  3. doodle labs and joystick setup
30 Posts 2 Posters 6.9k Views 1 Watching
  • Jetson NanoJ Jetson Nano
    @Eric-Katzfey yes , I am using the QGC to map joystick buttons. I am using the voxl-fpv-dev version from the modalai px4 repo. I am using the FPV 4-in-1 ESC. I am not able to get more than 2 toggle switches and also not able to assign them two way.
    Eric KatzfeyE Online
    @Jetson-Nano voxl-fpv-dev is the name of the branch. The version will be a number, such as 1.14.0-8.104.3. Most of the joystick button mapping is handled by QGC directly. It maps them to commands that are sent over Mavlink. But the turtle mode is something specific built into the ESC driver. For the joystick buttons to work for turtle mode you need to set VOXL_ESC_MODE to 1. For newer versions of the voxl-fpv-dev branch you can also set VOXL_ESC_MODE to 2. The verify that the button mapping is working you can look at the manual_control_setpoint topic in px4 and see if the aux1 / aux2 fields are changing between 0.0 and 1.0. (e.g. px4-listener manual_control_setpoint)
      Jetson NanoJ Offline
      Jetson Nano
      Veteran
      @Eric-Katzfey Thank you for the support. I will test it out and get back to you encase of any further queries.
        Jetson Nano
        Veteran
        I tested what you asked me, since i am using external Fc and doodle labs, I am not able to assign AUX to any button, is there any work around on how to assign AUX
          Jetson Nano
          Veteran
          @Eric-Katzfey @Alex-Kushleyev
          hey guys, just a random thought, can I enable turtle mode through a button instead of taking AUX 1 into consideration. just a thought, any guidance and help would be greatly appreciated.
            @Jetson-Nano What do you see if you go to the MAVLink console in QGC and look at the manual_control_setpoint topic? (listener manual_control_setpoint)?
            Eric KatzfeyE Jetson NanoJ 2 Replies Last reply
              @Eric-Katzfey Also, there is a parameter called VOXL_ESC_T_ON. How is that set? It determines which button will be used for turtle mode. The code is here: https://github.com/modalai/px4-firmware/blob/ea098200d3c09b7af548bf7be29fda245fad8f17/src/modules/mavlink/mavlink_receiver.cpp#L2083
                Jetson Nano
                Veteran
                #11
                This is the output i am getting while running listener manual_control_setpoint
                NuttShell (NSH) NuttX-11.0.0
                nsh> listener manual_control_setpoint
                TOPIC: manual_control_setpoint
                    timestamp: 438754659 (0.033455 seconds ago)
                    timestamp_sample: 438754653 (6 us before timestamp)
                    roll: 0.00000
                    pitch: 0.00000
                    yaw: 0.00000
                    throttle: 0.00000
                    flaps: 0.00000
                    aux1: 0.00000
                    aux2: 0.00000
                    aux3: 0.00000
                    aux4: 0.00000
                    aux5: 0.00000
                    aux6: 0.00000
                    buttons: 0
                    valid: True
                    data_source: 2
                    sticks_moving: False
                    timestamp: 446282690 (0.039850 seconds ago)
                    timestamp_sample: 446282683 (7 us before timestamp)
                    roll: 0.00000
                    pitch: 0.00000
                    yaw: 0.00000
                    throttle: 0.00000
                    flaps: 0.00000
                    aux1: 0.00000
                    aux2: 0.00000
                    aux3: 0.00000
                    aux4: 0.00000
                    aux5: 0.00000
                    aux6: 0.00000
                    buttons: 0
                    valid: True
                    data_source: 2
                  Jetson Nano
                  Veteran
                  #12
                  @Eric-Katzfey I am not able to see the option you have mentioned VOXL_ESC_T_ON
                    @Jetson-Nano said in doodle labs and joystick setup:
                    In the Mavlink console what do you see with "param show VOXL_ESC_*"?
                    And what about "ver all"?
