    voxl-open-vins-server
    375
    • J
      Jetson Nano
      @Alex-Kushleyev @tom @Vinny @zauberflote1 @Eric-Katzfey
      My drone is drifting off when i fly VOXL 2 with 2 tracking camera using voxl-open-vins-server.
      I am getting the following warnings on the terminal and i would to get some help get my drone flying without any errors and drift.
      The major drift is when the drone is yawing, it is drifting both is ground test and flight test
      voxl2:~$ voxl-open-vins-server
      Setting printing level to: SILENT
      =========================AUTO RESET==============================
      en_auto_reset:                    1
      auto_reset_max_velocity:          20.000
      auto_reset_max_v_cov_instant:      0.100
      auto_reset_max_v_cov:              0.100
      auto_reset_max_v_cov_timeout_s:    0.500
      auto_reset_min_features:          1
      auto_reset_min_feature_timeout_s:  3.000
      auto_fallback_timeout_s:  3.000
      auto_fallback_min_v:  0.600
      en_cont_yaw_checks: false
      fast_yaw_thresh:  5.000
      fast_yaw_timeout_s:  1.750
      ===========================STATE=================================
      do fej:                           true
      imu avg:                          true
      use rk4 integration:              true
      cam to imu refinement:            true
      cam intrins refinement:           true
      cam imu ts refinement:            true
      max clone size:                   8
      max slam features:                35
      max slam in update:               10
      max msckf in update:              10
      feat rep msckf:                   ANCHORED_MSCKF_INVERSE_DEPTH
      feat rep slam:                    ANCHORED_MSCKF_INVERSE_DEPTH
      cam imu time offset:              0.00000
      slam delay:                       1.00000
      pyr levels:                       6
      grid x:                           5
      grid y:                           5
      =====================INERTIAL INITIALIZER========================
      gravity mag:                      9.80665
      init window time:                 1.00000
      init imu thresh:                  1.00000
      init dyn use:                         false
      ==========================IMU NOISE==============================
      imu sigma w:                      0.00014
      imu sigma wb:                     0.00000
      imu sigma a:                      0.00389
      imu sigma ab:                     0.00006
      ========================FEATURE NOISE============================
      msckf chi^2 multiplier:           1.00000
      msckf sigma px:                   1.00000
      slam chi^2 multiplier:            40.00000
      slam sigma px:                    1.80000
      zupt chi^2 multiplier:            1.00000
      zupt sigma px:                    1.00000
      =============================ZUPT================================
      refine features:                  true
      max runs:                         5
      try zupt:                         true
      en_ext_feature_tracker:             0
      en_gpu_for_tracking:                1
      raansac_gn:                       false
      raansac_tri:                      true
      zupt max velocity:                0.03000
      zupt only at beginning:           true
      zupt noise multiplier:            1.00000
      zupt max disparity:               8.00000
      use mask:                         false
      use stereo:                       false
      use baro:                       false
      ========================FEATURE INITIALIZER======================
      triangulate 1d:                   false
      init lamda:                       0.00100
      max lamda:                        10000000000.00000
      min dx:                           0.00000
      min dcost:                        0.00000
      lam mult:                         10.00000
      min dist:                         0.10000
      max dist:                         60.00000
      max baseline:                     40.00000
      num_opencv_threads:                  4
      fast_threshold:                  15
      histogram_method:                  HISTOGRAM
      knn_ratio:                  0.70000
      track_frequency:                  15.00000
      publish_frequency:                  5
      imu takeoff accel thresh:                  0.50000
      force init on takeoff:                  true
      takeoff_threshold(m):                  -0.100000
      publish stats:                  false
      max_allowable_cep:                  1.00000
      force FLU to NED transform:                  true
      publish IMU frame:                  false
      VIO always on (for bench testing):                  true
      num_features_to_track:              20
      Enable Thermal Enhance:                  false
      Enable Overlay Landscape:                  false
      Thermal Brightness:                  1.00000
      Thermal Brightness BOSON:                  1.00000
      vio_cam config:
      cam 0:
          enable:                1
          pipe_for_preview:      tracking_front
          pipe_for_tracking:     tracking_front
          is_occluded_on_ground: 0
          imu:                   imu_apps
          is_extrinsic_present:  1
