  3. Requesting the factory original calibration files for ADK Ser#M2500000185
24 Posts 3 Posters 12.2k Views 1 Watching
  • L latif
    @tom Yeah, it's starting to look dangerous. Here's the output:
    tomT Online
    tomT Online
    @latif You should be able to go into /var and see what's full and deleting it
    • L latif
      L Offline
      L Offline
      latif
      @latif Thanks! syslog was 27G! Emptied it out and running voxl-configure-cameras again. Hopefully this will fix the other issues.
      L 1 Reply Last reply
      • L latif
        L Offline
        L Offline
        latif
        @latif Hi @tom, cleaning up the /var/syslog file enabled the camera server to run - so the cameras are fine. I'm still not sure if all the calibrations are right, I see an error message 38b571ca-0981-47b6-840b-b372622479ca-image.png when I try to bind the Commando8 Controller. Also, could never get a "READY" sign on QGroundControl. Should I run the "Sensor Calibration" options? Not knowing what that'd do, I didn't run them.
        If this is relevant information: I'm not getting GPS data consistently (right now getting nothing, but earlier at some point in time I did), right now I see this on QGC: cbaf5101-0eef-4acc-a295-5f60a218b725-image.png
        • L latif
          tomT Online
          tomT Online
          @latif What do you see if you run voxl-check-calibration?
          It sometimes takes a while to get a GPS lock for the first time in a new location, may have to let the drone sit outside for 5-10 minutes for the initial lock, will be much faster after that.
            L Offline
            L Offline
            latif
            @tom I'll let it sit outside for a few minutes for GPS locks. Here's the output for voxl-check-calibration: 79b81c4c-46e8-43f4-9733-0a577fae95f1-image.png
            • L latif
              tomT Online
              tomT Online
              @latif You'll want to load the GPS specific px4 param file in order for "position" mode to use GPS position as opposed to VIO position.
              If you run voxl-configure-px4-params -w and navigate to EKF2_helpers you should be able to see the relevant options.
                L Offline
                L Offline
                latif
                @tom Now that I seem to have a good health check and the cameras working, I'd like to do the simplest possible first flight -- I went through the video directions in the Bootcamp, but wasn't able to go beyond trying to "arm" it.
                • I can't tell if it is binding or not. Tried the voxl-elrs -b, which seems to take it as the blue flashing lights become steady, but no movement of the propellers on trying to arm. I'm seeing a "model mismatch" message on the Commando8 Remote Controller. This shipped with the ADK and nothing has been done to it.
                • I need some help in flying it, indoors if that's ealier without GPS, but ultimately with GPS mission-planning, but I seem to be far from it, because I haven't done even a simple off-the-shelf type of flight.
                • This is my first time handling a drone of any kind, so I'm lacking some knowledge and could use some instructions to get this simple first flight job done.
                • L latif
                  L Offline
                  L Offline
                  latif
                  @latif 88031482-bb56-49e6-887e-5152cc35af1e-image.png ![7999568d-997f-482e-9793-7c056611fb7b-image.png](Request Entity Too Large)
                  Maxwell SchaeferM 1 Reply Last reply
                  • L latif
                    Maxwell SchaeferM Offline
                    Maxwell Schaefer
                    wrote on last edited by Maxwell Schaefer
                    #23
                    @latif You should be able to disable the model match feature on the same screen which displayed the "Model Mismatch" error. By setting the model match id to 0, it will ignore the model match id set on the receiver and connect. The ExpressLRS documentation has more detail about how to set up the RC connection here.
                    • Maxwell SchaeferM Maxwell Schaefer
                      L Offline
                      L Offline
                      latif
                      @Maxwell-Schaefer Thank you! I was able to set the model match to off using the controller screen.