                          roll: 0.00000
                          pitch: 0.00000
                          yaw: 0.00000
                          throttle: 0.00000
                          flaps: 0.00000
                          aux1: 0.00000
                          aux2: 0.00000
                          aux3: 0.00000
                          aux4: 0.00000
                          aux5: 0.00000
                          aux6: 0.00000
                          buttons: 0
                          valid: True
                          data_source: 2
                          roll: 0.00000
                          pitch: 0.00000
                          yaw: 0.00000
                          throttle: 0.00000
                          flaps: 0.00000
                          aux1: 0.00000
                          aux2: 0.00000
                          aux3: 0.00000
                          aux4: 0.00000
                          aux5: 0.00000
                          aux6: 0.00000
                          buttons: 0
                          valid: True
                          data_source: 2
                      What is the parameter COM_RC_IN_MODE set to?
                        Jetson Nano
                        Veteran
                        @Eric-Katzfey COM_RC_IN_MODE is set to joystick only
                          Jetson Nano
                          Veteran
                          #16
                          @Eric-Katzfey Hey hope you are doing fine, I checked the code and various branches of PX4, I noticed I was able to see the parameter VOXL_ESC_T_ON but the option only showcased button 1 for assignment . what to do if I want to assign another button.
                            @Jetson-Nano You set that parameter to match the button you want to use.
                              Jetson Nano
                              Veteran
                              @Eric-Katzfey Thank you for reverting back, The options only show one option button 1. I tested with button one but the drone was not taking in the command for enabling the turtle mode.
                              I want to know whether the code was tested out, so that I can be sure about not missing out on any parameter or setup
                                @Jetson-Nano It's a parameter that you can set to any number you want. In QGC you can look at the joysticks tab and see as you press each button which number it is. Then set the parameter to that number.
                                  Jetson Nano
                                  Veteran
                                  @Eric-Katzfey I am not able to setup multiple buttons, it is only showing one option of button 1.
                                  Also after assigning the button one and trying to enable and use turtle mode, it is not working.
                                  Is there any particular version of px4 that this works with.
                                  My setup is VOXL 2 ---> TELEM 1 --> Flight core v2 --> TELEM 2 --> FPV ESC
                                  In normal setup the motors are working and rotating, but when I try to keep the drone upside down and enable the turtle mode , the QGC is still showing not ready message. Also I am not able to ARM because of this.
                                  Is there anything I am missing out?
                                    Jetson Nano
                                    Veteran
                                    @Eric-Katzfey could you please help me out here
                                      #22
                                      @Jetson-Nano Let's try to walk through this and see where it is going wrong. Please provide answers to all of the following questions. Go to the joystick tab in QGC and press the button on the joystick that you want to use for turtle mode. Which number lights up when you press the button? Next, go to the MAVLink console and provide the output of these commands: ver all, listener manual_control_setpoint, param show VOXL_ESC_MODE, param show VOXL_ESC_T_ON, and param show COM_RC_IN_MODE. If VOXL_ESC_T_ON is not set to the number of the button you just discovered on the joystick tab then change it to the value you want. For example, by default VOXL_ESC_T_ON is set to 9. If you want to use button 10 instead then do param set VOXL_ESC_T_ON 10. If you had to change that parameter then reboot and verify that it is now set correctly. You should see the aux1 value in manual_control_setpoint change from 0.0 to 1.0 when you press the button that you have chosen. Can you verify that you are seeing that?
                                        @Jetson-Nano If all that seems to be working then press the turtle button and arm (with drone right side up, not upside down) and verify that with turtle mode enabled the propellers are spinning in the opposite direction and the drone won't lift off. Of course, you must be extremely careful when running this test!!! Make sure that the drone is in a location where it cannot cause damage or injure someone if it goes out of control. It would be best to completely remove the propellers and just verify that the motors are spinning in the opposite direction of normal flight.
                                          Jetson Nano
                                          Veteran
                                          #24
                                          I followed the steps you suggested, i am attaching the Screenshots. I tried what you suggested the result is still the same, I am not able to arm the system. I tried with various options for VOXL_ESC_MODE, still the same.
                                          I clicked the assigned button here, AUX 1 values are changing but only when i keep the voxl_ESC_MODE to UART passthorugh