          extrinsic cam wrt imu:
          parent:                imu_apps
          child:                 tracking_front
          T_cam_wrt_imu:         0.131   0.017   0.033
          RPY_imu_to_cam:        0.0    90.0    90.0
          R_cam_to_imu:          0.000  -0.000   1.000
                                 1.000   0.000  -0.000
                                -0.000   1.000   0.000
          cal file:              opencv_tracking_front_intrinsics.yml
          is_cal_present:        1
          cam cal intrinsics:
          width:                 1280
          height:                800
          fx:                    462.958
          fy:                    464.368
          cx:                    632.240
          cy:                    398.053
          n_coeffs:              4
          is_fisheye:            1
          D: 0.0672 0.0019 0.0062 -0.0040
      cam 1:
          enable:                1
          pipe_for_preview:      tracking_down
          pipe_for_tracking:     tracking_down
          is_occluded_on_ground: 1
          imu:                   imu_apps
          parent:                imu_apps
          child:                 tracking_down
          T_cam_wrt_imu:         0.106   0.017   0.050
          RPY_imu_to_cam:        0.0     0.0   180.0
          R_cam_to_imu:         -1.000  -0.000   0.000
                                 0.000  -1.000  -0.000
                                 0.000   0.000   1.000
          cal file:              opencv_tracking_down_intrinsics.yml
          is_cal_present:        1
          cam cal intrinsics:
          width:                 1280
          height:                800
          fx:                    467.157
          fy:                    468.573
          cx:                    652.260
          cy:                    381.475
          n_coeffs:              4
          is_fisheye:            1
          D: 0.0618 0.0066 0.0043 -0.0039
      vio cam: 0 is occluded: 0
      [INFO] Camera: 0 -- converted extrinsics *in FLU* are: Roll: -0.000000, Pitch 90.000000, Yaw 90.000000 (1.570796)
      vio cam: 1 is occluded: 1
      [INFO] Camera: 1 -- converted extrinsics *in FLU* are: Roll: -0.000000, Pitch 0.000000, Yaw -180.000000 (-3.141593)
      WORLD QUATERNION: -0.000000 0.000000 -0.000000 1.000000
      OpenVINS using fisheye camera
      OpenVINS FINAL Cam extrinsics to IMU for tracking_front: 7
             0.5
            0.5
            0.5
            0.5
       0.131119
       -0.01686
      -0.032587
      OpenVINS FINAL Cam extrinsics to IMU for tracking_down: 7
                -0
      6.12323e-17
          0.10642
        -0.017472
        -0.049789
      OpenVINS reports number of cameras being used, regardless of delivery method (pipe, merge, etc...):  2
      Set camera intrinsics and extrinsics
      ====> Using Internal KLT feature tracker (w/ GPU) <====
      initialized ocl manager
      >>>>>>>>>> Current reference counts:
      trackDB: 1
      trackFEATS: 1
      propagator: 2
      updaterMSCKF: 1
      updaterSLAM: 1
      active_tracks_initializer: 1
      initializer: 1
      existing instance of voxl-open-vins-server found, attempting to stop it
      create_server_pipes
      connecting client pipes
      imu pipe name: imu_apps
      Number of Cameras active: 2
      Camera merge --- > ch: 1 to cam id: 0
      Opening camera pipe: tracking_front
      tmp_camera_pipe_names.push_back(): tracking_front
      Camera merge --- > ch: 2 to cam id: 1
      Opening camera pipe: tracking_down
      tmp_camera_pipe_names.push_back(): tracking_down
      [WARN] (0.005173 and 0.429242) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.005557 and 0.414437) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.004569 and 0.410084) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [INFO] world : 1.000000 1.000000  (2)
      [WARN] (0.002892 and 0.391982) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.005072 and 0.376832) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.003555 and 0.430667) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.005692 and 0.390681) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.004505 and 0.402070) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.003865 and 0.396118) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.002470 and 0.419256) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.005667 and 0.413984) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.003450 and 0.391701) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.004175 and 0.414603) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.002370 and 0.406459) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.005461 and 0.382791) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.005294 and 0.429766) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.004939 and 0.415523) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.005433 and 0.415484) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.002918 and 0.386400) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.005973 and 0.424467) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.005410 and 0.394569) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.003912 and 0.405820) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.004101 and 0.405439) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.003168 and 0.391471) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [ERROR] In init too long, timeout, retry  RESET 5016505415
