  3. VOXL2 troubleshooting
voxl-2
14 Posts 3 Posters 2.3k Views 1 Watching
  • C claw
    I have two VOXL2 boards as parts of Starling drones. They were both unresponsive to ADB so I reinstalled the base firmware using the unbrick procedures. I was able to get a successful result from QDL for both the provisioning and flat build install, however, ADB from my Linux machine does not find the devices. How do I troubleshoot this further?
    Thank you
    @claw what does lsusb report?
    C 1 Reply Last reply
    • ModeratorM Moderator
      C Offline
      C Offline
      claw
      @Moderator here is a screenshot before and after plugging the usb cable in:
      • C claw
        tomT Online
        tomT Online
        @claw It looks as though the board is booting into fastboot. At this point you should be able to install the voxl2_SDK with ./install.sh
          C Offline
          C Offline
          claw
          @tom oh, ok. I thought I'd have adb from the firmware. My mistake. Thanks for the help.
          • C claw
            C Offline
            C Offline
            claw
            @tom I tried to install the SDK but it failed.
            I did re-read the instructions for unbricking which do say that ADB should be available after installing the flat build. Is there a mechanism for returning the boards for repair?
            • C claw
              tomT Online
              tomT Online
              @claw Can you double check that you're loading the correct QDL image? You'll need to determine whether your board is an M0054-1 or M0054-2
              https://docs.modalai.com/m0054-versions/#m0054-1-and-m0054-2
                C Offline
                C Offline
                claw
                @tom i did check that initially and again before I loaded it this last time. We have the older version boards.
                • C claw
                  tomT Online
                  tomT Online
                  @claw Are you running Ubuntu natively? If so, what version?
                    C Offline
                    C Offline
                    claw
                    @tom yes, 22.04
                    • C claw
                      @tom yes, 22.04
                      tomT Online
                      tomT Online
                      @claw I would try installing the SDK with ./install.sh -w to wipe all partitions and start fresh.
                      If that doesn't work it may be worth submitting an RMA: https://www.modalai.com/pages/rma
                        C Offline
                        C Offline
                        claw
                        @tom thank you. I'll give that a shot.
                        • C claw
                          C Offline
                          C Offline
                          claw
                          @tom That completed successfully, but still doesn't provide adb. Also, lsusb still shows the fastboot device whereas the other Starlings that are working show a qualcom device.
                          • C claw
                            tomT Online
                            tomT Online
                            @claw That is definitely not the expected behavior, I recommend going through the RMA process
