  3. Requesting the factory original calibration files for ADK Ser#M2500000185
24 Posts 3 Posters 12.8k Views 1 Watching
  • L latif
    @tom Absolutely. I'd definitely like to have the correct files, On a closer look ADK-serial.jpg I probably read the S as a "5" - the serial number I think is "M250000018S" - that probably changes everything. Here's a photo of the drone: ADK.jpg
    You'll send me the voxl-imu-server.cal also, right? It's been flagged as missing. Thanks!
    I'm also attaching the packing slip so we can finalize on what the correct SKU should be. f0aa237d-575c-4b63-a6a7-edc1db988a2a-image.png
    L Offline
    L Offline
    latif
    @latif Hi @tom, thank you for sending me the yml file. Applying that I get a good healthcheck, after calibrating the imu.
    I do still have a problem with the cameras. I see that voxl-camera-server is not running (fails at startup).
    My SKU is the following, having taken the default cam config of 20:
    family code: MRB-D0011 (px4-autonomy-dev-kit)
    compute board: 4 (voxl2)
    hw version: 1
    cam config: 20
    modem config: 0 (none)
    tx config: 7 (elrs_beta_fpv)
    extras config: 0 (none)
    SKU: MRB-D0011-4-V1-C20-T7-M0-X0
    I did see this error while running voxl-configure-mpa: FAILED TO EXECUTE: voxl-configure-cameras 20 f7f4529c-e469-4945-b671-54c73ebc44d6-image.png
    Please advise what camera configuration to use. FYI, I did try 19, and with that it was able to run "voxl-configure-cameras 20", but the final result was the same, voxl-camera-server was not running.
    L 1 Reply Last reply
    • L latif
      hw version: 1
      cam config: 20
      L Offline
      L Offline
      latif
      @latif I meant "voxl-configure-cameras 19"... in the post above.
      • L latif
        @latif I wonder if you have the wrong kernel on there. If you run voxl-configure-cameras what options does it give you?
          L Offline
          L Offline
          latif
          • L Offline
            L Offline
            latif
            Maybe a different issue, running configure stand-alone shows this problem:
            Checking space I see this:
            • L latif
              wrote on last edited by tom
              #10
              @latif oh boy, well that is certainly an issue, can you run sudo du -h -d 1 / 2>/dev/null | sort -h to see which directory/partition is full?
              L 2 Replies Last reply
                L Offline
                L Offline
                latif
                @tom Yeah, it's starting to look bleak! Here's the output:
                The only user data I have is under /home/root, about 1.8GB. I can free up some of it, but how do I redirect the configuration processes to use a different directory other than /usr, /lib, etc.?
                Also, is there a way to increase the overall storage size? I see that the biggest partition ("sda") is only 118G and now full.
                • L latif
                  @latif /var being that full is very abnormal, here is a screenshot from one of my drones:
                    @tom It's possible /var/log/journal/ is full for some reason? You could try clearing stale logs from there
                      L Offline
                      L Offline
                      latif
                      @tom Yeah, it's starting to look dangerous. Here's the output:
                      tomT L 2 Replies Last reply
                      • L latif
                        @latif You should be able to go into /var and see what's full and deleting it
                        • L latif
                          L Offline
                          L Offline
                          latif
                          @latif Thanks! syslog was 27G! Emptied it out and running voxl-configure-cameras again. Hopefully this will fix the other issues.
                          • L latif
                            L Offline
                            L Offline
                            latif
                            @latif Hi @tom, cleaning up the /var/syslog file enabled the camera server to run - so the cameras are fine. I'm still not sure if all the calibrations are right, I see an error message 38b571ca-0981-47b6-840b-b372622479ca-image.png when I try to bind the Commando8 Controller. Also, could never get a "READY" sign on QGroundControl. Should I run the "Sensor Calibration" options? Not knowing what that'd do, I didn't run them.
                            If this is relevant information: I'm not getting GPS data consistently (right now getting nothing, but earlier at some point in time I did), right now I see this on QGC: cbaf5101-0eef-4acc-a295-5f60a218b725-image.png
                            • L latif
                              @latif What do you see if you run voxl-check-calibration?
                              It sometimes takes a while to get a GPS lock for the first time in a new location, may have to let the drone sit outside for 5-10 minutes for the initial lock, will be much faster after that.
                                L Offline
                                L Offline
                                latif
                                @tom I'll let it sit outside for a few minutes for GPS locks. Here's the output for voxl-check-calibration: 79b81c4c-46e8-43f4-9733-0a577fae95f1-image.png
                                • L latif
                                  @latif You'll want to load the GPS specific px4 param file in order for "position" mode to use GPS position as opposed to VIO position.
                                  If you run voxl-configure-px4-params -w and navigate to EKF2_helpers you should be able to see the relevant options.
                                    L Offline
                                    L Offline
                                    latif
                                    @tom Now that I seem to have a good health check and the cameras working, I'd like to do the simplest possible first flight -- I went through the video directions in the Bootcamp, but wasn't able to go beyond trying to "arm" it.
                                    • I can't tell if it is binding or not. Tried the voxl-elrs -b, which seems to take it as the blue flashing lights become steady, but no movement of the propellers on trying to arm. I'm seeing a "model mismatch" message on the Commando8 Remote Controller. This shipped with the ADK and nothing has been done to it.
                                    • I need some help in flying it, indoors if that's ealier without GPS, but ultimately with GPS mission-planning, but I seem to be far from it, because I haven't done even a simple off-the-shelf type of flight.
                                    • This is my first time handling a drone of any kind, so I'm lacking some knowledge and could use some instructions to get this simple first flight job done.
                                    • L latif
                                      L Offline
                                      L Offline
                                      latif
                                      @latif 88031482-bb56-49e6-887e-5152cc35af1e-image.png ![7999568d-997f-482e-9793-7c056611fb7b-image.png](Request Entity Too Large)
                                      Maxwell SchaeferM 1 Reply Last reply
                                      • L latif
                                        Maxwell SchaeferM Offline
                                        Maxwell Schaefer
                                        wrote on last edited by Maxwell Schaefer
                                        #23
                                        @latif You should be able to disable the model match feature on the same screen which displayed the "Model Mismatch" error. By setting the model match id to 0, it will ignore the model match id set on the receiver and connect. The ExpressLRS documentation has more detail about how to set up the RC connection here.
                                        • Maxwell SchaeferM Maxwell Schaefer
                                          L Offline
                                          L Offline
                                          latif
                                          @Maxwell-Schaefer Thank you! I was able to set the model match to off using the controller screen.