      [WARN] (0.004056 and 0.424981) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.005692 and 0.399984) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.003530 and 0.413739) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.005548 and 0.375363) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.004837 and 0.385353) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.004894 and 0.413352) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.005565 and 0.399380) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.005435 and 0.386146) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      [WARN] (0.004120 and 0.409839) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
      ^C
      en_auto_reset:                    1
      do fej:                           true
      imu avg:                          true
      max clone size:                   8
      slam delay:                       1.00000
      pyr levels:                       6
      grid x:                           5
      grid y:                           5
      init dyn use:                         false
      max runs:                         5
      try zupt:                         true
      raansac_gn:                       false
      raansac_tri:                      true
      use mask:                         false
      use stereo:                       false
      use baro:                       false
      init lamda:                       0.00100
      min dx:                           0.00000
      min dcost:                        0.00000
      lam mult:                         10.00000
      min dist:                         0.10000
      max dist:                         60.00000
      fast_threshold:                  15
      knn_ratio:                  0.70000
      force FLU to NED transform:                  false
      publish IMU frame:                  true
      num_features_to_track:              30
      vio_cam config:
      cam 0:
          enable:                1
          imu:                   imu_apps
          parent:                imu_apps
                                 1.000   0.000  -0.000
                                -0.000   1.000   0.000
          is_cal_present:        1
          cam cal intrinsics:
          width:                 1280
          height:                800
          fx:                    462.958
          fy:                    464.368
          cx:                    632.240
          cy:                    398.053
          n_coeffs:              4
          is_fisheye:            1
      cam 1:
          enable:                1
          imu:                   imu_apps
          parent:                imu_apps
                                 0.000  -1.000  -0.000
                                 0.000   0.000   1.000
          is_cal_present:        1
          cam cal intrinsics:
          width:                 1280
          height:                800
          fx:                    467.157
          fy:                    468.573
          cx:                    652.260
          cy:                    381.475
          n_coeffs:              4
          is_fisheye:            1
      [INFO] Camera: 0 -- converted extrinsics *in FLU* are: Roll: -0.000000, Pitch 90.000000, Yaw -90.000000 (-1.570796)
      [INFO] Camera: 1 -- converted extrinsics *in FLU* are: Roll: -0.000000, Pitch 180.000000, Yaw -360.000000 (-6.283185)
            -0.5
            0.5
           -0.5
            0.5
       0.131119
       -0.01686
      -0.032587
       -1.22465e-16
                -1
       -7.4988e-33
      -6.12323e-17
           0.10642
         -0.017472
         -0.049789
      trackDB: 1
      trackFEATS: 1
      propagator: 2
      updaterMSCKF: 1
      updaterSLAM: 1
      initializer: 1
      create_server_pipes
      client "voxl-portal63468110" connected to overlay
      FAILED TO FETCH IMG RINGBUF at time 0 -2 -2 -2 -2 -2
      ^C
      received SIGINT Ctrl-C
      Quiting OpenVINS server
      QUIT REQUESTED
      Exiting Cleanly
      voxl2:~$
      zauberflote1Z 1 Reply Last reply 2 Jun 2025, 15:23 Reply Quote 0
      • zauberflote1Z
        zauberflote1 ModalAI Team @Jetson Nano
        Hello @Jetson-Nano,
        Would you be able to confirm your SDK version?
        Also, have you attempted to recalibrate the IMU?
        voxl-calibrate-imu
        https://docs.modalai.com/calibrate-imu/
        All the best,
        ZBFT
        J 1 Reply Last reply 2 Jun 2025, 16:34 Reply Quote 0
        • J
          Jetson Nano @zauberflote1
          @zauberflote1 i am using the latest sdk 1.4.5
          I have calibrated the imu, as well as imu temp
          J 1 Reply Last reply 2 Jun 2025, 17:59 Reply Quote 0
          • J
            Jetson Nano @Jetson Nano
            @zauberflote1 @Alex-Kushleyev @Eric-Katzfey @tom
            I am providing my config file here for your reference.
            the drone contains a voxl 2 board, M1073 camera coax board with 2 tracking camera and 1 tof and 1 hires camers along with one flight core v2 as external fc.
