  3. Sentinel Not connecting over adb
4 Posts 1 Posters 897 Views
  • S Offline
    S Offline
    SMRazaRizvi
    I am trying to connect to my Sentinel drone over the USB, but suddenly it doesn't connect using the adb shell.
    My laptop can see the USB device when I do run lsusb
    Bus 001 Device 016: ID 05c6:900e Qualcomm, Inc. QUSB_BULK_SN:EBC5FC33
    but when I run adb shell it says
    error: no devices/emulators found
    Please help.
    S 1 Reply Last reply
    • S SMRazaRizvi
      Please help.
      S Offline
      S Offline
      SMRazaRizvi
      @SMRazaRizvi I even performed the Unbricking steps as mentioned here but the issue persists.
      • S SMRazaRizvi
        S Offline
        S Offline
        SMRazaRizvi
        @SMRazaRizvi The Unbricking, however, was successfull. Below are the last few lines from the output, and at some point inside the output I said [PROGRAM] flashed "system" successfully
        FIREHOSE READ: <?xml version="1.0" encoding="UTF-8" ?>
        <data>
        <log value="INFO: Calling handler for patch" /></data>
        LOG: INFO: Calling handler for patch
        <data>
        <response value="ACK" rawmode="false" /></data>
        FIREHOSE WRITE: <?xml version="1.0"?>
        <data><setbootablestoragedrive value="1"/></data>
        <data>
        <log value="INFO: Calling handler for setbootablestoragedrive" /></data>
        LOG: INFO: Calling handler for setbootablestoragedrive
        <data>
        <log value="INFO: Using scheme of value= 1" /></data>
        LOG: INFO: Using scheme of value= 1
        <data>
        partition 1 is now bootable
        <data><power value="reset"/></data>
        <data>
        <log value="INFO: Calling handler for power" /></data>
        LOG: INFO: Calling handler for power
        <data>
        • S SMRazaRizvi
          <data>
          <data>
          <data>
          <data>
          <data>
          <data>
          <data>
          S Offline
          S Offline
          SMRazaRizvi
          @SMRazaRizvi Issue resolved.
          I connected one of the camera ports in a wrong orientation.
