  3. VOXL2 troubleshooting
voxl-2
14 Posts 3 Posters 1.9k Views 1 Watching
  • C Offline
    C Offline
    claw
    I have two VOXL2 boards as parts of Starling drones. They were both unresponsive to ADB so I reinstalled the base firmware using the unbrick procedures. I was able to get a successful result from QDL for both the provisioning and flat build install, however, ADB from my Linux machine does not find the devices. How do I troubleshoot this further?
    Thank you
    ModeratorM 1 Reply Last reply
    • C claw
      Thank you
      @claw what does lsusb report?
      C 1 Reply Last reply
      • ModeratorM Moderator
        C Offline
        C Offline
        claw
        @Moderator here is a screenshot before and after plugging the usb cable in:
        • C claw
          @claw It looks as though the board is booting into fastboot. At this point you should be able to install the voxl2_SDK with ./install.sh
            C Offline
            C Offline
            claw
            @tom oh, ok. I thought I'd have adb from the firmware. My mistake. Thanks for the help.
            • C claw
              C Offline
              C Offline
              claw
              @tom I tried to install the SDK but it failed.
              I did re-read the instructions for unbricking which do say that ADB should be available after installing the flat build. Is there a mechanism for returning the boards for repair?
              • C claw
                @claw Can you double check that you're loading the correct QDL image? You'll need to determine whether your board is an M0054-1 or M0054-2
                https://docs.modalai.com/m0054-versions/#m0054-1-and-m0054-2
                  C Offline
                  C Offline
                  claw
                  @tom i did check that initially and again before I loaded it this last time. We have the older version boards.
                  • C claw
                    @claw Are you running Ubuntu natively? If so, what version?
                      C Offline
                      C Offline
                      claw
                      @tom yes, 22.04
                      • C claw
                        @tom yes, 22.04
                        @claw I would try installing the SDK with ./install.sh -w to wipe all partitions and start fresh.
                        If that doesn't work it may be worth submitting an RMA: https://www.modalai.com/pages/rma
                          C Offline
                          C Offline
                          claw
                          @tom thank you. I'll give that a shot.
                          • C claw
                            C Offline
                            C Offline
                            claw
                            @tom That completed successfully, but still doesn't provide adb. Also, lsusb still shows the fastboot device whereas the other Starlings that are working show a qualcom device.
                            • C claw
                              @claw That is definitely not the expected behavior, I recommend going through the RMA process