            The drone is losing position very easily. within the few seconds of take off
             "en_auto_reset":        true,
                    "auto_reset_max_velocity":      20,
                    "auto_reset_max_v_cov_instant": 0.10000000149011612,
                    "auto_reset_max_v_cov": 0.10000000149011612,
                    "auto_reset_max_v_cov_timeout_s":       0.5,
                    "auto_reset_min_features":      1,
                    "auto_reset_min_feature_timeout_s":     3,
                    "auto_fallback_timeout_s":      3,
                    "auto_fallback_min_v":  0.600000023841858,
                    "en_cont_yaw_checks":   true,
                    "fast_yaw_thresh":      5,
                    "fast_yaw_timeout_s":   1.75,
                    "do_fej":       true,
                    "imu_avg":      true,
                    "use_rk4_integration":  true,
                    "cam_to_imu_refinement":        true,
                    "cam_intrins_refinement":       true,
                    "cam_imu_ts_refinement":        true,
                    "max_clone_size":       8,
                    "max_slam_features":    35,
                    "max_slam_in_update":   10,
                    "max_msckf_in_update":  10,
                    "feat_rep_msckf":       4,
                    "feat_rep_slam":        4,
                    "cam_imu_time_offset":  0,
                    "slam_delay":   1,
                    "gravity_mag":  9.80665,
                    "init_window_time":     1,
                    "init_imu_thresh":      1,
                    "imu_sigma_w":  0.00013990944749616306,
                    "imu_sigma_wb": 4.1189724174615527e-07,
                    "imu_sigma_a":  0.0038947538150776763,
                    "imu_sigma_ab": 5.538346201712153e-05,
                    "msckf_chi2_multiplier":        1,
                    "slam_chi2_multiplier": 40,
                    "zupt_chi2_multiplier": 1,
                    "refine_features":      true,
                    "pyr_levels":   6,
                    "grid_x":       5,
                    "grid_y":       5,
                    "msckf_sigma_px":       1,
                    "slam_sigma_px":        1.8,
                    "zupt_sigma_px":        1,
                    "try_zupt":     true,
                    "zupt_max_velocity":    0.03,
                    "zupt_only_at_beginning":       true,
                    "zupt_noise_multiplier":        1,
                    "zupt_max_disparity":   8,
            "init_dyn_use": false,
                    "triangulate_1d":       false,
                    "max_runs":     5,
                    "init_lamda":   0.001,
                    "max_lamda":    10000000000,
                    "min_dx":       1e-06,
                    "min_dcost":    1e-06,
                    "lam_mult":     10,
                    "min_dist":     0.1,
                    "max_dist":     60,
                    "max_baseline": 40,
                    "max_cond_number":      600000,
                    "use_mask":     false,
                    "use_stereo":   false,
                    "use_baro":     true,
                    "num_opencv_threads":   4,
                    "fast_threshold":       15,
                    "histogram_method":     1,
                    "knn_ratio":    0.7,
                    "take_cam":0,
                    "takeoff_accel_threshold":      0.5,
                    "takeoff_threshold":    -0.1,
                    "use_stats":    false,
                    "max_allowable_cep":    1,
                    "en_force_init":        true,
                    "en_force_ned_2_flu":   false,
                    "en_imu_frame_output":  true,
                "track_frequency":      15,
                    "publish_frequency":    5,
                    "en_vio_always_on":     false,
                    "en_ext_feature_tracker":       false,
                    "en_gpu_for_tracking":  true,
                    "num_features_to_track":        30,
                    "raansac_gn":   false,
                    "raansac_tri":  true,
                    "en_thermal_enhance":   false,
                    "en_overlay_landscape": false,
                    "thermal_brightness":   1,
                    "thermal_brightness_bos":       1
            • zauberflote1Z
              Regarding the IMU temperature calibration, it is now optional as some platforms may underperform if the calibration is not executed properly, i.e., getting poor measurements at the cold phase. I would recommend removing the IMU temperature calibration file from /data/modalai and double-checking if the behaviour persists.
              Quick question: Which cameras are you using? Did you set your extrinsics file correctly?
              Please make sure you calibrate all the cameras as well.
              ZBFT
              J 1 Reply Last reply 3 Jun 2025, 19:29 Reply Quote 0
              • J
                @zauberflote1 I will the imu temp file and remove it for test.
                The ov overlay and map created by mapper, shows that the drone is not drifting in ground test, but in actual test the drone is jumping up and down. i would like to know why this is happening, this is only when when i use tracking camera data, when i use an optical flow that is directly connected to fc v2 the drone is very stable, and collision prevention is also working.
