    Sentinel Not connecting over adb
    • S
      SMRazaRizvi
      I am trying to connect to my Sentinel drone over the USB, but suddenly it doesn't connect using the adb shell.
      My laptop can see the USB device when I do run lsusb
      Bus 001 Device 016: ID 05c6:900e Qualcomm, Inc. QUSB_BULK_SN:EBC5FC33
      but when I run adb shell it says
      error: no devices/emulators found
      Please help.
      • S
        SMRazaRizvi @SMRazaRizvi
        @SMRazaRizvi I even performed the Unbricking steps as mentioned here but the issue persists.
        • S
          @SMRazaRizvi The Unbricking, however, was successfull. Below are the last few lines from the output, and at some point inside the output I said [PROGRAM] flashed "system" successfully
          <data>
          <log value="INFO: Calling handler for patch" /></data>
          LOG: INFO: Calling handler for patch
          <data>
          <data><setbootablestoragedrive value="1"/></data>
          <data>
          <log value="INFO: Calling handler for setbootablestoragedrive" /></data>
          LOG: INFO: Calling handler for setbootablestoragedrive
          <data>
          <log value="INFO: Using scheme of value= 1" /></data>
          LOG: INFO: Using scheme of value= 1
          <data>
          partition 1 is now bootable
          <data>
          <data>
          • S
            @SMRazaRizvi Issue resolved.
            I connected one of the camera ports in a wrong orientation.
