The board previously worked normally over ADB, but it now always shows up as:
    05c6:900e Qualcomm QUSB_BULK
    VOXL USB serial: c1abd993
    Qualcomm serial: D3323EEF
    I have SW2 set to OFF and have performed several full power cycles, but the board never appears in ADB or Fastboot.
    Before the failure, voxl-version reported:
    hw_platform: M0054
    mach.var: 1.2.0
    Based on that, I used the documented QDL recovery image for the Starling D0005 / M0054-2:
    2024-02-09-1.7.4-M0054-2
    The QDL process completed successfully. Sahara and Firehose communication worked, and the tool programmed the full image, which was approximately 3.2 GiB. The board then reset and re-enumerated.
    However, after removing power, setting SW2 back to OFF, and booting normally, it returned to the same 05c6:900e state.
    I was also able to capture a read-only Qualcomm Sahara crash dump. It is approximately 8.1 GiB and contains four 2 GiB DDR regions, along with OCIMEM, PIMEM, reset data, and PMIC metadata. I have not uploaded it publicly because it may have sensitive memory contents.
    Has anyone encountered this before?
    Does a persistent 900e state after a successful flash with the correct M0054-2 image usually indicate a hardware failure?
    Is there another recovery procedure I should try before contacting ModalAI for repair or an RMA?
    • A Offline
      alraj
      @alex-kushleyev @ModalAI-Team . Could you guys help me with this? thank you!