                All the camera where calibrated before the tests and calibration was successful. I have already checked out the obvious issues, and they all are fine, am i missing out something. help me out to get a better position hold and autonomy without drifting of the system
                @Alex-Kushleyev @Eric-Katzfey @tom @Vinny
                J 1 Reply Last reply 4 Jun 2025, 04:15 Reply Quote 0
                • J
                  @Alex-Kushleyev can you help me with this
                  also which is the preferred imu for the extrinsic when I am using voxl 2 + fc v2 + M1073
                  Alex KushleyevA 1 Reply Last reply 5 Jun 2025, 17:57 Reply Quote 0
                    Alex Kushleyev ModalAI Team @Jetson Nano
                    @Jetson-Nano , I am not the best person to answer questions regarding open-vins. Let me double check with other team members.
                    Also, can you please clarify your question "which is the preferred imu for the extrinsic when I am using voxl 2 + fc v2 + M1073" -- what do you mean which IMU? VOXL2 has two IMUs - one is used by PX4 for flight (accessed from DSP) and the second IMU is connected to the CPU. The latter is used for all VIO processing.
                    zauberflote1Z J 2 Replies Last reply 5 Jun 2025, 18:31 Reply Quote 0
                    • Cliff WongC
                      Cliff Wong ModalAI Team
                      Hi there, just a quick sanity check. Does the drone fly normal in manual mode?
                      If so, it is worthwhile to do a hand/bench test by powering up on a flat surface. Then connect to the drone via wifi and startup VOXL-Portal. Going to the VIO panel in portal, if you life the drone up and down, then left and right, it should be reflected in portal with the correct trajectory display. If not and it drifts in manual mode too, then there's like a voxl2 calibration or param issue (not vio).
                      • zauberflote1Z
                        zauberflote1 ModalAI Team @Alex Kushleyev
                        @Jetson-Nano
                        Could you confirm that you are using the correct camera stream?
                        Please run the following:
                        voxl-inspect-cams
                         voxl-inspect-vins #with openvins running on a separate terminal
                        Check if you have any error codes or camera feeds that have stalled.
                        Finally, double check your vio_cams.conf file to see if you are using the *misp_norm
                        camera pipes.
                        -- An easy way to do this is to reset your openvins and vio cam configuration files, run the following after backing up your .conf files.
                         voxl-configure-cameras
                        voxl-configure-open-vins
                        Then, reboot the platform and attempt to run openvins with the new conf files.
                        J 1 Reply Last reply 7 Jun 2025, 15:21 Reply Quote 0
                        • J
                          Jetson Nano @Alex Kushleyev
                          @zauberflote1 @Alex-Kushleyev @Cliff-Wong Thank you for reverting, I have setted up the openvins server now, the major cause of drift was improper extrinsic value, now the drone is much stable, but still drifting with in a small area, the vio data is fed into fc v2 . can that be an issue for the drifting
                          • zauberflote1Z zauberflote1 referenced this topic on 6 Jun 2025, 15:13
                          • J
                            @zauberflote1 @James-Strawson
                            I am attaching an issue i am facing, the drone is stable in a mat, but as soon as i bring it back i loses the position and drifts out and goes crazy when i try to give pilot input
                            ERROR in insert_data, detected timestamp out of order ov, 1440558439657 vs 1440591773303
                            ERROR in insert_data, detected timestamp out of order ov, 1456191779391 vs 1456191779391
                            ERROR in insert_data, detected timestamp out of order ov, 1460758438920 vs 1460791771472
                            ERROR in insert_data, detected timestamp out of order ov, 1461691774910 vs 1461691774910
                            ERROR in insert_data, detected timestamp out of order ov, 1461858441212 vs 1461858441212
                            ERROR in insert_data, detected timestamp out of order ov, 1462091774232 vs 1462125109024
                            ERROR in insert_data, detected timestamp out of order ov, 1462258438295 vs 1462291773555
                            ERROR in insert_data, detected timestamp out of order ov, 1462491774024 vs 1462525106316
                            ERROR in insert_data, detected timestamp out of order ov, 1462658436524 vs 1462725109597
                            ERROR in insert_data, detected timestamp out of order ov, 1462825106628 vs 1462891775690
                            ERROR in insert_data, detected timestamp out of order ov, 1462991771420 vs 1463058439440
                            ERROR in insert_data, detected timestamp out of order ov, 1464125106211 vs 1464125106211
