  3. doodle labs and joystick setup
30 Posts 2 Posters 6.9k Views 1 Watching
  • Jetson NanoJ Jetson Nano
    Hey @Alex-Kushleyev @Eric-Katzfey @Chad-Sweet
    I had a query about setting up joystick with doodle labs. I am not able to setup the joystick properly, not every buttons and toggle is working. AUX channels for Turtle mode or toggle for changing modes.
    my setup is
    • voxl 2 to Fc v2 to ESC
    • doodle labs nano to voxl 2
    Eric KatzfeyE Online
    @Jetson-Nano Are you using QGC to map joystick buttons to functions? What version of PX4 are you running on your FC v2?
    Eric KatzfeyE Jetson NanoJ 2 Replies Last reply
      @Eric-Katzfey For turtle mode with a joystick you need to set VOXL_ESC_MODE to 1 and, while not armed, press a button and keep it pressed while arming. For flight modes that should all be handled through QGC.
        Jetson NanoJ Offline
        Jetson Nano
        Veteran
        @Eric-Katzfey yes , I am using the QGC to map joystick buttons. I am using the voxl-fpv-dev version from the modalai px4 repo. I am using the FPV 4-in-1 ESC. I am not able to get more than 2 toggle switches and also not able to assign them two way.
          @Jetson-Nano voxl-fpv-dev is the name of the branch. The version will be a number, such as 1.14.0-8.104.3. Most of the joystick button mapping is handled by QGC directly. It maps them to commands that are sent over Mavlink. But the turtle mode is something specific built into the ESC driver. For the joystick buttons to work for turtle mode you need to set VOXL_ESC_MODE to 1. For newer versions of the voxl-fpv-dev branch you can also set VOXL_ESC_MODE to 2. The verify that the button mapping is working you can look at the manual_control_setpoint topic in px4 and see if the aux1 / aux2 fields are changing between 0.0 and 1.0. (e.g. px4-listener manual_control_setpoint)
            Jetson Nano
            Veteran
            @Eric-Katzfey Thank you for the support. I will test it out and get back to you encase of any further queries.
              Jetson Nano
              Veteran
              I tested what you asked me, since i am using external Fc and doodle labs, I am not able to assign AUX to any button, is there any work around on how to assign AUX
                Jetson Nano
                Veteran
                @Eric-Katzfey @Alex-Kushleyev
                hey guys, just a random thought, can I enable turtle mode through a button instead of taking AUX 1 into consideration. just a thought, any guidance and help would be greatly appreciated.
                  @Jetson-Nano What do you see if you go to the MAVLink console in QGC and look at the manual_control_setpoint topic? (listener manual_control_setpoint)?
                    @Eric-Katzfey Also, there is a parameter called VOXL_ESC_T_ON. How is that set? It determines which button will be used for turtle mode. The code is here: https://github.com/modalai/px4-firmware/blob/ea098200d3c09b7af548bf7be29fda245fad8f17/src/modules/mavlink/mavlink_receiver.cpp#L2083
                      Jetson Nano
                      Veteran
                      #11
                      This is the output i am getting while running listener manual_control_setpoint
                      NuttShell (NSH) NuttX-11.0.0
                      nsh> listener manual_control_setpoint
                      TOPIC: manual_control_setpoint
                          timestamp: 438754659 (0.033455 seconds ago)
                          timestamp_sample: 438754653 (6 us before timestamp)
                          roll: 0.00000
                          pitch: 0.00000
                          yaw: 0.00000
                          throttle: 0.00000
                          flaps: 0.00000
                          aux1: 0.00000
                          aux2: 0.00000
                          aux3: 0.00000
                          aux4: 0.00000
                          aux5: 0.00000
                          aux6: 0.00000
                          buttons: 0
                          valid: True
                          data_source: 2
                          sticks_moving: False
                          timestamp: 446282690 (0.039850 seconds ago)
                          timestamp_sample: 446282683 (7 us before timestamp)
                          roll: 0.00000
                          pitch: 0.00000
                          yaw: 0.00000
                          throttle: 0.00000
                          flaps: 0.00000
                          aux1: 0.00000
                          aux2: 0.00000
                          aux3: 0.00000
                          aux4: 0.00000
                          aux5: 0.00000
                          aux6: 0.00000
                          buttons: 0
                          valid: True
                          data_source: 2
                        Jetson Nano
                        Veteran
                        #12
                        @Eric-Katzfey I am not able to see the option you have mentioned VOXL_ESC_T_ON
                          @Jetson-Nano said in doodle labs and joystick setup:
                          In the Mavlink console what do you see with "param show VOXL_ESC_*"?
                          And what about "ver all"?
                                roll: 0.00000
                                pitch: 0.00000
                                yaw: 0.00000
                                throttle: 0.00000
                                flaps: 0.00000
                                aux1: 0.00000
                                aux2: 0.00000
                                aux3: 0.00000
                                aux4: 0.00000
                                aux5: 0.00000
                                aux6: 0.00000
                                buttons: 0
                                valid: True
                                data_source: 2
                                roll: 0.00000
                                pitch: 0.00000
                                yaw: 0.00000
                                throttle: 0.00000
                                flaps: 0.00000
                                aux1: 0.00000
                                aux2: 0.00000
                                aux3: 0.00000
                                aux4: 0.00000
                                aux5: 0.00000
                                aux6: 0.00000
                                buttons: 0
                                valid: True
                                data_source: 2
                            What is the parameter COM_RC_IN_MODE set to?
                              Jetson Nano
                              Veteran
                              @Eric-Katzfey COM_RC_IN_MODE is set to joystick only
                                Jetson Nano
                                Veteran
                                #16
                                @Eric-Katzfey Hey hope you are doing fine, I checked the code and various branches of PX4, I noticed I was able to see the parameter VOXL_ESC_T_ON but the option only showcased button 1 for assignment . what to do if I want to assign another button.
                                  @Jetson-Nano You set that parameter to match the button you want to use.
                                    Jetson Nano
                                    Veteran
                                    @Eric-Katzfey Thank you for reverting back, The options only show one option button 1. I tested with button one but the drone was not taking in the command for enabling the turtle mode.
                                    I want to know whether the code was tested out, so that I can be sure about not missing out on any parameter or setup
                                      @Jetson-Nano It's a parameter that you can set to any number you want. In QGC you can look at the joysticks tab and see as you press each button which number it is. Then set the parameter to that number.
                                        Jetson Nano
                                        Veteran
                                        @Eric-Katzfey I am not able to setup multiple buttons, it is only showing one option of button 1.
                                        Also after assigning the button one and trying to enable and use turtle mode, it is not working.
                                        Is there any particular version of px4 that this works with.
                                        My setup is VOXL 2 ---> TELEM 1 --> Flight core v2 --> TELEM 2 --> FPV ESC
                                        In normal setup the motors are working and rotating, but when I try to keep the drone upside down and enable the turtle mode , the QGC is still showing not ready message. Also I am not able to ARM because of this.
                                        Is there anything I am missing out?
                                          Jetson Nano
                                          Veteran
                                          @Eric-Katzfey could you please help me out here