                            ERROR in insert_data, detected timestamp out of order ov, 1464291773919 vs 1464291773919
                            ERROR in insert_data, detected timestamp out of order ov, 1464458441002 vs 1464458441002
                            ERROR in insert_data, detected timestamp out of order ov, 1464691773398 vs 1464725105273
                            ERROR in insert_data, detected timestamp out of order ov, 1465425110585 vs 1465558437773
                            ERROR in insert_data, detected timestamp out of order ov, 1465658438450 vs 1465825104596
                            ERROR in insert_data, detected timestamp out of order ov, 1465925106418 vs 1466091986731
                            ERROR in insert_data, detected timestamp out of order ov, 1466091986731 vs 1466225109387
                            ERROR in insert_data, detected timestamp out of order ov, 1466258441991 vs 1466391773450
                            ERROR in insert_data, detected timestamp out of order ov, 1467658442251 vs 1467691776314
                            ERROR in insert_data, detected timestamp out of order ov, 1470658438812 vs 1470658438812
                            ERROR in insert_data, detected timestamp out of order ov, 1470791773187 vs 1470858439698
                            ERROR in insert_data, detected timestamp out of order ov, 1470958439854 vs 1471025104073
                            ERROR in insert_data, detected timestamp out of order ov, 1471125105010 vs 1471191771000
                            ERROR in insert_data, detected timestamp out of order ov, 1471325106781 vs 1471358439125
                            ERROR in insert_data, detected timestamp out of order ov, 1471491772927 vs 1472058437406
                            ERROR in insert_data, detected timestamp out of order ov, 1471658438604 vs 1472225105843
                            ERROR in insert_data, detected timestamp out of order ov, 1471791775375 vs 1472225105843
                            ERROR in insert_data, detected timestamp out of order ov, 1471958440114 vs 1472425105999
                            ERROR in insert_data, detected timestamp out of order ov, 1472125105427 vs 1472592004124
                            ERROR in insert_data, detected timestamp out of order ov, 1472291774385 vs 1472758439489
                            ERROR in insert_data, detected timestamp out of order ov, 1472491771728 vs 1472925109124
                            waiting for enough clone states (1 of 5)....
                            waiting for enough clone states (2 of 5)....
                            waiting for enough clone states (3 of 5)....
                            waiting for enough clone states (4 of 5)....
                            ERROR in insert_data, detected timestamp out of order ov, 1474458439176 vs 1474458439176
                            ERROR in insert_data, detected timestamp out of order ov, 1474858440061 vs 1475625107196
                            ERROR in insert_data, detected timestamp out of order ov, 1474891775321 vs 1475625107196
                            ERROR in insert_data, detected timestamp out of order ov, 1474925109957 vs 1475625107196
                            ERROR in insert_data, detected timestamp out of order ov, 1474958443290 vs 1475625107196
                            ERROR in insert_data, detected timestamp out of order ov, 1474991770946 vs 1475625107196
                            ERROR in insert_data, detected timestamp out of order ov, 1475025106050 vs 1475625107196
                            ERROR in insert_data, detected timestamp out of order ov, 1475058439748 vs 1475625107196
                            [WARN] Motion detected, going to full processing
                            ERROR in insert_data, detected timestamp out of order ov, 1475091775165 vs 1475625107196
                            ERROR in insert_data, detected timestamp out of order ov, 1475125106571 vs 1475625107196
                            ERROR in insert_data, detected timestamp out of order ov, 1475158441363 vs 1475625107196
                            ERROR in insert_data, detected timestamp out of order ov, 1475191774279 vs 1475625107196
                            ERROR in insert_data, detected timestamp out of order ov, 1475225106988 vs 1475625107196
                            ERROR in insert_data, detected timestamp out of order ov, 1475258438550 vs 1475625107196
                            ERROR in insert_data, detected timestamp out of order ov, 1475291774540 vs 1475625107196
                            ERROR in insert_data, detected timestamp out of order ov, 1475325106311 vs 1475625107196
                            ERROR in insert_data, detected timestamp out of order ov, 1475458439384 vs 1477225106518
                            ERROR in insert_data, detected timestamp out of order ov, 1475491771415 vs 1477225106518
                            ERROR in insert_data, detected timestamp out of order ov, 1475691776883 vs 1477558441674
                            ERROR in insert_data, detected timestamp out of order ov, 1475725110738 vs 1477558441674
                            ERROR in insert_data, detected timestamp out of order ov, 1475758443863 vs 1477558441674
                            ERROR in insert_data, detected timestamp out of order ov, 1475791778446 vs 1477558441674
                            ERROR in insert_data, detected timestamp out of order ov, 1475825110321 vs 1477558441674
                            ERROR in insert_data, detected timestamp out of order ov, 1475858439383 vs 1477558441674
                            ERROR in insert_data, detected timestamp out of order ov, 1475891772613 vs 1477558441674
                            ERROR in insert_data, detected timestamp out of order ov, 1475925110581 vs 1477558441674
                            ERROR in insert_data, detected timestamp out of order ov, 1475958442873 vs 1477558441674
                            ERROR in insert_data, detected timestamp out of order ov, 1475991771154 vs 1477558441674
                            ERROR in insert_data, detected timestamp out of order ov, 1476291770633 vs 1478191770789
                            ERROR in insert_data, detected timestamp out of order ov, 1476325110946 vs 1478191770789
                            ERROR in insert_data, detected timestamp out of order ov, 1476358440894 vs 1478191770789
                            ERROR in insert_data, detected timestamp out of order ov, 1476392017456 vs 1478191770789
                            ERROR in insert_data, detected timestamp out of order ov, 1476425106258 vs 1478191770789
                            ERROR in insert_data, detected timestamp out of order ov, 1476458439956 vs 1478191770789
                            ERROR in insert_data, detected timestamp out of order ov, 1476491775894 vs 1478191770789
                            ERROR in insert_data, detected timestamp out of order ov, 1476525105946 vs 1478191770789
                            ERROR in insert_data, detected timestamp out of order ov, 1478325107247 vs 1480091772507
                            ERROR in insert_data, detected timestamp out of order ov, 1478358437924 vs 1480091772507
                            ERROR in insert_data, detected timestamp out of order ov, 1478391771674 vs 1480091772507
                            ERROR in insert_data, detected timestamp out of order ov, 1478425108653 vs 1480091772507
                            ERROR in insert_data, detected timestamp out of order ov, 1478458442768 vs 1480091772507
                            ERROR: invalid metadata, magic number=387521565, expected 1448040524
                            most likely client fell behind and pipe overflowed
                            ERROR in insert_data, detected timestamp out of order ov, 1514291774160 vs 1514291774160
                            ERROR: features were 0 for a long time! cur: 1, min_req: 15 (are you bench testing?)
                            [VIO_BAD_STATE] No Stable feature.
                            WARNING auto-resetting, Bad VIO, State:  true   Q: -1   Vel: 1.738034 Uncert: 0.000915 State: 0(1)
                            ERROR DIAGONAL WENT NEGATIVE
                            voxl-open-vins-server: /builds/voxl-public/voxl-sdk/third-party/voxl-open-vins/open_vins/ov_msckf/src/state/StateHelper.cpp:114: Assertion `!found_neg' failed.
                            Aborted
                            voxl2:~$ voxl-inspect-vins
                            waiting for server at /run/mpa/ov_extended
                                T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)| state| error_code
                                0.00    0.00    0.00|  -0.8   -2.7    0.0| OKAY | DROPPED_IMU
                            voxl-open-vins-server disconnected
                                0.00    0.00    0.00|  -0.9   -2.7    0.0| OKAY | ERROR validating EXT VIO t
                            read 8424 bytes, but it should be a multiple of 5268
                            ERROR validating EXT VIO data received through pipe: read partial packet
                            read 4224 bytes, but it should be a multiple of 5268
                            read 2112 bytes, but it should be a multiple of 5268
                               -0.00   -0.00    0.00|  -0.9   -2.8    0.0| OKAY | ERROR validating EXT VIO t
                            read 6336 bytes, but it should be a multiple of 5268
                            read 7380 bytes, but it should be a multiple of 5268
                                4.38   -1.43    1.78|  -1.6   19.3   -4.9| OKAY |
                            ERROR in pipe_client_open opening request pipe: No such device or address
                            J 1 Reply Last reply 26 days ago Reply Quote 0
                            • J
                              @zauberflote1 @Cliff-Wong @James-Strawson
                              guys, can you help me with the error mentioned.
                              now i have an another error where, if I arm the drone, the vio is drifting, and i can see the values increasing without any movement.
                              what would cause this kind of errors, earlier the drone was flying fine, then it started drifting, even when just armed.
